Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
INTEGRATED CIRCUITS
DATA SHEET
For a complete data sheet, please also download:
• The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Information
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines
74HC/HCT367
Hex buffer/line driver; 3-state
Product specification
File under Integrated Circuits, IC06
December 1990
74HC/HCT367
The 74HC/HCT367 are hex non-inverting buffer/line
drivers with 3-state outputs. The 3-state outputs (nY) are
controlled by the output enable inputs (1OE, 2OE).
FEATURES
• Non-inverting outputs
• Output capability: bus driver
• ICC category: MSI
A HIGH on nOE causes the outputs to assume a high
impedance OFF-state.
GENERAL DESCRIPTION
The “367” is identical to the “368” but has non-inverting
outputs.
The 74HC/HCT367 are high-speed Si-gate CMOS devices
and are pin compatible with low power Schottky TTL
(LSTTL). They are specified in compliance with JEDEC
standard no. 7.
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns
TYPICAL
SYMBOL
PARAMETER
CONDITIONS
UNIT
HC
tPHL/ tPLH
propagation delay nA to nY
CI
input capacitance
CPD
power dissipation capacitance per buffer
CL = 15 pF; VCC = 5 V
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW):
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
∑ (CL × VCC2 × fo) = sum of outputs
CL = output load capacitance in pF
VCC = supply voltage in V
2. For HC the condition is VI = GND to VCC
For HCT the condition is VI = GND to VCC − 1.5 V
ORDERING INFORMATION
See “74HC/HCT/HCU/HCMOS Logic Package Information”.
December 1990
2
HCT
8
11
ns
3.5
3.5
pF
30
32
pF
74HC/HCT367
PIN DESCRIPTION
PIN NO.
SYMBOL
NAME AND FUNCTION
1, 15
1OE, 2OE
output enable inputs (active LOW)
2, 4, 6, 10, 12, 14
1A to 6A
data inputs
3, 5, 7, 9, 11, 13
1Y to 6Y
data outputs
8
GND
ground (0 V)
16
VCC
positive supply voltage
Fig.1 Pin configuration.
December 1990
Fig.2 Logic symbol.
3
Fig.3 IEC logic symbol.
74HC/HCT367
FUNCTION TABLE
INPUTS
OUTPUTS
nOE
nA
nY
L
L
H
L
H
X
L
H
Z
Notes
1. H = HIGH voltage level
L = LOW voltage level
X = don’t care
Z = high impedance OFF-state
Fig.4 Functional diagram.
Fig.5 Logic diagram.
December 1990
4
74HC/HCT367
DC CHARACTERISTICS FOR 74HC
For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”.
ICC category: MSI
AC CHARACTERISTICS FOR 74HC
GND = 0 V; tr = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HC
SYMBOL
PARAMETER
+25
−40 to +85
−40 to +125
min. typ. max. min. max. min.
UNIT V
WAVEFORMS
CC
(V)
max.
tPHL/ tPLH
propagation delay
nA to nY
28
10
8
95
19
16
120
24
29
25
ns
2.0
4.5
6.0
Fig.6
tPZH/ tPZL
3-state output enable time
nOE to nY
44
16
13
150
30
26
190
38
33
225
45
38
ns
2.0
4.5
6.0
Fig.7
tPHZ/ tPLZ
3-state output disable time
nOE to nY
55
150
30
26
190
38
33
225
45
38
ns
2.0
4.5
6.0
Fig.7
tTHL/ tTLH
output transition time
14
5
4
60
12
10
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.6
December 1990
5
74HC/HCT367
DC CHARACTERISTICS FOR 74HCT
ICC category: MSI
Note to HCT types
The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications.
To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below.
INPUT
UNIT LOAD COEFFICIENT
1OE
2OE
nA
1.00
0.90
1.00
AC CHARACTERISTICS FOR 74HCT
Tamb (°C)
TEST CONDITIONS
74HCT
SYMBOL
PARAMETER
+25
−40 to +85
−40 to +125
UNIT V
WAVEFORMS
CC
(V)
max.
tPHL/ tPLH
propagation delay
nA to nY
14
25
31
38
ns
4.5
Fig.6
tPZH/ tPZL
nOE to nY
16
35
44
53
ns
4.5
Fig.7
tPHZ/ tPLZ
nOE to nY
21
35
44
53
ns
4.5
Fig.7
tTHL/ tTLH
5
12
15
18
ns
4.5
Fig.6
December 1990
6
74HC/HCT367
AC WAVEFORMS
(1) HC : VM = 50%; VI = GND to VCC.
HCT : VM = 1.3 V; VI = GND to 3 V.
Fig.6 Waveforms showing the input (nA) to output (nY) propagation delays and the output transition times.
Fig.7 Waveforms showing the 3-state enable and disable times.
PACKAGE OUTLINES
See “74HC/HCT/HCU/HCMOS Logic Package Outlines”.
December 1990
7
很抱歉,暂时无法提供与“74HC367DB,112”相匹配的价格&库存,您可以联系我们找货
