2412PS-12W-B30-A00
2412PS-12W-B30-A00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 60X30MM 115VAC WIRE
2412PS-12W-B30-A00 数据手册
06030PB (60 X 30L) Legacy Part No. 2412PS NMBTC.COM / 818.341.3355 Characteristic Curves General Specifications Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: Static Pressure In H2O (Pa) .12 30 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps .08 20 .04 10 AC Axial Fans Expected Life 0 Failure Rate: 10% 25°C 100,000 Hours 60Hz 50Hz (m3/min) 0.1 0.2 0.3 3.5 7.0 10.5 CFM Air Flow Outline Material Casing : Aluminum Black Painting Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3266, AWG22 AIR Panel Cut-Outs .14 ± .02 (3.5) inch Units: (mm) 1.97 ± .001 (50.0 ± 0.3) .14 .02 (3.5) 1.18 ±.02 ± 0.5 (30 ) Flange Type 2.36 ± .002 (60.0 ± 0.5) φ (φ 2.3 58 0 .5 ) 1.97 (50) .169 4 – (φ4.3 ± 0.2) NAME PLATE 1.97 ± .001 (50.0 ± 0.3) .169 8 – (φ4.3 ± 0.2) 11.8 2.36 ± .002 (60.0 ± 0.5) (300) min ROTATION 1.97 (50) INLET SIDE / OUTLET SIDE Specifications MODEL LEGACY P/N Rated Frequency Starting Current Input Speed Voltage Voltage Power (V) Max. Max. Static Noise Air Flow Pressure Mass (W) - 20% (min-1)*2 CFM*1 (m3/min)*2 in H2O (Pa)*2 (dB)*2 (g) +10% (Hz) (V) (A)*1 100 06030PB-A0L-AA-00 2412PS-10W-B30-B00 100 50 65 0.080 6.0 2000 7.0 0.20 0.05 13.7 28 60 65 0.070 5.0 2600 9.1 0.26 0.09 22.6 29 140 06030PB-A1L-AA-00 2412PS-12W-B30-A00 115 50 65 0.070 4.5 2000 7.0 0.20 0.05 13.7 28 140 115 60 65 0.060 4.0 2600 9.1 0.26 0.09 22.6 29 140 Rotation: Counterclockwise Airflow Outlet: Air out over struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air 140
2412PS-12W-B30-A00 价格&库存
很抱歉,暂时无法提供与“2412PS-12W-B30-A00”相匹配的价格&库存,您可以联系我们找货
