04028DA-12Q-AA-F0
04028DA-12Q-AA-F0
    NMBTECHNOLOGIESCORPORATION
    FAN AXIAL 40X28MM 12VDC WIRE
04028DA-12Q-AA-F0 数据手册
04028DA (40 X 28L) NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Protection: P-Q Curve In H2O (Pa) Insulation Resistance: 1.8 Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: Static Pressure -10°C ~ +70°C (Operating) -30°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life 1.4 500 20000 450 18000 400 16000 350 14000 300 12000 250 1.0 8000 Q class 150 .6 4000 50 .2 0 2000 0.0 0.1 0.2 0.0 0.3 0.4 3.5 0 0.6 (m3/min) 0.5 14.1 CFM 21.1 Air Flow Material ROTATION AIR NAME PLATE inch Units: (mm) .169 (4 – φ3.5) 1.6 (φ4 1 1.0 1.6 (φ4 1 1.0 ) .157 (4.0) 1.10 (28.0± 0.5) Reference PWM Duty Vs. Speed Curve 1.26 (32.0) 1.26 (32.0) 1.51 (38.4) 1.51 (38.4) INLET SIDE OUTLET SIDE R class [04028DA-12R-AU-F0] 20000 18000 16000 14000 Speed (min- 1) PWM Control Voltage max 12000 10000 Vst = 0V ~ 0.4V Stop (On Duty 0%) Vst = 3.0V ~ 5.0V Full Speed (On Duty 100%) Vst = Open Full Speed (On Duty 100%) (At Ta = 25°C, rated voltage 12VDC, f=25.0kHz) mi n 8000 6000 4000 2000 0 Specifications LOT NO. 1.26 (32.0± 0.3) 1.57 (40.0 ± 0.5) .157 (4.0) ) 0.1 4-R 1 3 1.51 (38.4) 1.26 (32.0) 1.6 (φ4 1 1.0 ) 0.1 4-R 1 3 1.26 (32.0) 1.51 (38.4) ) .137 (4 – φ3.5) 1.57 (40.0± 0.0) 0.137 (4−φ3.5± 0.3) Panel Cut-Outs 1.6 (φ4 1 1.0 7.88 min (200) Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL10368, AWG 26, +Red, -Black Tach Sig. : White PWM Control : Brown 0 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% PWM Duty (%) Rated Operating Current Input Speed Max. Max. Static Noise Voltage Voltage Power Air Flow Pressure (V) (V) (A)*1 04028DA-12Q-AA-F0 12 12 10.8 ~ 13.2 10.8 ~ 13.2 0.18 0.29 2.16 3.48 12000 15000 13.1 16.6 0.37 0.47 0.92 1.37 230.0 340.0 45.0 49.5 53 53 04028DA-12R-AA-F0 12 10.8 ~ 13.2 0.43 5.16 18000 20.1 0.57 1.93 480.0 54.5 53 MODEL 4 6000 P class 100 Failure Rate: 10% 40°C 70,000 Hours 10000 R class 200 1.26 (32.0± 0.3) DC Axial Fans 10M Ω by DC500V Megger Speed Curve N [min -1 ] Speed Auto Restart/Polarity Protection 04028DA-12P-AA-F0 Rotation: Clockwise Airflow Outlet: Air Out Over Struts (W)*1 (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 *1: Average Values in Free Air Mass (g) Note: PWM/Locked Rotor/Tach Available
04028DA-12Q-AA-F0 价格&库存
很抱歉,暂时无法提供与“04028DA-12Q-AA-F0”相匹配的价格&库存,您可以联系我们找货
