74ABT125DB,112
74ABT125DB,112
    NEXPERIA(安世)
    SSOP-14_6.2X5.3MM
    IC BUF NON-INVERT 5.5V 14SSOP
74ABT125DB,112 数据手册
74ABT125 Quad buffer; 3-state Rev. 8 — 30 June 2021 Product data sheet 1. General description The 74ABT125 is a quad buffer/line driver with 3-state outputs controlled by the output enable inputs (nOE). A HIGH on nOE causes the outputs to assume a high impedance OFF-state. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • • • Supply voltage range from 4.5 V to 5.5 V BiCMOS high speed and output drive Direct interface with TTL levels Power-up 3-state Inputs are disabled during 3-state mode IOFF circuitry provides partial Power-down mode operation Latch-up protection exceeds 500 mA per JESD78B class II level A Quad bus interface 3-state buffers Live insertion and extraction permitted Output capability: HIGH -32 mA; LOW +64 mA ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ABT125D -40 °C to +85 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74ABT125PW -40 °C to +85 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74ABT125BQ -40 °C to +85 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm SOT762-1 74ABT125 Nexperia Quad buffer; 3-state 4. Functional diagram 2 1A 1 1OE 5 2A 4 2OE 9 3A 10 3OE 12 4A 13 4OE 1Y 3 2 2Y 1 6 3Y 6 4 8 9 8 10 4Y 11 3 EN1 5 11 13 nOE mna229 Logic symbol Fig. 2. nY nA 12 mna228 Fig. 1. 1 IEC logic symbol mna227 Fig. 3. Logic diagram (one buffer) 5. Pinning information 5.1. Pinning 1 terminal 1 index area 2 1Y 3 12 4A 2OE 4 11 4Y 2A 5 10 3OE 2Y 6 9 3A GND 7 8 3Y 12 4A 4 11 4Y 2A 5 2Y 6 GND(1) 10 3OE 9 3A 001aai028 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 001aai027 Fig. 4. 3 8 1A 14 VCC 13 4OE 1Y 3Y 1 13 4OE 2OE 7 1OE 2 GND 74ABT125 1A 14 VCC 1OE 74ABT125 Pin configuration SOT108-1 (SO14) and SOT402-1 (TSSOP14) Fig. 5. Pin configuration SOT762-1 (DHVQFN14) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 4, 10, 13 output enable input (active LOW) 1A, 2A, 3A, 4A 2, 5, 9, 12 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 2 / 12 74ABT125 Nexperia Quad buffer; 3-state 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Output Inputs nOE nA nY L L L L H H H X Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current IOK Min Max Unit -0.5 +7.0 V [1] -1.2 +7.0 V [1] -0.5 +5.5 V VI < 0 V -18 - mA output clamping current VO < 0 V -50 - mA IO output current output in LOW-state - 128 mA Tj junction temperature - 150 °C Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] [2] Tamb = -40 °C to +85 °C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. 8. Recommended operating conditions Table 5. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VIH HIGH-level input voltage VIL LOW-level Input voltage IOH Min Max Unit 4.5 5.5 V 0 VCC V 2.0 - V - 0.8 V HIGH-level output current -32 - mA IOL LOW-level output current - 64 mA Δt/ΔV input transition rise and fall rate - 10 ns/V Tamb ambient temperature -40 +85 °C 74ABT125 Product data sheet Conditions in free air All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 3 / 12 74ABT125 Nexperia Quad buffer; 3-state 9. Static characteristics Table 6. Static characteristics Symbol Parameter Conditions 25 °C -40 °C to +85 °C Unit Min Typ Max Min Max - -0.9 -1.2 - -1.2 V VCC = 4.5 V; IOH = -3 mA 2.5 2.9 - 2.5 - V VCC = 5.0 V; IOH = -3 mA 3.0 3.4 - 3.0 - V VCC = 4.5 V; IOH = -32 mA 2.0 2.4 - 2.0 - V VIK input clamping voltage VCC = 4.5 V; IIK = -18 mA VOH HIGH-level output voltage VI = VIL or VIH VOL LOW-level output voltage VCC = 4.5 V; IOL = 64 mA; VI = VIL or VIH - 0.35 0.55 - 0.55 V II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - ±0.01 ±1.0 - ±1.0 μA IOFF power-off leakage current VCC = 0.0 V; VI or VO ≤ 4.5 V - ±5.0 ±100 - ±100 μA IO(pu/pd) power-up/power-down VCC = 2.1 V; VO = 0.5 V; output current VI = GND or VCC; OE = don’t care - ±5.0 ±50 - ±50 μA IOZ OFF-state output current VO = 2.7 V - 1.0 50 - 50 μA VO = 0.5 V - -1.0 -50 - -50 μA - 5.0 50 - 50 μA -50 -100 -180 -50 -180 mA outputs HIGH-state - 65 250 - 250 μA outputs LOW-state - 12 15 - 30 mA outputs disabled - 65 250 - 50 μA outputs enabled - 0.5 1.5 - 1.5 mA outputs disabled - 50 250 - 250 mA one enable input at 3.4 V and other inputs at VCC or GND; outputs disabled - 0.5 1.5 - 1.5 mA VCC = 5.5 V; VI = VIL or VIH ICEX output high leakage current HIGH-state; VO = 5.5 V; VCC = 5.5 V; VI = GND or VCC IO output current VCC = 5.5 V; VO = 2.5 V ICC supply current VCC = 5.5 V; VI = GND or VCC ΔICC additional supply current [1] per control pin; VCC = 5.5 V; one control input at 3.4 V, other inputs at VCC or GND [2] [3] CI input capacitance VI = 0 V or VCC - 4 - - - pF CO output capacitance outputs disabled; VO = 0 V or VCC - 7 - - - pF [1] [2] [3] This parameter is valid for any VCC between 0 V and 2.1 V, with a transition time of up to 10 ms. From VCC = 2.1 V to VCC = 5 V ± 10 %, a transition time of up to 100 μs is permitted. Not more than one output should be tested at a time, and the duration of the test should not exceed one second. This is the increase in supply current for each input at 3.4 V. 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 4 / 12 74ABT125 Nexperia Quad buffer; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V. Test circuit is shown in Fig. 8. Symbol Parameter Conditions 25 °C; VCC = 5.0 V -40 °C to +85 °C; Unit VCC = 5.0 V ± 0.5 V Min Typ Max Min Max tPLH LOW to HIGH propagation delay nA to nY, see Fig. 6 1.0 2.8 4.1 1.0 4.6 ns tPHL HIGH to LOW propagation delay nA to nY; see Fig. 6 1.0 3.1 4.6 1.0 4.9 ns tPZH OFF-state to HIGH propagation delay nOE to nY; see Fig. 7 1.0 3.2 5.0 1.0 5.9 ns tPZL OFF-state to LOW propagation delay nOE to nY; see Fig. 7 1.0 4.2 6.2 1.0 6.8 ns tPHZ HIGH to OFF-state propagation delay nOE to nY; see Fig. 7 1.0 4.1 5.4 1.0 6.2 ns tPLZ LOW to OFF-state propagation delay nOE to nY; see Fig. 7 1.5 2.8 5.0 1.5 5.5 ns 10.1. Waveforms and test circuit VI VM nA input GND tPHL tPLH VOH VM nY output VOL mna230 VM = 1.5 V VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Propagation delay input (nA) to output (nY) 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 5 / 12 74ABT125 Nexperia Quad buffer; 3-state VI nOE input VM VM GND tPZL tPLZ output LOW-to-OFF OFF-to-LOW 3.5 V VM VOL + 0.3 V VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VOH - 0.3 V VM GND outputs enabled outputs enabled outputs disabled 001aal294 VM = 1.5 V VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Enable and disable times VI negative pulse tW 90 % 90 % VM 10 % 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VEXT VCC G 90 % VM VI DUT VM 10 % RT 10 % tW RL VO CL mna616 001aai298 a. Input pulse definition RL b. Test circuit Test data is given in Table 8. Test circuit definitions: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig. 8. Test circuit for measuring switching times Table 8. Test data Input Load VEXT VI fI tW tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 3.0 V 1 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω open open 7.0 V 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 6 / 12 74ABT125 Nexperia Quad buffer; 3-state 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 7 / 12 74ABT125 Nexperia Quad buffer; 3-state TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 10. Package outline SOT402-1 (TSSOP14) 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 8 / 12 74ABT125 Nexperia Quad buffer; 3-state DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 11. Package outline SOT762-1 (DHVQFN14) 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 9 / 12 74ABT125 Nexperia Quad buffer; 3-state 12. Abbreviations Table 9. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ABT125 v.8 20210630 Product data sheet - 74ABT125 v.7 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74ABT125DB (SOT337-1/SSOP14) removed. Section 1 and Section 2 updated. Section 7: Derating values for Ptot total power dissipation updated. 74ABT125 v.7 20151125 Modifications: • 74ABT125 v.6 20111103 Modifications: • 74ABT125 v.5 20101124 74ABT125 v.4 Product data sheet - 74ABT125 v.6 Type number 74ABT125N (SOT27-1) removed. - 74ABT125 v.5 Product data sheet - 74ABT125 v.4 20100427 Product data sheet - 74ABT125 v.3 74ABT125 v.3 20080429 Product data sheet - 74ABT125 v.2 74ABT125 v.2 19980116 Product specification - 74ABT125 v.1 74ABT125 v.1 19960305 - - - 74ABT125 Product data sheet Product data sheet Legal pages updated All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 10 / 12 74ABT125 Nexperia Quad buffer; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74ABT125 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 11 / 12 74ABT125 Nexperia Quad buffer; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 5 10.1. Waveforms and test circuit........................................ 5 11. Package outline.......................................................... 7 12. Abbreviations............................................................ 10 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 June 2021 74ABT125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 30 June 2021 © Nexperia B.V. 2021. All rights reserved 12 / 12
74ABT125DB,112 价格&库存
很抱歉,暂时无法提供与“74ABT125DB,112”相匹配的价格&库存,您可以联系我们找货
