DC
DC Fan
DC Fan 92 mm sq.
92×92×25 mm
San Cooler 92 9A type
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Yellow
Sensor
· Mass………………………………………… 100 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
[V]
[V]
[A]
[W]
[min-1]
Max. airflow
[m3/min]
[CFM]
Max. static pressure
[Pa]
[inchH2O]
SPL
Operating temperature
[dB (A)]
[˚C]
[h]
-20 to +60
30000/60˚C
(53000/40˚C)
-20 to +70
40000/60˚C
(70000/40˚C)
9A0912G401
0.39
4.68
3900
1.76
62.1
66.5
0.267
43
9A0912S401
9A0912H401
9A0912F401
9A0912M401
9A0912L401
0.27
0.21
0.14
0.12
0.07
3.24
2.52
1.68
1.44
0.84
3550
3150
2650
2250
1750
1.66
1.45
1.24
1.04
0.8
58.6
51.2
43.8
36.7
28.2
56.1
44
32.2
22.6
13.4
0.225
0.177
0.129
0.091
0.054
39
33
30
27
23
0.19
4.56
3900
1.76
62.1
66.5
0.267
43
0.15
0.1
0.08
0.05
0.04
0.08
3.6
2.4
1.92
1.2
0.96
3.84
3550
3150
2650
2250
1750
3550
1.66
1.45
1.24
1.04
0.8
1.66
58.6
51.2
43.8
36.7
28.2
58.6
56.1
44
32.2
22.6
13.4
56.1
0.225
0.177
0.129
0.091
0.054
0.225
39
33
30
27
23
39
6 to 13.8
12
7 to 13.8
9A0924G401
9A0924S401
9A0924H401
9A0924F401
9A0924M401
9A0924L401
9A0948S401
12 to 27.6
24
14 to 27.6
40.5 to 53
48
-20 to +60
-20 to +70
Expected life
30000/60˚C
(53000/40˚C)
40000/60˚C
(70000/40˚C)
-20 to +60
Note 1: Sensor and control options are available for selection. Refer to the table on p. 624.
Note 2: The
mark indicates Short Lead Time Service applicable models. See p. 654 for details.
■ Airflow - Static Pressure Characteristics
9A0912G401
9A0912S401
With pulse sensor
(inch H2O) (Pa)
13.8 V
12 V
60
0.20
0.15
0.10
0.05
(inch H2O) (Pa)
6V
0.4
0.8
1.2
1.6
2.0 (m3/min)
0 10 20 30 40 50 60 70
Airflow
(CFM)
70
0.25
60
0.20
50
0.15
40
0.10
0.25
80
0.20
Static pressure
0.25
80
Static pressure
Static pressure
0.30
0.30
13.8 V
12 V
6V
30
10
With pulse sensor
(inch H2O) (Pa)
0.40 100
0.35
9A0912H401
With pulse sensor
0.5
1.0
1.5
2.0
0 10 20 30 40 50 60 70 80
Airflow
2.5 (m3/min)
(CFM)
0.15
60
13.8 V
50
12 V
40
6V
30
0.10
0.05
1.0
1.5
2.0 (m3/min)
0 10 20 30 40 50 60 70 (CFM)
Airflow
CATALOG No. C1111B002 '21.9.IT
147
9A0912F401
9A0912M401
With pulse sensor
13.8 V
40
30
6V
0.12
0.08
0.06
0.04
10
0.5
10
1.0
Airflow
1.5
40
50
(m3/min)
60 (CFM)
(inch H2O) (Pa)
80
27.6 V
Static pressure
24 V
0.20
0.10
0.05
12 V
0.8
10
1.2
1.6
2.0 (m3/min)
0.25
Static pressure
Static pressure
12 V
10
0.15
40
0.10
9A0948S401
10
1.0
Airflow
1.5
40
50
(m3/min)
60 (CFM)
With pulse sensor
(inch H2O) (Pa)
80
70
0.20
50
0.15
40
0.10
0.05
53 V
48 V
40.5 V
30
1.0
1.5
2.0
2.5 (m3/min)
Airflow
148
9A0924H401
24 V
12 V
0.5
1.0
1.5
2.0
0.15
(CFM)
1.0 (m3/min)
(CFM)
With pulse sensor
60
24 V
40
12 V
0.10
0.05
1.0
1.5
2.0 (m3/min)
Airflow
9A0924L401
With pulse sensor
(inch H2O) (Pa)
40
0.12
24 V
12 V
27.6 V
0.10
27.6 V
30
10
0.08
24 V
0.04
14 V
10
0.02
27.6 V
50
(CFM)
0.06
0.04
0.8
30
30
2.5 (m3/min)
With pulse sensor
0.10
0.08
0.6
27.6 V
30
0.05
0.4
10
Airflow
0.02
0.5
0.2
0.14
24 V
(CFM)
0.25
60
50
0.16
50
27.6 V
0.25
40
(inch H2O) (Pa)
30
50
30
7V
10
(inch H2O) (Pa)
9A0924M401
With pulse sensor
40
0.04
Airflow
(inch H2O) (Pa)
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
0.20
(CFM)
12 V
1.5 (m3/min)
With pulse sensor
Airflow
9A0924F401
1.0
Static pressure
Static pressure
0.30
60
0.5
0.40 100
80
0.08
Airflow
9A0924S401
With pulse sensor
13.8 V
0.02
(inch H2O) (Pa)
0.15
6V
Static pressure
0.25
12 V
0.10
30
0.10
13.8 V
30
0.02
9A0924G401
0.30
0.12
0.14
12 V
(inch H2O) (Pa)
40
Static pressure
0.16
With pulse sensor
(inch H2O) (Pa)
50
Static pressure
Static pressure
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
9A0912L401
With pulse sensor
(inch H2O) (Pa)
Static pressure
DC
DC Fan 92 mm sq.
0.5
10
30
Airflow
40
1.5 (m3/min)
50
(CFM)
0.4
0.6
Airflow
0.8
30
1.0 (m3/min)
(CFM)
DC
(With ribs)
25±0.5
92±0.5
4-ø4.3±0.3
Mounting hole
82.5±0.3
(4)
(4)
DC Fan 92 mm sq.
■ Dimensions (unit: mm)
92±0.5
82.5±0.3
Lead wire
AWG24
UL 1007
+50
300 0
(10)
Airflow direction
Rotating direction
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side
90.5
Outlet side
02
4- ø 4.5
ø1
90.5
82.5±0.3
90.5
2
ø9
82.5±0.3
90.5
4- ø 4.5
82.5±0.3
82.5±0.3
■ Options
Finger guards
page: p. 584
Model no.: 109-099E, 109-099H, 109-099C
Resin filter kits
Resin finger guards
page: p. 591
Model no.: 109-1001G
page: p. 592
Model no.: 109-1001F13 (13PPI), 109-1001F20 (20PPI),
109-1001F30 (30PPI), 109-1001F40 (40PPI)
149
很抱歉,暂时无法提供与“9A0912G401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+97.17152
- 5+94.25564
- 10+91.35018
- 25+89.41321
- 50+87.46582
