80×80×15 mm
San Ace 80 9P type
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Yellow
Sensor
· Mass………………………………………… 68 g
■ Specifications
The models listed below have ribs and pulse sensors.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
[V]
[V]
[A]
[W]
[min-1]
109P0812H701
12
109P0812M701
109P0824H701
7 to 13.8
24
109P0824M701
14 to 27.6
Max. airflow
[m3/min]
[CFM]
Max. static pressure
[Pa]
[inchH2O]
SPL
Operating temperature
[dB (A)]
[˚C]
[h]
-20 to +70
40000/60˚C
(70000/40˚C)
60000/60˚C
(90000/40˚C)
40000/60˚C
(70000/40˚C)
60000/60˚C
(90000/40˚C)
0.2
2.4
3100
0.91
32.1
29.4
0.118
31
0.09
1.08
2000
0.57
20.1
12.6
0.051
21
0.1
2.4
3100
0.91
32.1
29.4
0.118
31
0.05
1.2
2000
0.57
20.1
12.6
0.051
21
Expected life
Note 1: Sensor and control options are available for selection. Refer to the table on p. 622.
Note 2: The
mark indicates Short Lead Time Service applicable models. See p. 654 for details.
■ Airflow - Static Pressure Characteristics
109P0812H701
109P0812M701
With pulse sensor
0.12
12 V
7V
0.06
0.04
0.06
13.8 V
30
0.10
0.08
10
0.2 0.4 0.6 0.8 1.0 1.2 (m3/min)
40
Airflow
96
0.05
CATALOG No. C1111B002 '21.9.IT
(CFM)
0.16
16
12 V
12
0.03
0.02
7V
8
40
0.14
13.2 V
0.04
0.01
0.02
(inch H2O) (Pa)
Static pressure
0.07
0.14
With pulse sensor
(inch H2O) (Pa)
40
Static pressure
0.16
109P0824H701
With pulse sensor
(inch H2O) (Pa)
Static pressure
DC
DC Fan 80 mm sq.
DC Fan
4
0.12
27.6 V
30
24 V
0.10
0.08
14 V
0.06
0.04
10
0.02
0.4
10
15
0.6
Airflow
0.8 (m3/min)
25
30
(CFM)
Airflow
40
(CFM)
109P0824M701
DC
DC Fan 80 mm sq.
With pulse sensor
(inch H2O) (Pa)
0.07
Static pressure
0.06
0.05
16
27.6 V
24 V
12
0.04
0.03
0.02
0.01
14 V
8
4
0.4
10
0.6
15
0.8 (m3/min)
25
30
(CFM)
Airflow
■ Dimensions (unit: mm)
+1
15 0
4-ø4.3±0.3
Mounting hole
(3.5)
(3.5)
Lead wire
AWG24
UL 1007
+30
300 0
71.5±0.3
80±0.5
80±0.5
71.5±0.3
(10)
Airflow direction
Rotating direction
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side
Outlet side
71.5±0.3
4-ø4.5
5
9.
4
ø8
78
71.5±0.3
ø8
78
4-ø4.5
78
71.5±0.3
71.5±0.3
78
■ Options
Finger guards
page: p. 584
Model no.: 109-049E, 109-049H, 109-049C
Resin filter kits
Resin finger guards
page: p. 591
Model no.: 109-1002G
page: p. 592
Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI),
109-1002F30 (30PPI), 109-1002F40 (40PPI)
97
很抱歉,暂时无法提供与“109P0812M702”相匹配的价格&库存,您可以联系我们找货
