15025PA-12N-AA-00
15025PA-12N-AA-00
    NMBTECHNOLOGIESCORPORATION
    FAN AXIAL 172X25.4MM 12VDC WIRE
15025PA-12N-AA-00 数据手册
5910PL (150 X ∅172 X 25L) For New Designs we Recommend 15025PA NMBTC.COM / 248.919.2250 Auto Restart/Polarity Protection 10M Ω or over with a DC500V Megger AC 700V 1s Static Pressure In H2O (Pa) 1.0  Ps -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) 0.9  0.8  0.7  0.6  0.5  0.4  0.3  0.2  0.1  0 B70 B60 B50 B40 B30 B20 B10 (m3/min) 0       1.4 2.83 4.25 5.66 7.08 8.5 CFM Air Flow inch Units: (mm) .169 4 – (φ4.29) 6.77 (φ172.0) 55 NAME PLATE ° 5.9 (150) .00 .0 ° 55 HOLE CUTOUT 0° Casing : Aluminum (Black) Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG22, +Red, -Black ° 55 55 (.2) min 1.0 (25.4 ±0.5) (φ 1 5.9 50 .87 ) .169 4 – (φ4.3) Thru 6.37 (φ162.0) 6.37 (φ162.0 B.C.) 15.75 (400) min .196 (5.0 ±0.2) ROTATION Rib Type Only Rated Operating Voltage Voltage Product No. (V) (V) (A)*1 (W)*1 (min-1)*1 5910PL-04W-B10- L00 12 6.0 ~ 18.0 0.86 10.3 5910PL-04W-B20- L00 12 6.0 ~ 18.0 1.13 13.6 5910PL-04W-B30- L00 12 6.0 ~ 18.0 1.52 18.2 5910PL-04W-B40- L00 12 6.0 ~ 18.0 1.70 20.4 3350 230.0 6.52 .56 141.0 61.5 510.3 5910PL-04W-B50- L00 12 6.0 ~ 18.0 2.06 24.7 3500 250.0 7.08 .65 163.7 62.5 510.3 5910PL-05W-B10- L00 24 12.0 ~ 30.0 0.41 9.8 2500 170.0 4.81 .30 76.0 54.1 510.3 5910PL-05W-B20- L00 24 12.0 ~ 30.0 0.58 13.9 5910PL-05W-B30- L00 24 12.0 ~ 30.0 0.75 18.0 5910PL-05W-B40- L00 24 12.0 ~ 30.0 0.86 20.6 Casing : Plastic (Black) 94V-0 2850 190.0 5.38 .37 93.2 57.0 510.3 Impeller : Plastic (Black) 94V-0 3150 210.0 5.95 .46 115.2 58.9 510.3 Bearing : Ball Bearing 3350 230.0 6.52 .56 141.0 61.5 510.3 Lead Wire : UL1061, AWG22 , +Red, -Black 5910PL-05W-B50- L00 24 12.0 ~ 30.0 1.00 24.0 3500 250.0 7.08 .65 163.7 62.5 510.3 5910PL-05W-B60- L00 24 12.0 ~ 30.0 1.16 27.8 3750 270.0 7.65 .74 187.0 62.9 510.3 MODEL Current Input Speed Power Max. Max. Static Air Flow Pressure Noise Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 2500 170.0 4.81 .30 76.0 54.1 510.3 2850 190.0 5.38 .37 93.2 57.0 510.3 3150 210.0 5.95 .46 115.2 58.9 510.3 5910PL-05W-B70- L00 24 12.0 ~ 30.0 1.55 37.2 4100 290.0 8.20 .89 233.0 65.4 510.3 5910PL-07W-B10- L00 48 25.0 ~ 60.0 0.22 10.6 2500 170.0 4.81 .30 76.0 54.1 510.3 5910PL-07W-B20- L00 48 25.0 ~ 60.0 0.28 13.4 2850 190.0 5.38 .37 93.2 57.0 510.3 5910PL-07W-B30- L00 48 25.0 ~ 60.0 0.37 17.8 3150 210.0 5.95 .46 115.2 58.9 510.3 5910PL-07W-B40- L00 48 25.0 ~ 60.0 0.45 21.6 3350 230.0 6.52 .56 141.0 61.5 510.3 5910PL-07W-B50- L00 48 25.0 ~ 60.0 0.51 24.5 3500 250.0 7.08 .65 163.7 62.5 510.3 5910PL-07W-B60- L00 48 25.0 ~ 60.0 0.58 27.8 3750 270.0 7.65 .74 187.0 62.9 510.3 5910PL-07W-B70- L00 48 25.0 ~ 60.0 0.74 35.5 4100 290.0 8.20 .89 233.0 65.4 510.3 Rotation: Counterclockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air
15025PA-12N-AA-00 价格&库存
很抱歉,暂时无法提供与“15025PA-12N-AA-00”相匹配的价格&库存,您可以联系我们找货
