9A0924G401
9A0924G401
    SANYODENKI
    FAN92X25MM24VDCTACH
9A0924G401 数据手册
DC DC Fan DC Fan 92 mm sq. 92×92×25 mm San Cooler 92 9A type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Yellow Sensor · Mass………………………………………… 100 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] Max. airflow [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] SPL Operating temperature [dB (A)] [˚C] [h] -20 to +60 30000/60˚C (53000/40˚C) -20 to +70 40000/60˚C (70000/40˚C) 9A0912G401 0.39 4.68 3900 1.76 62.1 66.5 0.267 43 9A0912S401 9A0912H401 9A0912F401 9A0912M401 9A0912L401 0.27 0.21 0.14 0.12 0.07 3.24 2.52 1.68 1.44 0.84 3550 3150 2650 2250 1750 1.66 1.45 1.24 1.04 0.8 58.6 51.2 43.8 36.7 28.2 56.1 44 32.2 22.6 13.4 0.225 0.177 0.129 0.091 0.054 39 33 30 27 23 0.19 4.56 3900 1.76 62.1 66.5 0.267 43 0.15 0.1 0.08 0.05 0.04 0.08 3.6 2.4 1.92 1.2 0.96 3.84 3550 3150 2650 2250 1750 3550 1.66 1.45 1.24 1.04 0.8 1.66 58.6 51.2 43.8 36.7 28.2 58.6 56.1 44 32.2 22.6 13.4 56.1 0.225 0.177 0.129 0.091 0.054 0.225 39 33 30 27 23 39 6 to 13.8 12 7 to 13.8 9A0924G401 9A0924S401 9A0924H401 9A0924F401 9A0924M401 9A0924L401 9A0948S401 12 to 27.6 24 14 to 27.6 40.5 to 53 48 -20 to +60 -20 to +70 Expected life 30000/60˚C (53000/40˚C) 40000/60˚C (70000/40˚C) -20 to +60 Note 1: Sensor and control options are available for selection. Refer to the table on p. 624. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics 9A0912G401 9A0912S401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 13.8 V 12 V 60 0.20 0.15 0.10 0.05 0 40 20 0 (inch H2O) (Pa) 6V 0.4 0.8 1.2 1.6 2.0 (m3/min) 0 10 20 30 40 50 60 70 Airflow (CFM) 70 0.25 60 0.20 50 0.15 40 0.10 0.25 80 0.20 Static pressure 0.25 80 Static pressure Static pressure 0.30 0.30 13.8 V 12 V 6V 30 20 0.05 10 0 0 With pulse sensor Operating voltage range (inch H2O) (Pa) 0.40 100 0.35 9A0912H401 With pulse sensor 0.5 1.0 1.5 2.0 0 10 20 30 40 50 60 70 80 Airflow 2.5 (m3/min) (CFM) 0.15 60 13.8 V 50 12 V 40 6V 30 0.10 0.05 0 20 10 0 0.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 (CFM) Airflow CATALOG No. C1111B002 '21.9.IT 147 9A0912F401 9A0912M401 With pulse sensor Operating voltage range 13.8 V 40 30 6V 20 10 0.12 0.08 0.06 0.04 10 0.5 10 1.0 20 30 Airflow 1.5 40 50 0 (m3/min) 0 60 (CFM) (inch H2O) (Pa) 80 27.6 V Static pressure 24 V 0.20 0.10 0.05 0 40 12 V 20 0 0.4 0.8 10 1.2 1.6 2.0 (m3/min) 0 10 20 30 40 50 60 70 0.25 Static pressure Static pressure 12 V 10 0.15 40 0.10 9A0948S401 10 1.0 20 30 Airflow 1.5 40 50 (m3/min) 60 (CFM) With pulse sensor Operating voltage range (inch H2O) (Pa) 80 70 0.20 50 0.15 40 0.10 0.05 0 53 V 48 V 40.5 V 30 20 10 0 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 Airflow 148 9A0924H401 24 V 12 V 20 10 0 0 0.12 0.5 1.0 1.5 2.0 0.15 CATALOG No. C1111B002 '21.9.IT (CFM) 0 1.0 (m3/min) (CFM) With pulse sensor 60 24 V 40 12 V 0.10 0.05 20 10 0 0.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 (CFM) Airflow 9A0924L401 With pulse sensor Operating voltage range (inch H2O) (Pa) 40 0.12 24 V 12 V 20 30 27.6 V 0.10 27.6 V 30 10 0.08 24 V 20 0.06 0.04 14 V 10 0.02 0 0 27.6 V 50 (CFM) 0.06 0.04 0.8 30 30 0 2.5 (m3/min) With pulse sensor 0.10 0.08 0.6 20 Operating voltage range 27.6 V 30 0.05 0.4 10 Airflow 0.02 0.5 0.2 0 0.20 0.14 24 V 0 0 (CFM) 0.25 60 50 0.16 20 60 50 Operating voltage range 27.6 V 0.25 40 (inch H2O) (Pa) 0 0.30 30 0 10 20 30 40 50 60 70 80 50 30 7V 10 (inch H2O) (Pa) 9A0924M401 With pulse sensor 40 0.04 Airflow (inch H2O) (Pa) 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 20 70 0.20 (CFM) Operating voltage range 12 V 20 0.06 0 1.5 (m3/min) With pulse sensor Airflow 9A0924F401 1.0 Static pressure Static pressure 0.30 60 0.5 Operating voltage range 0.40 100 80 0.08 Airflow 9A0924S401 With pulse sensor 13.8 V 0.02 0 (inch H2O) (Pa) 0.15 6V 20 Static pressure 0 Operating voltage range 0.25 12 V 0.10 30 0.10 13.8 V 30 0.02 9A0924G401 0.30 0.12 0.14 12 V 0 0.35 (inch H2O) (Pa) 40 Static pressure 0.16 With pulse sensor Operating voltage range (inch H2O) (Pa) 50 Static pressure Static pressure 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 9A0912L401 With pulse sensor Operating voltage range (inch H2O) (Pa) Static pressure DC DC Fan 92 mm sq. ■ Airflow - Static Pressure Characteristics 0.5 10 20 1.0 30 Airflow 40 1.5 (m3/min) 50 (CFM) 0 0 0.2 0 10 0.4 0.6 20 Airflow 0.8 30 1.0 (m3/min) (CFM) DC (With ribs) 25±0.5 92±0.5 4-ø4.3±0.3 Mounting hole 82.5±0.3 (4) (4) DC Fan 92 mm sq. ■ Dimensions (unit: mm) 92±0.5 82.5±0.3 Lead wire AWG24 UL 1007 +50 300 0 (10) Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side 90.5 Outlet side 02 4- ø 4.5 ø1 90.5 82.5±0.3 90.5 2 ø9 82.5±0.3 90.5 4- ø 4.5 82.5±0.3 82.5±0.3 ■ Options Finger guards page: p. 584 Model no.: 109-099E, 109-099H, 109-099C Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1001G page: p. 592 Model no.: 109-1001F13 (13PPI), 109-1001F20 (20PPI), 109-1001F30 (30PPI), 109-1001F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 149
9A0924G401 价格&库存
很抱歉,暂时无法提供与“9A0924G401”相匹配的价格&库存,您可以联系我们找货
