Splash Proof Fan
60×60×25 mm
IP68
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in indoor free air at 60°C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black
Yellow
Sensor
· Mass………………………………………… 110 g
· Ingress protection………………………… IP68
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
[V]
[V]
[A]
[W]
[min-1]
10.2 to 13.2
9WP0612G401
12
9WP0612D401
9WP0612H401
9WP0624J401
9WP0624G401
9WP0624H401
9WP0648H401
10.2 to 13.8
21.6 to 26.4
24
48
20.4 to 27.6
40 to 53
Max. airflow
[m3/min]
[CFM]
Max. static pressure
[Pa]
[inchH2O]
SPL
Operating temperature
[dB (A)]
[˚C]
0.21
2.52
5600
0.78
27.5
87.3
0.351
39
0.21
0.11
0.2
0.13
0.06
0.04
2.52
1.32
4.8
3.12
1.44
1.92
5150
3800
7600
5600
3800
3800
0.72
0.53
1.06
0.78
0.53
0.53
25
18.7
37.1
27.5
18.7
18.7
73.5
40.2
155.0
87.3
40.2
40.2
0.3
0.161
0.622
0.351
0.161
0.161
37
28
44
39
28
28
Expected life
[h]
40000/60˚C
(70000/40˚C)
60000/60˚C
(90000/40˚C)
-20 to +60
-20 to +70
-20 to +60
40000/60˚C
(70000/40˚C)
-20 to +70
60000/60˚C
(90000/40˚C)
Note: Sensor and control options are available for selection. Refer to the table on pp. 638 to 639.
■ Airflow - Static Pressure Characteristics
9WP0612D401
With pulse sensor
(inch H2O) (Pa)
0.40
0.35
0.30
0.25
0.20
0.15
0.10
0.05
100
90
80
70
60
50
40
30
13.2 V
12 V
10.2 V
60
0.30
0.25
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min)
5 10 15 20 25 30
Airflow
CATALOG No. C1111B002 '21.9.IT
(CFM)
0.25
0.20
80
13.8 V
60
12 V
0.20
0.15
0.10
0.05
(inch H2O) (Pa)
0.40 100
0.35
10.2 V
40
10 15 20 25 30
Airflow
With pulse sensor
(inch H2O) (Pa)
Static pressure
0.45
9WP0612H401
With pulse sensor
Static pressure
9WP0612G401
Static pressure
Splash Proof Fan 60 mm sq.
DC
San Ace 60W 9WP type
(CFM)
0.15
0.10
13.8 V
50
12 V
40
10.2 V
30
0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min)
10
15
Airflow
(CFM)
9WP0624G401
Static pressure
26.4 V
24 V
21.6 V
0.2 0.4 0.6 0.8 1.0 1.2 1.4 (m3/min)
0 5 10 15 20 25 30 35 40 45
0.45 110
0.40 100
0.35 90
80
0.30
70
0.25 60
0.20 50
0.15 40
30
0.10
(inch H2O) (Pa)
0.20
27.6 V
24 V
20.4 V
5
10 15 20 25 30
Airflow
9WP0648H401
0.15
0.10
60
27.6 V
50
24 V
40
20.4 V
30
(CFM)
0.25
Static pressure
0.8 200
0.7 180
160
0.6
140
0.5 120
0.4 100
0.3 80
60
0.2
40
0.1 20
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
Static pressure
9WP0624H401
With pulse sensor
10
(CFM)
Airflow
DC
With pulse sensor
5
10
15
(CFM)
Airflow
With pulse sensor
(inch H2O) (Pa)
0.25
60
Static pressure
53 V
50
0.20
48 V
40
0.15
30
0.10
40 V
10
10
15
25 (CFM)
Airflow
■ Dimensions (unit: mm)
(With ribs)
+1
60 0
50±0.3
25±0.5
4-ø4.3±0.3
Mounting hole
(3)
(3)
+50
300 0
50±0.3
+1
60 0
Lead wire
AWG24
UL 1007
(10)
Rotating direction
Airflow direction
281
9WP0624J401
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
59
50±0.3
59
29.7
62
.7
4-ø4.5
50±0.3
DC
29.7
■ Options
Finger guards
Model no.: 109-139E, 109-139H
282
page: p. 584
Resin finger guards
Model no.: 109-1003G
page: p. 591
很抱歉,暂时无法提供与“9WP0624H401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+242.34041
- 5+235.07155
- 10+228.02138
- 25+221.17949
- 125+214.54587
