74LVT241DB,118
74LVT241DB,118
    NEXPERIA(安世)
    SSOP20_7.2X5.3MM
    IC BUF NON-INVERT 3.6V 20SSOP
74LVT241DB,118 数据手册
74LVT241 3.3 V octal buffer/line driver; 3-state Rev. 4 — 27 March 2019 Product data sheet 1. General description The 74LVT241 high-performance BiCMOS device combines low static and dynamic power dissipation with high speed and high output drive. This device is an octal buffer that is ideal for driving bus lines. The device features two output enables (1OE, 2OE), each controlling four of the 3-state outputs. 2. Features • • • • • • • • • • • 3-state buffers Octal bus interface Input and output interface capability to systems at 5 V supply TTL input and output switching levels Output capability: +64 mA/-32 mA Latch-up protection exceeds 500 mA per JESD78 class II level A ESD protection: • HBM JESD22-A114E exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Bus-hold data inputs eliminate the need for external pull-up resistors for unused inputs Live insertion/extraction permitted Power-up 3-state No bus current loading when output is tied to 5 V bus 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVT241D -40 °C to +85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74LVT241PW -40 °C to +85 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74LVT241BQ -40 °C to +85 °C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm SOT764-1 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 4. Functional diagram 2 4 6 8 1 17 15 13 11 19 1A0 1Y0 1A1 1Y1 1A2 1Y2 1A3 1Y3 18 16 14 12 1 EN 1OE 2A0 2Y0 2A1 2Y1 2A2 2Y2 2A3 2Y3 3 2 18 4 16 6 14 8 12 5 19 7 9 2OE EN 11 9 13 7 15 5 17 3 mna773 mna772 Fig. 1. Logic symbol 74LVT241 Product data sheet Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 2 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 5. Pinning information 5.1. Pinning 1 terminal 1 index area 2 20 VCC 19 2OE 2Y0 3 18 1Y0 1A1 4 17 2A0 2Y1 5 16 1Y1 1A2 6 2Y2 7 14 1Y2 1A3 8 13 2A2 2Y3 9 12 1Y3 GND 10 11 2A3 74LVT241 19 2OE 2Y0 3 18 1Y0 1A1 4 17 2A0 2Y1 5 16 1Y1 1A2 6 15 2A1 2Y2 7 1A3 8 2Y3 9 14 1Y2 GND(1) 13 2A2 12 1Y3 001aah735 Transparent top view 15 2A1 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. 001aah734 Fig. 3. 2 2A3 11 1 1A0 1A0 GND 10 1OE 20 VCC 1OE 74LVT241 Pin configuration for SO20 and TSSOP20 Fig. 4. Pin configuration for DHVQFN20 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE 1 output enable input (active LOW) 1A0 to 1A3 2, 4, 6, 8 data input 2A0 to 2A3 17, 15, 13, 11 data input GND 10 ground (0 V) 1Y0 to 1Y3 18, 16, 14, 12 data output 2Y0 to 2Y3 3, 5, 7, 9 data output 2OE 19 output enable input (active HIGH) VCC 20 supply voltage 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 3 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = Don’t care; Z = High impedance "OFF" state. Inputs Outputs 1OE 2OE 1An 2An 1Yn 2Yn L H L L L L L H H H H H H L X X Z Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage output in OFF or HIGH state IIK input clamping current IOK IO Max Unit -0.5 +4.6 V -0.5 +7.0 V [1] -0.5 +7.0 V VI < 0 V -50 - mA output clamping current VO < 0 V -50 - mA output current output in LOW state - 128 mA output in HIGH state -64 - mA -65 +150 °C [2] - +150 °C [3] - 500 mW storage temperature Tj junction temperature Ptot total power dissipation [3] Min [1] Tstg [1] [2] Conditions Tamb = -40 °C to +85 °C The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 °C. For SO20 package: above 70 °C derate linearly with 8 mW/K. For TSSOP20 package: above 60 °C derate linearly with 5.5 mW/K. For DHVQFN20 package: above 60 °C derate linearly with 4.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC supply voltage 2.7 3.6 V VI input voltage 0 5.5 V IOH HIGH-level output current -32 - mA IOL LOW-level output current - 32 mA - 64 mA -40 +85 °C 0 10 ns/V current duty cycle ≤ 50 %; fi ≥ 1 kHz Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate output enabled 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 4 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V); Tamb = -40 °C to +85 °C. Symbol Parameter Conditions Min Typ[1] Max VIK input clamping voltage VCC = 2.7 V; IIK = –18 mA -1.2 -0.9 - V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V VOH HIGH-level output voltage VCC = 2.7 V to 3.6 V; IOH = -100 μA - V VOL II VCC - 0.2 VCC - 0.1 VCC = 2.7 V; IOH = -8 mA 2.4 2.5 - V VCC = 3.0 V; IOH = -32 mA 2.0 2.2 - V 0.1 0.2 V LOW-level output voltage VCC = 2.7 V; IOL = 100 μA input leakage current Unit VCC = 2.7 V; IOL = 24 mA - 0.3 0.5 V VCC = 3.0 V; IOL = 16 mA - 0.25 0.4 V VCC = 3.0 V; IOL = 32 mA - 0.3 0.5 V VCC = 3.0 V; IOL = 64 mA - 0.4 0.55 V - 1 10 μA - 0.1 ±1 μA VCC = 3.6 V; VI = VCC - 0.1 1 μA VCC = 3.6 V; VI = 0 V -5 -1 - μA - 1 ±100 μA control and data pins VCC = 0 V or 3.6 V; VI = 5.5 V control pins VCC = 3.6 V; VI = VCC or GND data pins [2] IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V IBHL bus hold LOW current VCC = 3.0 V; VI = 0.8 V 75 150 - μA IBHH bus hold HIGH current VCC = 3.0 V; VI = 2.0 V - -150 -75 μA IBHLO bus hold LOW overdrive current VCC = 3.6 V; VI = 0 V to 3.6 V [3] 500 - - μA IBHHO bus hold HIGH overdrive current VCC = 3.6 V; VI = 0 V to 3.6 V [3] - - -500 μA ILO output leakage current VO = 5.5 V; VCC = 3.0 V; output HIGH - 60 125 μA - ±1 ±100 μA IO(pu/pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; 1OE, 2OE = don’t care IOZ VCC = 3.6 V; VO = 3.0 V - 1 5 μA VCC = 3.6 V; VO = 0.5 V -5 -1 - μA outputs HIGH - 0.12 0.19 mA outputs LOW - 3 12 mA [5] - 0.12 0.19 mA [6] - 0.1 0.25 mA - 4 - pF ICC OFF-state output current supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A outputs disabled ΔICC additional supply current per input pin; VCC = 3.0 V to 3.6 V; one input = VCC - 0.6 V other inputs at VCC or GND CI input capacitance 1OE and 2OE inputs; outputs disabled; VI = 0 V or 3.0 V 74LVT241 Product data sheet [4] All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 5 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state Symbol Parameter Conditions CI/O at input/output data pins, outputs disabled; VI/O = 0 V or 3.0 V [1] [2] [3] [4] [5] [6] input/output capacitance Min Typ[1] Max - 8 - Unit pF All typical values are measured at Tamb = 25 °C. Unused pins at VCC or GND. This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 ms is permitted. This parameter is valid for Tamb = +25 °C only. ICC with the outputs disabled is measured with outputs pulled to VCC or GND. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 8; Tamb = -40 °C to +85 °C. Symbol Parameter Conditions tPLH 1An to 1Yn, 2An to 2Yn; see Fig. 5 LOW to HIGH propagation delay VCC = 2.7 V VCC = 3.3 V ± 0.3 V tPHL HIGH to LOW propagation delay Typ[1] Max Unit - - 4.0 ns 1.0 2.8 3.8 ns 1An to 1Yn, 2An to 2Yn; see Fig. 5 VCC = 2.7 V VCC = 3.3 V ± 0.3 V tPZH Min - - 4.0 ns 1.0 2.8 3.8 ns - - 5.0 ns 1.0 3.2 4.4 ns - - 5.6 ns 1.0 3.8 5.1 ns - - 4.9 ns 1.0 3.1 4.3 ns - - 5.4 ns 1.0 3.8 5.0 ns OFF-state to HIGH propagation delay 1OE to 1Yn; see Fig. 6 VCC = 2.7 V VCC = 3.3 V ± 0.3 V 2OE to 2Yn; see Fig. 7 VCC = 2.7 V VCC = 3.3 V ± 0.3 V OFF-state to LOW propagation delay 1OE to 1Yn; see Fig. 6 tPZL VCC = 2.7 V VCC = 3.3 V ± 0.3 V 2OE to 2Yn; see Fig. 7 VCC = 2.7 V VCC = 3.3 V ± 0.3 V tPHZ HIGH to OFF-state propagation delay 1OE to 1Yn; see Fig. 6 VCC = 2.7 V VCC = 3.3 V ± 0.3 V - - 5.4 ns 2.0 3.6 5.2 ns - - 5.0 ns 1.0 3.1 4.5 ns - - 4.3 ns 1.6 2.9 4.2 ns - - 4.3 ns 1.0 2.8 4.0 ns 2OE to 2Yn; see Fig. 7 VCC = 2.7 V VCC = 3.3 V ± 0.3 V LOW to OFF-state propagation delay 1OE to 1Yn; see Fig. 6 tPLZ VCC = 2.7 V VCC = 3.3 V ± 0.3 V 2OE to 2Yn; see Fig. 7 VCC = 2.7 V VCC = 3.3 V ± 0.3 V [1] Typical values are measured at Tamb = 25 °C and VCC = 3.3 V. 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 6 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 10.1. Waveforms and test circuit VI VM 1An, 2An input GND tPHL tPLH VOH VM 1Yn, 2Yn output VOL mna774 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. Input (1An, 2An) to output (1Yn, 2Yn) propagation delays and output transition times VI 1OE input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL 3.0 V VM VX VOL tPZH tPHZ output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs enabled outputs disabled 001aah813 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. 3-state output enable and disable times VI 2OE input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL 3.0 V VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled 001aah814 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. 3-state output enable and disable times 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 7 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state Table 8. Measurement points Input VCC 2.7 V to 3.6 V Output VM VX VY VM 1.5 V VOL + 0.3 V VOH - 0.3 V 1.5 V tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 8. Test circuit for switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf RL CL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 500 Ω 50 pF GND 6V open 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 8 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 11. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 9 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 10. Package outline SOT360-1 (TSSOP20) 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 10 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm B D SOT764-1 A A A1 E c detail X terminal 1 index area terminal 1 index area e1 C e b 2 9 v w C A B C y1 C y L 1 10 Eh e 20 11 19 12 X Dh 0 2.5 5 mm scale Dimensions (mm are the original dimensions) Unit mm A(1) A1 b max 1.00 0.05 0.30 nom 0.90 0.02 0.25 min 0.80 0.00 0.18 c D(1) Dh E(1) Eh e e1 L v 0.2 4.6 4.5 4.4 3.15 3.00 2.85 2.6 2.5 2.4 1.15 1.00 0.85 0.5 3.5 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT764-1 --- MO-241 --- sot764-1_po European projection Issue date 03-01-27 14-12-12 Fig. 11. Package outline SOT764-1 (DHVQFN20) 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 11 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status 74LVT241 v. 3 20190327 Product data sheet Modifications: • • • • Supersedes 74LVT241 v. 3 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Fig. 11: package outline drawing SOT764-1 (DHVQFN20) updated. Type number 74LVT241DB (SOT339-1) removed. 74LVT241 v. 3 20080507 Modifications: • • • Change notice Product data sheet ECN07_046 74LVT241 v. 2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. DHVQFN20 package added Section 3 and Section 11. 74LVT241 v. 2 19980219 Product specification - 74LVT241 v. 1 74LVT241 v. 1 19960529 Product specification - - 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 12 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVT241 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 13 / 14 74LVT241 Nexperia 3.3 V octal buffer/line driver; 3-state Contents 1. General description...................................................... 1 2. Features.........................................................................1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 7 11. Package outline.......................................................... 9 12. Abbreviations............................................................ 12 13. Revision history........................................................12 14. Legal information......................................................13 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 March 2019 74LVT241 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 14 / 14
74LVT241DB,118 价格&库存
很抱歉,暂时无法提供与“74LVT241DB,118”相匹配的价格&库存,您可以联系我们找货
