■ General Specifications
Motor Protection
Auto Restart / Polarity Protection
Insulation Resistance 10MΩ or over with a DC500V Megger
Dielectric Withstand Voltage:AC700V 1s
:M, N, P, Q Class : 10℃ ~ +70℃ (Operating)
Allowable Ambient R Class
: 10℃ ~ +60℃ (Operating)
Temperature Range
: 40℃ ~ +70℃ (Storage)
General
purpose
DC Axial Fan
120 X38L
DC FAN
12038VA (E-Type)
Industrial
non-condensing environment
Server
■ Outline
※ Failure Rate: 10%(L10 Life)
60℃ 40,000 (Hours)
■ Panel Out-cuts
36
.0
.0
27
5.0
105.0 ±0.5
5.0
38.0±0.5
105.0
117.6
120.0 ±0.5
Blower
105.0
117.6
4 – φ4.3
φ1
NAME
PLATE
φ1
120.0 ±0.5
AIR
4 – φ4.3
105.0 ±0.5
8 – φ4.3 ±0.3
(Outlet Side)
105.0
117.6
min 300
(Inlet Side)
105.0
117.6
*Outline is E (Flange) type.
■ Characteristic Curves
Static Pressure
400
Ps
(Pa)
■ Material
R Class
Casing
Impeller
Bearing
Lead Wire
Q Class
300
P Class
N Class
200
:Plastic (Black) UL94V-0
:Ball Bearing
:UL10368 AWG24 +:Red, :Black
M Class
100
4.0
Q
Air Flow
6.0
8.0
Customize service for IP compatible type and Oil-proof type is available for this item.
Please contact to our sales representative for more detail.
(m3/min)
■ Specifications
□= Casing Form - - - A: Rib Type、E: Flange Type
Model
12038VA-24M- □ AE12038VA-24N- □ AE12038VA-24P- □ AE12038VA-24Q- □ AE12038VA-24R- □ AE-
Rating Voltage Operating Voltage
Product No.
(V)
(V)
18.0 ~ 27.6
Rotation: Clockwise as seen from the label side
Airflow Outlet: Label side
Current
Input Power
Speed
Max.Air Flow
(A)*1
0.45
0.74
0.74
1.04
1.48
(W)*1
10.80
17.76
17.76
24.96
35.52
(min-1)*1
3800
4700
5000
5700
6400
(m3/min)*1 (CFM)*1
4.00
141.2
5.17
182.6
5.35
188.9
6.11
215.7
6.90
243.6
Max. Static Pressure
(Pa)*1
150.0
207.0
235.0
287.0
370.0
(In H2O)*1
0.60
0.83
0.94
1.15
1.49
Refrigerator
■ Expected Life
Noise
Mass
(dB)*1
53.0
59.0
60.0
63.0
66.0
(g)
370
*1: Average Values in Free Air
PWM 12038VA-24R (120 X 38)
Pulse Width Modulation Axial Cooling Fan
NMBTC.COM / 248.919.2250
PWM Benefits & Applications
Motor Type:
PWM Benefits
Increased Life Expectancy
Energy Saving
Lower Vibration
Lower Noise
Current Spike Prevention
PWM Applications
Routers
Switches
Storage
Data Centers
Optical Repeaters
Broadcast Equipment
Inverters
UPS
Battery Chargers
Fuel Cells
Industrial Power Supplies
Welders
Plasma Cutters
Instrumentation
Test Equipment
Enclosures and more
DC Brushless Motor
Motor Protection: Auto Restart/Polarity Protection
Motor withstands reverse connection for positive and
negative leads.
Insulation Resistance:
10M Ω or over with a DC500V Megger
AC 700V 1s or 500V 1min
Allowable Ambient Temperature Range:
-10°C ~ +60°C (Operating)
-40°C ~ +60°C (Storage)
(non-condensing environment)
Characteristics Curves
Customized fan performances at multiple
operating points.
Peak efficiency resulting in lower total
ownership costs.
Cost effective and better reliability.
Life Expectancy L10
60°C
40,000 Hours
Speed
Max.
Specifications
Rated Operating
MODEL
Voltage
(V)
12038VA-24R-FU-6
24
Voltage
(V)
Current
Avg
(A)
*1
18.0 ~ 27.6 1.48
Input Power
Max
(A)
*1
1.77
Avg
Air Flow
Max
*1
(min )
35.52 42.48
6400
(W)
*1
(W)
Max. Static
-1 *1
Noise
Mass
Pressure
(CFM) (m /min) (inH2O)
(Pa)
(dB)*1
(g)
243.7
370
64.0
370
3
6.90
1.49
*1: Values in Free Air
Page 1 of 3
PWM Specifications
PWM Characteristics Curve
TACHO Specifications
Page 2 of 3
Panel Cut-Outs
Materials
Casing
: Plastic (Black UL94V-0)
Impeller
Bearing
: Ball Bearing
Lead Wire : UL3443 AWG24
(+) : Red (-) : Black
PWM : Brown Tach : White
Unit: mm (inch)
Outline
Unit: mm (inch)
Page 3 of 3
12038VA (120 X 38L)
IP69K
Motor Protection:
P-Q Curve
(Pa)
1.60
400
8,000
Dielectric Withstand Voltage: AC 700V 1s
1.40
350
7,000
1.20
300
6,000
1.00
250
5,000
0.80
200
4,000
0.60
150
3,000
Ps 0.40
100
2,000
0.20
50
1,000
Static Pressure
IP Code: IP69K
Expected Life
25°C
100,000 Hours (L10)
Speed Curve
2
3
4
5
6
7
(m3/min)
70
105
140
175
210
245
CFM
Air Flow
Material
Outline
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL10368, AWG22, +Red, -Black
11.81
min (300)
NO SOLDER
inch
Units: (mm)
AIR
NAME
PLATE
( 5.3
13 5
6)
4.13
(105)
4.13
(105)
( 5.0
12 0
7)
4.63
(117.6)
.169
(4 – φ4.3)
4.63
(117.6)
.169
(4 – φ4.3)
.197
(5.0)
.197
(5.0)
4.13
(105± 0.5)
4.72
(120.0± 0.5)
1.50
(38± 0.5)
4.13
(105)
4.13
(105)
4.63
(117.6)
4.63
(117.6)
INLET SIDE
OUTLET SIDE
4.72
(120.0± 0.5)
Panel Cut-Outs
4.13
(105± 0.5)
ROTATION
0.169
(8−φ4.3± 0.3)
Specifications
MODEL
12038VA-24R-GA-00
Rotation: Clockwise
Rated
Operating
Voltage
Voltage
(V)
(V)
24
18.0 ~ 27.6
Current
Input
Speed
Power
(A)*1
1.48
Airflow Outlet: Air Out Over Struts
(W)*1
35.5
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
6400
243.67
6.9
1.48
370
64.0
Mass
(g)
370
Note: PWM/Locked Rotor/Tach Available
Extreme Environment
In H2O
Speed
很抱歉,暂时无法提供与“12038VA-24R-GA-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+408.929681+52.93169
