MD9238E12B-FSR
MD9238E12B-FSR
    MECHATRONICSFANGROUP(机电一体化)
    FAN AXIAL 92X38MM 12VDC
MD9238E12B-FSR 数据手册
HIGH PERFORMANCE 3.62 ±0.01 (92 ±0.3) 3.25 ±0.01 (82.5 ±0.2) 0.18 (4.5) 1.50 ±0.01 (38 ±0.2) 21.0 0.18 (4.5) STATIC PRESSURE - MM OF WATER DC AXIAL FANS MD9238 series E H 15.0 M 12.0 L 9.0 6.0 3.0 0 0.6 1.2 1.8 2.4 3.0 3.6 AIR FLOW (M3/MIN) 4x Ø 0.17 ±0.01 (Ø 4.4 ±0.2) (92 x 92 x 38 mm) X 18.0 3.62 x 3.62 x 1.5 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing Connection: Frame: Rated Voltage V Speed Current mA 12 24 48 RPM Air Volume M³/Min. CFM Max. Static Pressure (H2 0) MM Sound Noise Weight INCH dbA g AWG 24, UL1007 lead wires MD9238L 12/24/48 360 190 100 3,200 2.01 71.06 7.86 0.31 44.5 180 flanged MD9238M 12/24/48 580 300 200 3,800 2.46 86.85 10.24 0.40 50.0 180 MD9238H 12/24/48 880 450 220 4,400 2.85 100.69 15.30 0.60 53.5 180 Protection: thermal Options: tachometer output or locked rotor alarm signal; PWM speed control w w w.mechatronic s.com 10.18.21 Model No. MD9238E 12/24 1000 500 - 4,800 3.13 110.56 16.93 0.67 55.0 180 MD9238X 24 - 700 - 5,400 3.50 123.57 21.39 0.84 58.4 180 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
MD9238E12B-FSR 价格&库存
很抱歉,暂时无法提供与“MD9238E12B-FSR”相匹配的价格&库存,您可以联系我们找货
