120×120×38 mm
San Ace 120 9SG type
Model 9SG1224H101 is not certified.
■ General Specifications
· Material……………………………………… Frame: Aluminum, Impeller: Plastic (Flammability: UL 94V-1)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Sensor
Yellow
· Mass………………………………………… 400 g
■ Specifications
The models listed below have pulse sensors.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
SPL
Operating temperature
Expected life
[V]
[V]
[A]
[W]
[min-1]
[m3/min]
[CFM]
[Pa]
[inchH2O]
[dB (A)]
[˚C]
[h]
12
10.2 to 13.8
24
20.4 to 27.6
6000
6000
3400
6000
7.35
7.35
4.02
7.35
260
260
142
260
340
340
126
340
1.37
1.37
0.51
1.37
64
64
48
64
40000/60˚C
(70000/40˚C)
40.8 to 55.2
48.0
48.0
11.0
48.0
-20 to +70
48
4.0
2.0
0.46
1.0
9SG1212G101
9SG1224G101
9SG1224H101
9SG1248G101
Max. airflow
Max. static pressure
Note 1: Sensor and control options are available for selection. Refer to the table on p. 636.
Note 2: The
mark indicates Short Lead Time Service applicable models. See p. 654 for details.
■ Airflow - Static Pressure Characteristics
9SG1212G101
9SG1224G101
With pulse sensor
1.25
400
350
300
1.00
250
0.75
200
0.50
0.25
(inch H2O) (Pa)
1.50
12 V
10.2 V
150
100
1 2 3 4 5 6 7 8
9 (m3/min)
50 100 150 200 250 300
Airflow
CATALOG No. C1111B002 '21.9.IT
(CFM)
450
400
350
300
1.00
250
0.75
200
0.50
0.25
50
1.75
13.8 V
(inch H2O) (Pa)
27.6 V
24 V
20.4 V
150
100
160
0.6
140
0.5 120
1 2 3 4 5 6 7 8
9 (m3/min)
Airflow
(CFM)
27.6 V
24 V
20.4 V
0.4 100
0.3
0.2
0.1
50
With pulse sensor
Static pressure
1.50
450
Static pressure
1.75
9SG1224H101
With pulse sensor
(inch H2O) (Pa)
Static pressure
DC
DC Fan 120 mm sq.
DC Fan
60
40
2
3
4
5
(m3/min)
0 20 40 60 80 100120140160 180 (CFM)
Airflow
With pulse sensor
DC Fan 120 mm sq.
9SG1248G101
DC
(inch H2O) (Pa)
1.75
Static pressure
1.50
1.25
450
350
250
0.75
200
0.25
48 V
300
1.00
0.50
55.2 V
400
40.8 V
150
100
50
1 2 3 4 5 6 7 8 9 (m3/min)
50 100 150 200 250 300 (CFM)
Airflow
■ Dimensions (unit: mm)
8-ø4.3±0.3
Mounting hole
Lead wire
AWG24
UL 1007
120±0.8
104.8±0.3
AWG22
UL 1430
(Model no.: 9SG1212G101 only)
+30
300 0
(10)
6.5±0.3
(3.5)
104.8±0.3
120±0.8
6.5±0.3
(3.5)
38±0.5
Airflow direction
Rotating direction
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side
Outlet side
104.8±0.3
4-ø4.5
118
118
104.8±0.3
35
ø1
104.8±0.3
27
ø1
118
104.8±0.3
4-ø4.5
118
■ Options
Finger guards
page: p. 585
Model no.: 109-019E, 109-019K, 109-019C, 109-019H
Resin filter kits
Resin finger guards
page: p. 591
Model no.: 109-1000G
page: p. 592
Model no.: 109-1000F13 (13PPI), 109-1000F20 (20PPI),
109-1000F30 (30PPI), 109-1000F40 (40PPI)
185
很抱歉,暂时无法提供与“9SG1224P1G01”相匹配的价格&库存,您可以联系我们找货
