AW-30SBW
AW-30SBW
    PUIAUDIO
    SIREN 9-28VDC 32 TONE
AW-30SBW 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE TONE OUTPUT CURRENT CONSUMPTION (NOMINAL) INGRESS PROTECTION CASE MATERIAL/COLOR TERMINAL OPERATING TEMPERATURE WEIGHT 107 VALUES UNITS 24 9 ~ 28 SEE 32 TONE CHART SEE 32 TONE CHART IP42 ABS/WHITE SCREW -25 ~ +55 580 Vdc Vdc THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING ADDED RoHS NOTE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED DIMENSIONS 12/20/2005 5/22/2007 6/22/2010 6/8/2018 R.W. B.R. M.L. mA C grams 88 2 2 50 100 60 50 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AW-30SBW.idw Designed by Date Checked by Date Approved by J.A.F. 12/20/2005 E.P. 12/20/2005 B.R. Date Drawn Date 12/20/2005 6/22/2010 AW-30SBW Siren Edition Sheet - 1/1
AW-30SBW 价格&库存
很抱歉,暂时无法提供与“AW-30SBW”相匹配的价格&库存,您可以联系我们找货
