DC Fan
60×60×20 mm
San Ace 60 9P type
■ General Specifications
・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C,
rated voltage)
・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 547.
・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet
・ Storage temperature ……………………… -30 to +70˚C (Non-condensing)
・ Lead wire ………………………………………
Red
Black or Blue
Yellow
Sensor
・ Mass ……………………………………………… 90 g
■ Specifications
The models listed below have ribs and pulse sensors.
Rated voltage Operating voltage range Rated current Rated input
Model no.
[V]
109P0612W601
109P0612H601
109P0612M601
109P0624W601
109P0624H601
109P0624M601
109P0648H601
12
Max. static pressure
[W]
[min-1]
[m³/min]
[CFM]
[Pa]
6 to 16
0.13
0.13
0.09
0.07
0.07
0.05
0.07
1.56
1.56
1.08
1.68
1.68
1.2
3.36
4200
4200
3200
4200
4200
3200
5600
0.42
0.42
0.3
0.42
0.42
0.3
0.55
14.8
14.8
10.6
14.8
14.8
10.6
19.4
31.8
31.8
18.8
31.8
31.8
18.8
52.9
12 to 30
20.4 to 27.6
48
Max. airflow
[A]
10.2 to 13.8
24
Rated speed
[V]
43 to 53
SPL
[inchH²O]
Operating temperature Expected life
[dB (A)]
[˚C]
31
31
25
31
31
25
41
-20 to +70
0.128
0.128
0.076
0.128
0.128
0.076
0.212
[h]
60000/60˚C
40000/60˚C
The following sensor and control options are available for selection.
Available for all models. Without sensor
Lock sensor
■ Airflow - Static Pressure Characteristics
109P0612W601
109P0612H601
With pulse sensor
0.10
16 V
40
12 V
30
6V
10
5
0.4
10
15
Airflow
風量
0.6 (m3/min)
(CFM)
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
(inch H2O) (Pa)
50
0.12
13.8 V
40
Static静圧
pressure
0.15
50
Static静圧
pressure
Static静圧
pressure
60
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
0.20
109P0612M601
With pulse sensor
12 V
30
10.2 V
30
0.10
0.08
13.8 V
12 V
0.06
0.04
10.2 V
10
0.02
0.4
10
15
Airflow
風量
0.6 (m3/min)
(CFM)
5
0.3
10
Airflow
風量
0.4
15
0.5 (m3/min)
(CFM)
109P0624H601
With pulse sensor
0.10
30 V
40
24 V
30
12 V
10
109P0648H601
5
0.4
10
0.6 (m3/min)
15
Airflow
風量
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
(inch H2O) (Pa)
50
0.12
27.6 V
40
Static静圧
pressure
0.15
50
Static静圧
pressure
Static静圧
pressure
60
24 V
30
20.4 V
30
0.10
0.08
27.6 V
24 V
0.06
0.04
20.4 V
10
0.02
(CFM)
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
0.20
109P0624M601
With pulse sensor
DC Fan 60 mm sq.
109P0624W601
DC
5
0.4
10
15
Airflow
風量
0.6 (m3/min)
(CFM)
5
0.3
10
Airflow
風量
0.4
15
0.5 (m3/min)
(CFM)
With pulse sensor
(inch H2O) (Pa)
70
Static静圧
pressure
0.25
0.20
0.15
0.10
60
53 V
50
48 V
40
43 V
30
10
0.4
10
Airflow
風量
0.6 (m3/min)
15
(CFM)
■ Dimensions (unit: mm)
+1
60 0
4-ø4.3±0.3
Mounting
取付用穴 hole
50±0.3
(3)
(5)
50±0.3
+1
60 0
Lead
wire
リー
ド線
AWG24
UL 1007
+50
300 0
(10)
Rotating
direction
回転方向
Airflow
direction
風吹出方向
69
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
58
4-ø4.5
50±0.3
3
58
50±0.3
ø6
■ Options
Finger guards
page: p. 532
Model no.: 109-139E, 109-139H
Resin filter kits
Model no.: 109-1003G
page: p. 540
Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI),
109-1003F30 (30PPI), 109-1003F40 (40PPI)
70
Resin finger guards
page: p. 539
很抱歉,暂时无法提供与“109P0624H602”相匹配的价格&库存,您可以联系我们找货
