DC Fan
60×60×38 mm
San Ace 60 9G type
(Ribless model depicted)
■ General Specifications
・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0)
・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C,
rated voltage)
・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 547.
・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet
・ Storage temperature ……………………… -30 to +70˚C (Non-condensing)
・ Lead wire ………………………………………
Red
Black
Yellow
Sensor
・ Mass ……………………………………………… 110 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Rated voltage Operating voltage range Rated current Rated input
Model no.
[V]
9G0612G101
9G0612S101
9G0624G101
9G0624S101
9G0624H101
9G0648G101
9G0648S101
[V]
12
7.0 to 13.8
24
14.0 to 27.6
48
28 to 55.2
Rated speed
Max. airflow
Max. static pressure
[A]
[W]
[min-1]
[m³/min]
[CFM]
[Pa]
1.54
1.36
0.85
0.7
0.57
0.35
0.29
18.5
16.3
20.4
16.8
13.68
16.8
13.9
11800
10800
11800
10800
9800
11800
10800
1.84
1.7
1.84
1.7
1.54
1.84
1.7
65
60
65
60
54.4
65
60
435
370
435
370
304.6
435
370
[inchH²O]
SPL
Operating temperature Expected life
[dB (A)]
[˚C]
[h]
58
56
58
56
54
58
56
-20 to +70
40000/60˚C
1.747
1.486
1.747
1.486
1.223
1.747
1.486
The following sensor and control options are available for selection.
Available for all models. Without sensor
Differs according to the model. Refer to the table on pp. 567 to 568. Lock sensor
PWM control
■ Airflow - Static Pressure Characteristics
9G0612G101
9G0612S101
With pulse sensor
12 V
7V
0.4 0.8 1.2 1.6 2.0 2.4 (m3/min)
60
Airflow
風量
80
(CFM)
450
1.6
400
1.4
350
1.2
300
1.0
250
0.8
200
0.6
150
0.4
100
0.2
50
(inch H2O) (Pa)
13.8 V
Static静圧
pressure
13.8 V
1.8
With pulse sensor
(inch H2O) (Pa)
550
500
450
400
350
300
250
200
150
100
50
Static静圧
pressure
Static静圧
pressure
(inch H2O) (Pa)
2.2
2.0
1.8
1.6
1.4
1.2
1.0
0.8
0.6
0.4
0.2
9G0624G101
With pulse sensor
12 V
7V
0.4
40
Airflow
風量
1.6
60
2.0
(m3/min)
80 (CFM)
2.2
2.0
1.8
1.6
1.4
1.2
1.0
0.8
0.6
0.4
0.2
500
450
400
350
300
250
200
150
100
50
27.6 V
24 V
14 V
60
Airflow
風量
80
(CFM)
9G0624H101
With pulse sensor
400
1.4
350
1.2
300
1.0
250
0.8
200
0.6
150
0.4
100
0.2
50
27.6 V
1.6 400
24 V
14 V
0.4
9G0648S101
0.8
40
Airflow
風量
1.6
2.0
60
1.4 350
Static静圧
pressure
1.6
(inch H2O) (Pa)
1.8 450
Static静圧
pressure
Static静圧
pressure
450
27.6 V
1.2 300
1.0 250
0.8 200
24 V
0.6 150
14 V
0.4 100
0.2
50
(m3/min)
80 (CFM)
0.4
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
1.8
9G0648G101
With pulse sensor
DC Fan 60 mm sq.
9G0624S101
DC
0.8
1.2
1.6
2.0 (m3/min)
10 20 30 40 50 60 70 (CFM)
Airflow
風量
2.2
2.0
1.8
1.6
1.4
1.2
1.0
0.8
0.6
0.4
0.2
500
450
400
350
300
250
200
150
100
50
55.2 V
48 V
28 V
60
Airflow
風量
80
(CFM)
With pulse sensor
Static静圧
pressure
(inch H2O) (Pa)
1.8
450
1.6
400
1.4
350
1.2
300
1.0
250
0.8
200
0.6
150
0.4
100
0.2
50
55.2 V
48 V
28 V
0.4
40
Airflow
風量
1.6
2.0
60
■ Dimensions (unit: mm)
+1
60 0
50±0.3
(m3/min)
80 (CFM)
(With ribs)
4-ø4.3±0.3
Mounting
取付用穴 hole
38±0.5
(4)
(4)
Lead
wire
リード線
AWG24
UL 1007
+1
60 0
50±0.3
+50
300 0
(10)
Rotating
direction
回転方向
Airflow
direction
風吹出方向
93
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
59
50±0.3
29.7
59
29.7
50±0.3
62
.7
4-ø4.5
■ Options
Finger guards
page: p. 532
Model no.: 109-139E, 109-139H
Resin filter kits
Model no.: 109-1003G
page: p. 540
Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI),
109-1003F30 (30PPI), 109-1003F40 (40PPI)
94
Resin finger guards
page: p. 539
很抱歉,暂时无法提供与“9G0612P1G03”相匹配的价格&库存,您可以联系我们找货
