DC
DC Fan 60 mm sq.
DC Fan
60×60×25 mm
San Ace 60 9R type
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Sensor
Yellow
· Mass………………………………………… 90 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Model no.
109R0605H401
109R0605F401
109R0605M401
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
SPL
Operating temperature
Expected life
[V]
[V]
[A]
[W]
[min-1]
[m3/min]
[CFM]
[Pa]
[inchH2O]
[dB (A)]
[˚C]
[h]
4.5 to 5.5
0.34
0.2
0.13
1.7
1.0
0.65
3800
3200
2600
0.53
0.44
0.36
18.7
15.5
12.7
40.2
29.4
19.6
0.161
0.118
0.079
28
24
-20 to +70
-20 to +60
-20 to +70
60000/60˚C
(90000/40˚C)
0.47
5.64
7600
1.06
37.1
155.0
0.622
44
-20 to +60
40000/60˚C
(70000/40˚C)
2.88
2.52
2.04
1.32
1.08
0.72
5.76
3.12
2.88
1.92
1.44
1.2
0.96
5.76
3.36
5600
5150
4600
3800
3200
2600
7600
5600
5150
4600
3800
3200
2600
7600
5600
0.78
0.72
0.65
0.53
0.44
0.36
1.06
0.78
0.72
0.65
0.53
0.44
0.36
1.06
0.78
27.5
25.4
23.0
18.7
15.5
12.7
37.1
27.5
25.4
23.0
18.7
15.5
12.7
37.1
27.5
87.3
73.5
56.8
40.1
29.4
19.6
155.0
87.3
73.5
56.8
40.2
29.4
19.6
155.0
87.3
0.351
0.295
0.228
0.161
0.118
0.079
0.622
0.351
0.295
0.228
0.161
0.118
0.079
0.622
0.351
39
37
33
28
24
39
37
33
28
24
39
-20 to +70
60000/60˚C
(90000/40˚C)
14 to 27.6
43.2 to 52.8
43 to 53
0.24
0.21
0.17
0.11
0.09
0.06
0.24
0.13
0.12
0.08
0.06
0.05
0.04
0.12
0.07
40 to 53
0.04
1.92
3800
0.53
18.7
40.2
0.161
28
5
109R0612J401
109R0612G401
109R0612D401
109R0612S401
109R0612H401
109R0612F401
109R0612M401
109R0624J401
109R0624G401
109R0624D401
109R0624S401
109R0624H401
109R0624F401
109R0624M401
109R0648J401
109R0648G401
10.8 to 13.2
12
10.2 to 13.8
6 to 13.8
7 to 13.8
21.6 to 26.4
20.4 to 27.6
24
48
109R0648H401
12 to 27.6
Note 1: Sensor and control options are available for selection. Refer to the table on pp. 622 to 623.
Note 2: The
mark indicates Short Lead Time Service applicable models. See p. 654 for details.
74
CATALOG No. C1111B002 '21.9.IT
Max. airflow
Max. static pressure
-20 to +60
-20 to +70
-20 to +60
-20 to +70
40000/60˚C
(70000/40˚C)
60000/60˚C
(90000/40˚C)
40000/60˚C
(70000/40˚C)
60000/60˚C
(90000/40˚C)
109R0605F401
With pulse sensor
(inch H2O) (Pa)
0.16
5V
30
4.5 V
0.08
5V
4.5 V
0.06
0.04
10
0.02
0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min)
10
15
25 (CFM)
0.1 0.2 0.3 0.4 0.5 0.6 (m3/min)
Airflow
109R0612J401
109R0612G401
With pulse sensor
0.5
0.4
0.3
0.2
0.1
0.40
13.2 V
12 V
10.8 V
0.35
0.30
0.25
0.20
0.15
0.10
0.05
0.2 0.4 0.6 0.8 1.0 1.2 1.4 (m3/min)
0 5 10 15 20 25 30 35 40 45
60
0.15
40
0.10
0.05
13.8 V
Static pressure
Static pressure
50
12 V
6V
30
0.10
0.2
0.4
10
0.6
15
12 V
10.8 V
25
(m3/min)
5
10 15 20 25 30
15
0.04
10
0.02
5
13.8 V
0.7
12 V
7V
0.6
0.5
0.4
0.3
0.2
0.1
0.3
10
Airflow
0.4
15
0.5
(m3/min)
20 (CFM)
0.4
10
0.5 (m3/min)
15
(CFM)
With pulse sensor
100
0.3
80
12 V
60
10.2 V
0.2
40
0.1
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8
10
15
(m3/min)
30 (CFM)
109R0612F401
With pulse sensor
0.18
0.16
12 V
40
30
6V
10
40
13.8 V
0.14
0.12
12 V
30
0.10
0.08
6V
0.04
10
0.02
180
160
140
120
100
80
60
40
5
5
10
15
25 (CFM)
5
10
15
(CFM)
Airflow
109R0624G401
With pulse sensor
0.8
0.2
0.1
Airflow
With pulse sensor
(inch H2O) (Pa)
0.1
13.8 V
109R0624J401
With pulse sensor
Static pressure
Static pressure
0.08
(inch H2O) (Pa)
25
5
4.5 V
Airflow
(inch H2O) (Pa)
0.10
0.02
(CFM)
With pulse sensor
50
30 (CFM)
0.12
10
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min)
Airflow
109R0612M401
0.04
5V
13.2 V
10
13.8 V
109R0612H401
(inch H2O) (Pa)
0.20
0.06
5.5 V
109R0612D401
80
60
(inch H2O) (Pa)
0.25
0.08
Airflow
With pulse sensor
70
25
(inch H2O) (Pa)
110
100
90
80
70
60
50
40
30
(CFM)
0.30
0.10
Airflow
With pulse sensor
Airflow
109R0612S401
30
(CFM)
(inch H2O) (Pa)
200
180
160
140
120
100
80
60
40
Static pressure
Static pressure
0.6
(inch H2O) (Pa)
0.7
15
0.12
Airflow
0.8
10
Static pressure
5.5 V
Static pressure
0.05
30
Static pressure
40
0.12
(inch H2O) (Pa)
26.4 V
24 V
Static pressure
0.10
5.5 V
Static pressure
Static pressure
0.15
(inch H2O) (Pa)
40
0.14
50
With pulse sensor
(inch H2O) (Pa)
60
0.20
109R0605M401
With pulse sensor
DC Fan 60 mm sq.
109R0605H401
DC
■ Airflow - Static Pressure Characteristics
21.6 V
Airflow
(CFM)
0.50
0.45
0.40
0.35
0.30
0.25
0.20
0.15
0.10
0.05
110
100
90
80
70
60
50
40
30
27.6 V
24 V
20.4 V
10 15 20 25 30
(CFM)
Airflow
75
109R0624S401
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
(inch H2O) (Pa)
80
60
100
0.30
80
0.3
24 V
Static pressure
Static pressure
27.6 V
60
0.2
12 V
40
0.1
50
0.15
40
0.10
10
15
(m3/min)
24 V
12 V
30
30 (CFM)
0.2
0.12
Static pressure
Static pressure
27.6 V
0.14
24 V
30
0.10
12 V
10
0.04
0.02
5
10
15
109R0648G401
0.08
15
0.04
10
0.02
5
5
109R0648J401
(inch H2O) (Pa)
60
Static pressure
0.20
53 V
48 V
43 V
0.15
0.10
27.6 V
0.7
24 V
0.6
14 V
(m3/min)
0.1
0.2
5
0.3
10
0.4
15
0.5
(m3/min)
20 (CFM)
53 V
48 V
40
30
40 V
10
Airflow
5
10
15
25 (CFM)
Airflow
(With ribs)
+1
60 0
50±0.3
4-ø4.3±0.3
Mounting hole
25±0.5
(3)
(3)
Lead wire
AWG24
UL 1007
50±0.3
+50
300 0
(10)
Rotating direction
15
25 (CFM)
With pulse sensor
0.4
0.3
0.2
180
160
140
120
100
80
60
40
52.8 V
48 V
43.2 V
Airflow
With pulse sensor
50
10 15 20 25 30 35 (CFM)
0.5
0.1
10
120
110
100
90
80
70
60
50
40
30
10
109R0648H401
With pulse sensor
■ Dimensions (unit: mm)
0.05
Airflow
Airflow
(inch H2O) (Pa)
5
12 V
(inch H2O) (Pa)
(CFM)
30 (CFM)
With pulse sensor
Airflow
Static pressure
24 V
40
(m3/min)
30
0.10
0.40
0.35
0.30
0.25
0.20
0.15
0.10
0.05
0.8
(inch H2O) (Pa)
0.18
0.08
0.6
(inch H2O) (Pa)
0.12
0.4
10
109R0624M401
With pulse sensor
40
0.10
27.6 V
50
Airflow
0.16
0.15
10
Airflow
109R0624F401
0.20
27.6 V
60
0.20
0.05
With pulse sensor
Static pressure
0.4
109R0624H401
With pulse sensor
Static pressure
109R0624D401
+1
60 0
DC
DC Fan 60 mm sq.
Airflow direction
(CFM)
DC
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
DC Fan 60 mm sq.
Inlet side, Outlet side
59
50±0.3
29.7
59
29.7
50±0.3
62
.7
4-ø4.5
■ Options
Finger guards
page: p. 584
Model no.: 109-139E, 109-139H
Resin filter kits
Resin finger guards
page: p. 591
Model no.: 109-1003G
page: p. 592
Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI),
109-1003F30 (30PPI), 109-1003F40 (40PPI)
77
很抱歉,暂时无法提供与“109R0648J401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+125.36184
- 5+123.17493
- 10+120.11326
- 25+117.11407
- 50+114.18778
