DC Fan
60×60×38 mm
San Ace 60 9GV type
■ General Specifications
・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C,
rated voltage)
・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 547.
・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet
・ Storage temperature ……………………… -30 to +70˚C (Non-condensing)
・ Lead wire ………………………………………
Red
Black
Sensor
Yellow
Control
Brown
・ Mass ……………………………………………… 130 g
■ Specifications
The models listed below have ribs and pulse sensors with PWM control function. For models without ribs, append "1" to the end of model numbers.
Rated voltage Operating voltage range
Model no.
[V]
[V]
9GV0612P1G03
9GV0612P1H03
12
8.0 to 13.8
9GV0612P1M03
10.8 to 13.8
9 G V 0 6 1 2 P 1 L 01 * *
9GV0624P1G03
24
20.4 to 27.6
48
38 to 57
9GV0624P1M03**
9GV0648P1H03
* PWM frequency: 25 kHz
PWM duty
cycle* [%]
Rated current Rated input Rated speed
100
100
100
Max. airflow
Max. static pressure
[A]
[W]
[min-1]
[m³/min]
[CFM]
[Pa]
2.8
0.12
2.0
0.1
1.5
0.08
0.7
1.4
0.12
0.73
0.5
0.08
33.6
1.5
24.0
1.2
18.0
1.0
8.4
33.6
2.88
17.52
24
3.84
16000
3100
14500
2700
13000
2500
10000
16000
6000
13000
14500
6000
2.37
0.44
2.15
0.4
1.93
0.38
1.49
2.37
0.89
1.93
2.15
0.89
84
15
76
14
68
13
52.6
84
31
68.0
76
31
751
26
617
21
496
18
293
751
105
496
617
105
[inchH²O]
3.02
0.1
2.48
0.09
1.99
0.07
1.17
3.02
0.42
1.99
2.48
0.42
SPL
Operating temperature
Expected life
[dB (A)]
[˚C]
[h]
66
25
63
22
60
19
52
66
38
60
63
38
-20 to +70
40000/60˚C
** Fan does not rotate when PWM duty cycle is 0%.
The following sensor and control options are available for selection.
Differs according to the model. Refer to the table on p. 574. Without sensor
Pulse sensor
Lock sensor
■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example
With pulse sensor with PWM control function
DC12
12
VDC
DC12
VV
900
3.6 900
3.6
800
3.2 800
3.2
700
2.8 700
2.8
600
2.4 600
2.4
500
2.0 500
2.0
1.6
400
1.6 400
300
1.2 300
1.2
200
0.8 200
0.8
100
0.4 100
0.4
00
00
PWMデューティ
PWM
duty cycle
PWMデューティ
100%
100%
50%
50%
0%
0%
3 3
/min)
/min)
0.4
0.4 0.8
0.81.2
1.21.6
1.62.0
2.02.4
2.42.8
2.8(m(m
(CFM)
0010
1020203030404050506060707080809090100
100(CFM)
Airflow
風量
風量
88
(inch
H2O)
(Pa)
(inch
H2O)
(Pa)
900
3.63.6 900
800
3.23.2 800
(min-1)
PWM
duty cycle 100%
PWMデューティ100%
PWMデューティ100%
18000
Voltage:
12 VDC
電圧:DC12
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
16000 min-1
16000
700
2.82.8 700
600
2.42.4 600
13.8
13.8
VV
500
2.02.0 500
400
1.61.6 400
1.21.2 300
300
1212
VV
8V
8V
0.80.8 200
200
0.40.4 100
100
00
PWM duty - Speed characteristics example
14000
回転速度
Fan
speed
Static静圧
pressure
静圧
2O) (Pa)
(inchHH2O)
(Pa)
(inch
静圧
PWM duty cycle
Static静圧
pressure
9GV0612P1G03
12000
10000
8000
6000
4000
2000
0 0 0.40.40.80.8
3
/min)
(m3(m
/min)
1.21.21.61.6
2.02.0
2.42.4
2.82.8
(CFM)
(CFM)
50 50
60 60
2020
3030
70 70
80 80
0 10
40 40
90 100
90 100
0 10
風量
Airflow
風量
3100 min-1
100 (%)
PWM
duty cycle
PWM
デューティサイクル
(Pa)
(Pa)
(inch
(inch
H2O)
H2O)
3.63.6 900
900
3.23.2 800
800
2.82.8 700
700
2.82.8 700
700
500
2.02.0 500
PWM
duty cycle
PWMデューティ
PWMデューティ
100%
100%
1.61.6 400
400
0.80.8 200
200
00
0 0 0.40.40.80.81.21.21.61.62.02.02.42.42.82.8(m(m
3 3
/min)
/min)
Airflow
風量
風量
(inch
(inch
H2O)
H2O)(Pa)
(Pa)
12
VDC
DC12
DC12
V V
3.63.6 900
900
00
(inch H2O) (Pa)
1.6
400
1.6
400
1.4
350
1.4
350
1.2
300
1.2
300
1.0
250
1.0
250
0.8
200
0.8
200
0.6
150
0.6
150
0.4
100
0.4
100
0.2
50
0.2
50
PWM duty cycle
PWMデューティ
100%
50%
0.8
1.2 1.6
2.0 (m3/min)
Airflow
風量
1.2
300
0.8
200
0.4
100
100 (%)
(min-1)
PWM
duty cycle 100%
PWMデューティ100%
13.8 V
12 V
10.8 V
0.4
0.8
1.2 1.6
11000
10000
9000
8000
7000
6000
5000
4000
3000
2000
1000
Voltage:
12 VDC
電圧:DC12
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
10000 min-1
100 (%)
2.0 (m3/min)
PWM
duty cycle
PWM
デューティサイクル
Airflow
風量
24
VDC
DC24
V
PWM duty cycle
PWMデューティ
100%
50%
0%
0.4 0.8 1.2 1.6 2.0 2.4 2.8 (m3/min)
0 10 20 30 40 50 60 70 80 90100 (CFM)
Airflow
風量
(inch H2O) (Pa)
Static静圧
pressure
400
2500 min-1
(inch H2O) (Pa)
1.6
4000
PWM duty cycle
500
6000
PWM
duty cycle
PWM
デューティサイクル
0 10 20 30 40 50 60 70 (CFM)
2.0
8000
Airflow
風量
風量
Static静圧
pressure
Static静圧
pressure
3 3
/min)
/min)
(CFM)
(CFM)
7070
8080
100
0 01010
2020
3030
4040
5050
6060
9090
100
12
VDC
DC12
V
600
10000
2000
(inch H2O) (Pa)
700
13000 min-1
PWM duty cycle
9GV0624P1G03
88
VV
0.40.4 100
100
Airflow
風量
風量
0.4
1212
VV
1.21.2 300
300
0.80.8 200
200
50%
50%
回転速度
Fan
speed
Static静圧
pressure
静圧
静圧
Static静圧
pressure
1.61.6 400
400
100
0 01010
4040
100
2020
3030
9090
5050
6060
7070
8080
(CFM)
(CFM)
2.4
13.8
13.8
VV
500
2.02.0 500
PWM
duty cycle
PWMデューティ
PWMデューティ
100%
100%
0.40.4 100
100 0%
0%
00 00
3 3
/min)
/min)
2.8
14000
Voltage:
12 VDC
電圧:DC12
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
12000
2.42.4 600
600
500
2.02.0 500
800
(min-1)
2.82.8 700
700
2.82.8 700
700
2.42.4 600
600
3.2
3.23.2 800
800
9GV0612P1L01
100 (%)
duty cycle
PWMPWM
デューティサイクル
PWM
duty cycle 100%
PWMデューティ100%
PWMデューティ100%
3.63.6 900
900
3.23.2 800
800
0.80.8 200
200
2700 min-1
(inch
(inch
H2O)
H2O)
(Pa)
(Pa)
Static静圧
pressure
3 3
/min)
/min)
1.21.2 300
300
6000
Airflow
風量
風量
PWM duty cycle
1.61.6 400
400
8000
4000
(CFM)
(CFM)
2020
3030
5050
6060
7070
8080
9090
0 01010
4040
100
100
(CFM)
(CFM)
7070
8080
0 01010
4040
100
2020
3030
9090
100
5050
6060
10000
2000
0.40.4 100
100
0%
0%
9GV0612P1M03
8 8V V
回転速度
Fan
speed
00
1212V V
1.61.6 400
400
4.0 1000
3.6 900
3.2 800
2.8 700
2.4 600
2.0 500
1.6 400
1.2 300
0.8 200
0.4 100
(min-1)
PWM
duty cycle 100%
PWMデューティ100%
16000
Voltage:
24 VDC
電圧:DC24
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
16000 min-1
14000
27.6 V
24 V
12000
回転速度
Fan
speed
0.40.4 100
100
2.02.0 500
500
0.80.8 200
200
50%
50%
14500 min-1
12000
13.8
13.8V V
1.21.2 300
300
1.21.2 300
300
16000
Voltage:
12 VDC
電圧:DC12
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
14000
2.42.4 600
600
2.42.4 600
600
静圧
3.63.6 900
900
3.23.2 800
800
(min-1)
PWM
duty cycle 100%
PWMデューティ100%
PWMデューティ100%
Static静圧
pressure
静圧
Static静圧
pressure
(Pa)
(Pa)
(inch
(inch
H2O)
H2O)
12
VDC
DC12
DC12
V V
回転速度
Fan
speed
PWM duty cycle
20.4 V
10000
8000
6000 6000 min-1
4000
2000
(m3/min)
Airflow
風量
100 (%)
PWM
duty cycle
PWM
デューティサイクル
89
DC Fan 60 mm sq.
9GV0612P1H03
DC
9GV0624P1M03
(inch H2O) (Pa)
2.0 500
2.4 600
Static静圧
pressure
2.4 600
PWMデューティ
PWM duty cycle
100%
1.6 400
1.2 300
0.8 200
50%
9GV0648P1H03
500
1.6
400
1.2
300
0.8
200
0.4
100
0.4 0.8 1.2 1.6 2.0 2.4 (m3/min)
(inch H2O) (Pa)
PWM duty cycle
PWMデューティ
100%
50%
0%
(m3/min)
Airflow
風量
■ Dimensions (unit: mm)
4000
100 (%)
3.2
800
2.8
700
2.4
600
2.0
500
1.6
400
1.2
300
0.8
200
0.4
100
(min-1)
PWM
duty cycle 100%
PWMデューティ100%
16000
38 V
10000
8000
6000 6000 min-1
4000
2000
(m3/min)
Airflow
風量
(10)
Lead
wire
リー
ド線
AWG26
UL 1007
(Model no.: 9GV0612P1G03 only)
UL 1430 (型番:9GV0612P1G03
のみ)
(4)
(4)
60±0.5
38±0.5
Rotating
direction
回転方向
Airflow
direction
風吹出方向
100 (%)
duty cycle
PWMPWM
デューティサイクル
+50
300 0
50±0.3
14500 min-1
12000
48 V
(With ribs)
50±0.3
Voltage:
48 VDC
電圧:DC48
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
14000
57 V
4-ø4.5±0.3
Mounting
取付用穴hole
60±0.5
6000
0 10 20 30 40 50 60 70 80 90 100 (CFM)
0 10 20 30 40 50 60 70 80 90 (CFM)
90
8000
PWM
duty cycle
PWM
デューティサイクル
(CFM)
48
VDC
DC48
V
2000
Static静圧
pressure
Static静圧
pressure
2.0
0.8 200
13000 min-1
(inch H2O) (Pa)
600
20.4 V
1.2 300
Voltage:
24 VDC
電圧:DC24
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
12000
Airflow
風量
PWM duty cycle
700
24 V
(CFM)
Airflow
風量
2.4
27.6 V
1.6 400
2.8
2.0 500
14000
0.4 100
0.4 100
(min-1)
PWM
duty cycle 100%
PWMデューティ100%
回転速度
Fan
speed
Static静圧
pressure
(inch H2O) (Pa)
24
VDC
DC24
V
回転速度
Fan
speed
PWM duty cycle
DC
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
DC Fan 60 mm sq.
59
50±0.3
29.7
59
29.7
50±0.3
62
.7
4-ø4.5
■ Options
Finger guards
page: p. 532
Model no.: 109-139E, 109-139H
Resin filter kits
Resin finger guards
page: p. 539
Model no.: 109-1003G
page: p. 540
Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI),
109-1003F30 (30PPI), 109-1003F40 (40PPI)
91
很抱歉,暂时无法提供与“9GV0612P1M03”相匹配的价格&库存,您可以联系我们找货
