UF300BNA12-H1C2A
UF300BNA12-H1C2A
    MECHATRONICSFANGROUP(机电一体化)
    FAN AXIAL 380X98MM 115VAC
UF300BNA12-H1C2A 数据手册
1 = 60 Hz 0.43 (11) 60 ø15.67 ±0.02 (ø398 ±0.5) ø12.87 ±0.02 (ø327 ±0.5) 6x 14 . ( 3 96 ± 80 0 ± 2 .79 0) 15.67 dia. x 3.87 inches Features: 0.6 0.4 0.2 250 500 750 1000 1250 1500 3.87 (98.3) See page 43 for part system forward curved impeller Model No. aluminum die cast motor base, steel frame and impeller UF300BNA12-H1C2A Bearing option: ball bearing UF300BNA23-H1C2A Motor: permanent split capacitor Air Flow: axial Connection: AWM 2517 lead wires w w w.mechatronic s.com 06.10.15 2 0.8 AIR FLOW (CFM) 6- ø0.34 ±0.01 (ø8.7 ±0.3) Operating voltage: 115 or 230 VAC Construction: 1 1.0 0 (398 dia. x 98.3 mm) 2 = 50 Hz 1.2 ° 0.31 (8) 3.16 ±0.02 (80.3 ±0.5) STATIC PRESSURE - IN. OF WATER ø14.97 ±0.01 (ø380.3 ±0.3) 15° AC AXIAL FANS UF300BNA series E - mail: S ales @ M echatronic s.com Max. Static Sound Weight Rated Freq. Input Rated Locked Speed Air Volume Pressure (H2 0) Noise Voltage Power Cur. Cur. V HZ W A A RPM M³/Min. CFM MM INCH dbA kg 115 50 150 1.60 3.15 2,650 40.6 1435 31 1.2 75 115 60 200 2.40 3.10 2,950 45.7 1615 29 1.1 78 4.5 230 50 150 0.90 1.60 2,650 40.6 1435 31 1.2 75 4.5 230 60 200 1.20 1.56 2,950 45.7 1615 29 1.1 78 4.5 Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 4.5 Cooling Simplified
UF300BNA12-H1C2A 价格&库存
很抱歉,暂时无法提供与“UF300BNA12-H1C2A”相匹配的价格&库存,您可以联系我们找货
