NE
W
R150 (150
X Ø172 X 51L)
NMBTC.COM / 818.341.3355
Characteristic Curves
In H2O (Pa)
6
Static Pressure
High Power Fans
5
4
1600
9,300rpm
1400
6,300rpm
1200
1000
3
2
1
800
600
400
200
200
200
General Specifications
300
400
400
500
600
600 [CFM]
[m3/h]
800
Air Flow
Outline
Motor Protection:
inch
Units: (mm)
Locked Rotor, Reverse Polarity
ROTATION
Insulation Resistance:
0.161
(8-F4.1 )
Dielectric Withstand Voltage: AC 700V 1 minute
Allowable Ambient Temperature Range:
11.42
Min 290
6.80
(F172.7 )
-30°C ~ +70°C (Operating)
-40°C ~ +80°C (Storage)
6.30
(F162 ± 0.2)
10M Ω min measured with 500V DC between all leads
shorted together and case
0.32
8-8.2
DEPTH 0.3
0.161
(8-R4.1)
NAME PLATE
AIR
Expected Life
Failure Rate: 10%
40°C 70,000 Hours (L10)
55
.5˚
.5˚
0.34
(4-8.8)
55
5.91
(150)
Material
2.00
(50.8 ± 0.2)
Casing : Aluminum
Impeller : Plastic
Bearing : Ball Bearing
Lead Wire : UL3266, AWG22, +Red, -Black,
Speed Control = Yellow,
Speed Signal = White
Specifications
MODEL
1.3
x.x
Rated
Voltage
Operating
Current
Voltage
Input
Speed
Power
Max.
Air Flow
Max. Static
(V)
(V)
(A)*1
(W)*1
(min-1)*1
R150A3-051-D0790
48
30 ~ 72
4.10
196.8
9300
544
15.41
6.21
R150A1-051-D0760
48
30 ~ 72
1.50
72.0
6300
365
10.33
3.48
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
Noise
Mass
Pressure
CFM*1 (m3/min)*1 in H2O (Pa)*1
(dB)*1
(g)
1550
85
1000
870
73
1000
*1: Average Values in Free Air and Rated Voltage Condition
0.35
(4-9)
很抱歉,暂时无法提供与“R150A3-051-D0790”相匹配的价格&库存,您可以联系我们找货
