3122FT-D4W-B56-E50
3122FT-D4W-B56-E50
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X56MM 12VDC WIRE
3122FT-D4W-B56-E50 数据手册
OLD Ps 11000 Sp Static 600 1.60 400 9000 .80 200 7000 3122FT (80 X 56L) (m3/min) 5000 0 0.0 NMBTC.COM / 818.341.3355 1.0 0.0 35 2.0 3.0 4.0 PATENT 70 PENDING105 5.0 140 175 Air Flow Characteristic Curves General Specifications Motor Protection: P-Q Curve In H2O Insulation Resistance: min 10M Ω by DC500V Megger Static Pressure Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +60°C (Operating) -40°C ~ +60°C (Storage) (non-condensing environment) Ps Expected Life (Pa) Speed Curve 4.0 996 16000 3.5 872 15000 3.0 747 14000 2.5 623 13000 2.0 498 12000 1.5 374 11000 1.0 249 10000 0.5 125 9000 0.0 0.0 Failure Rate: 10% 25°C 100,000 Hours 0 20 40 60 80 100 120 140 8000 160 0 .57 1.13 1.70 2.27 2.83 3.40 3.99 4.53 Speed Auto Restart/Polarity Protection/Hot Swap: Available (m3/min) CFM Air Flow PATENT PENDING inch Units: (mm) .169 (4 – F4.3) 0.157 (4.0± 0.3) 2.21 (56.0 ± 1.0) 3.15 (80.0± 0.5) 2.81 (2-71.5± 0.5) NAME PLATE 0.157 (4.0± 0.3) (F 3.2 83 9 .6 ) 3.07 (78.0) 2.81 (71.5) 3.07 (78.0) 2.81 (71.5) 5.91 min (150) 0.169  F4.3± 0.3) LOT NO. ON OTHER SIDE AIR (F 3.4 86 0 .4 ) .169 (4 – F4.3) ROTATION DC Axial Fans - TurboFans Panel Cut-outs Outline 2.81 (71.5) 3.07 (78.0) 2.81 (71.5) 3.07 (78.0) INLET SIDE OUTLET SIDE Material Casing : Plastic (Black) 94V-0 Impeller : Plastic (Black) 94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG20 or 22, +Red, -Black Tach Sig. : White AWG22 or 24 PWM Control : Brown AWG22 or 24 2.81 2-71.5± 0.5) 3.15 (80.0 ± 0.5) Reference PWM Duty vs Speed Curve PWM Control Voltage Vst = 0V ~ 0.3V Low Speed Duty 0% = Low Speed Vst = 3.2V ~ 4.5V High Speed Duty 100% = Full Speed Vst = Open High Speed Duty 100% = Full Speed IPWM = max 1.2mA (At Ta = 25°C, rated voltage + 12VDC and f=66.4 kHz) at Vin=12V, f=66.4kHz, Vst=3.3V, Ta=25˚C 16000 14000 Speed 12000 max Target 10000 Sample Curve 8000 min Target 6000 4000 2000 0 0% 20% 40% 60% 80% 100% PWM Duty Rated Voltage Operating Voltage Current Input Power Speed Product No. (V) (V) (A)*1 (W)*1 (min-1)*1 EXX 12 10.8 ~ 13.2 3.90 46.80 13,500 MODEL 3122FT-D4W-B56- Rotation: Clockwise Airflow Outlet: Air Out Over Struts Max. Air Flow Noise Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 (g) 138.0 65.5 220 3.90 *1: Average Values in Free Air Max. Static Pressure 3.63 905.0 0.0
3122FT-D4W-B56-E50
1. 物料型号:NMB-MAT 200 7000 3122FT (80 X 56L) 2. 器件简介: - 电机保护:自动重启/极性保护/热插拔:可用 - 绝缘电阻:最小10MΩ,通过DC500V Megger测量 - 介质耐电压:AC 700V 1秒 - 允许的环境温度范围:-10°C ~ +60°C(操作)-40°C ~ +60°C(存储)(非凝结环境) 3. 引脚分配:文档中未提供引脚分配信息。 4. 参数特性: - 额定电压:12V - 工作电压:10.8~13.2V - 电流:3.90A - 输入:46.80CFM(立方米/分钟) - 最大静态压力:13,500Pa - 噪音:138.0dB - 质量:905.0g 5. 功能详解: - 转速:5.91 min (150 RPM) - 预期寿命:在25°C下,故障率为10%,预期寿命为100,000小时 6. 应用信息:文档中未提供具体的应用信息。 7. 封装信息: - 外壳:塑料(黑色)94V-0 - 叶轮:塑料(黑色)94V-0 - 轴承:球轴承 - 引线:UL3385, AWG20或22, +红色, -黑色 - 转速信号:白色AWG22或24 - PWM控制:棕色AWG22或24
3122FT-D4W-B56-E50 价格&库存
很抱歉,暂时无法提供与“3122FT-D4W-B56-E50”相匹配的价格&库存,您可以联系我们找货
