F175A1-062-D0750
F175A1-062-D0750
    NMBTECHNOLOGIESCORPORATION
    FAN IMP MTRZD 175X69.3MM 48VDC
F175A1-062-D0750 数据手册
NE W ! F175 (Ø175 X 69L) NMBTC.COM / 818.341.3355 Characteristic Curves In H2O (Pa) 1400 5 5,300rpm 4,600rpm 1000 4,400rpm 800 3 600 2 400 1 200 0 0 100 200 200 300 400 400 600 600 [CFM] 500 800 1,000 [m3/h] Impellers Static Pressure 4 5,600rpm 1200 Air Flow Outline General Specifications Motor Protection: inch Units: (mm) ROTATION Insulation Resistance: 10M Ω min measured with 500V DC between all leads shorted together and case 2.28 (4xM4 P.C.D. 58) ˚ 45 Expected Life 90 Failure Rate: 10% 40°C 70,000 Hours 0.23 (6.0 ) ˚ 25.61 (650 ± 20 ) 90˚ 6.89 (F175.0 ) 3.74 (F95.0) Dielectric Withstand Voltage: AC 700V 1 minute Allowable Ambient Temperature Range: -30°C ~ +70°C (Operating) -40°C ~ +80°C (Storage) 2.73 (69.3) 2.45 (62.2) 5.18 (F131.5) 5.04 (F128.1 ) Locked Rotor, Reverse Polarity 0.42 (10.7) (L10) 92 0. 3.5 R2 1.33 (34.0) Material Impeller : Plastic Bearing : Ball Bearing Lead Wire : UL1015, AWG18, +Red, -Black, Speed Control = Yellow, Speed Signal = White Specifications Rated Voltage MODEL Operating Current Voltage Input Speed Power Max. Air Flow Max. Static (V) (V) (A)*1 (W)*1 (min-1)*1 F175A1-062-D0750 48 30 ~ 72 2.45 117.6 5600 551 15.60 5.11 F175A2-062-D0740 48 30 ~ 72 1.35 64.8 4600 442 12.52 3.36 F175A3-062-D0550 24 18 ~ 30 3.85 92.4 5300 505 14.30 F175A4-062-D0540 24 18 ~ 30 2.40 57.6 4400 413 11.69 Rotation: Clockwise *1: Average Values in Free Air and Rated Voltage Condition Noise Mass Pressure CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 1275 78 1000 839 73 1000 4.26 1064 77 1000 2.95 738 72 1000 x.x
F175A1-062-D0750 价格&库存
很抱歉,暂时无法提供与“F175A1-062-D0750”相匹配的价格&库存,您可以联系我们找货
