FBL12G12H1A
FBL12G12H1A
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 120X38MM 12VDC WIRE
FBL12G12H1A 数据手册
FBL12G (120 X 38L) EMINEBEA.COM THIS MODEL IS NO LONGER AVAILABLE FOR NEW DESIGNS See other models available in this frame size here - 4715VL Allowable Ambient Temperature Range: Failure Rate: 10% -10°C ~ +70°C (65%RH) (Operating) -40°C ~ +75°C (65%RH) (Storage) (non-condensing environment) 30,000 Hours (25°C, 65%RH) 10,000 Hours (70°C, 65%RH) inch Units: (mm) ˜ÊÓ" (Pa) Static Pressure 1.49 (38.0) 4.13 (105) 4.72 (120) .236 (6) outlet inlet NAME PLATE Ps 4.13 (105) 4.72 (120) -Pin +Pin FLOW 100 90 °£x °££ °äÇ °äÎ 40 30 20 10 80 70 12V(24V)-H 60 50 12V(24V)-M 12V(24V)-L N (m3/min) 0 0.5 1 1.5 Óä {ä Èä nä Air Flow 2.5 2 3 3.5 ­ ® .185 4 – (f4.7) £ää £Óä Bearing: Hydro Wave Bearing 5 (f1 .20 32 ) 4.64 (118) 4.13 (105) °Î™ °Îx °Î£ °ÓÇ °ÓÎ °£™ (min - 1 ) Normal Speed ROTATION .177 4 – (f4.5) 4.13 (105) 4.64 (118) OUTLET SIDE Rated Operating Voltage Voltage (V) (V) FBL12G 12L 12 7.0 ~ 13.8 170 2.04 1700 68.9 1.94 .13 32.4 30.0 270 FBL12G 12M 12 7.0 ~ 13.8 280 3.36 2100 86.5 2.45 .18 47.1 35.5 270 270 MODEL Current (A)*1 Power Input Rated Speed (W)*1 (min-1)*1 Max. Air Flow Max. Static Noise Mass (dB)*1 (g) Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 FBL12G 12H 12 7.0 ~ 13.8 370 4.44 2500 103.8 2.94 .26 66.7 41.5 FBL12G 24L 24 14.0 ~ 27.6 86 2.30 1700 68.9 1.95 .13 32.4 30.0 270 FBL12G 24M 24 14.0 ~ 27.6 124 2.98 2100 86.5 2.45 .18 47.1 35.5 270 FBL12G 24H 24 14.0 ~ 27.6 200 4.80 2500 103.8 2.94 .26 66.7 41.5 270 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air
FBL12G12H1A 价格&库存
很抱歉,暂时无法提供与“FBL12G12H1A”相匹配的价格&库存,您可以联系我们找货
