74LVT162244BDGG,51
74LVT162244BDGG,51
    NEXPERIA(安世)
    TSSOP-48
    IC BUF NON-INVERT 3.6V 48TSSOP
74LVT162244BDGG,51 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS 74LVT162244B 3.3V 16-bit buffer/driver with 30 termination resistors Product specification Supersedes data of 1998 Feb 19 IC23 Data Handbook       1998 Oct 07 Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B FEATURES DESCRIPTION • 16-bit bus interface • 3-State buffers • Output capability: +12mA/-12mA • TTL input and output switching levels • Input and output interface capability to systems at 5V supply • Bus-hold data inputs eliminate the need for external pull-up The 74LVT162244B is a high-performance BiCMOS product designed for VCC operation at 3.3V. The 74LVT162244B is designed with 30Ω series resistance in both the High and Low states of the output. This design reduces line noise in applications such as memory address drivers, clock drivers, and bus receivers/transmitters. This device is a 16-bit buffer and line driver featuring non-inverting 3-State bus outputs. The device can be used as four 4-bit buffers, two 8-bit buffers, or one 16-bit buffer. resistors to hold unused inputs • Live insertion/extraction permitted • Outputs include series resistance of 30Ω making external The 74LVT162244B is the same as the 74LVT16244B-1. The part number has been changed to reflect industry standards. terminating resistors unnecessary • Power-up 3-State • No bus current loading when output is tied to 5V bus • Latch-up protection exceeds 500mA per JEDEC Std 17 • ESD protection exceeds 2000V per MIL STD 883 Method 3015 and 200V per Machine Model • Same part as 74LVT16244B-1 QUICK REFERENCE DATA SYMBOL CONDITIONS Tamb = 25°C PARAMETER TYPICAL UNIT 2.8 ns 3 pF tPLH tPHL Propagation delay nAx to nYx CL = 50pF; VCC = 3.3V CIN Input capacitance nOE VI = 0V or 3.0V COUT Output capacitance Outputs disabled; VO = 0V or 3.0V 9 pF ICCZ Total supply current Outputs disabled; VCC = 3.6V 70 µA ORDERING INFORMATION TEMPERATURE RANGE OUTSIDE NORTH AMERICA NORTH AMERICA DWG NUMBER 48-Pin Plastic SSOP Type III PACKAGES –40°C to +85°C 74LVT162244B DL VT162244B DL SOT370-1 48-Pin Plastic TSSOP Type II –40°C to +85°C 74LVT162244B DGG VT162244B DGG SOT362-1 LOGIC SYMBOL 47 46 44 43 1 41 40 38 37 48 PIN DESCRIPTION 1A0 1Y0 1A1 1Y1 1A2 1Y2 1A3 1Y3 2 36 3 35 5 33 6 1OE 25 2A0 2Y0 2A1 2Y1 2A2 2Y2 2A3 2Y3 2OE 32 8 30 9 29 11 12 27 26 24 3A0 3Y0 3A1 3Y1 3A2 3Y2 3A3 3Y3 PIN NUMBER SYMBOL NAME AND FUNCTION 47, 46, 44, 43 41, 40, 38, 37 36, 35, 33, 32 30, 29, 27, 26 1A0 - 1A3, 2A0 - 2A3, 3A0 - 3A3, 4A0 - 4A3 Data inputs 2, 3, 5, 6 8, 9, 11, 12 13, 14, 16, 17 19, 20, 22, 23 1Y0 - 1Y3, 2Y0 - 2Y3, 3Y0 - 3Y3, 4Y0 - 4Y3 Data outputs 1, 48 25, 24 1OE, 2OE, 3OE, 4OE 20 4, 10, 15, 21 28, 34, 39, 45 GND Ground (0V) 22 7, 18, 31, 42 VCC Positive supply voltage 13 14 16 17 3OE 4A0 4Y0 4A1 4Y1 4A2 4Y2 4A3 4Y3 19 Output enables 23 4OE SA00014 1998 Oct 07 2 853-1779 20144 Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B LOGIC SYMBOL (IEEE/IEC) 1OE 1 2OE 48 EN2 3OE 25 EN3 4OE 1A1 1A2 1A3 1A4 2A1 2A2 2A3 2A4 3A1 3A2 3A3 3A4 4A1 4A2 4A3 4A4 PIN CONFIGURATION EN1 24 EN4 47 1OE 1 48 2OE 1Y0 2 47 1A0 1Y1 3 46 1A1 GND 4 45 GND 1Y2 5 44 1A2 1Y3 6 43 1A3 42 VCC 2 1Y1 46 3 1Y2 44 VCC 7 5 1Y3 2Y0 8 41 2A0 43 6 1Y4 2Y1 9 40 2A1 8 2Y1 GND 10 39 GND 2Y2 2Y2 11 38 2A2 11 2Y3 2Y3 12 37 2A3 12 2Y4 3Y0 13 36 3A0 3Y1 14 35 3A1 GND 15 34 GND 3Y2 16 33 3A2 3Y4 17 32 3A3 VCC 18 31 VCC 4Y0 19 30 4A0 4Y1 20 29 4A1 GND 21 28 GND 4Y2 22 27 4A2 4Y3 23 26 4A3 4OE 24 25 3OE 1 41 1 1∇ 2∇ 40 9 38 37 36 1 3∇ 35 13 14 33 16 32 17 30 1 4∇ 29 19 20 27 22 23 26 3Y1 3Y2 3Y3 3Y4 4Y1 4Y2 4Y3 4Y4 SA00019 SCHEMATIC OF EACH OUTPUT SA00013 VCC VCC FUNCTION TABLE INPUTS 27Ω OUTPUTS nOE nAx nYx L L L L H H H X Z OUTPUT 27Ω H = High voltage level L = Low voltage level X = Don’t care Z = High Impedance “off ” state SW00007 1998 Oct 07 3 Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B ABSOLUTE MAXIMUM RATINGS1, 2 PARAMETER SYMBOL VCC IIK RATING UNIT -0.5 to +4.6 V -50 mA -0.5 to +7.0 V VO < 0 -50 mA Output in Off or High state -0.5 to +7.0 V Output in Low state 128 Output in High state -64 DC supply voltage DC input diode current VI < 0 voltage3 VI DC input IOK DC output diode current VOUT CONDITIONS DC output voltage3 IOUT O DC output current Tstg Storage temperature range mA -65 to +150 °C NOTES: 1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150°C. 3. The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. RECOMMENDED OPERATING CONDITIONS LIMITS SYMBOL VCC PARAMETER UNIT DC supply voltage MIN MAX 2.7 3.6 V 0 5.5 V VI Input voltage VIH High-level input voltage VIL Input voltage 0.8 V IOH High-level output current -12 mA IOL Low-level output current 12 mA ∆t/∆v Input transition rise or fall rate; Outputs enabled 10 ns/V Tamb Operating free-air temperature range +85 °C 1998 Oct 07 2.0 -40 4 V Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B DC ELECTRICAL CHARACTERISTICS LIMITS SYMBOL PARAMETER TEST CONDITIONS Temp = -40°C to +85°C MIN VIK Input clamp voltage VCC = 2.7V; IIK = -18mA VOH High-level output voltage VCC = 3.0V; IOH = -12mA VOL Low-level output voltage VCC = 3.0V; IOL = 12mA Input leakage current VCC = 0 or 3.6V; VI = 5.5V Data Bus Hold current A inputs6 0.1 ±1.0 0.4 10 0.1 1 -0.4 -5 0.1 ±100 µA pins4 VCC = 0V; VI or VO = 0 to 4.5V VCC = 3V; VI = 0.8V IHOLD V 0.8 Control pins VCC = 3.6V; VI = VCC Output off current MAX 2.0 VCC = 3.6V; VI = 0 IOFF UNIT -1.2 VCC = 3.6V; VI = VCC or GND II TYP1 VCC = 3V; VI = 2.0V 75 135 -75 -135 µA µA ±500 VCC = 0V to 3.6V; VCC = 3.6V Current into an output in the High state when VO > VCC VO = 5.5V; VCC = 3.0V 50 125 µA Power up/down 3-State output current3 VCC ≤ 1.2V; VO = 0.5V to VCC; VI = GND or VCC; OE/OE = Don’t care 1 ±100 µA IOZH 3-State output High current VCC = 3.6V; VO = 3.0V; VI = VIL or VIH 0.5 5 µA IOZL 3-State output Low current VCC = 3.6V; VO = 0.5V; VI = VIL or VIH 0.5 -5 µA VCC = 3.6V; Outputs High, VI = GND or VCC, IO = 0 0.07 0.12 IEX IPU/PD ICCH ICCL Quiescent supply current ICCZ ∆ICC Additional supply current per input pin2 VCC = 3.6V; Outputs Low, VI = GND or VCC, IO = 0 4.0 6.0 VCC = 3.6V; Outputs Disabled; VI = GND or VCC, IO = 05 0.07 0.12 VCC = 3V to 3.6V; One input at VCC-0.6V, Other inputs at VCC or GND 0.1 0.2 mA mA NOTES: 1. All typical values are at VCC = 3.3V and Tamb = 25°C. 2. This is the increase in supply current for each input at the specified voltage level other than VCC or GND 3. This parameter is valid for any VCC between 0V and 1.2V with a transition time of up to 10msec. From VCC = 1.2V to VCC = 3.3V ± 0.3V a transition time of 100µsec is permitted. This parameter is valid for Tamb = 25°C only. 4. Unused pins at VCC or GND. 5. ICCZ is measured with outputs pulled to VCC or GND. 6. This is the bus hold overdrive current required to force the input to the opposite logic state. AC CHARACTERISTICS GND = 0V; tR = tF = 2.5ns; CL = 50pF; RL = 500Ω; Tamb = -40°C to +85°C. LIMITS SYMBOL PARAMETER VCC = 3.3V ±0.3V WAVEFORM VCC = 2.7V UNIT MIN TYP1 MAX MAX 2.8 2.5 4.2 4.2 5.0 5.0 ns tPLH tPHL Propagation delay nAx to nYx 1 0.5 0.5 tPZH tPZL Output enable time to High and Low level 2 1.0 1.0 3.5 3.1 5.5 5.5 7.0 6.5 ns tPHZ tPLZ Output disable time from High and Low Level 2 1.0 1.0 3.6 3.1 5.5 5.5 6.0 6.0 ns NOTE: 1. All typical values are at VCC = 3.3V and Tamb = 25°C. 1998 Oct 07 5 Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B AC WAVEFORMS VM = 1.5V, VIN = GND to 3.0V 2.7V nOE INPUT VM VM 2.7V 0V nAx INPUT VM tPZL VM tPLZ 3.5V 0V tPLH nYx OUTPUT tPHL VM VOL + 0.3V VOH VOL tPHZ tPZH VM VM nYx OUTPUT VOH VOH – 0.3V nYx OUTPUT VOL VM 0V SW00008 SW00009 Waveform 1. Input (nAx) to Output (nYx) Propagation Delays Waveform 2. 3-State Output Enable and Disable Times TEST CIRCUIT AND WAVEFORMS 6V VCC OPEN VIN VOUT PULSE GENERATOR tW 90% RL GND CL 10% 10% 0V RL tTHL (tF) tTLH (tR) tTLH (tR) tTHL (tF) 90% POSITIVE PULSE Test Circuit for 3-State Outputs SWITCH tPHZ/tPZH GND tPLZ/tPZL 6V tPLH/tPHL open VM VM 10% tW 0V VM = 1.5V Input Pulse Definition INPUT PULSE REQUIREMENTS DEFINITIONS FAMILY RL = Load resistor; see AC CHARACTERISTICS for value. CL = Load capacitance includes jig and probe capacitance; see AC CHARACTERISTICS for value. AMP (V) 90% 10% SWITCH POSITION TEST AMP (V) VM VM NEGATIVE PULSE D.U.T. RT 90% 74LVT16 Amplitude Rep. Rate tW tR 2.7V ≤10MHz 500ns ≤2.5ns tF ≤2.5ns RT = Termination resistance should be equal to ZOUT of pulse generators. SW00003 1998 Oct 07 6 Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm 1998 Oct 07 7 SOT370-1 Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1mm 1998 Oct 07 8 SOT362-1 Philips Semiconductors Product specification 3.3V 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B NOTES 1998 Oct 07 9 Philips Semiconductors Product specification 3.3V LVT 16-bit buffer/driver with 30Ω termination resistors (3-State) 74LVT162244B Data sheet status Data sheet status Product status Definition [1] Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make chages at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. [1] Please consult the most recently issued datasheet before initiating or completing a design. Definitions Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Disclaimers Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified.  Copyright Philips Electronics North America Corporation 1998 All rights reserved. Printed in U.S.A. Philips Semiconductors 811 East Arques Avenue P.O. Box 3409 Sunnyvale, California 94088–3409 Telephone 800-234-7381 print code Document order number:       yyyy mmm dd 10 Date of release: 05-96 9397-750-04705
74LVT162244BDGG,51 价格&库存
很抱歉,暂时无法提供与“74LVT162244BDGG,51”相匹配的价格&库存,您可以联系我们找货
