DC Fan
80×80×32 mm
San Ace 80 9P type
■ General Specifications
・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C,
rated voltage)
・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 529.
・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet
・ Storage temperature ……………………… -30 to +70˚C (Non-condensing)
・ Lead wire ………………………………………
Red
Black or Blue
Yellow
Sensor
・ Mass ……………………………………………… 150 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Rated voltage Operating voltage range Rated current Rated input
Model no.
[V]
109P0812A201
109P0812H201
109P0812M201
109P0824A201
109P0824H201
109P0824M201
109P0848H201
12
48
Max. airflow
Max. static pressure
[A]
[W]
[min-1]
[m³/min]
[CFM]
[Pa]
6 to 13.2
0.56
0.16
0.07
0.29
0.09
0.04
0.06
6.72
1.92
0.84
6.96
2.16
0.96
2.88
4600
3150
2000
4600
3150
2000
3350
1.52
1.05
0.65
1.52
1.05
0.65
1.1
53.7
37.1
23.0
53.7
37.1
23.0
38.9
91.1
43.1
18.6
91.1
43.1
18.6
50.9
10.2 to 13.8
12 to 26.4
24
Rated speed
[V]
20.4 to 27.6
43 to 53
SPL
[inchH²O]
Operating temperature Expected life
[dB (A)]
[˚C]
[h]
45
33
21
45
33
21
35
-20 to +55
40000 (+55˚C)
40000/60˚C
60000/60˚C
0.366
0.173
0.075
0.366
0.173
0.075
0.204
-20 to +70
-20 to +60
40000/60˚C
-20 to +70
60000/60˚C
40000/60˚C
Other sensor specifications are available as options. Refer to the index (pp. 544 to 545).
■ Airflow - Static Pressure Characteristics
109P0812H201
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
120
60
Static静圧
pressure
0.4
0.3
0.25
13.2 V
100
Static静圧
pressure
0.5
12 V
80
60
0.2
0.1
6V
40
1.0
1.5
2.0 (m3/min)
0 10 20 30 40 50 60 70
風量
Airflow
126
109P0812M201
With pulse sensor
(CFM)
0.20
0.15
(inch H2O) (Pa)
0.12
13.8 V
50
12 V
40
10.2 V
30
0.10
0.05
With pulse sensor
Static静圧
pressure
109P0812A201
0.10
0.08
13.8 V
12 V
0.06
0.04
10.2 V
10
0.02
10
30
風量
Airflow
40
1.5 (m3/min)
50
(CFM)
Airflow
風量
1.0
30
(m3/min)
40 (CFM)
(inch H2O) (Pa)
(inch H2O) (Pa)
120
60
Static静圧
pressure
0.4
0.3
0.25
26.4 V
100
Static静圧
pressure
0.5
24 V
80
60
0.2
0.1
12 V
40
1.0
1.5
風量
Airflow
0.20
0.15
0.05
0.12
27.6 V
24 V
40
20.4 V
30
0.10
0.10
0.08
27.6 V
24 V
0.06
0.04
20.4 V
10
0.02
10
(CFM)
With pulse sensor
(inch H2O) (Pa)
50
2.0 (m3/min)
109P0848H201
109P0824M201
With pulse sensor
DC Fan 80 mm sq.
109P0824H201
With pulse sensor
Static静圧
pressure
109P0824A201
DC
10
30
風量
Airflow
40
1.5 (m3/min)
50
(CFM)
Airflow
風量
1.0
30
(m3/min)
40 (CFM)
With pulse sensor
(inch H2O) (Pa)
70
Static静圧
pressure
0.25
60
0.20
50
0.15
40
0.10
0.05
53 V
48 V
43 V
30
1.0
1.5
2.0 (m3/min)
Airflow
風量
■ Dimensions (unit: mm)
(CFM)
(With ribs)
80±0.5
71.5±0.3
32±0.5
4-ø4.3±0.3
Mounting
取付用穴 hole
(4)
(4)
71.5±0.3
80±0.5
Lead
wire
リー
ド線
AWG24
UL 1007
+30
300 0
(10)
Rotating
direction
回転方向
Airflow
direction
風吹出方向
127
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side
Outlet side
71.5±0.3
4-ø4.5
5
9.
4
ø8
78
71.5±0.3
ø8
78
4-ø4.5
78
71.5±0.3
71.5±0.3
78
■ Options
Finger guards
page: p. 513
Model no.: 109-049C, 109-049E, 109-049H
Resin filter kits
Model no.: 109-1002G
page: p. 521
Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI),
109-1002F30 (30PPI), 109-1002F40 (40PPI)
128
Resin finger guards
page: p. 520
很抱歉,暂时无法提供与“109P0812H2011”相匹配的价格&库存,您可以联系我们找货
