9CRA0612P6J001
9CRA0612P6J001
    SANYODENKI
    FAN60X56MM12VDCTACH,PWM
9CRA0612P6J001 数据手册
Counter rotating fans feature high airflow and high static pressure. Related product: Long Life Fan pp. 401, 403, 410 ■ Model Numbering System Not every combination of the following codes or characters is available. Contact us for an available combination. 9CRA 04 12 K 4 01 Type name Frame size Voltage Speed code Frame thickness Sensor specifications Fans with PWM control function 9CRA 03 12 P 4 K Type name Frame size Voltage PWM control function Frame thickness Speed code Type name 03 Individual customer’s spec (2 to 3 digits) 9CRA 9CRH etc. Frame size (mm) 03 04 06 08 12 57 ø 172 × 150 38 × 38 40 × 40 60 × 60 80 × 80 120 × 120 (sidecut) Voltage (V) 12 12 Speed code G H 48 48 J K S etc. Frame thickness (mm) 0 76 Sensor specifications 01, 001 02, 002 D01, D001 With a pulse sensor Without a sensor With a lock sensor 4 48 5 51, 56 6 56 8 80 9 102 ■ How to Read Specifications (DC fan) The following is a sample. See respective product pages for detailed information. Model no. 9GA0412G70 01 Rated voltage Operating voltage range Rated current Rated input Rated speed [V] 12 Rated voltage ………………… Operating voltage range …… Rated current ………………… Rated input …………………… Rated speed …………………… Max. airflow …………………… Max. static pressure ………… SPL ……………………………… Operating temperature ……… Expected life …………………… [V] 7 to 13.8 [A] 0.17 [W] 2.04 [min-1] 13100 Max. airflow [m³/min] 0.36 [CFM] 12.7 Max. static pressure [Pa] 192 [inchH²O] 0.77 SPL Operating temperature [dB (A)] [˚C] [h] -20 to +70 40000/60˚C (70000/40˚C) 42 Expected life This is the necessary voltage to drive the fan. E.g.) 12 VDC, 24 VDC, 48 VDC The voltage range over which fan operation is guaranteed. The current when the fan is operating at rated voltage (at free air). The power value when the fan is operating at rated voltage (at free air). The speed when the fan is operating at rated voltage (at free air). The maximum airflow that the fan can generate during rated operation (measured with our double chamber measuring device). Airflow is the volume of air generated by the fan per unit of time. The maximum static pressure value that the fan can produce during rated operation (measured with our double chamber measuring device). Static pressure indicates a fan's ability to move air against resistance due to the internal structure of the device to which the fan is installed. SPL stands for Sound Pressure Level. The noise level during the fan's rated operation. Please refer to the technical material section for the measurement method. The temperature range over which fan operation is guaranteed (Non- condensing). Service life hours that 90% of bearings will survive without failing when continuously operated at the rated voltage and 60˚C temperature. Expected life at 40˚C is for reference only. For more information, please refer to the technical material section. CATALOG No. C1111B002 '21.9.IT 223 Counter Rotating Fan DC Counter Rotating Fan 38×38×48 mm San Ace 38 9CRA type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 80 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] [min-1] Inlet 9CRA0312P4K03 12 10.8 to 13.2 9CRA0312P4J03 100 0 100 0 1.5 0.2 1.1 0.18 18.0 2.4 13.2 2.2 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 0.77 0.22 0.7 0.21 27.2 7.8 24.7 7.4 700.0 54.9 560.0 50.4 2.81 0.22 2.25 0.2 64 33 62 31 -20 to +70 40000/60˚C (70000/40˚C) Outlet 17600 14520 5280 4200 16000 13200 4800 3960 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: Sensor and control options are available for selection. Refer to the table on p. 625. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRA0312P4K03 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 2.5 600 2.0 500 50% 1.5 400 300 1.0 200 0.5 100 0 0% 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m /min) 5 10 15 20 25 30 Airflow CATALOG No. C1111B002 '21.9.IT 2.0 500 1.5 400 1.0 (CFM) 0 20000 13.2 V 700 600 (min-1) PWM duty cycle 100% 800 2.5 0.5 3 0 224 3.0 PWM duty cycle 100% 700 Static pressure 3.0 (inch H2O) (Pa) 12 VDC 800 PWM duty - Speed characteristics example Voltage: 12 VDC PWM frequency: 25 kHz 17600 min-1 Inlet 12 V 15000 10.8 V Fan speed PWM duty cycle Static pressure Counter Rotating Fan 38 mm sq. DC Counter Rotating Fan 300 200 14520 min-1 5280 min-1 Outlet 10000 5000 4200 min-1 100 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) 0 5 10 15 20 25 30 Airflow (CFM) 0 PWM duty cycle 100 (%) ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example PWM duty cycle Operating voltage range (inch H2O) (Pa) 12 VDC 700 2.0 500 1.5 400 1.0 0.5 0 50% 300 200 0% 100 0 5 10 1.0 10.8 V 400 300 200 0 15 Airflow 20 25 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 (m3/min) 0 (CFM) 10000 5000 0 5 10 15 20 Airflow Voltage: 12 VDC PWM frequency: 25 kHz 25 (CFM) 0 16000 min-1 Inlet 15000 0.5 100 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 (m3/min) 0 12 V 2.0 500 1.5 20000 13.2 V 2.5 600 PWM duty cycle 100% Static pressure Static pressure 600 (min-1) PWM duty cycle 100% 700 Fan speed (inch H2O) (Pa) 2.5 PWM duty - Speed characteristics example 13200 min-1 4800 min-1 Outlet 3960 min-1 PWM duty cycle 100 (%) ■ Dimensions (unit: mm) Inlet side Outlet side +30 320 0 4-ø3.5±0.3 Mounting hole 48±0.5 (10) (5) 38±0.5 (5) 30±0.3 4-ø3.5±0.3 Mounting hole +30 320 0 38±0.5 30±0.3 (10) Lead wire AWG28 UL 1007 Rotating direction Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 37 37 4-ø3.7 30±0.3 37 .5 (16) (16) 30±0.3 ■ Options Finger guards page: p. 584 Model no.: 109-1065 CATALOG No. C1111B002 '21.9.IT 225 DC With pulse sensor with PWM control function Counter Rotating Fan 38 mm sq. 9CRA0312P4J03 40×40×48 mm San Ace 40 9CRA type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 80 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed SPL Operating temperature Expected life [m3/min] [CFM] [Pa] [inchH2O] [dB (A)] [˚C] [h] 17500 11700 0.92 5250 3510 0.276 16200 10800 0.85 4500 3000 0.236 14700 9800 0.77 4410 2940 0.231 32.5 9.75 30.0 8.33 27.2 8.16 650.0 58.5 560.0 43.2 460.0 41.4 2.61 0.235 2.25 0.173 1.85 0.166 64 33 62 28 59 28 -20 to +70 40000/60˚C (70000/40˚C) [W] [min-1] Inlet 9CRA0412P4K03 12 9CRA0412P4J03 10.8 to 13.2 9CRA0412P4G03 100 0 100 0 100 0 1.6 0.19 1.2 0.15 1.0 0.15 19.2 2.28 14.4 1.8 12.0 1.8 Max. airflow Max. static pressure Outlet * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: Sensor and control options are available for selection. Refer to the table on p. 625. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRA0412P4K03 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 600 2.0 500 1.5 400 1.0 0.5 0 PWM duty cycle 100% 50% 300 200 100 0% 5 10 15 20 25 30 35 Airflow CATALOG No. C1111B002 '21.9.IT (CFM) 800 700 13.2 V 600 12 V 2.0 500 1.5 400 1.0 0 (min-1) PWM duty cycle 100% 2.5 0.5 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 226 3.0 700 2.5 Static pressure 3.0 (inch H2O) (Pa) 12 VDC 800 PWM duty - Speed characteristics example 20000 17500 min-1 15000 10.8 V 300 200 5250 min-1 11700 min-1 10000 Outlet 5000 3510 min-1 100 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 Voltage: 12 VDC PWM frequency: 25 kHz Inlet Fan speed PWM duty cycle Static pressure Counter Rotating Fan 40 mm sq. DC Counter Rotating Fan 5 10 15 20 25 30 35 Airflow (CFM) 0 PWM duty cycle 100 (%) ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example Operating voltage range (inch H2O) (Pa) 600 2.0 500 1.5 400 1.0 0.5 0 PWM duty cycle 100% 50% 300 200 0% 100 2.0 500 1.5 400 5 10 15 20 25 30 35 800 0 (CFM) PWM duty cycle 100 (%) 50% 0% PWM duty - Speed characteristics example (min-1) PWM duty cycle 100% 20000 Voltage: 12 VDC PWM frequency: 25 kHz 700 2.5 600 13.2 V 2.0 500 12 V 1.5 400 10.8 V 200 0.5 4410 min 10000 Airflow 9800 min-1 Outlet 5000 2940 min-1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 (CFM) 14700 min-1 -1 100 0 Inlet 15000 300 1.0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 Outlet 3000 min-1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) (inch H2O) (Pa) PWM duty cycle 100% 100 10800 min-1 10000 100 3.0 200 4500 min-1 5000 Operating voltage range 12 VDC 300 12 V 10.8 V Airflow 700 600 16200 min-1 15000 200 0 Voltage: 12 VDC PWM frequency: 25 kHz Inlet 13.2 V 300 1.0 0 Static pressure Static pressure 400 20000 With pulse sensor with PWM control function 800 2.5 0 1.5 Airflow (inch H2O) (Pa) 0.5 500 0.5 PWM duty cycle 1.0 2.0 5 10 15 20 25 30 35 (CFM) 9CRA0412P4G03 3.0 600 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 700 2.5 (min-1) PWM duty cycle 100% Fan speed 2.5 800 3.0 700 Static pressure Static pressure 3.0 (inch H2O) (Pa) 12 VDC 800 PWM duty - Speed characteristics example Fan speed PWM duty cycle 5 10 15 20 25 30 35 0 (CFM) PWM duty cycle 100 (%) Airflow ■ Dimensions (unit: mm) Inlet side 4-ø3.5±0.3 Mounting hole Outlet side +30 320 0 40±0.5 48±0.5 (10) (5) (5) 32±0.3 Lead wire AWG28 UL 1007 4-ø3.5±0.3 Mounting hole +30 320 0 Rotating direction Airflow direction 40±0.5 32±0.3 (10) Rotating direction CATALOG No. C1111B002 '21.9.IT 227 DC With pulse sensor with PWM control function Counter Rotating Fan 40 mm sq. 9CRA0412P4J03 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side (17.6) 39 4-ø3.7 40 Counter Rotating Fan 40 mm sq. (17.6) 32±0.3 DC 39 32±0.3 ■ Options Finger guards Model no.: 109-059, 109-059H 228 CATALOG No. C1111B002 '21.9.IT page: p. 584 Counter Rotating Fan San Ace 40 9CRJ type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 110 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] [min-1] Inlet 12 9CRJ0412P5J001 10.8 to 12.6 100 20 3.1 0.1 37.2 1.2 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 1.06 0.11 37.4 3.9 2400 40 9.64 0.16 72 28 -20 to +70 30000/60˚C (53000/40˚C) Outlet 36200 32000 4500 4000 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRJ0412P5J001 With pulse sensor with PWM control function PWM duty cycle Operating voltage range PWM duty cycle 100% 8 2000 6 1500 4 1000 2 500 0 0 0 60% 20% 0.2 0.4 0.6 0.8 1.0 1.2 10 20 Airflow 30 40 (m3/min) (CFM) (min-1) PWM duty cycle 100% 10 2500 Static pressure Static pressure (inch H2O) (Pa) 12 VDC 10 2500 40000 12 V/12.6 V 8 2000 4 1000 500 0 0 0 36200 min-1 32000 min-1 30000 10.8 V 6 1500 2 Voltage: 12 VDC PWM frequency: 25 kHz 35000 Speed (inch H2O) (Pa) PWM duty - Speed characteristics example 25000 Inlet 20000 15000 Outlet 10000 5000 0.2 0.4 0.6 0.8 1.0 1.2 10 20 30 40 (m3/min) (CFM) 0 PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 229 Counter Rotating Fan 40 mm sq. DC 40×40×56 mm ■ Dimensions (unit: mm) +30 320 0 4-ø3.5±0.3 Mounting hole Outlet side 56±0.5 (10) (5) 40±0.3 32±0.3 (5) 320 32±0.3 40±0.3 (10) +30 0 Lead wire AWG 26 UL 10368 Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 39 32±0.3 (17.6) 39 (17.6) 4-ø3.7 32±0.3 40 Counter Rotating Fan 40 mm sq. DC Inlet side ■ Options Finger guards Model no.: 109-059, 109-059H 230 CATALOG No. C1111B002 '21.9.IT page: p. 584 4-ø3.5±0.3 Mounting hole Rotating direction Counter Rotating Fan San Ace 40 9CRH type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 110 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty cycle* [%] Rated current Rated input [A] Rated speed [W] [min-1] Inlet 12 9CRH0412P5J001 10.8 to 12.6 100 20 2.52 0.06 30.24 0.72 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 0.93 0.08 32.9 2.8 1700 17 6.83 0.07 70 20 -20 to +70 30000/60˚C (53000/40˚C) Outlet 29500 25500 3000 2600 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRH0412P5J001 With pulse sensor with PWM control function Operating voltage range 12 VDC 8.0 2000 PWM duty cycle 7.0 1800 100% 1600 6.0 1400 5.0 1200 4.0 1000 3.0 800 60% 600 2.0 400 1.0 200 20% 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 Airflow (CFM) (inch H2O) (Pa) (min-1) PWM duty cycle 100% 8.0 2000 12 V/12.6 V 7.0 1800 1600 6.0 10.8 V 1400 5.0 1200 4.0 1000 3.0 800 600 2.0 400 1.0 200 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 0 PWM duty - Speed characteristics example 5 10 15 20 25 30 35 30000 Voltage: 12 VDC PWM frequency: 25 kHz 20000 29500 min-1 25500 min-1 25000 Fan speed Static pressure (inch H2O) (Pa) Static pressure PWM duty cycle Inlet 15000 10000 Outlet 5000 (m3/min) (CFM) 0 PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 231 Counter Rotating Fan 40 mm sq. DC 40×40×56 mm ■ Dimensions (unit: mm) Outlet side +30 320 0 4-ø3.5±0.3 56±0.5 (10) (5) (5) Mounting hole 40±0.3 32±0.3 +30 0 32±0.3 320 Lead wire AWG 24 UL 1061 Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 39 32±0.3 39 (17.6) 32±0.3 4-ø3.7 (17.6) ■ Options Finger guards Model no.: 109-059, 109-059H 232 CATALOG No. C1111B002 '21.9.IT page: p. 584 4-ø3.5±0.3 Mounting hole Rotating direction 40±0.3 (10) 40 Counter Rotating Fan 40 mm sq. DC Inlet side Counter Rotating Fan San Ace 40 9CRV type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 100 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty cycle* [%] Rated current Rated input [A] Rated speed [W] [min-1] Inlet 12 9CRV0412P5J201 10.8 to 13.2 100 0 1.8 0.11 21.6 1.32 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 0.9 0.14 31.8 4.9 1050 30 4.22 0.12 68 26 -20 to +70 40000/60˚C (70000/40˚C) Outlet 22500 20000 3800 3500 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function Operating voltage range Static pressure (inch H2O) (Pa) 12 VDC 4.5 1100 PWM duty cycle 4.0 1000 100% 900 3.5 800 3.0 700 2.5 600 2.0 500 50% 1.5 400 300 1.0 200 0% 0.5 100 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 Airflow (CFM) (inch H2O) (Pa) Static pressure PWM duty cycle PWM duty - Speed characteristics example 0 (min-1) PWM duty cycle 100% 4.5 1100 12 V/13.2 V 4.0 1000 900 10.8 V 3.5 800 3.0 700 2.5 600 2.0 500 1.5 400 300 1.0 200 0.5 100 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 5 10 15 20 25 30 35 (CFM) 25000 20000 Fan speed 9CRV0412P5J201 Voltage: 12 VDC PWM frequency: 25 kHz 22500 min-1 22000 min-1 Inlet 15000 10000 3800 min-1 Outlet 5000 3500 min-1 0 PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 233 Counter Rotating Fan 40 mm sq. DC 40×40×56 mm ■ Dimensions (unit: mm) Outlet side +30 320 0 4-ø3.5±0.3 Mounting hole 56±0.5 (10) (5) 40±0.3 32±0.3 (5) +30 320 0 Lead wire AWG 28 UL 1061 Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 39 32±0.3 39 (17.6) 32±0.3 4-ø3.7 (17.6) ■ Options Finger guards Model no.: 109-059, 109-059H 234 CATALOG No. C1111B002 '21.9.IT page: p. 584 4-ø3.5±0.3 Mounting hole Rotating direction 40±0.3 32±0.3 (10) 40 Counter Rotating Fan 40 mm sq. DC Inlet side Counter Rotating Fan San Ace 40 9CRD type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 90 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] [min-1] Inlet 9CRD0412P5J03 9CRD0412P5G03 12 10.8 to 13.2 9CRD0412P5H03 9CRD0412P5M03 100 0 100 0 100 0 100 0 1.15 0.12 0.9 0.1 0.6 0.09 0.52 0.07 13.8 1.44 10.8 1.2 7.2 1.08 6.24 0.84 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 0.87 0.15 0.77 0.13 0.7 0.12 0.65 0.07 30.72 5.3 27.19 4.59 24.72 4.24 22.95 2.47 630 25 500 21 410 16 360 7 2.53 0.1 2.01 0.08 1.65 0.06 1.45 0.03 61 22 58 21 56 20 54 15 -20 to +70 40000/60˚C (70000/40˚C) Outlet 19000 12600 3700 2500 16700 11250 3350 2250 15000 10000 3000 2000 14000 9300 2000 1300 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 12 VDC 700 3.0 600 PWM duty cycle 100% 2.0 500 1.5 400 1.0 0.5 0 50% 300 200 100 0% 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 (CFM) Airflow Static pressure Static pressure 2.5 (inch H2O) (Pa) 800 700 2.5 600 20000 Voltage: 12 VDC PWM frequency: 25 kHz 19000 min-1 Inlet 13.2 V 12 V 1.5 400 300 1.0 200 0.5 100 10.8 V 15000 12600 min-1 3700 min-1 10000 Outlet 5000 2500 min-1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 (min-1) PWM duty cycle 100% 2.0 500 0 PWM duty - Speed characteristics example Fan speed 9CRD0412P5J03 PWM duty cycle 5 10 15 20 25 30 35 (CFM) 0 PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 235 Counter Rotating Fan 40 mm sq. DC 40×40×56 mm ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function Operating voltage range 3.0 600 PWM duty cycle 100% 2.0 500 Static pressure 1.5 400 0.5 0 300 200 100 0% 700 2.5 600 3.0 600 PWM duty cycle 100% 2.0 500 Static pressure Static pressure (inch H2O) (Pa) 12 VDC 1.5 400 0.5 0 50% 200 100 0% 800 700 2.5 600 2.0 500 1.5 400 300 1.0 200 0.5 100 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 (CFM) 9CRD0412P5M03 12 VDC 0 PWM duty cycle 100% 2.0 500 100 (%) (min-1) PWM duty cycle 100% 20000 13.2 V 15000 12 V 10.8 V Voltage: 12 VDC PWM frequency: 25 kHz 15000 min-1 Inlet 10000 min-1 10000 3000 min-1 Outlet 5000 2000 min-1 0 5 10 15 20 25 30 35 (CFM) PWM duty cycle 100 (%) 50% 1.0 0.5 0% 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 (CFM) CATALOG No. C1111B002 '21.9.IT 0 PWM duty - Speed characteristics example (min-1) PWM duty cycle 100% 20000 Voltage: 12 VDC PWM frequency: 25 kHz 700 600 1.5 400 300 Airflow 236 2.5 800 2.0 500 1.5 400 0 (inch H2O) (Pa) 3.0 600 100 PWM duty cycle PWM duty - Speed characteristics example Operating voltage range 700 0.5 0 With pulse sensor with PWM control function (inch H2O) (Pa) 200 Outlet Airflow PWM duty cycle 1.0 11250 min-1 2250 min-1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) Airflow 2.5 3350 min-1 10000 5000 Operating voltage range 700 1.0 16700 min-1 Inlet With pulse sensor with PWM control function (inch H2O) (Pa) 300 Voltage: 12 VDC PWM frequency: 25 kHz Airflow PWM duty cycle 2.5 10.8 V 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 (CFM) Airflow 9CRD0412P5H03 15000 12 V 1.5 400 300 1.0 200 0.5 100 0 20000 13.2 V 2.0 500 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 (CFM) (min-1) PWM duty cycle 100% Fan speed 1.0 50% 800 300 200 15000 13.2 V Fan speed Static pressure 2.5 (inch H2O) (Pa) 12 VDC 700 Static pressure Counter Rotating Fan 40 mm sq. (inch H2O) (Pa) PWM duty - Speed characteristics example Fan speed PWM duty cycle Static pressure DC 9CRD0412P5G03 12 V 10.8 V 10000 Outlet 1300 min-1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m /min) 3 0 9300 min-1 2000 min-1 5000 100 14000 min-1 Inlet 5 10 15 20 25 30 35 (CFM) Airflow 0 PWM duty cycle 100 (%) ■ Dimensions (unit: mm) 4-ø3.5±0.3 Mounting hole 56±0.5 (10) (5) (5) 40±0.3 32±0.3 4-ø3.5±0.3 Mounting hole Lead wire AWG28 UL 1007 Airflow direction Rotating direction 40±0.3 +30 320 0 32±0.3 (10) Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 39 32±0.3 39 (17.6) 40 32±0.3 4-ø3.7 (17.6) ■ Options Finger guards page: p. 584 Model no.: 109-059, 109-059H CATALOG No. C1111B002 '21.9.IT 237 DC Outlet side +30 320 0 Counter Rotating Fan 40 mm sq. Inlet side 40×40×56 mm San Ace 40 9CRE type ■ General Specifications · Material……………………………………… Frame: Aluminum, Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 110 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] [min-1] Inlet 12 9CRE0412P5J03 10.8 to 13.2 100 0 1.4 0.1 16.8 1.2 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 0.9 0.12 31.8 4.2 570.0 13.7 2.29 0.055 62 20.5 -20 to +70 40000/60˚C (70000/40˚C) Outlet 15800 12200 2850 2250 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: Sensor and control options are available for selection. Refer to the table on p. 626. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRE0412P5J03 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 700 2.4 600 2.0 500 1.6 400 1.2 300 0.8 200 0.4 100 0 0 PWM duty cycle 100% 50% 0% 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 Airflow 238 (inch H2O) (Pa) 12 VDC Static pressure 2.8 CATALOG No. C1111B002 '21.9.IT (CFM) 2.8 700 2.4 600 2.0 500 1.6 400 1.2 300 0.8 200 0.4 100 0 0 PWM duty - Speed characteristics example (min-1) PWM duty cycle 100% 20000 13.2 V 12 V Voltage: 12 VDC PWM frequency: 25 kHz 15800 min-1 Inlet 15000 10.8 V Fan speed PWM duty cycle Static pressure Counter Rotating Fan 40 mm sq. DC Counter Rotating Fan -1 10000 2850 min 12200 min-1 Outlet 5000 2250 min-1 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 (m3/min) 0 5 10 15 20 25 30 35 Airflow (CFM) 0 PWM duty cycle 100 (%) ■ Dimensions (unit: mm) +30 320 0 4-ø3.5±0.3 Mounting hole 56±0.5 (10) 5±0.3 5±0.3 40±0.3 32±0.3 4-ø3.5±0.3 Mounting hole (10) 32±0.3 40±0.3 +30 320 0 Lead wire AWG28 UL 1061 Airflow direction Rotating direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 39 (17.6) 39 4-ø3.7 40 (17.6) 32±0.3 32±0.3 ■ Options Finger guards page: p. 584 Model no.: 109-059, 109-059H CATALOG No. C1111B002 '21.9.IT 239 DC Outlet side Counter Rotating Fan 40 mm sq. Inlet side 60×60×51 mm San Ace 60 9CR type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 180 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] 9CR0612P5G03 12 10.8 to 13.2 9CR0612P5H03 PWM duty Rated current Rated input cycle* [%] [A] 100 0 100 0 Rated speed [W] 2.7 0.22 2.0 0.22 [min-1] 32.4 2.64 24.0 2.64 Inlet Outlet 11500 3000 10500 3000 9000 2300 8200 2300 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 2.03 0.48 1.85 0.48 71.7 16.9 65.4 16.9 600 40 500 40 2.41 0.16 2.01 0.16 68 34 65 34 -20 to +70 40000/60˚C (70000/40˚C) * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: Sensor and control options are available for selection. Refer to the table on p. 625. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 700 2.5 600 2.0 500 1.5 1.0 0.5 0 (inch H2O) (Pa) 12 VDC 400 50% 300 200 100 0 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 90 (CFM) Airflow 240 600 2.0 500 1.5 1.0 0.5 0% 0.5 2.5 CATALOG No. C1111B002 '21.9.IT 0 (min-1) PWM duty cycle 100% 700 PWM duty cycle 100% PWM duty - Speed characteristics example 15000 13.2 V Inlet 10.8 V 400 300 200 11500 min-1 10000 9000 min-1 3000 min-1 Outlet 5000 100 0 Voltage: 12 VDC PWM frequency: 25 kHz 12 V Fan speed PWM duty cycle Static pressure 9CR0612P5G03 Static pressure Counter Rotating Fan 60 mm sq. DC Counter Rotating Fan 2300 min-1 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 90 (CFM) Airflow 0 PWM duty cycle 100 (%) ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CR0612P5H03 Operating voltage range (inch H2O) (Pa) Static pressure Static pressure 1.0 400 300 50% 200 0.5 0 0% 100 0 0.5 1.0 1.5 0 10 20 30 40 50 60 70 10.8 V 200 0.5 Inlet 10000 10500 min-1 8200 min-1 3000 min-1 Outlet 5000 100 2300 min-1 0 0.5 1.0 1.5 2.0 (m3/min) 0 10 20 30 40 50 60 70 (CFM) Voltage: 12 VDC PWM frequency: 25 kHz 12 V 300 0 2.0 (m3/min) 15000 13.2 V 1.5 400 1.0 (min-1) PWM duty cycle 100% 600 2.0 500 PWM duty cycle 100% 2.0 500 1.5 2.5 12 VDC 600 Fan speed (inch H2O) (Pa) 2.5 PWM duty - Speed characteristics example Airflow (CFM) 0 PWM duty cycle 100 (%) Airflow ■ Dimensions (unit: mm) Inlet side Outlet side +50 300 0 51±0.5 4-ø4.3±0.3 (4) (10) Mounting hole 60±0.5 50±0.3 (4) 4-ø4.3±0.3 Mounting hole +50 300 0 60±0.5 50±0.3 (10) Lead wire AWG26 UL 1430 Airflow direction Rotating direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 59 50±0.3 59 50±0.3 62 29.7 4- ø 4.5 .7 29.7 ■ Options Finger guards page: p. 584 Model no.: 109-139E, 109-139H Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1003G page: p. 592 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 241 Counter Rotating Fan 60 mm sq. PWM duty cycle DC With pulse sensor with PWM control function 60×60×56 mm San Ace 60 9CRA type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 200 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty cycle* [%] Rated current Rated input [A] Rated speed [W] [min-1] Inlet 9CRA0612P6K001 12 9CRA0612P6J001 10.8 to 13.2 9CRA0612P6G001 100 0 100 0 100 0 3.1 0.17 2.3 0.15 1.3 0.1 37.2 2.0 27.6 1.8 15.6 1.2 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 2.28 0.47 2.1 0.47 1.65 0.36 80.5 16.6 74.2 16.6 58.3 12.7 1130 49 950 49 620 31 4.54 0.2 3.82 0.2 2.49 0.12 73 35 70 35 65 29 Outlet 18300 15800 3800 3300 16800 14500 3800 3300 13500 11400 3000 2500 30000/60˚C (53000/40˚C) -20 to +70 40000/60˚C (70000/40˚C) * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRA0612P6K001 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) PWM duty cycle 100% 50% 0% 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 Airflow 242 (inch H2O) (Pa) 12 VDC Static pressure 5.5 1400 5.0 1200 4.5 4.0 1000 3.5 800 3.0 2.5 600 2.0 1.5 400 1.0 200 0.5 0 0 CATALOG No. C1111B002 '21.9.IT (CFM) 5.5 1400 5.0 1200 4.5 4.0 1000 3.5 800 3.0 2.5 600 2.0 1.5 400 1.0 200 0.5 0 0 PWM duty - Speed characteristics example (min-1) PWM duty cycle 100% 13.2 V 12 V 10.8 V 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 Airflow Fan speed PWM duty cycle Static pressure Counter Rotating Fan 60 mm sq. DC Counter Rotating Fan (CFM) Voltage: 12 VDC PWM frequency: 25 kHz 20000 18000 Inlet 16000 14000 3800 min-1 12000 10000 8000 6000 4000 3300 min-1 2000 0 18300 min-1 15800 min-1 Outlet PWM duty cycle 100 (%) ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRA0612P6J001 (inch H2O) (Pa) 800 3.0 2.5 600 2.0 50% 400 1.5 1.0 200 0.5 0 0% 0 0.5 1.0 1.5 2.0 2.0 1.5 1.0 0.5 0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 3.0 2.5 800 10.8 V 400 0.5 (inch H2O) (Pa) 4.5 1.5 1.0 0.5 0 PWM duty cycle 100% 600 400 200 0 3800 min-1 Outlet 6000 0 (CFM) 3300 min-1 PWM duty cycle 100 (%) PWM duty - Speed characteristics example (min-1) PWM duty cycle 100% 1200 18000 3.5 3.0 2.5 0% 2.0 1.5 1.0 0.5 0.5 0 50% 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 14000 800 13.2 V 12 V 600 10.8 V 400 200 0 13500 min-1 Inlet 12000 10000 8000 11400 min-1 3000 min-1 Outlet 6000 4000 2000 0.5 2.0 2.5 (m3/min) 1.0 1.5 0 10 20 30 40 50 60 70 80 (CFM) Voltage: 12 VDC PWM frequency: 25 kHz 16000 4.0 1000 Static pressure Static pressure 2.5 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 4.0 1000 2.0 2.0 1.0 1.5 14500 min-1 8000 2000 0 16800 min-1 Inlet Airflow 12 VDC 1200 3.0 10000 4000 200 Operating voltage range 800 12000 Voltage: 12 VDC PWM frequency: 25 kHz With pulse sensor with PWM control function (inch H2O) (Pa) 3.5 14000 600 (CFM) PWM duty cycle 4.5 16000 12 V Airflow 9CRA0612P6G001 18000 13.2 V 4.0 1000 3.5 (min-1) PWM duty cycle 100% 1200 Fan speed Static pressure 3.5 4.5 PWM duty cycle 100% 4.0 1000 Static pressure 4.5 (inch H2O) (Pa) 12 VDC 1200 PWM duty - Speed characteristics example Airflow 0 (CFM) 2500 min-1 PWM duty cycle 100 (%) Airflow ■ Dimensions (unit: mm) Inlet side 50±0.3 60±0.5 4-ø4.5±0.3 Mounting hole Outlet side +50 300 0 (10) Lead wire AWG26 UL 1430 50±0.3 60±0.5 Rotating direction (4) (4) 56±0.5 Airflow direction 4-ø4.5±0.3 Mounting hole Rotating direction CATALOG No. C1111B002 '21.9.IT 243 Counter Rotating Fan 60 mm sq. Operating voltage range Fan speed PWM duty cycle DC With pulse sensor with PWM control function ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side DC 59 50±0.3 59 50±0.3 29.7 4-ø4.5 6622 ..77 Counter Rotating Fan 60 mm sq. 29.7 ■ Options Finger guards page: p. 584 Model no.: 109-139E, 109-139H Resin filter kits Model no.: 109-1003G page: p. 592 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) 244 CATALOG No. C1111B002 '21.9.IT Resin finger guards page: p. 591 Counter Rotating Fan San Ace 60 9CRE type ■ General Specifications · Material……………………………………… Frame: Aluminum, Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 300 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] [min-1] Inlet 12 9CRE0612P0G001 10.8 to 13.2 100 0 2.3 0.22 27.6 2.7 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 2.0 0.43 70.6 15.1 1000 47.6 4.0 0.19 66 32 -20 to +70 40000/60˚C (70000/40˚C) Outlet 16500 13000 3600 2800 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRE0612P0G001 With pulse sensor with PWM control function PWM duty cycle Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) Static pressure 2.0 1.0 0 4.0 800 600 50% 400 200 0 0% 0.5 1.0 1.5 2.0 0 10 20 30 40 50 60 70 80 Airflow 2.5 (m3/min) (CFM) 3.0 2.0 1.0 0 (min-1) PWM duty cycle 100% 1200 18000 14000 12 V 800 600 10.8 V 400 16500 min-1 Inlet 13000 min-1 12000 10000 3600 min-1 8000 Outlet 6000 4000 200 0 Voltage: 12 VDC PWM frequency: 25 kHz 16000 13.2 V 1000 Fan speed PWM duty cycle 100% 4.0 1000 3.0 5.0 12 VDC 1200 Static pressure 5.0 PWM duty - Speed characteristics example 2000 0.5 1.0 1.5 2.0 0 10 20 30 40 50 60 70 80 2.5 (m3/min) (CFM) 0 2800 min-1 PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 245 Counter Rotating Fan 60 mm sq. DC 60×60×76 mm ■ Dimensions (unit: mm) Outlet side DC 50±0.3 50±0.3 +50 300 0 60±0.5 (10) (10) 4-ø4.3±0.3 Mounting hole 4±0.3 +50 300 0 4±0.3 76±0.5 Lead wire AWG26 UL 1430 Rotating direction Airflow direction 4-ø4.3±0.3 Mounting hole Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 59 50±0.3 59 50±0.3 29.7 4- ø 4.5 .7 29.7 62 Counter Rotating Fan 60 mm sq. Inlet side 60±0.5 ■ Options Finger guards page: p. 584 Model no.: 109-139E, 109-139H Resin filter kits Model no.: 109-1003G page: p. 592 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) 246 CATALOG No. C1111B002 '21.9.IT Resin finger guards page: p. 591 Counter Rotating Fan San Ace 60 9CRA type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 270 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] [min-1] Inlet 9CRA0612P0G001 12 10.8 to 13.2 9CRA0612P0S001 100 0 100 0 2.3 0.22 1.5 0.17 27.6 2.7 18.0 2.1 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 2.0 0.43 1.7 0.38 70.6 15.1 60.0 13.4 1000 47.6 720 37.6 4.0 0.19 2.89 0.15 66 32 63 29 -20 to +70 40000/60˚C (70000/40˚C) Outlet 16500 13000 3600 2800 14000 11000 3200 2500 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRA0612P0G001 With pulse sensor with PWM control function Operating voltage range (inch H O) (Pa) (inch H2O) (Pa) PWM duty cycle 100% Static pressure 4.0 1000 3.0 2.0 1.0 0 800 600 50% 400 200 0 5.0 12 VDC 1200 3.0 2.0 1.0 0% 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 (CFM) Airflow 0 (min-1) PWM duty cycle 100% 1200 18000 13.2 V 4.0 1000 Static pressure 5.0 PWM duty - Speed characteristics example 2 12 V 14000 800 10.8 V 600 400 16500 min-1 12000 10000 8000 Inlet 13000 min-1 3600 min-1 Outlet 6000 4000 200 0 Voltage: 12 VDC PWM frequency: 25 kHz 16000 Fan speed PWM duty cycle -1 2000 2800 min 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 (CFM) 0 PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 247 Counter Rotating Fan 60 mm sq. DC 60×60×76 mm ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 5.0 1200 5.0 1200 12 VDC 2.0 1.0 0 Static pressure 3.0 PWM duty cycle 100% 800 600 50% 400 200 3.0 2.0 1.0 0% 0 0.5 1.0 1.5 2.0 0 10 20 30 40 50 60 70 80 18000 14000 min-1 14000 12 V 600 10.8 V 400 Inlet 12000 11000 min-1 10000 8000 3200 min-1 6000 Outlet 4000 200 (CFM) Voltage: 12 VDC PWM frequency: 25 kHz 16000 13.2 V 800 0 2.5 (m3/min) (min-1) PWM duty cycle 100% 4.0 1000 4.0 1000 Static pressure -1 2000 2500 min 0 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 (CFM) Airflow 0 PWM duty cycle 100 (%) Airflow ■ Dimensions (unit: mm) Inlet side Outlet side 60±0.5 76±0.5 (4) (10) 50±0.3 (4) 300 50±0.3 (10) +50 0 60±0.5 +50 300 0 4-ø4.5±0.3 Mounting hole Lead wire AWG26 UL 1430 4-ø4.5±0.3 Mounting hole Rotating direction Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 59 50±0.3 59 50±0.3 4- ø 4.5 .7 29.7 62 Counter Rotating Fan 60 mm sq. (inch H2O) (Pa) PWM duty - Speed characteristics example Fan speed PWM duty cycle 29.7 DC 9CRA0612P0S001 ■ Options Finger guards page: p. 584 Model no.: 109-139E, 109-139H Resin filter kits Model no.: 109-1003G page: p. 592 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) 248 CATALOG No. C1111B002 '21.9.IT Resin finger guards page: p. 591 Counter Rotating Fan San Ace 80 9CRB type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 430 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] Inlet 12 9CRB0812P8G001 10.8 to 13.2 100 20 9.2 0.17 Max. airflow [min-1] 110.4 2.04 SPL Operating temperature Expected life [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 5.5 0.7 194 24.7 1150 21.6 4.6 0.09 80 24 -20 to +70 40000/60˚C (70000/40˚C) Outlet 14600 12200 2000 1670 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRB0812P8G001 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 1200 4 1000 3 2 1 0 PWM duty cycle 100% 800 600 60% 400 200 0 20% 1 2 3 4 5 6 (m3/min) 0 20 40 60 80 100 120 140 160 180 200 Airflow (CFM) 5 1200 4 1000 3 2 (min-1) PWM duty cycle 100% 1400 Static pressure Static pressure 5 (inch H2O) (Pa) 12 VDC 1400 PWM duty - Speed characteristics example 16000 13.2 V 600 400 1 200 0 0 14600 min-1 12200 min-1 12000 10.8 V 800 Voltage: 12 VDC PWM frequency: 25 kHz 14000 12 V Fan speed PWM duty cycle 10000 Inlet 8000 6000 Outlet 4000 2000 1 2 3 4 5 6 (m3/min) 0 20 40 60 80 100 120 140 160 180 200 (CFM) 0 100 (%) PWM duty cycle Airflow CATALOG No. C1111B002 '21.9.IT 249 Counter Rotating Fan 80 mm sq. DC 80×80×80 mm ■ Dimensions (unit: mm) Inlet side Outlet side Lead wire AWG22 UL 1430 80±0.5 71.5±0.5 80±1 (4) (4) 300 71.5±0.5 (10) +30 0 Rotating direction Airflow direction 80±0.5 Counter Rotating Fan 80 mm sq. DC 4-ø4.5±0.5 Mounting hole 4-ø4.5±0.5 Mounting hole Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 78.5 4-ø4.5 78.5 71.5±0.3 ø9 0 71.5±0.3 ■ Options Finger guards page: p. 584 Model no.: 109-049E, 109-049H Resin filter kits Model no.: 109-1002G page: p. 592 Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI), 109-1002F30 (30PPI), 109-1002F40 (40PPI) 250 CATALOG No. C1111B002 '21.9.IT Resin finger guards page: p. 591 Counter Rotating Fan San Ace 80 9CRE type ■ General Specifications · Material……………………………………… Frame: Aluminum, Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 490 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] Inlet 12 9CRE0812P8G001 10.8 to 13.2 100 0 5.3 0.2 Max. airflow [min-1] 63.6 2.4 SPL Operating temperature Expected life [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 4.5 0.74 158.9 26.1 1150 31.9 4.62 0.13 76 30 -20 to +70 40000/60˚C (70000/40˚C) Outlet 12000 11300 2000 1900 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function PWM duty cycle Operating voltage range (inch H2O) (Pa) 1200 4.0 1000 3.0 2.0 1.0 0 PWM duty cycle 100% 800 600 50% 400 200 0 0% 1.0 2.0 3.0 4.0 5.0 (m3/min) 0 20 40 60 80 100 120 140 160 Airflow 5.0 (CFM) 1000 3.0 800 2.0 1.0 0 12 V/13.2 V 1200 4.0 (min-1) PWM duty cycle 100% 1400 Static pressure Static pressure 5.0 (inch H2O) (Pa) 12 VDC 1400 PWM duty - Speed characteristics example 10.8 V Fan speed 9CRE0812P8G001 600 400 200 0 1.0 2.0 3.0 4.0 5.0 (m3/min) 0 20 40 60 80 100 120 140 160 (CFM) Voltage: 12 VDC PWM frequency: 25 kHz 13000 12000 11000 10000 9000 8000 7000 2000 min-1 6000 5000 4000 3000 2000 1900 min-1 1000 0 12000 min-1 11300 min-1 Inlet Outlet PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 251 Counter Rotating Fan 80 mm sq. DC 80×80×80 mm ■ Dimensions (unit: mm) Outlet side DC 71.5±0.5 80±0.5 71.5±0.5 300 +50 0 (10) (10) 4-ø4.3±0.5 Mounting hole Rotating direction 4±0.3 +50 300 0 4±0.3 80±1 Lead wire AWG24 UL 1430 Airflow direction 4-ø4.3±0.5 Mounting hole Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side Outlet side 78.5 78.5 4-ø4.5 ø8 78.5 71.5±0.3 ø9 78.5 4-ø4.5 2 71.5±0.3 0 71.5±0.3 71.5±0.3 Counter Rotating Fan 80 mm sq. Inlet side 80±0.5 ■ Options Finger guards page: p. 584 Model no.: 109-049E, 109-049H Resin filter kits Model no.: 109-1002G page: p. 592 Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI), 109-1002F30 (30PPI), 109-1002F40 (40PPI) 252 CATALOG No. C1111B002 '21.9.IT Resin finger guards page: p. 591 Counter Rotating Fan San Ace 80 9CRA type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 450 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] Inlet 9CRA0812P8G001 12 10.8 to 13.2 9CRA0824P8G001 24 21.6 to 26.4 9CRA0848P8G001 48 40.8 to 55.2 100 0 100 0 100 0 5.3 0.2 2.65 0.09 1.32 0.29 Max. airflow [min-1] 63.6 2.4 63.6 2.16 63.4 13.9 SPL Operating temperature Expected life [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 4.5 0.74 4.5 0.74 4.5 1.88 158.9 26.1 158.9 26.1 158.9 66.2 1150 31.9 1150 31.9 1150 200 4.62 0.13 4.62 0.13 4.62 0.8 76 30 76 30 76 52 -20 to +70 40000/60˚C (70000/40˚C) Outlet 12000 11300 2000 1900 12000 11300 2000 1900 12000 11300 5000 4700 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note 1: Sensor and control options are available for selection. Refer to the table on p. 625. mark indicates Short Lead Time Service applicable models. See p. 654 for details. Note 2: The ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function PWM duty cycle Operating voltage range (inch H2O) (Pa) 1200 4.0 1000 3.0 2.0 1.0 0 PWM duty cycle 100% 800 600 50% 400 200 0% 0 1.0 5.0 1000 3.0 800 2.0 1.0 2.0 3.0 4.0 5.0 (m3/min) 0 20 40 60 80 100 120 140 160 Airflow (CFM) 0 12 V/13.2 V 1200 4.0 (min-1) PWM duty cycle 100% 1400 Static pressure Static pressure 5.0 (inch H2O) (Pa) 12 VDC 1400 PWM duty - Speed characteristics example 10.8 V Fan speed 9CRA0812P8G001 600 400 200 0 1.0 2.0 3.0 4.0 5.0 (m3/min) 0 20 40 60 80 100 120 140 160 (CFM) Voltage: 12 VDC PWM frequency: 25 kHz 12000 11000 Inlet 10000 9000 8000 7000 2000 min-1 6000 5000 4000 3000 2000 1900 min-1 1000 0 12000 min-1 11300 min-1 Outlet PWM duty cycle 100 (%) Airflow CATALOG No. C1111B002 '21.9.IT 253 Counter Rotating Fan 80 mm sq. DC 80×80×80 mm ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example With pulse sensor with PWM control function PWM duty cycle Operating voltage range 3.0 2.0 1.0 0 800 600 50% 400 200 0% 0 1.0 1200 4.0 1000 3.0 2.0 1.0 2.0 3.0 4.0 0 5.0 (m3/min) 0 20 40 60 80 100 120 140 160 24 V/26.4 V 21.6 V 800 600 400 200 0 1.0 1.0 0 PWM duty cycle 100% 50% 600 400 0% 200 0 5.0 1.0 2.0 3.0 4.0 3.0 800 2.0 1.0 0 5.0 (m3/min) 0 20 40 60 80 100 120 140 160 1000 40.8 V 600 400 200 0 1.0 2.0 3.0 4.0 Airflow Voltage: 48 VDC PWM frequency: 25 kHz 12000 11000 Inlet 10000 9000 8000 5000 min-1 7000 6000 5000 4700 min-1 4000 3000 2000 1000 5.0 (m3/min) 0 20 40 60 80 100120140160 (CFM) (min-1) 48 V/55.2 V 1200 4.0 PWM duty - Speed characteristics example Fan speed 2.0 100 (%) PWM duty cycle PWM duty cycle 100% 1400 Static pressure Static pressure 800 (inch H2O) (Pa) 48 VDC 1200 3.0 0 (CFM) Airflow Inlet side Outlet side 4-ø4.5±0.5 Mounting hole 80±1 (4) 80±0.5 71.5±0.5 (4) 71.5±0.5 80±0.5 (10) +30 300 0 Lead wire AWG24 UL 1430 Rotating direction 4-ø4.5±0.5 Mounting hole Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side Outlet side 78.5 78.5 4-ø4.5 2 71.5±0.3 CATALOG No. C1111B002 '21.9.IT 78.5 78.5 ø9 ø8 0 71.5±0.3 4-ø4.5 12000 min-1 11300 min-1 Outlet PWM duty cycle ■ Dimensions (unit: mm) 254 Outlet 0 (CFM) Operating voltage range 1400 1000 5.0 (m3/min) 12000 min-1 11300 min-1 With pulse sensor with PWM control function (inch H2O) (Pa) 4.0 4.0 13000 12000 Inlet 11000 10000 9000 8000 -1 7000 2000 min 6000 5000 4000 3000 2000 1900 min-1 1000 Airflow PWM duty cycle 5.0 3.0 0 20 40 60 80 100 120 140 160 (CFM) Airflow 9CRA0848P8G001 2.0 Voltage: 24 VDC PWM frequency: 25 kHz (min-1) Fan speed Static pressure 4.0 1000 5.0 PWM duty - Speed characteristics example PWM duty cycle 100% 1400 PWM duty cycle 100% 5.0 1200 Static pressure (inch H2O) (Pa) 24 VDC 1400 71.5±0.3 Counter Rotating Fan 80 mm sq. (inch H2O) (Pa) 71.5±0.3 DC 9CRA0824P8G001 100 (%) ■ Options Model no.: 109-049E, 109-049H Resin filter kits Resin finger guards page: p. 591 DC page: p. 584 Model no.: 109-1002G Counter Rotating Fan 80 mm sq. Finger guards page: p. 592 Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI), 109-1002F30 (30PPI), 109-1002F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 255 92×92×76 mm San Ace 92 9CRA type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 510 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] PWM duty Rated current Rated input cycle* [%] [A] Rated speed [W] 12 9CRA0912P0G001 10.2 to 13.2 48 9CRA0948P0G601 36 to 60 100 20 100 20 9.0 0.42 2.2 0.15 108.0 5.04 105.6 7.2 Max. airflow [min-1] Inlet SPL Operating temperature Expected life [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 5.8 1.48 5.8 1.48 205 52.3 205 52.3 1650 140 1650 140 6.63 0.56 6.63 0.56 81 47 81 47 -20 to +70 40000/60˚C (70000/40˚C) Outlet 13300 12200 3500 3200 13300 12200 3500 3200 * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CRA0912P0G001 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 6 1400 1200 4 1000 3 800 1 0 60% 600 400 20% 6 5 800 2 1 0 0 1 2 3 4 5 6 (m3/min) Airflow CATALOG No. C1111B002 '21.9.IT (CFM) 12000 10.2 V 1200 600 13300 min-1 12200 min-1 Inlet 10000 8000 6000 Outlet 4000 400 2000 200 0 Voltage: 12 VDC PWM frequency: 25 kHz 14000 12 V 1400 3 16000 13.2 V 1600 1000 (min-1) PWM duty cycle 100% 1800 4 200 0 20 40 60 80 100 120 140 160 180 200 256 7 PWM duty cycle 100% 1600 5 2 (inch H2O) (Pa) 12 VDC 1800 Static pressure 7 PWM duty - Speed characteristics example Fan speed PWM duty cycle Static pressure Counter Rotating Fan 92 mm sq. DC Counter Rotating Fan 1 2 3 4 5 6 (m3/min) 0 20 40 60 80 100 120 140 160 180 200 Airflow (CFM) 0 100 (%) PWM duty cycle ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example Operating voltage range (inch H2O) (Pa) Static pressure 6 5 1200 1000 3 800 1 0 6 1400 4 2 7 PWM duty cycle 100% 1600 Static pressure 7 (inch H2O) (Pa) 48 VDC 1800 60% 600 400 20% 1 1000 3 800 2 1 200 0 1200 2 3 4 5 0 20 40 60 80 100 120 140 160 180 200 12000 36 V 2000 2 3 4 5 6 (m3/min) 0 20 40 60 80 100 120 140 160 180 200 Outlet 6000 200 1 Inlet 8000 4000 0 13300 min-1 12200 min-1 10000 400 (CFM) Voltage: 48 VDC PWM frequency: 25 kHz 14000 48 V 600 0 6 (m3/min) 16000 60 V 1400 4 (min-1) PWM duty cycle 100% 1800 1600 5 PWM duty - Speed characteristics example Fan speed PWM duty cycle 0 100 (%) PWM duty cycle (CFM) Airflow Airflow ■ Dimensions (unit: mm) Inlet side Outlet side 4-ø4.5±0.5 Mounting hole Lead wire AWG22 UL 3266 76±1 (4) 92±0.5 82.5±0.5 (4) 300 82.5±0.5 92±0.5 (10) +30 0 4-ø4.5±0.5 Mounting hole Airflow direction Rotating direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 90.5 4-ø4.5 90.5 82.5±0.3 7 ø9 82.5±0.3 ■ Options Finger guards page: p. 584 Model no.: 109-099E, 109-099H Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1001G page: p. 592 Model no.: 109-1001F13 (13PPI), 109-1001F20 (20PPI), 109-1001F30 (30PPI), 109-1001F40 (40PPI) CATALOG No. C1111B002 '21.9.IT DC With pulse sensor with PWM control function Counter Rotating Fan 92 mm sq. 9CRA0948P0G601 257 120×120×76 mm San Ace 120 9CR type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 670 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] 12 9CR1212P0G03 10.8 to 13.2 PWM duty Rated current Rated input cycle* [%] [A] 100 0 Rated speed [W] 7.2 1.1 [min-1] 86.4 13.2 Inlet Outlet 6200 2700 3800 1800 SPL Operating temperature Expected life [m3/min] Max. airflow [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 8.5 3.8 300 134 480 95 1.93 0.38 70 51 -20 to +60 40000/60˚C (70000/40˚C) * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. Note: Sensor and control options are available for selection. Refer to the table on p. 625. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CR1212P0G03 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 600 2.0 500 1.5 1.0 0.5 0 PWM duty cycle 100% 50% 400 300 200 0% 2 0 4 100 6 200 8 10 300 Airflow 258 2.5 600 2.0 500 1.5 1.0 0.5 100 0 CATALOG No. C1111B002 '21.9.IT PWM duty cycle 100% 700 Static pressure 2.5 (inch H2O) (Pa) 12 VDC 700 (m3/min) 400 (CFM) 0 PWM duty - Speed characteristics example (min-1) Inlet 10.8 V 400 300 200 2 0 4 100 6 200 Airflow 8 300 10 (m3/min) 400 (CFM) 6200 min-1 6000 2700 min-1 4000 3800 min-1 Outlet 2000 100 0 Voltage: 12 VDC PWM frequency: 25 kHz 8000 13.2 V 12 V Fan speed PWM duty cycle Static pressure Counter Rotating Fan 120 mm sq. DC Counter Rotating Fan 0 1800 min-1 PWM duty cycle 100 (%) ■ Dimensions (unit: mm) Outlet side 76±1 120±0.8 104.8±0.3 Airflow direction Rotating direction 4-ø4.3±0.3 Mounting hole DC Inlet side 4-ø4.3±0.3 Mounting hole Counter Rotating Fan 120 mm sq. +30 300 0 (10) 120±0.8 +30 300 0 104.8±0.3 (10) Lead wire AWG22 UL 1430 Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side Outlet side 104.8±0.3 4-ø4.5 35 ø1 118 118 104.8±0.3 27 ø1 4-ø4.5 118 104.8±0.3 104.8±0.3 118 ■ Options Finger guards page: p. 585 Model no.: 109-019E, 109-019K Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1000G page: p. 592 Model no.: 109-1000F13 (13PPI), 109-1000F20 (20PPI), 109-1000F30 (30PPI), 109-1000F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 259 ø 172×150×102 mm San Ace 172 9CR type Sidecut type ■ General Specifications · Material……………………………………… Frame: Aluminum, Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Inlet Red Black Sensor Yellow Control Brown Outlet Orange Gray Sensor Purple Control White · Mass………………………………………… 1600 g ■ Specifications The models listed below have pulse sensors with PWM control function. Rated voltage Operating voltage range Model no. [V] [V] 48 9CR5748P9G001 36 to 72 PWM duty Rated current Rated input cycle* [%] [A] 100 0 Rated speed [W] 5.5 0.5 264 24 Max. airflow [min-1] Inlet Outlet 7300 2400 6400 1900 SPL Operating temperature Expected life [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] [dB (A)] [˚C] [h] 18 5.5 636 194.3 1400 152 5.62 0.61 83 54 -20 to +70 40000/60˚C (70000/40˚C) * PWM input frequency is 25 kHz; models without specifications at 0% PWM duty cycle have zero fan speed at 0%. ■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example 9CR5748P9G001 With pulse sensor with PWM control function Operating voltage range (inch H2O) (Pa) 5 1200 50% 4 1000 3 2 1 0 800 600 400 5 10 15 0 100 200 300 400 500 600 20 (m3/min) 700 (CFM) Airflow 260 5 3 2 CATALOG No. C1111B002 '21.9.IT 0 (min-1) PWM duty cycle 100% 1600 8000 72 V 1400 7000 48 V 1200 4 1000 1 0% 200 0 6 PWM duty cycle 100% 1400 Static pressure 6 (inch H2O) (Pa) 48 VDC 1600 PWM duty - Speed characteristics example Fan speed PWM duty cycle Static pressure Counter Rotating Fan ø172 mm DC Counter Rotating Fan 36 V 800 600 3000 2000 1000 5 10 15 20 (m3/min) Airflow Outlet 4000 200 0 100 200 300 400 500 600 700 (CFM) 7300 min-1 6400 min-1 Inlet 6000 2400 min-1 5000 400 0 Voltage: 48 VDC PWM frequency: 25 kHz 0 1900 min-1 PWM duty cycle 100 (%) Outlet side 102±1 300 +30 0 (10) 150±0.8 7.5±0.4 162±0.5 (10) +30 300 0 Lead wire Counter Rotating Fan ø172 mm Mounting hole 7.5±0.4 4-ø4.5±0.3 Mounting hole ø172±0.8 4-ø4.5±0.3 Inlet side DC ■ Dimensions (unit: mm) AWG22 UL 1430 .5° 55 55 .5° Airflow direction Rotating direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 9.5 162±0.5 ø1 68 4-ø4.5 55 5° .5° 147 55. ■ Options Finger guards page: p. 586 Model no.: 109-319J, 109-319E, 109-319H, 109-320 CATALOG No. C1111B002 '21.9.IT 261 Finger guards List Increases safety by preventing foreign objects from entering fans. Fans can be used with little effect on airflow and static pressure. Size Model no. Mounting side Surface treatment 36 mm sq. type 38 mm sq. type 40 mm sq. type 109-1050 Inlet side, Outlet side ✓ - 109-1065 Inlet side, Outlet side ✓ - ✓ - - ✓ 109-059 109-059H 52 mm sq. type 60 mm sq. type 109-149E Inlet side, Outlet side ✓ - 109-149 Outlet side ✓ - ✓ - - ✓ ✓ - ✓ - - ✓ - 109-139E 109-139H 70 mm sq. type, ø70 mm type 80 mm sq. type 109-1128 109-049E 109-049H 92 mm sq. type ø 92 mm type 92 mm sq. type, ø100 mm type Outlet side Outlet side ✓ - 109-1147 Impeller side, Nameplate side ✓ - 109-099E ✓ - - ✓ ✓ - - ✓ ✓ - - ✓ 109-019E 109-019H ø 150 mm type 172 mm Sidecut type ø 172 mm Sidecut, Round type - 109-722H Inlet side, Outlet side - ✓ 109-723 Outlet side ✓ - 109-1112 Inlet side ✓ - 109-1139 Impeller side, Nameplate side ✓ - ✓ - - ✓ - 109-719 172 mm Round type ø 200 mm type 109-1051 Inlet side, Outlet side 109-1052 Outlet side ✓ - ✓ - - ✓ ✓ - - ✓ 109-1104 109-619E Outlet side ✓ - Inlet side, Outlet side ✓ - ✓ - - ✓ 109-319E Outlet side ✓ - 109-1066 Inlet side, Outlet side ✓ - 109-1068 Outlet side ✓ - ✓ - - ✓ ✓ - - ✓ ✓ - - ✓ ✓ - - ✓ ✓ - - ✓ ✓ - - ✓ ✓ - - ✓ 109-1102* 109-720 109-720H 109-721 109-721H 109-1138 109-1138H 225 mm type Inlet side, Outlet side 109-320 109-1103H* ø Inlet side, Outlet side 109-319J 109-1103* 221 mm type Inlet side 109-620 109-1102H* ø Inlet side, Outlet side ✓ 109-319H ø Outlet side ✓ 109-619H ø Inlet side, Outlet side Inlet side, Outlet side 109-1104H 160 mm sq. type Inlet side, Outlet side 109-722 109-719H 150 mm sq. type Inlet side, Outlet side 109-099C 109-019C 127 mm sq. type ø 133 mm type ø 136 mm type 140 mm sq. type Inlet side, Outlet side 109-049C 109-019K 127 mm sq. type, ø175 mm type Inlet side, Outlet side ✓ 109-099H 120 mm sq. type Inlet side, Outlet side 109-1137 109-1137H 270 mm sq. type (for Bracket-mounted Centrifugal Fan) 109-1146H 109-1146 Inlet side, Outlet side Outlet side Inlet side, Outlet side Outlet side Inlet side Inlet side Inlet side Option Nickel-chrome plating (silver) Cation electropainting (black) * Applicable model no.: 9GV20* CATALOG No. C1111B002 '21.9.IT 583 Options Finger guards Dimensions (unit: mm) For use in environments subject to water splashes, cation electroplating models are recommended. 36 mm sq. type 38 mm sq. type 40 mm sq. type Model no. Surface treatment Mass (g) 109-1050 Nickel-chrome plating (silver) 4 Model no. Surface treatment Mass (g) 109-1065 Nickel-chrome plating (silver) 5 Model no. Surface treatment Mass (g) 109-059 Nickel-chrome plating (silver) 7 109-059H Cation electropainting (black) Inlet side, Outlet side Inlet side, Outlet side Inlet side, Outlet side 4-ø4±0.3 4.8±0.5 3.5±0.3 6 ø1.6 .5 ø29 ø2 8. 5 ø1 8. 3 5.3 ø4 5 0. .5 7.5 ±0 ø1 ø1.6 30 ± .5 5 29 ø1 6 .6 49 +1.5 -0.5 32 29 ø2 ø1.6 ø1 ø1. 34 6 ø1. +1 4 0 38.5 30 .5 ± ±0 0. 5 .5 +1 +0.3 0 4.8 0 4-ø4 52 mm sq. type 60 mm sq. type Model no. Surface treatment Mass (g) 109-149E Nickel-chrome plating (silver) 9 Model no. Surface treatment Mass (g) 109-149 Nickel-chrome plating (silver) 7 Model no. Surface treatment Mass (g) 109-139E Nickel-chrome plating (silver) 14.5 109-139H Cation electropainting (black) Inlet side, Outlet side Outlet side Inlet side, Outlet side ø1.6 ø53 6 ø1. .8 +1.5 63.2 -0.5 53.3 63.2 +1.5 -0.5 ø43 6 ø32. ø5 4 +1 0 ø70.7 9.4 ø59.4 4.3±0.3 ø1.6 ø1.6 +1.5 ø43.8 .6 +1 4 0 53.3 ø1.6 ø1 3.7±0.3 75 -0.5 3.7±0.3 62 +1 4 0 70 mm sq. type, ø70 mm type 80 mm sq. type Model no. Surface treatment Mass (g) 109-1128 Nickel-chrome plating (silver) 17 Model no. Surface treatment Mass (g) 109-049E Nickel-chrome plating (silver) 21 109-049H Cation electropainting (black) Model no. Surface treatment Mass (g) 109-049C Nickel-chrome plating (silver) 17 Inlet side, Outlet side Inlet side, Outlet side Outlet side 4.3±0.3 ø75 5 4.3±0.3 5 +10 ø1.6 ø75 88 +1.5 105 -0.5 88 78 +1.5 ø1.6 91 -0.5 3.2 105 +1.5 -0.5 ø6 4.3±0.3 ø1.6 ø1.6 5 +10 ø1.6 16 ø1.6 ø +1 0 ø3 (ø8 7) ø101.2 ø101.2 Option 9.6 92 mm sq. type ø92 Model no. Surface treatment Mass (g) 109-099C Nickel-chrome plating (silver) 22 Model no. Surface treatment Mass (g) 109-1147 Nickel-chrome plating (silver) 23 Model no. Surface treatment Mass (g) 109-099E Nickel-chrome plating (silver) 29 109-099H Cation electropainting (black) Outlet side Impeller side, Nameplate side Inlet side, Outlet side 5) 7.6 ø7 ø1.6 ø1.6 99 +1.5 120.5 -0.5 75 3.5±0.5 8. ø1 6. 6 +1 4 0 .6 16 CATALOG No. C1111B002 '21.9.IT ø1 ø87 88.8±0.5 3.5±0.3 ø1.6 +1 5 0 4.3±0.3 ø1.6 ø1.6 ( ø8 3.5±0.5 ø1 6.6 ø11 584 5 99 120.5 +1.5 -0.5 4.3±0.3 ø1.6 ø1.6 9.8 ø3ø87 +1 0 92 mm sq., ø100 mm type mm type 2 Finger guards Dimensions (unit: mm) For use in environments subject to water splashes, cation electroplating models are recommended. 127 mm sq., ø175 mm type 120 mm sq. type Model no. Surface treatment Mass (g) 109-019E Nickel-chrome plating (silver) 42 109-019K Cation electropainting (black) Model no. Surface treatment Mass (g) 109-019C Nickel-chrome plating (silver) 32 109-019H Cation electropainting (black) Model no. Surface treatment Mass (g) 109-722 Nickel-chrome plating (silver) 43 109-722H Cation electropainting (black) Inlet side, Outlet side Outlet side Inlet side, Outlet side 19 142 130 4.3±0.3 ø24.6 ø1 13 ø1 .2 ø1.6 +0.4 4.3 -0.2 ø42 130 4.3±0.3 ø18.6 152.5±0.5 ø1.6 ø1.6 ø1.6 165±0.5 3 11 ø +1 5 0 ø148 ø1.6 ø1.6 +1 5 0 ø160.5 ø14 5 -10 8 152.5 +1.5 -0.5 127 mm sq. type ø133 ø136 Model no. Surface treatment Mass (g) 109-723 Nickel-chrome plating (silver) 34 Model no. Surface treatment Mass (g) 109-1112 Nickel-chrome plating (silver) 65 Model no. Surface treatment Mass (g) 109-1139 Nickel-chrome plating (silver) 41 Outlet side Inlet side Impeller side, Nameplate side mm type 4.3±0.3 ø1.6 .4 08 ø1 120 133±2 ø87 123.1±1 165±0.5 4.3±0.2 19 ø1 ) (ø60 ø1.6 3.2±1 ø1.6 ø1.6 ø16 ø1.6 ø1.6 3.5±0.3 ø118 3.2 -10 mm type ø1 ø160.5 28) (ø1 6 5 +1 0 140 mm sq. type 150 mm sq. type Model no. Surface treatment Mass (g) 109-719 Nickel-chrome plating (silver) 51 109-719H Cation electropainting (black) Model no. Surface treatment Mass (g) 109-1051 Nickel-chrome plating (silver) 63 Model no. Surface treatment Mass (g) 109-1052 Nickel-chrome plating (silver) 53 Inlet side, Outlet side Inlet side, Outlet side Outlet side +0.4 -0.2 0 5.5 -1 4.3±0.2 4-12 ø156 4-4.5 (ø6 2.2 ø1 6.8 ) .8 43 ø1.6 .8 ø1.6 mm type ø1.6 43 ø1 .2 36 ø1.6 ø150 ø2 ø1 26.8 ø 4-4.5 ø145 4-12 ø1.6 0 3.2 -1 Option 4.3 197.7±0.5 ø1.6 +0 -1 5.5 0 -1 ø190.9 ø190.9 .5 +0.4 -0.2 ø201 + 6 -1 ø1706.5 ø18 4.3 160 mm sq. type Model no. Surface treatment Mass (g) 109-1104 Nickel-chrome plating (silver) 31 109-1104H Cation electropainting (black) Model no. Surface treatment Mass (g) 109-619E Nickel-chrome plating (silver) 85 109-619H Cation electropainting (black) Model no. Surface treatment Mass (g) 109-620 Nickel-chrome plating (silver) 74 Inlet side Inlet side, Outlet side Outlet side ø1.8 +0.4 5.5 -0.2 0 3.6 -1.5 ø1.8 ø1.8 ø184 ø111.5 8 -1.5 5.9 7 3 0 +0.4 -0.2 5 +01. - 6. ø1.8 5.5 5.2 ø2 .9 ø ø20 5 +01. - +0.4 4.3 -0.2 9 ø1 59. ø1 5.2 95 7 ø1 59. ø1 .6 97 ø20 ø1.6 ø128.7 +2 ø136.2 -1  0 5.5 -1 7 1. ø6 ø1.6 CATALOG No. C1111B002 '21.9.IT 585 Options Finger guards Dimensions (unit: mm) For use in environments subject to water splashes, cation electroplating models are recommended. ø172 mm Sidecut type Model no. Surface treatment Mass (g) 109-319J Nickel-chrome plating (silver) Applicable model no. 9HV57*/9SG57*/9GV57* 9CR57*/9WG57* 65 Finger guard 109-319J should be mounted with four holes as in the drawing. Hexagonal nuts Inlet side, Outlet side +0.4 4.3 -0.2 ø1.6 Plain washers Spring washers 0 5.5 -1 Screws ø152 ø162 ø172 +0.5 -1 ø1.6 ø147 Finger guards Fan 55 .5° 71.3±1 71.3±1 ●No nuts or screws for use in attachment included. ø172 mm Sidecut, Round type Model no. Surface treatment Mass (g) 109-319E Nickel-chrome plating (silver) 69 109-319H Cation electropainting (black) Model no. Surface treatment Mass (g) 109-320 Nickel-chrome plating (silver) 53 Inlet side, Outlet side Outlet side 5 +0. 2 -1 ø17 ø162 ø1.6 ø1 +0.4 4.3 +0.4 -0.2 ø1.6 ø1.6 ø62.2 0 4.3 -0.2 ø1.6 9.5 -1 48 Finger guards 109-319E, 109-319H, and 109-320 should be mounted with two holes as in the drawing and do not use any other holes. Hexagonal nuts  0 3.2 -1 Finger guards Plain washers Spring washers ø152 Screws ø148 ø172 +0.5 -1 ø162 Fan ●No nuts or screws for use in attachment included. mm Round type Model no. Surface treatment Mass (g) 109-1066 Nickel-chrome plating (silver) 61 Model no. Surface treatment Mass (g) 109-1068 Nickel-chrome plating (silver) 54 Inlet side, Outlet side Outlet side ø162 -1 ø172 +0.5 ø1.6 +0.4 4.3 -0.2 ø1.6 0 9.5 -1 ø148 ø152 Option ø172 586 CATALOG No. C1111B002 '21.9.IT ø162 -1 ø172 +0.5 ø1.6 ø148 +0.4 4.3 -0.2 ø1.6 ø62.2 0 3.2 -1 Finger guards Dimensions (unit: mm) For use in environments subject to water splashes, cation electroplating models are recommended. mm type Model no. Surface treatment Mass (g) 109-1102 Nickel-chrome plating (silver) 100 109-1102H Cation electropainting (black) Applicable model no. Model no. Surface treatment Mass (g) 109-1103 Nickel-chrome plating (silver) 80 109-1103H Cation electropainting (black) 9GV20* Inlet side, Outlet side 0 89 214.1 -0.5 (196.3) B ø1.6 +0.4 ø1.6 +0 4.3 -0.2 3.2 -1 .8 ø2 .2) +1 (ø92 +1 ø1.6 1 00 8 +0 -1 ø1 9.5 ø20 +0 9.5 -1 A 8 ø20 .8 82 ø1 9 19 4.3 -0.2 ø1.6 9GV20* Outlet side +0.4 +1 -0.5 Applicable model no. 214.1 -0.5 ø200 B A ø200 断面AAAA Section 断面BB BB Section mm type Model no. Surface treatment Mass (g) 109-720 Nickel-chrome plating (silver) 84 109-720H Cation electropainting (black) Applicable model no. 109E20* 9EC20* Model no. Surface treatment Mass (g) 109-721 Nickel-chrome plating (silver) 66 109-721H Cation electropainting (black) Inlet side, Outlet side Outlet side ø18 78 ø1 0 8 -1 8.4 8.4 ø18 1 7 ø1 4.3 +0.4 -0.2 ø1.6 +1 -0.5 mm type Inlet side Inlet side A ø194.1 217.6±1 210.6±1.5 0 5.5-1 86 .9 B +1 250.8 - 0.5 A ø1.6 ø1 ±1 .4 19 4 5. 20 4.3±0.3 ø26.8 B ø1.6 ø1.6 ø213.3 ø1.6 ø1.6 .2 80 ø192 ø1 ø245 +0.4 4.3 - 0.2 ø1.6 Option Model no. Surface treatment Mass (g) 109-1137 Nickel-chrome plating (silver) 94 109-1137H Cation electropainting (black) 9± 1. 5 Model no. Surface treatment Mass (g) 109-1138 Nickel-chrome plating (silver) 105 109-1138H Cation electropainting (black) 6.8 3.2 -10 194.5 ø178 +1 194.5 -0.5 ø225 mm type ø2 4.3 +0.4 -0.2 ø1.6 ø1.6 ø1.6 ø221 Applicable model no. 109E20* 9EC20* 5±0.5 Section 断面 AAAA -1 3.2 +0 断面BBBB Section CATALOG No. C1111B002 '21.9.IT 587 Options Finger guards Dimensions (unit: mm) For use in environments subject to water splashes, cation electroplating models are recommended. 270 mm sq. type (for Bracket-mounted Centrifugal Fan) Finger guard 109-1146 and 109-1146H should be mounted with four holes as in the drawing. Model no. Surface treatment Mass (g) 109-1146 Nickel-chrome plating (silver) 106 109-1146H Cation electropainting (black) Inlet side 5.3±0.3 Finger guard ド フィンガーガー ø2 A Screws ネジ .9 86 ø1 19 4 .4 ±1 .7 .2 80 ø305 ø1 B ø1.6 ø1.6 ø26 311±1 ø194.1 .8 +0.5 3.6 -1 B +0 3.2 -1 Section BB 断面BB A Fan ファン 5±1 ●No nuts or screws for use in attachment included. Section AA 断面AA Mounting example Axial fan Centrifugal fan Hexagonal nuts Fan Finger guard Hexagonal nuts Plain washers Inlet nozzle Spring washers Finger guard Screws Plain washers Fan Chassis Option ●No nuts or screws for use in attachment included. 588 CATALOG No. C1111B002 '21.9.IT Spring washers Screws Inlet nozzle for centrifugal fan and splash proof centrifugal fan Dimensions (unit: mm) Nozzle mounted in fan inlet side to adjust the flow of introduced air. Material: Steel sheet For use in environments subject to water splashes, cation electroplating models are recommended. ø70 ø100 mm type Model no. 109-1106 Surface treatment Electro nickel plating (silver) Mass (g) 40 mm type Model no. 109-1080 109-1080H E等a )) 配ch .3 ø4 .5 ±0 5 0. 5± 4. Surface treatment Electro nickel plating (silver) Cation electropainting (black) Mass (g) mm type Model no. 109-1081 109-1081H 76 °( 1( °± 等 E等a (E 配 ) h)) 4- ø4 c 配 h) ac 4- 70 ±0.5 90 0.5 1( ° Mass (g) ø100 7±1 (1) .5 ø85± 13±1 (1) Surface treatment Electro nickel plating (silver) Cation electropainting (black) ø128±0 1 9± ø13 .5 ø118±0 1 9± ø12 °± ) 4.8 (R 4- ø 4- ø150 90 ±0.5 °( 1( ) ch .8) (R2 mm type Model no. 109-1069 109-1069H 80 °± 5 a (E ø133 Mass (g) ø70 ±0. 5±1 (1) 90 ±0.5 ø116.6 ±1 8 ø12 ø56 1° °± 90 0.5 ø87± 1 8± ø9 3±1 (1) Surface treatment Electro nickel plating (silver) Cation electropainting (black) 0. .5± ±0 6) (R ø4 .5 .5 5 100 Model no. 109-1135 109-1135H 5.5 ±0 45° .5 90 0.5 6± ±1 ø12 52 ø2 ø158±0.5 ±1 ø170 14±1 (1) 6-ø Surface treatment Electro nickel plating (silver) Cation electropainting (black) 6 0°± ( (E等 1° ac配 h)) 1 °± )) 配ch E等a °( ( 0.5 5± 4- 0.5 ø242± 0) .5 ø4 (R1 Mass (g) 230 5 Mass (g) ±0.5 4.3 4-ø 21±1 (0.8) 118±1 ) ±0 22 (R .5 Option ø24 ±1° ± 0. Surface treatment Electro nickel plating (silver) Cation electropainting (black) 5.2 Model no. 109-1073 109-1073H mm type ø15 ø221 mm type 90°±1( ° (Each) 等配) ø175 ø225 mm type Model no. 109-1134 109-1134H Surface treatment Electro nickel plating (silver) Cation electropainting (black) Mass (g) 360 ø14 ) ) c配h E等a °( 1( °± 0.5 6± 90 ø210±0.5 ±1 ø223 29.5±1 (1.5) .5± 4-4 ) 0.5 24 (R CATALOG No. C1111B002 '21.9.IT 589 Options EMC guards Dimensions (unit: mm) It is a metallic piece that protects materials from the adverse effects of electromagnetic noise sources. It provides electromagnetic shielding. It is attached to the casing of a device by means of the fan fixing screw (s). Ground the devices equipped with an EMC guard. Rust may occur if used in wet environments. Please refer to page 606 for detail. 80 mm sq. type 80 mm sq. type 92 mm sq. type Model no. Surface treatment Mass (g) 109-1038 Nickel-chrome plating (silver) 14 Model no. Surface treatment Mass (g) 109-1039 Nickel-chrome plating (silver) 10 Model no. Surface treatment Mass (g) 109-1040 Nickel-chrome plating (silver) 15 Representative fans model numbers Dimensions of fans (mm) Representative fans model numbers Dimensions of fans (mm) Representative fans model numbers Dimensions of fans (mm) 109P08* 9GV08* 9GV08* 9HV08* 9HVA08* 9HVB08* 80 × 80 × 20 80 × 80 × 25 109P08* 9GA08* 109R08* 9A08* 9GA08* 9GA08* 80 × 80 × 15 80 × 80 × 20 9G09* 9G09* 9GV09* 9GA09* 9AD09* 92 × 92 × 32 80 × 80 × 25 80 × 80 × 32 9G08* 9GA08* 5 80 × 80 × 38 +1 0 4.3 ±0.3 ø1.6 3 4.3 ±0.3 1 +1.5 +1.5 88 6.6 ø172 Model no. Surface treatment Mass (g) 109-1037 Nickel-chrome plating (silver) 26 Model no. Surface treatment Mass (g) 109-1036 Nickel-chrome plating (silver) 49 Dimensions of fans (mm) 9G12* 9GV12* 9GL12* 9G12* 9GV12* 9HV12* 9LG12* 9AD12* 120 × 120 × 25 120 × 120 × 38 5 +1 0 ø 172 × 25 +0.5 ø172-1 ø 172 × 51 +0 9.5-1 +0.4 4.3- 0.2 ø1.6 8 ø14 EMC guard 590 attached to a cooling fan CATALOG No. C1111B002 '21.9.IT ø152 ø7 7.2 ø5 130 152.5 ±0.5 2 Option ø1.6 Dimensions of fans (mm) 109E47* 109L17* 9GV57* 109E17* 109E57* 9SG57* ø162 4.3 ±0.3 mm type Representative fans model numbers +1 0 ø43 ø11 .2 1.2 ø101 ø10 120 mm sq. type Representative fans model numbers 5 ø1.6 ø3 105- 0.5 88 +1.5 +1 0 ø1.6 ø4 105- 0.5 5 120.5- 0.5 4.3 ±0.3 92 × 92 × 38 99 80 × 80 × 38 Resin finger guards Dimensions (unit: mm) Material Frame: Resin (PPE+PS) UL file no. E82268 94V-0 60 mm sq. type 80 mm sq. type Mass (g) 7 6.5±0.5 4-2±0.5 82±1 92 mm sq. type 7±0.5 4-2±0.5 4-ø4.3±0.3 120 mm sq. type Model no. 109-1001G Mass (g) 12 92±1 82.5±0.3 Mass (g) 23 119±1 104.8±0.3 4-ø4.3±0.3 7±0.5 4-ø4.3±0.3 4-2 ±0.5 119±1 104.8±0.3 7±0.5 4-2±0.5 Model no. 109-1000G 82.5±0.3 92±1 Mass (g) 10 82±1 71.5±0.3 4-ø4.3±0.3 50±0.3 60.5±1 60.5±1 50±0.3 Model no. 109-1002G 71.5±0.3 Model no. 109-1003G Airflow - Static pressure characteristics Mounting example Measured with our double chamber measuring device (120 mm sq. type) (Pa) 160 Fan unit (9G1212G101) Static pressure 140 120 Hexagonal nuts (4) 100 80 With resin finger guard 60 (109-1000G) equipped* Fan 40 20 1 2 3 Airflow 4 5 (m3/min) Applied voltage: 12 VDC * Finger guard is attached on air inlet side of fan. Chassis Option 0 Finger guard Small pan-head screws (4) ● Operating temperature limit is between -20 to +70˚C. (non condensing) ● Plastic finger guards are placed on both the intake and exhaust sides of the fan. ●No nuts or screws for use in attachment included. CATALOG No. C1111B002 '21.9.IT 591 Options Resin filter kits Dimensions (unit: mm) Material Guard, cover: Resin (PPE+PS) UL file no. E82268 94V-0 Filter: Polyurethane foam UL file no. E74916 (S) 94HF-1 PPI: Particles Per Inch Indicates the number of holes per inch. Note that the higher the number, the finer the grain of the sponge. 60 mm sq. type 80 mm sq. type Model no. 109-1003F13 (13 PPI) 109-1003F20 (20 PPI) 109-1003F30 (30 PPI) 109-1003F40 (40 PPI) Mass (g) Replacement filter model no. 109-1003M13 (13 PPI) 109-1003M20 (20 PPI) 109-1003M30 (30 PPI) 109-1003M40 (40 PPI) Quantity Replacement filter model no. 109-1002M13 (13 PPI) 109-1002M20 (20 PPI) 109-1002M30 (30 PPI) 109-1002M40 (40 PPI) Quantity 5 85.5±1 71.5±0.3 4-ø4.3±0.3 85.5±1 4-ø10±0.5 4-ø10±0.5 4-2±0.5 92 mm sq. type Model no. 109-1001F13 (13 PPI) 109-1001F20 (20 PPI) 109-1001F30 (30 PPI) 109-1001F40 (40 PPI) Mass (g) 10.5±0.5 4-ø4.3±0.3 4-2±0.5 Replacement filter model no. 109-1001M13 (13 PPI) 109-1001M20 (20 PPI) 109-1001M30 (30 PPI) 109-1001M40 (40 PPI) Quantity Model no. 109-1000F13 (13 PPI) 109-1000F20 (20 PPI) 109-1000F30 (30 PPI) 109-1000F40 (40 PPI) Mass (g) Replacement filter model no. 109-1000M13 (13 PPI) 109-1000M20 (20 PPI) 109-1000M30 (30 PPI) 109-1000M40 (40 PPI) Quantity 25 5 10.5±0.5 124±1 104.8±0.3 4-ø4.3±0.3 124±1 82.5±0.3 4-ø9.5±0.5 4-ø11±0.5 4-2±0.5 Airflow - Static pressure characteristics 44 5 10.5±0.5 4-ø4.3±0.3 104.8±0.3 96.5±1 Mounting example 4-2±0.5 Filter replacement (example) Measured with our double chamber measuring device (120 mm sq. type) (Pa) 160 Hexagonal nuts (4) Replacement filters can be replaced by taking off the front part of the filter kit. There is no need to remove the screws. Fan unit (9G1212G101) 140 Static pressure 5 120 mm sq. type 82.5±0.3 Option 19 71.5±0.3 9.5±0.5 50±0.3 64±1 Mass (g) 11 64±1 50±0.3 96.5±1 Model no. 109-1002F13 (13 PPI) 109-1002F20 (20 PPI) 109-1002F30 (30 PPI) 109-1002F40 (40 PPI) 120 With filter kit (109-1000F20) equipped* 100 With filter kit (109-1000F40) equipped* 80 60 Fan 40 20 0 Chassis 1 2 3 Airflow 4 5 (m3/min) Applied voltage: 12 VDC * Filter kit is attached on air inlet side of fan. Filter kits Small pan-head screws (4) Replacement filters ● Filter kit is one of the option to keep air in the chassis clean filtering dust in external atmosphere when pulling-air cooling is implemented. The filter kit is hooked up through mounting hole of fan frame with screw as well as finger guard. Some performances (airflow & static pressure) of the fan motor decreases when filter kit is hooked up. ● This Filter Kit is composed of 3 components, including a guard, a filter and a cover. It is delivered as a finished product at delivery, saving assembly time when mounting. It can be mounted by inserting a screw in the apertures of the cover. ● The filter and cover can be easily removed from the guard with one touch. There is no need for fan removal when undertaking maintenance. ● Operating temperature limit is between -10 to +60˚C. (non condensing) ● The filter will deteriorate with age, and the level of deterioration will vary upon usage conditions. Please be aware that the filter has a greater tendency to deteriorate under high temperature and humidity. For long-term storage, please store under the temperature range of 10 to 30˚C, humidity range of 20 to 65%. Usage and storage period is approximately 2 years. ● Cooling ability decreases with filter contamination due to clogging. Filter replacement is recommended approximately every six months of usage. Please replace the filter if deterioration or clogging is seen at inspection. ● When replacing the filter, please use genuine SANYO DENKI filters. ●Do not water-wash the filter. ● Avoid use and storage under high temperature or humidity, direct sunlight or exposure to ultraviolet light, or in corrosive gas. ●No nuts or screws for use in attachment included. 592 CATALOG No. C1111B002 '21.9.IT Index by Model No. - DC Fans List of models DC Index by Model No. Models listed in product pages 109BC12FC7-1 109BC12GC7-1 109BC12HC7-1 109BC12MC7-1 109BC24FC7-1 109BC24GC7-1 109BC24HC7-1 109BD12FC2 109BD12HC2 109BD12MC2 109BD24FC2 109BD24HC2 109BD24MC2 109BG12HC1 109BG12MC1 109BG24HC1 109BG24MC1 109BJ12HC2 109BJ12MC2 109BJ24HC2 109BJ24MC2 109BM12GC2-1 109BM12HC2-1 109BM12MC2-1 109BM24GC2-1 109BM24HC2-1 109BM24MC2-1 109E1312A101 109E1312S101 109E1324A101 109E1324G101 109E1324S101 109E1348A101 109E1348G101 109E1348S101 109E1712F501 109E1712H501 109E1712K501 109E1712M501 109E1712Y501 109E1724C501 109E1724F501 109E1724H501 109E1724K501 109E1724M501 109E1748C501 109E1748F501 109E1748H501 109E1748K501 109E1748M501 109E4712L401 109E4712M401 109E4724F401 109E4724H401 109E4724L401 109E4724M401 109E4748F401 109E4748H401 109E4748L401 109E4748M401 109E4748S401 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Without sensor With pulse sensor With lock sensor 109BC12FA7-1 109BC12GA7-1 109BC12HA7-1 109BC12MA7-1 109BC24FA7-1 109BC24GA7-1 109BC24HA7-1 109BD12FA2 109BD12HA2 109BD12MA2 109BD24FA2 109BD24HA2 109BD24MA2 109BG12HA1 109BG12MA1 109BG24HA1 109BG24MA1 109BJ12HA2 109BJ12MA2 109BJ24HA2 109BJ24MA2 109BM12GA2-1 109BM12HA2-1 109BM12MA2-1 109BM24GA2-1 109BM24HA2-1 109BM24MA2-1 109E1312A102 109E1312S102 109E1324A102 109E1324G102 109E1324S102 109E1348A102 109E1348G102 109E1348S102 109E1712F502 109E1712H502 109E1712K502 109E1712M502 109E1712Y502 109E1724C502 109E1724F502 109E1724H502 109E1724K502 109E1724M502 109E1748C502 109E1748F502 109E1748H502 109E1748K502 109E1748M502 109E4712L402 109E4712M402 109E4724F402 109E4724H402 109E4724L402 109E4724M402 109E4748F402 109E4748H402 109E4748L402 109E4748M402 109E4748S402 109BC12FC7-1 109BC12GC7-1 109BC12HC7-1 109BC12MC7-1 109BC24FC7-1 109BC24GC7-1 109BC24HC7-1 109BD12FC2 109BD12HC2 109BD12MC2 109BD24FC2 109BD24HC2 109BD24MC2 109BG12HC1 109BG12MC1 109BG24HC1 109BG24MC1 109BJ12HC2 109BJ12MC2 109BJ24HC2 109BJ24MC2 109BM12GC2-1 109BM12HC2-1 109BM12MC2-1 109BM24GC2-1 109BM24HC2-1 109BM24MC2-1 109E1312A101 109E1312S101 109E1324A101 109E1324G101 109E1324S101 109E1348A101 109E1348G101 109E1348S101 109E1712F501 109E1712H501 109E1712K501 109E1712M501 109E1712Y501 109E1724C501 109E1724F501 109E1724H501 109E1724K501 109E1724M501 109E1748C501 109E1748F501 109E1748H501 109E1748K501 109E1748M501 109E4712L401 109E4712M401 109E4724F401 109E4724H401 109E4724L401 109E4724M401 109E4748F401 109E4748H401 109E4748L401 109E4748M401 109E4748S401 109BC12FD7-1 109BC12GD7-1 109BC12HD7-1 109BC12MD7-1 109BC24FD7-1 109BC24GD7-1 109BC24HD7-1 109BD12FD2 109BD12HD2 109BD12MD2 109BD24FD2 109BD24HD2 109BD24MD2 109BG12HD1 109BG12MD1 109BG24HD1 109BG24MD1 109BJ12HD2 109BJ12MD2 109BJ24HD2 109BJ24MD2 109BM12GD2-1 109BM12HD2-1 109BM12MD2-1 109BM24GD2-1 109BM24HD2-1 109BM24MD2-1 109E1312A1D01 109E1312S1D01 109E1324A1D01 109E1324G1D01 109E1324S1D01 109E1348A1D01 109E1348G1D01 109E1348S1D01 109E1712F5D01 109E1712H5D01 - - - 109E1724C5D01 109E1724F5D01 109E1724H5D01 109E1724K5D01 109E1724M5D01 - - 109E1748H5D01 - - 109E4712L4D01 109E4712M4D01 109E4724F4D01 109E4724H4D01 109E4724L4D01 109E4724M4D01 109E4748F4D01 109E4748H4D01 109E4748L4D01 109E4748M4D01 109E4748S4D01 Frame size Rib page 52 × 15 mm 52 × 15 mm 52 × 15 mm 52 × 15 mm 52 × 15 mm 52 × 15 mm 52 × 15 mm 76 × 30 mm 76 × 30 mm 76 × 30 mm 76 × 30 mm 76 × 30 mm 76 × 30 mm 160 × 40 mm 160 × 40 mm 160 × 40 mm 160 × 40 mm 127 × 32 mm 127 × 32 mm 127 × 32 mm 127 × 32 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm ø 172 × 147 × 25 mm - - - - - - - - - - - - - - - - - - - - - - - - - - - 492 492 492 492 492 492 492 496 496 496 496 496 496 512 512 512 512 510 510 510 510 506 506 506 506 506 506 189 189 189 189 189 189 189 189 215 215 215 215 215 215 215 215 215 215 215 215 215 215 215 202 202 202 202 202 202 202 202 202 202 202 With PWM control function and pulse sensor - - - - - - - - 109BD12P2H01 - - - - - - - - - - - - - - 109BM12P2M01 - - - - - - - - - - - - - - - - 9EH1724P5C01 - - - - - - - 109E1748P5K03 - - - - 109E4724P4H01 - - - - - - - Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 620 CATALOG No. C1111B002 '21.9.IT No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No List of models Without sensor With pulse sensor With lock sensor 109E5712F502 109E5712H502 109E5712K502 109E5712M502 109E5712Y502 109E5724C502 109E5724F502 109E5724H502 109E5724K502 109E5724M502 109E5748C502 109E5748F502 109E5748H502 109E5748K502 109E5748M502 109L1712H502 109L1712M502 109L1724H502 109L1724M502 109L1748H502 109L1748M502 109L5712H502 109L5712M502 109L5724H502 109L5724M502 109L5748H502 109L5748M502 109P0405F3023 109P0405F602 109P0405H3023 109P0405H602 109P0405H702 109P0405H902 109P0405J602 109P0405M602 109P0405M702 109P0405M902 109P0412B3023 109P0412D602 109P0412E602 109P0412F3023 109P0412F602 109P0412G3023 109P0412G602 109P0412H3023 109P0412H602 109P0412H702 109P0412H902 109P0412J3023 109P0412K3023 109P0412M3023 109P0412M602 109P0412M702 109P0412M902 109P0412R702 109P0412S702 109P0424B3023 109P0424B602 109P0424D602 109P0424F3023 109P0424F602 109E5712F501 109E5712H501 109E5712K501 109E5712M501 109E5712Y501 109E5724C501 109E5724F501 109E5724H501 109E5724K501 109E5724M501 109E5748C501 109E5748F501 109E5748H501 109E5748K501 109E5748M501 109L1712H501 109L1712M501 109L1724H501 109L1724M501 109L1748H501 109L1748M501 109L5712H501 109L5712M501 109L5724H501 109L5724M501 109L5748H501 109L5748M501 109P0405F3013 109P0405F601 109P0405H3013 109P0405H601 109P0405H701 109P0405H901 109P0405J601 109P0405M601 109P0405M701 109P0405M901 109P0412B3013 109P0412D601 109P0412E601 109P0412F3013 109P0412F601 109P0412G3013 109P0412G601 109P0412H3013 109P0412H601 109P0412H701 109P0412H901 109P0412J3013 109P0412K3013 109P0412M3013 109P0412M601 109P0412M701 109P0412M901 109P0412R701 109P0412S701 109P0424B3013 109P0424B601 109P0424D601 109P0424F3013 109P0424F601 - 109E5712H5D01 109E5712K5D01 109E5712M5D01 - 109E5724C5D01 - 109E5724H5D01 109E5724K5D01 - - - 109E5748H5D01 - - 109L1712H5D01 109L1712M5D01 109L1724H5D01 109L1724M5D01 109L1748H5D01 109L1748M5D01 109L5712H5D01 109L5712M5D01 109L5724H5D01 109L5724M5D01 109L5748H5D01 109L5748M5D01 109P0405F3D013 109P0405F6D01 109P0405H3D013 109P0405H6D01 109P0405H7D01 109P0405H9D01 - 109P0405M6D01 109P0405M7D01 109P0405M9D01 109P0412B3D013 109P0412D6D01 109P0412E6D01 109P0412F3D013 109P0412F6D01 109P0412G3D013 109P0412G6D01 109P0412H3D013 109P0412H6D01 109P0412H7D01 109P0412H9D01 109P0412J3D013 109P0412K3D013 109P0412M3D013 109P0412M6D01 109P0412M7D01 109P0412M9D01 109P0412R7D01 109P0412S7D01 109P0424B3D013 109P0424B6D01 109P0424D6D01 109P0424F3D013 109P0424F6D01 Frame size Rib page ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm No No No No No No No No No No No No No No No No No No No No No No No No No No No Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes 212 212 212 212 212 212 212 212 212 212 212 212 212 212 212 440 440 440 440 440 440 438 438 438 438 438 438 53 34 53 34 27 23 34 34 27 23 53 34 34 53 34 53 34 53 34 27 23 53 53 53 34 27 23 27 27 53 34 34 53 34 With PWM control function and pulse sensor - - 109E5712P5K04 - - 9EH5724P5C01 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 109P0412P3B013 - - - - - - 109P0412P3H013 - - 109P0412P9H01 9PH0412P3J013 9PH0412P3K033 - - - - - - - - - - - 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 15 mm 40 × 40 × 10 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 15 mm 40 × 40 × 10 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 15 mm 40 × 40 × 10 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 15 mm 40 × 40 × 10 mm 40 × 40 × 15 mm 40 × 40 × 15 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 28 mm 40 × 40 × 20 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 621 Index by Model No. 109E5712F501 109E5712H501 109E5712K501 109E5712M501 109E5712Y501 109E5724C501 109E5724F501 109E5724H501 109E5724K501 109E5724M501 109E5748C501 109E5748F501 109E5748H501 109E5748K501 109E5748M501 109L1712H501 109L1712M501 109L1724H501 109L1724M501 109L1748H501 109L1748M501 109L5712H501 109L5712M501 109L5724H501 109L5724M501 109L5748H501 109L5748M501 109P0405F3013 109P0405F601 109P0405H3013 109P0405H601 109P0405H701 109P0405H901 109P0405J601 109P0405M601 109P0405M701 109P0405M901 109P0412B3013 109P0412D601 109P0412E601 109P0412F3013 109P0412F601 109P0412G3013 109P0412G601 109P0412H3013 109P0412H601 109P0412H701 109P0412H901 109P0412J3013 109P0412K3013 109P0412M3013 109P0412M601 109P0412M701 109P0412M901 109P0412R701 109P0412S701 109P0424B3013 109P0424B601 109P0424D601 109P0424F3013 109P0424F601 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Models listed in product pages List of models DC Index by Model No. Models listed in product pages 109P0424G3013 109P0424G601 109P0424H3013 109P0424H601 109P0424H901 109P0424H701 109P0424J3013 109P0424R3013 109P0505M701 109P0812C601 109P0812H601 109P0812H701 109P0812M601 109P0812M701 109P0824H601 109P0824H701 109P0824M601 109P0824M701 109P0848C601 109P0848H601 109P1312H101 109P1312H1011 109P1312S101 109P1312S1011 109P1324H101 109P1324H1011 109P1324S101 109P1324S1011 109P1348H101 109P1348H1011 109P1348S101 109P1348S1011 109P1412H101 109P1412M101 109P1424H101 109P1424M101 109P1448H101 109P1448M101 109R0605F401 109R0605F4011 109R0605H401 109R0605H4011 109R0605M401 109R0605M4011 109R0612D401 109R0612D4011 109R0612F401 109R0612F4011 109R0612G401 109R0612G4011 109R0612H401 109R0612H4011 109R0612J401 109R0612J4011 109R0612M401 109R0612M4011 109R0612S401 109R0612S4011 109R0624D401 109R0624D4011 109R0624F401 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Without sensor With pulse sensor With lock sensor 109P0424G3023 109P0424G602 109P0424H3023 109P0424H602 109P0424H902 109P0424H702 109P0424J3023 109P0424R3023 109P0505M702 109P0812C602 109P0812H602 109P0812H702 109P0812M602 109P0812M702 109P0824H602 109P0824H702 109P0824M602 109P0824M702 109P0848C602 - 109P1312H102 109P1312H1021 109P1312S102 109P1312S1021 109P1324H102 109P1324H1021 109P1324S102 109P1324S1021 109P1348H102 109P1348H1021 109P1348S102 109P1348S1021 109P1412H102 109P1412M102 109P1424H102 109P1424M102 109P1448H102 109P1448M102 109R0605F402 109R0605F4021 109R0605H402 109R0605H4021 109R0605M402 109R0605M4021 109R0612D402 109R0612D4021 109R0612F402 109R0612F4021 109R0612G402 109R0612G4021 109R0612H402 109R0612H4021 109R0612J402 109R0612J4021 109R0612M402 109R0612M4021 109R0612S402 109R0612S4021 109R0624D402 109R0624D4021 109R0624F402 109P0424G3013 109P0424G601 109P0424H3013 109P0424H601 109P0424H901 109P0424H701 109P0424J3013 109P0424R3013 109P0505M701 109P0812C601 109P0812H601 109P0812H701 109P0812M601 109P0812M701 109P0824H601 109P0824H701 109P0824M601 109P0824M701 109P0848C601 109P0848H601 109P1312H101 109P1312H1011 109P1312S101 109P1312S1011 109P1324H101 109P1324H1011 109P1324S101 109P1324S1011 109P1348H101 109P1348H1011 109P1348S101 109P1348S1011 109P1412H101 109P1412M101 109P1424H101 109P1424M101 109P1448H101 109P1448M101 109R0605F401 109R0605F4011 109R0605H401 109R0605H4011 109R0605M401 109R0605M4011 109R0612D401 109R0612D4011 109R0612F401 109R0612F4011 109R0612G401 109R0612G4011 109R0612H401 109R0612H4011 109R0612J401 109R0612J4011 109R0612M401 109R0612M4011 109R0612S401 109R0612S4011 109R0624D401 109R0624D4011 109R0624F401 109P0424G3D013 109P0424G6D01 109P0424H3D013 109P0424H6D01 109P0424H9D01 109P0424H7D01 109P0424J3D013 - 109P0505M7D01 109P0812C6D01 109P0812H6D01 109P0812H7D01 109P0812M6D01 109P0812M7D01 109P0824H6D01 109P0824H7D01 109P0824M6D01 109P0824M7D01 109P0848C6D01 109P0848H6D01 109P1312H1D01 109P1312H1D011 109P1312S1D01 109P1312S1D011 109P1324H1D01 109P1324H1D011 109P1324S1D01 109P1324S1D011 109P1348H1D01 109P1348H1D011 109P1348S1D01 109P1348S1D011 109P1412H1D01 - 109P1424H1D01 - - - 109R0605F4D01 - 109R0605H4D01 - 109R0605M4D01 - 109R0612D4D01 109R0612D4D011 109R0612F4D01 109R0612F4D011 109R0612G4D01 109R0612G4D011 109R0612H4D01 109R0612H4D011 109R0612J4D01 109R0612J4D011 109R0612M4D01 109R0612M4D011 109R0612S4D01 109R0612S4D011 109R0624D4D01 - 109R0624F4D01 Frame size - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 109R0612P4J03 109R0612P4J061 - - - - - - - 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 10 mm 40 × 40 × 15 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 52 × 52 × 15 mm 80 × 80 × 20 mm 80 × 80 × 20 mm 80 × 80 × 15 mm 80 × 80 × 20 mm 80 × 80 × 15 mm 80 × 80 × 20 mm 80 × 80 × 15 mm 80 × 80 × 20 mm 80 × 80 × 15 mm 80 × 80 × 20 mm 80 × 80 × 20 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 127 × 127 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 622 CATALOG No. C1111B002 '21.9.IT Rib page Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes No Yes No Yes No Yes No Yes No Yes No Yes Yes Yes Yes Yes Yes Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes 53 34 53 34 23 27 53 53 60 101 101 96 101 96 101 96 101 96 101 101 192 192 192 192 192 192 192 192 192 192 192 192 198 198 198 198 198 198 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 With PWM control function and pulse sensor List of models Without sensor With pulse sensor With lock sensor 109R0624F4021 109R0624G402 109R0624G4021 109R0624H402 109R0624H4021 109R0624J402 109R0624J4021 109R0624M402 109R0624M4021 109R0624S402 109R0624S4021 109R0648G402 109R0648G4021 109R0648H402 109R0648H4021 109R0648J402 109R0648J4021 109R0805F402 109R0805F4021 109R0805M402 109R0805M4021 109R0812E402 - 109R0812F402 109R0812F4021 109R0812G402 109R0812G4021 109R0812H402 109R0812H4021 109R0812L402 109R0812L4021 109R0812M402 109R0812M4021 109R0812S402 109R0812S4021 109R0824F402 109R0824F4021 109R0824G402 109R0824G4021 109R0824H402 109R0824H4021 109R0824L402 109R0824L4021 109R0824M402 109R0824M4021 109R0824S402 109R0824S4021 109R0848K402 109R0848K4021 109R0848S402 109R0848S4021 9A0612F402 9A0612F4021 9A0612G402 9A0612G4021 9A0612H402 9A0612H4021 9A0612M402 9A0612M4021 9A0612S402 9A0612S4021 109R0624F4011 109R0624G401 109R0624G4011 109R0624H401 109R0624H4011 109R0624J401 109R0624J4011 109R0624M401 109R0624M4011 109R0624S401 109R0624S4011 109R0648G401 109R0648G4011 109R0648H401 109R0648H4011 109R0648J401 109R0648J4011 109R0805F401 109R0805F4011 109R0805M401 109R0805M4011 109R0812E401 109R0812E4011 109R0812F401 109R0812F4011 109R0812G401 109R0812G4011 109R0812H401 109R0812H4011 109R0812L401 109R0812L4011 109R0812M401 109R0812M4011 109R0812S401 109R0812S4011 109R0824F401 109R0824F4011 109R0824G401 109R0824G4011 109R0824H401 109R0824H4011 109R0824L401 109R0824L4011 109R0824M401 109R0824M4011 109R0824S401 109R0824S4011 109R0848K401 109R0848K4011 109R0848S401 109R0848S4011 9A0612F401 9A0612F4011 9A0612G401 9A0612G4011 9A0612H401 9A0612H4011 9A0612M401 9A0612M4011 9A0612S401 9A0612S4011 109R0624F4D011 109R0624G4D01 109R0624G4D011 109R0624H4D01 109R0624H4D011 109R0624J4D01 109R0624J4D011 109R0624M4D01 109R0624M4D011 109R0624S4D01 109R0624S4D011 109R0648G4D01 109R0648G4D011 109R0648H4D01 109R0648H4D011 109R0648J4D01 - 109R0805F4D01 - 109R0805M4D01 - - - 109R0812F4D01 109R0812F4D011 109R0812G4D01 109R0812G4D011 109R0812H4D01 109R0812H4D011 109R0812L4D01 109R0812L4D011 109R0812M4D01 109R0812M4D011 109R0812S4D01 109R0812S4D011 109R0824F4D01 109R0824F4D011 109R0824G4D01 109R0824G4D011 109R0824H4D01 109R0824H4D011 109R0824L4D01 109R0824L4D011 109R0824M4D01 109R0824M4D011 109R0824S4D01 109R0824S4D011 109R0848K4D01 109R0848K4D011 109R0848S4D01 109R0848S4D011 9A0612F4D01 9A0612F4D011 9A0612G4D01 9A0612G4D011 9A0612H4D01 9A0612H4D011 9A0612M4D01 9A0612M4D011 9A0612S4D01 9A0612S4D011 Frame size Rib page 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 74 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 109 80 80 80 80 80 80 80 80 80 80 With PWM control function and pulse sensor - - - - - 9RH0624P4J01 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 9AH0612P4G03 - 9AH0612P4H05 - - - - 9AH0612P4S011 Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 623 Index by Model No. 109R0624F4011 109R0624G401 109R0624G4011 109R0624H401 109R0624H4011 109R0624J401 109R0624J4011 109R0624M401 109R0624M4011 109R0624S401 109R0624S4011 109R0648G401 109R0648G4011 109R0648H401 109R0648H4011 109R0648J401 109R0648J4011 109R0805F401 109R0805F4011 109R0805M401 109R0805M4011 109R0812E401 109R0812E4011 109R0812F401 109R0812F4011 109R0812G401 109R0812G4011 109R0812H401 109R0812H4011 109R0812L401 109R0812L4011 109R0812M401 109R0812M4011 109R0812S401 109R0812S4011 109R0824F401 109R0824F4011 109R0824G401 109R0824G4011 109R0824H401 109R0824H4011 109R0824L401 109R0824L4011 109R0824M401 109R0824M4011 109R0824S401 109R0824S4011 109R0848K401 109R0848K4011 109R0848S401 109R0848S4011 9A0612F401 9A0612F4011 9A0612G401 9A0612G4011 9A0612H401 9A0612H4011 9A0612M401 9A0612M4011 9A0612S401 9A0612S4011 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Models listed in product pages List of models Models listed in product pages (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Index by Model No. Without sensor 9A0624F401 9A0624F4011 9A0624G401 9A0624G4011 9A0624H401 9A0624H4011 9A0624M401 9A0624M4011 9A0624S401 9A0624S4011 9A0812F401 9A0812F4011 9A0812G401 9A0812G4011 9A0812H401 9A0812H4011 9A0812L401 9A0812L4011 9A0812M401 9A0812M4011 9A0812S401 9A0812S4011 9A0824F401 9A0824F4011 9A0824G401 9A0824G4011 9A0824H401 9A0824H4011 9A0824L401 9A0824L4011 9A0824M401 9A0824M4011 9A0824S401 9A0824S4011 9A0912F401 9A0912F4011 9A0912G401 9A0912G4011 9A0912H401 9A0912H4011 9A0912L401 9A0912L4011 9A0912M401 9A0912M4011 9A0912S401 9A0912S4011 9A0924F401 9A0924F4011 9A0924G401 9A0924G4011 9A0924H401 9A0924H4011 9A0924L401 9A0924L4011 9A0924M401 9A0924M4011 9A0924S401 9A0924S4011 9A0948S401 9A0948S4011 9B1TP24P0H001 9A0624F402 9A0624F4021 9A0624G402 9A0624G4021 9A0624H402 9A0624H4021 9A0624M402 9A0624M4021 9A0624S402 9A0624S4021 9A0812F402 9A0812F4021 9A0812G402 9A0812G4021 9A0812H402 9A0812H4021 9A0812L402 9A0812L4021 9A0812M402 9A0812M4021 9A0812S402 9A0812S4021 9A0824F402 9A0824F4021 9A0824G402 9A0824G4021 9A0824H402 9A0824H4021 9A0824L402 9A0824L4021 9A0824M402 9A0824M4021 9A0824S402 9A0824S4021 9A0912F402 9A0912F4021 9A0912G402 9A0912G4021 9A0912H402 9A0912H4021 9A0912L402 9A0912L4021 9A0912M402 9A0912M4021 9A0912S402 9A0912S4021 9A0924F402 9A0924F4021 9A0924G402 9A0924G4021 9A0924H402 9A0924H4021 9A0924L402 9A0924L4021 9A0924M402 9A0924M4021 9A0924S402 9A0924S4021 9A0948S402 9A0948S4021 - With pulse sensor With lock sensor 9A0624F401 9A0624F4011 9A0624G401 9A0624G4011 9A0624H401 9A0624H4011 9A0624M401 9A0624M4011 9A0624S401 9A0624S4011 9A0812F401 9A0812F4011 9A0812G401 9A0812G4011 9A0812H401 9A0812H4011 9A0812L401 9A0812L4011 9A0812M401 9A0812M4011 9A0812S401 9A0812S4011 9A0824F401 9A0824F4011 9A0824G401 9A0824G4011 9A0824H401 9A0824H4011 9A0824L401 9A0824L4011 9A0824M401 9A0824M4011 9A0824S401 9A0824S4011 9A0912F401 9A0912F4011 9A0912G401 9A0912G4011 9A0912H401 9A0912H4011 9A0912L401 9A0912L4011 9A0912M401 9A0912M4011 9A0912S401 9A0912S4011 9A0924F401 9A0924F4011 9A0924G401 9A0924G4011 9A0924H401 9A0924H4011 9A0924L401 9A0924L4011 9A0924M401 9A0924M4011 9A0924S401 9A0924S4011 9A0948S401 9A0948S4011 - 9A0624F4D01 9A0624F4D011 9A0624G4D01 - 9A0624H4D01 9A0624H4D011 9A0624M4D01 9A0624M4D011 9A0624S4D01 9A0624S4D011 9A0812F4D01 9A0812F4D011 9A0812G4D01 9A0812G4D011 9A0812H4D01 9A0812H4D011 9A0812L4D01 9A0812L4D011 9A0812M4D01 9A0812M4D011 9A0812S4D01 9A0812S4D011 9A0824F4D01 9A0824F4D011 9A0824G4D01 9A0824G4D011 9A0824H4D01 9A0824H4D011 9A0824L4D01 9A0824L4D011 9A0824M4D01 9A0824M4D011 9A0824S4D01 9A0824S4D011 9A0912F4D01 9A0912F4D011 9A0912G4D01 9A0912G4D011 9A0912H4D01 9A0912H4D011 9A0912L4D01 9A0912L4D011 9A0912M4D01 9A0912M4D011 9A0912S4D01 9A0912S4D011 9A0924F4D01 9A0924F4D011 9A0924G4D01 - 9A0924H4D01 9A0924H4D011 9A0924L4D01 9A0924L4D011 9A0924M4D01 9A0924M4D011 9A0924S4D01 9A0924S4D011 9A0948S4D01 - - Frame size - - - - - - - - - - - - 9AH0812P4G04 9AH0812P4G011 9AH0812P4H04 - - - - - - - - - - - - - - - - - - - - - 9AH0912P4G03 - 9AH0912P4H03 - - - - - - - - - - - - - - - - - - - - - 9B1TP24P0H001 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 270 × 270 × 99 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 624 CATALOG No. C1111B002 '21.9.IT Rib page Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No - 80 80 80 80 80 80 80 80 80 80 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 114 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 147 485 With PWM control function and pulse sensor List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) 9B1TP48P0G001 9B1TP48P0H001 9B1TS48P0G001 9B1TS48P0H001 9B1W2TP24P0H001 9B1W2TP48P0S001 9B1W2TS48P0S001 9BD12FC6-1 9BD12HC6-1 9BD12SC6-1 9BD24FC6-1 9BD24HC6-1 9BD24SC6-1 9BFB12P2H003 9BFB24P2H003 9BMB12F201 9BMB12G201 9BMB12H201 9BMB12K201 9BMB12P2F01 9BMB12P2G01 9BMB12P2H01 9BMB12P2K01 9BMB12P2S01 9BMB12S201 9BMB24F201 9BMB24G201 9BMB24H201 9BMB24K201 9BMB24P2F01 9BMB24P2G01 9BMB24P2H01 9BMB24P2K01 9BMB24P2S01 9BMB24S201 9BMC12P2G001 9BMC24P2G001 9CR0612P5G03 9CR0612P5H03 9CR1212P0G03 9CR5748P9G001 9CRA0312P4J03 9CRA0312P4K03 9CRA0412P4G03 9CRA0412P4J03 9CRA0412P4K03 9CRA0612P0G001 9CRA0612P0S001 9CRA0612P6G001 9CRA0612P6J001 9CRA0612P6K001 9CRA0812P8G001 9CRA0824P8G001 9CRA0848P8G001 9CRA0912P0G001 9CRA0948P0G601 9CRB0812P8G001 9CRD0412P5G03 9CRD0412P5H03 9CRD0412P5J03 9CRD0412P5M03 With pulse sensor With lock sensor - - - - - - - - - - - - - - - - - - - - - 9BD12FA6-1 9BD12HA6-1 9BD12SA6-1 9BD24FA6-1 9BD24HA6-1 9BD24SA6-1 - - 9BMB12F202 9BMB12G202 9BMB12H202 9BMB12K202 9BMB12F202 9BMB12G202 9BMB12H202 9BMB12K202 9BMB12S202 9BMB12S202 9BMB24F202 9BMB24G202 9BMB24H202 9BMB24K202 9BMB24F202 9BMB24G202 9BMB24H202 9BMB24K202 9BMB24S202 9BMB24S202 9BMC12G2002 - 9CR0612G502 - 9CR1212G002 - - 9CRA0312K402 9CRA0412G402 9CRA0412J402 9CRA0412K402 - - - - - - - - - - - - - - - 9BD12FC6-1 9BD12HC6-1 9BD12SC6-1 9BD24FC6-1 9BD24HC6-1 9BD24SC6-1 - - 9BMB12F201 9BMB12G201 9BMB12H201 9BMB12K201 9BMB12F201 9BMB12G201 9BMB12H201 9BMB12K201 9BMB12S201 9BMB12S201 9BMB24F201 9BMB24G201 9BMB24H201 9BMB24K201 9BMB24F201 9BMB24G201 9BMB24H201 9BMB24K201 9BMB24S201 9BMB24S201 - - 9CR0612G501 9CR0612H501 9CR1212G001 - 9CRA0312J401 - - 9CRA0412J401 9CRA0412K401 - - - - - 9CRA0812G8001 - - - - - - - - - 9BD12FD6-1 9BD12HD6-1 9BD12SD6-1 9BD24FD6-1 9BD24HD6-1 9BD24SD6-1 - 9BFB24H2D001 9BMB12F2D01 9BMB12G2D01 9BMB12H2D01 - 9BMB12F2D01 9BMB12G2D01 9BMB12H2D01 - - - 9BMB24F2D01 9BMB24G2D01 9BMB24H2D01 9BMB24K2D01 9BMB24F2D01 9BMB24G2D01 9BMB24H2D01 - - - - - - - - - - - - - - - - - - - - 9CRA0824G8D001 - - - - - - - - Frame size Rib page 270 × 270 × 99 mm 270 × 270 × 99 mm 270 × 270 × 119 mm 270 × 270 × 119 mm 270 × 270 × 99 mm 270 × 270 × 99 mm 270 × 270 × 119 mm 76 × 20 mm 76 × 20 mm 76 × 20 mm 76 × 20 mm 76 × 20 mm 76 × 20 mm 120 × 32 mm 120 × 32 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 97 × 33 mm 60 × 60 × 51 mm 60 × 60 × 51 mm 120 × 120 × 76 mm ø 172 × 150 × 102 mm 38 × 38 × 48 mm 38 × 38 × 48 mm 40 × 40 × 48 mm 40 × 40 × 48 mm 40 × 40 × 48 mm 60 × 60 × 76 mm 60 × 60 × 76 mm 60 × 60 × 56 mm 60 × 60 × 56 mm 60 × 60 × 56 mm 80 × 80 × 80 mm 80 × 80 × 80 mm 80 × 80 × 80 mm 92 × 92 × 76 mm 92 × 92 × 76 mm 80 × 80 × 80 mm 40 × 40 × 56 mm 40 × 40 × 56 mm 40 × 40 × 56 mm 40 × 40 × 56 mm - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 485 485 488 488 353 353 356 494 494 494 494 494 494 508 508 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 498 498 240 240 258 260 224 224 226 226 226 247 247 242 242 242 253 253 253 256 256 249 235 235 235 235 With PWM control function and pulse sensor 9B1TP48P0G001 9B1TP48P0H001 9B1TS48P0G001 9B1TS48P0H001 9B1W2TP24P0H001 9B1W2TP48P0S001 9B1W2TS48P0S001 - - 9BD12P6S01 - - 9BD24P6S06 9BFB12P2H003 9BFB24P2H003 9BMB12P2F01 9BMB12P2G01 9BMB12P2H01 9BMB12P2K01 9BMB12P2F01 9BMB12P2G01 9BMB12P2H01 9BMB12P2K01 9BMB12P2S01 9BMB12P2S01 9BMB24P2F01 9BMB24P2G01 9BMB24P2H01 9BMB24P2K01 9BMB24P2F01 9BMB24P2G01 9BMB24P2H01 9BMB24P2K01 9BMB24P2S01 9BMB24P2S01 9BMC12P2G001 9BMC24P2G001 9CR0612P5G03 9CR0612P5H03 9CR1212P0G03 9CR5748P9G001 9CRA0312P4J03 9CRA0312P4K03 9CRA0412P4G03 9CRA0412P4J03 9CRA0412P4K03 9CRA0612P0G001 9CRA0612P0S001 9CRA0612P6G001 9CRA0612P6J001 9CRA0612P6K001 9CRA0812P8G001 9CRA0824P8G001 9CRA0848P8G001 9CRA0912P0G001 9CRA0948P0G601 9CRB0812P8G001 9CRD0412P5G03 9CRD0412P5H03 9CRD0412P5J03 9CRD0412P5M03 Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 625 Index by Model No. Without sensor DC Models listed in product pages List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Models listed in product pages DC Index by Model No. Without sensor 9CRE0412P5J03 9CRE0612P0G001 9CRE0812P8G001 9CRH0412P5J001 9CRJ0412P5J001 9CRL0612P0G001 9CRL0812P8G001 9CRLA0612P0G001 9CRV0412P5J201 9EC2024H001 9EC2048A001 9EC2048H001 9EC2048J001 9G0612P4H001 9G0612P4H0011 9G0612P4S001 9G0612P4S0011 9G0624P4F001 9G0624P4F0011 9G0624P4H001 9G0624P4H0011 9G0624P4S001 9G0624P4S0011 9G0648P4S001 9G0648P4S0011 9G0812G101 9G0812G1011 9G0812H101 9G0812H1011 9G0812K101 9G0812K1011 9G0824G101 9G0824G1011 9G0824H101 9G0824H1011 9G0848G101 9G0848G1011 9G0848H101 9G0848H1011 9G0912A201 9G0912A2011 9G0912G101 9G0912G1011 9G0912H101 9G0912H1011 9G0912H201 9G0912H2011 9G0912M201 9G0912M2011 9G0912S201 9G0912S2011 9G0924A201 9G0924A2011 9G0924G101 9G0924G1011 9G0924H101 9G0924H1011 9G0924H201 9G0924H2011 9G0924M201 9G0924M2011 With pulse sensor With lock sensor 9CRE0412J502 - - - - - - - - - - - - - - - - - - - - - - - 9EC2024H002 9EC2048A002 9EC2048H002 9EC2048J002 9G0612H4002 9G0612H40021 9G0612S4002 9G0612S40021 9G0624F4002 - 9G0624H4002 9G0624H40021 9G0624S4002 9G0624S40021 9G0648S4002 - 9G0812G102 9G0812G1021 9G0812H102 9G0812H1021 9G0812K102 9G0812K1021 9G0824G102 9G0824G1021 9G0824H102 9G0824H1021 9G0848G102 9G0848G1021 9G0848H102 9G0848H1021 9G0912A202 9G0912A2021 9G0912G102 9G0912G1021 9G0912H102 9G0912H1021 9G0912H202 9G0912H2021 9G0912M202 9G0912M2021 9G0912S202 9G0912S2021 9G0924A202 9G0924A2021 9G0924G102 9G0924G1021 9G0924H102 9G0924H1021 9G0924H202 9G0924H2021 9G0924M202 9G0924M2021 9EC2024H001 9EC2048A001 9EC2048H001 9EC2048J001 - 9G0612H40011 9G0612S4001 - - - 9G0624H4001 - - - - - 9G0812G101 9G0812G1011 9G0812H101 9G0812H1011 9G0812K101 9G0812K1011 9G0824G101 9G0824G1011 9G0824H101 9G0824H1011 9G0848G101 9G0848G1011 9G0848H101 9G0848H1011 9G0912A201 9G0912A2011 9G0912G101 9G0912G1011 9G0912H101 9G0912H1011 9G0912H201 9G0912H2011 9G0912M201 9G0912M2011 9G0912S201 9G0912S2011 9G0924A201 9G0924A2011 9G0924G101 9G0924G1011 9G0924H101 9G0924H1011 9G0924H201 9G0924H2011 9G0924M201 9G0924M2011 9EC2024H0D01 9EC2048A0D01 - - 9G0612H4D001 9G0612H4D0011 - - - - 9G0624H4D001 - 9G0624S4D001 - - - 9G0812G1D01 9G0812G1D011 9G0812H1D01 9G0812H1D011 9G0812K1D01 - 9G0824G1D01 9G0824G1D011 9G0824H1D01 9G0824H1D011 9G0848G1D01 9G0848G1D011 9G0848H1D01 - 9G0912A2D01 9G0912A2D011 9G0912G1D01 - 9G0912H1D01 9G0912H1D011 9G0912H2D01 9G0912H2D011 9G0912M2D01 9G0912M2D011 9G0912S2D01 9G0912S2D011 9G0924A2D01 9G0924A2D011 9G0924G1D01 9G0924G1D011 9G0924H1D01 9G0924H1D011 9G0924H2D01 9G0924H2D011 9G0924M2D01 9G0924M2D011 Frame size Rib page 40 × 40 × 56 mm 60 × 60 × 76 mm 80 × 80 × 80 mm 40 × 40 × 56 mm 40 × 40 × 56 mm 60 × 60 × 76 mm 80 × 80 × 80 mm 60 × 60 × 76 mm 40 × 40 × 56 mm ø 200 × 70 mm ø 200 × 70 mm ø 200 × 70 mm ø 200 × 70 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm - - - - - 238 245 251 231 229 403 410 401 233 220 220 220 220 71 71 71 71 71 71 71 71 71 71 71 71 134 134 134 134 134 134 134 134 134 134 134 134 134 134 150 150 162 162 162 162 150 150 150 150 150 150 150 150 162 162 162 162 150 150 150 150 With PWM control function and pulse sensor 9CRE0412P5J03 9CRE0612P0G001 9CRE0812P8G001 9CRH0412P5J001 9CRJ0412P5J001 9CRL0612P0G001 9CRL0812P8G001 9CRLA0612P0G001 9CRV0412P5J201 - 9EC2048P0A01 - 9EC2048P0J01 9G0612P4H001 9G0612P4H0011 9G0612P4S001 9G0612P4S0011 9G0624P4F001 9G0624P4F0011 9G0624P4H001 9G0624P4H0011 9G0624P4S001 9G0624P4S0011 9G0648P4S001 9G0648P4S0011 9G0812P1G04 9G0812P1G081 9G0812P1H03 9G0812P1H051 9G0812P1K08 9G0812P1K081 9G0824P1G04 - - - 9G0848P1G03 - 9G0848P1H04 - 9G0912P2A01 - 9G0912P1G03 9G0912P1G031 9G0912P1H05 - 9G0912P2H01 - - - 9G0912P2S01 - - - - - - - - - - - Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 626 CATALOG No. C1111B002 '21.9.IT No No No - No No No No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) 9G0924S201 9G0924S2011 9G0948A201 9G0948A2011 9G0948G101 9G0948G1011 9G0948H101 9G0948H1011 9G0948H201 9G0948H2011 9G0948J101 9G0948J1011 9G0948M201 9G0948M2011 9G0948S201 9G0948S2011 9G1212A401 9G1212A4011 9G1212B401 9G1212B4011 9G1212E101 9G1212E1011 9G1212E401 9G1212E4011 9G1212F101 9G1212F1011 9G1212F401 9G1212F4011 9G1212G101 9G1212G1011 9G1212G401 9G1212G4011 9G1212H101 9G1212H1011 9G1212H401 9G1212H4011 9G1212M101 9G1212M1011 9G1212M401 9G1212M4011 9G1224A401 9G1224A4011 9G1224E101 9G1224E1011 9G1224E401 9G1224E4011 9G1224F101 9G1224F1011 9G1224F401 9G1224F4011 9G1224G101 9G1224G1011 9G1224G401 9G1224G4011 9G1224H101 9G1224H1011 9G1224H401 9G1224H4011 9G1224M101 9G1224M1011 9G1224M401 9G0924S202 9G0924S2021 9G0948A202 9G0948A2021 9G0948G102 9G0948G1021 9G0948H102 - 9G0948H202 9G0948H2021 - - 9G0948M202 9G0948M2021 9G0948S202 9G0948S2021 9G1212A402 9G1212A4021 - - 9G1212E102 9G1212E1021 9G1212E402 9G1212E4021 9G1212F102 9G1212F1021 9G1212F402 9G1212F4021 9G1212G102 9G1212G1021 9G1212G402 9G1212G4021 9G1212H102 9G1212H1021 9G1212H402 9G1212H4021 9G1212M102 9G1212M1021 9G1212M402 9G1212M4021 9G1224A402 9G1224A4021 9G1224E102 9G1224E1021 9G1224E402 9G1224E4021 9G1224F102 9G1224F1021 9G1224F402 9G1224F4021 9G1224G102 9G1224G1021 9G1224G402 9G1224G4021 9G1224H102 9G1224H1021 9G1224H402 9G1224H4021 9G1224M102 9G1224M1021 9G1224M402 With pulse sensor With lock sensor 9G0924S201 9G0924S2011 9G0948A201 9G0948A2011 9G0948G101 9G0948G1011 9G0948H101 9G0948H1011 9G0948H201 9G0948H2011 9G0948J101 9G0948J1011 9G0948M201 9G0948M2011 9G0948S201 9G0948S2011 9G1212A401 9G1212A4011 9G1212B401 9G1212B4011 9G1212E101 9G1212E1011 9G1212E401 9G1212E4011 9G1212F101 9G1212F1011 9G1212F401 9G1212F4011 9G1212G101 9G1212G1011 9G1212G401 9G1212G4011 9G1212H101 9G1212H1011 9G1212H401 9G1212H4011 9G1212M101 9G1212M1011 9G1212M401 9G1212M4011 9G1224A401 9G1224A4011 9G1224E101 9G1224E1011 9G1224E401 9G1224E4011 9G1224F101 9G1224F1011 9G1224F401 9G1224F4011 9G1224G101 9G1224G1011 9G1224G401 9G1224G4011 9G1224H101 9G1224H1011 9G1224H401 9G1224H4011 9G1224M101 9G1224M1011 9G1224M401 9G0924S2D01 9G0924S2D011 9G0948A2D01 9G0948A2D011 9G0948G1D01 - 9G0948H1D01 - 9G0948H2D01 9G0948H2D011 - - 9G0948M2D01 9G0948M2D011 9G0948S2D01 9G0948S2D011 9G1212A4D01 9G1212A4D011 - - 9G1212E1D01 9G1212E1D011 9G1212E4D01 9G1212E4D011 9G1212F1D01 - 9G1212F4D01 9G1212F4D011 9G1212G1D01 9G1212G1D011 9G1212G4D01 9G1212G4D011 9G1212H1D01 9G1212H1D011 9G1212H4D01 9G1212H4D011 9G1212M1D01 9G1212M1D011 9G1212M4D01 9G1212M4D011 9G1224A4D01 9G1224A4D011 9G1224E1D01 9G1224E1D011 9G1224E4D01 9G1224E4D011 9G1224F1D01 - 9G1224F4D01 9G1224F4D011 9G1224G1D01 9G1224G1D011 9G1224G4D01 9G1224G4D011 9G1224H1D01 9G1224H1D011 9G1224H4D01 9G1224H4D011 9G1224M1D01 9G1224M1D011 9G1224M4D01 Frame size Rib page Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes 150 150 150 150 162 162 162 162 150 150 162 162 150 150 150 150 172 172 172 172 186 186 172 172 186 186 172 172 186 186 172 172 186 186 172 172 186 186 172 172 172 172 186 186 172 172 186 186 172 172 186 186 172 172 186 186 172 172 186 186 172 With PWM control function and pulse sensor - - - - - - - - - - - 9G0948P1J031 - - - - - - - - - - 9G1212P4E05 9G1212P4E041 - - - - 9G1212P1G04 9G1212P1G081 9G1212P4G03 9G1212P4G031 - - 9G1212P4H04 9G1212P4H091 - - - - - - - - 9G1224P4E01 - - - - - 9G1224P1G01 - - - - - - - - - - 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 627 Index by Model No. Without sensor DC Models listed in product pages List of models DC Index by Model No. Models listed in product pages 9G1224M4011 9G1248A401 9G1248A4011 9G1248E101 9G1248E1011 9G1248E401 9G1248E4011 9G1248F101 9G1248F1011 9G1248F401 9G1248F4011 9G1248G101 9G1248G1011 9G1248G401 9G1248G4011 9G1248H101 9G1248H1011 9G1248H401 9G1248H4011 9G1248M101 9G1248M1011 9G1248M401 9G1248M4011 9GA0312P3G001 9GA0312P3G0011 9GA0312P3J001 9GA0312P3J0011 9GA0312P3K001 9GA0312P3K0011 9GA0405P6F001 9GA0405P6H001 9GA0412G7001 9GA0412H7001 9GA0412P3G01 9GA0412P3G011 9GA0412P3H01 9GA0412P3H011 9GA0412P3J01 9GA0412P3J011 9GA0412P3K01 9GA0412P3K011 9GA0412P3M01 9GA0412P3M011 9GA0412P6F001 9GA0412P6G001 9GA0412P6H001 9GA0412P7G001 9GA0424P3G001 9GA0424P3G0011 9GA0424P3H001 9GA0424P3H0011 9GA0424P3J001 9GA0424P3J0011 9GA0424P3M001 9GA0424P3M0011 9GA0424P6F001 9GA0424P6G001 9GA0424P6H001 9GA0512P7A001 9GA0512P7G001 9GA0512P7H001 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Without sensor With pulse sensor With lock sensor 9G1224M4021 9G1248A402 9G1248A4021 9G1248E102 9G1248E1021 9G1248E402 9G1248E4021 9G1248F102 9G1248F1021 9G1248F402 9G1248F4021 9G1248G102 9G1248G1021 9G1248G402 9G1248G4021 9G1248H102 9G1248H1021 9G1248H402 9G1248H4021 9G1248M102 9G1248M1021 9G1248M402 9G1248M4021 - - - - - - 9GA0405F6002 9GA0405H6002 9GA0412G7002 9GA0412H7002 9GA0412G302 9GA0412G3021 9GA0412H302 9GA0412H3021 9GA0412J302 9GA0412J3021 9GA0412K302 9GA0412K3021 9GA0412M302 9GA0412M3021 9GA0412F6002 9GA0412G6002 9GA0412H6002 9GA0412G7002 9GA0424G3002 9GA0424G30021 9GA0424H3002 9GA0424H30021 9GA0424J3002 9GA0424J30021 9GA0424M3002 9GA0424M30021 9GA0424F6002 9GA0424G6002 9GA0424H6002 9GA0512A7002 9GA0512G7002 9GA0512H7002 9G1224M4011 9G1248A401 9G1248A4011 9G1248E101 9G1248E1011 9G1248E401 9G1248E4011 9G1248F101 9G1248F1011 9G1248F401 9G1248F4011 9G1248G101 9G1248G1011 9G1248G401 9G1248G4011 9G1248H101 9G1248H1011 9G1248H401 9G1248H4011 9G1248M101 9G1248M1011 9G1248M401 9G1248M4011 9GA0312G3001 - 9GA0312J3001 - 9GA0312K3001 - 9GA0405F6001 9GA0405H6001 9GA0412G7001 9GA0412H7001 9GA0412G301 9GA0412G3011 9GA0412H301 9GA0412H3011 9GA0412J301 9GA0412J3011 9GA0412K301 9GA0412K3011 9GA0412M301 9GA0412M3011 9GA0412F6001 9GA0412G6001 9GA0412H6001 9GA0412G7001 9GA0424G3001 9GA0424G30011 9GA0424H3001 9GA0424H30011 9GA0424J3001 9GA0424J30011 9GA0424M3001 9GA0424M30011 9GA0424F6001 9GA0424G6001 9GA0424H6001 9GA0512A7001 9GA0512G7001 9GA0512H7001 9G1224M4D011 9G1248A4D01 9G1248A4D011 9G1248E1D01 9G1248E1D011 9G1248E4D01 9G1248E4D011 9G1248F1D01 - 9G1248F4D01 9G1248F4D011 9G1248G1D01 9G1248G1D011 9G1248G4D01 9G1248G4D011 9G1248H1D01 9G1248H1D011 9G1248H4D01 9G1248H4D011 9G1248M1D01 9G1248M1D011 9G1248M4D01 9G1248M4D011 9GA0312G3D001 - - - 9GA0312K3D001 9GA0312K3D0011 - - 9GA0412G7D001 9GA0412H7D001 - - 9GA0412H3D01 9GA0412H3D011 9GA0412J3D01 - 9GA0412K3D01 - 9GA0412M3D01 - - - - 9GA0412G7D001 9GA0424G3D001 - 9GA0424H3D001 - 9GA0424J3D001 - - 9GA0424M3D001 9GA0424F6D001 9GA0424G6D001 9GA0424H6D001 - - 9GA0512H7D001 Frame size - - - - - 9G1248P4E05 - - - - - 9G1248P1G04 9G1248P1G041 9G1248P4G04 - - - - - - - - - 9GA0312P3G001 9GA0312P3G0011 9GA0312P3J001 9GA0312P3J0011 9GA0312P3K001 9GA0312P3K0011 9GA0405P6F001 9GA0405P6H001 9GA0412P7G001 - 9GA0412P3G01 9GA0412P3G011 9GA0412P3H01 9GA0412P3H011 9GA0412P3J01 9GA0412P3J011 9GA0412P3K01 9GA0412P3K011 9GA0412P3M01 9GA0412P3M011 9GA0412P6F001 9GA0412P6G001 9GA0412P6H001 9GA0412P7G001 9GA0424P3G001 9GA0424P3G0011 9GA0424P3H001 9GA0424P3H0011 9GA0424P3J001 9GA0424P3J0011 9GA0424P3M001 9GA0424P3M0011 9GA0424P6F001 9GA0424P6G001 9GA0424P6H001 9GA0512P7A001 9GA0512P7G001 9GA0512P7H001 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 15 mm 40 × 40 × 15 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 15 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 628 CATALOG No. C1111B002 '21.9.IT Rib page No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes Yes Yes Yes Yes No Yes No Yes No Yes No Yes No Yes Yes Yes Yes Yes No Yes No Yes No Yes No Yes Yes Yes Yes Yes Yes 172 172 172 186 186 172 172 186 186 172 172 186 186 172 172 186 186 172 172 186 186 172 172 18 18 18 18 18 18 30 30 25 25 44 44 44 44 44 44 44 44 44 44 30 30 30 25 44 44 44 44 44 44 44 44 30 30 30 56 56 56 With PWM control function and pulse sensor List of models Without sensor With pulse sensor With lock sensor 9GA0512M7002 9GA0524A7002 9GA0524G7002 9GA0524H7002 9GA0524M7002 9GA0612G702 9GA0612G9002 9GA0612H6002 9GA0612H702 9GA0612H9002 9GA0612L702 9GA0612L9002 9GA0612M6002 9GA0612M702 9GA0612H102 9GA0612H1021 9GA0612J102 9GA0612J1021 9GA0612K102 9GA0612K1021 - - 9GA0612G6002 9GA0612S6002 9GA0612G702 9GA0612H702 9GA0624H6002 9GA0624M6002 9GA0624M702 9GA0624J102 9GA0624J1021 9GA0624K102 - 9GA0624G6002 9GA0624S6002 9GA0624G702 - - - - 9GA0812A2002 9GA0812A20021 9GA0812B2002 9GA0812B20021 9GA0812H7002 9GA0812L2002 9GA0812L20021 - - 9GA0812H162 9GA0812H1621 9GA0812S162 9GA0812S1621 - - - - - - 9GA0812G4002 9GA0812G40021 9GA0512M7001 9GA0524A7001 9GA0524G7001 9GA0524H7001 9GA0524M7001 9GA0612G701 9GA0612G9001 9GA0612H6001 9GA0612H701 9GA0612H9001 9GA0612L701 9GA0612L9001 9GA0612M6001 9GA0612M701 9GA0612H101 9GA0612H1011 9GA0612J101 9GA0612J1011 9GA0612K101 9GA0612K1011 - - 9GA0612G6001 9GA0612S6001 9GA0612G701 9GA0612H701 9GA0624H6001 9GA0624M6001 9GA0624M701 9GA0624J101 9GA0624J1011 - - 9GA0624G6001 9GA0624S6001 - - - - - 9GA0812A2001 9GA0812A20011 9GA0812B2001 9GA0812B20011 9GA0812H7001 9GA0812L2001 9GA0812L20011 - - 9GA0812H161 9GA0812H1611 9GA0812S161 9GA0812S1611 - - - - 9GA0812S2001 - 9GA0812G4001 9GA0812G40011 - 9GA0524A7D001 9GA0524G7D001 - - 9GA0612G7D01 9GA0612G9D001 9GA0612H6D001 9GA0612H7D01 9GA0612H9D001 9GA0612L7D01 9GA0612L9D001 9GA0612M6D001 - - - 9GA0612J1D01 - 9GA0612K1D01 9GA0612K1D011 - - - - 9GA0612G7D01 9GA0612H7D01 9GA0624H6D001 9GA0624M6D001 - - - 9GA0624K1D01 - 9GA0624G6D001 - - - - 9GA0712H1D001 - 9GA0812A2D001 9GA0812A2D0011 9GA0812B2D001 9GA0812B2D0011 9GA0812H7D001 9GA0812L2D001 9GA0812L2D0011 - - 9GA0812H1D61 - 9GA0812S1D61 - - - - - - - 9GA0812G4D001 - Frame size Rib page 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 60 × 60 × 15 mm 60 × 60 × 10 mm 60 × 60 × 20 mm 60 × 60 × 15 mm 60 × 60 × 10 mm 60 × 60 × 15 mm 60 × 60 × 10 mm 60 × 60 × 20 mm 60 × 60 × 15 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 15 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 15 mm 70 × 70 × 38 mm 70 × 70 × 38 mm 70 × 70 × 38 mm 70 × 70 × 38 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 15 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 25 mm 80 × 80 × 25 mm Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes No Yes No Yes No Yes No Yes Yes Yes Yes Yes Yes Yes Yes No Yes No Yes Yes Yes Yes No Yes No Yes No Yes No Yes Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No 56 56 56 56 56 64 62 67 64 62 64 62 67 64 85 85 85 85 85 85 85 85 67 67 64 64 67 67 64 85 85 85 85 67 67 64 91 91 91 91 117 117 117 117 93 117 117 128 128 128 128 128 128 117 117 117 117 117 117 104 104 With PWM control function and pulse sensor 9GA0512P7M001 9GA0524P7A001 9GA0524P7G001 9GA0524P7H001 9GA0524P7M001 9GA0612P7G01 9GA0612P9G001 - 9GA0612P7H01 - - - - - 9GA0612P1H03 9GA0612P1H031 9GA0612P1J03 9GA0612P1J031 9GA0612P1K03 9GA0612P1K031 9GA0612P1K60 9GA0612P1K601 9GA0612P6G001 9GA0612P6S001 9GA0612P7G01 9GA0612P7H01 - - - 9GA0624P1J03 9GA0624P1J031 9GA0624P1K03 9GA0624P1K031 9GA0624P6G001 9GA0624P6S001 9GA0624P7G01 9GA0712P1G001 9GA0712P1G0011 9GA0712P1H001 9GA0712P1H0011 - - - - - - - 9GA0812P1G61 9GA0812P1G611 9GA0812P1H61 9GA0812P1H611 9GA0812P1S61 9GA0812P1S611 9GA0812P2H001 9GA0812P2H0011 9GA0812P2M001 9GA0812P2M0011 9GA0812P2S001 9GA0812P2S0011 9GA0812P4G001 9GA0812P4G0011 Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 629 Index by Model No. 9GA0512P7M001 9GA0524P7A001 9GA0524P7G001 9GA0524P7H001 9GA0524P7M001 9GA0612G701 9GA0612G9001 9GA0612H6001 9GA0612H701 9GA0612H9001 9GA0612L701 9GA0612L9001 9GA0612M6001 9GA0612M701 9GA0612P1H03 9GA0612P1H031 9GA0612P1J03 9GA0612P1J031 9GA0612P1K03 9GA0612P1K031 9GA0612P1K60 9GA0612P1K601 9GA0612P6G001 9GA0612P6S001 9GA0612P7G01 9GA0612P7H01 9GA0624H6001 9GA0624M6001 9GA0624M701 9GA0624P1J03 9GA0624P1J031 9GA0624P1K03 9GA0624P1K031 9GA0624P6G001 9GA0624P6S001 9GA0624P7G01 9GA0712P1G001 9GA0712P1G0011 9GA0712P1H001 9GA0712P1H0011 9GA0812A2001 9GA0812A20011 9GA0812B2001 9GA0812B20011 9GA0812H7001 9GA0812L2001 9GA0812L20011 9GA0812P1G61 9GA0812P1G611 9GA0812P1H61 9GA0812P1H611 9GA0812P1S61 9GA0812P1S611 9GA0812P2H001 9GA0812P2H0011 9GA0812P2M001 9GA0812P2M0011 9GA0812P2S001 9GA0812P2S0011 9GA0812P4G001 9GA0812P4G0011 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Models listed in product pages List of models DC Index by Model No. Models listed in product pages 9GA0812P4H001 9GA0812P4H0011 9GA0812P4J001 9GA0812P4J0011 9GA0812P6G001 9GA0812P6M001 9GA0812P7G001 9GA0812P7S001 9GA0824A2001 9GA0824A20011 9GA0824B2001 9GA0824B20011 9GA0824H7001 9GA0824L2001 9GA0824L20011 9GA0824P1H61 9GA0824P1H611 9GA0824P1S61 9GA0824P1S611 9GA0824P2S001 9GA0824P2S0011 9GA0824P4G001 9GA0824P4G0011 9GA0824P4H001 9GA0824P4H0011 9GA0824P4J001 9GA0824P4J0011 9GA0824P6G001 9GA0824P6M001 9GA0824P7G001 9GA0824P7S001 9GA0848P1S61 9GA0848P1S611 9GA0848P2S001 9GA0848P2S0011 9GA0912F401 9GA0912F4011 9GA0912H401 9GA0912H4011 9GA0912L401 9GA0912L4011 9GA0912M401 9GA0912M4011 9GA0912P1H03 9GA0912P1H031 9GA0912P4G03 9GA0912P4G031 9GA0912P4J03 9GA0912P4J031 9GA0912P4S03 9GA0912P4S031 9GA0912W401 9GA0912W4011 9GA0924F401 9GA0924F4011 9GA0924H401 9GA0924H4011 9GA0924L401 9GA0924L4011 9GA0924M401 9GA0924M4011 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Without sensor With pulse sensor With lock sensor With PWM control function and pulse sensor 9GA0812H4002 9GA0812H40021 9GA0812J4002 9GA0812J40021 9GA0812G6002 9GA0812M6002 9GA0812G7002 - 9GA0824A2002 9GA0824A20021 9GA0824B2002 9GA0824B20021 9GA0824H7002 9GA0824L2002 9GA0824L20021 9GA0824H162 9GA0824H1621 9GA0824S162 9GA0824S1621 9GA0824S2002 - 9GA0824G4002 9GA0824G40021 9GA0824H4002 9GA0824H40021 9GA0824J4002 9GA0824J40021 9GA0824G6002 9GA0824M6002 9GA0824G7002 9GA0824S7002 - - - - 9GA0912F402 9GA0912F4021 9GA0912H402 9GA0912H4021 9GA0912L402 9GA0912L4021 9GA0912M402 9GA0912M4021 9GA0912H102 9GA0912H1021 9GA0912G402 9GA0912G4021 9GA0912J402 9GA0912J4021 9GA0912S402 9GA0912S4021 9GA0912W402 9GA0912W4021 9GA0924F402 9GA0924F4021 9GA0924H402 9GA0924H4021 9GA0924L402 9GA0924L4021 9GA0924M402 9GA0924M4021 9GA0812H4001 9GA0812H40011 9GA0812J4001 9GA0812J40011 9GA0812G6001 9GA0812M6001 9GA0812G7001 - 9GA0824A2001 9GA0824A20011 9GA0824B2001 9GA0824B20011 9GA0824H7001 9GA0824L2001 9GA0824L20011 9GA0824H161 9GA0824H1611 9GA0824S161 9GA0824S1611 - - 9GA0824G4001 9GA0824G40011 9GA0824H4001 9GA0824H40011 9GA0824J4001 9GA0824J40011 9GA0824G6001 9GA0824M6001 - - - - - - 9GA0912F401 9GA0912F4011 9GA0912H401 9GA0912H4011 9GA0912L401 9GA0912L4011 9GA0912M401 9GA0912M4011 9GA0912H101 9GA0912H1011 9GA0912G401 9GA0912G4011 9GA0912J401 9GA0912J4011 9GA0912S401 9GA0912S4011 9GA0912W401 9GA0912W4011 9GA0924F401 9GA0924F4011 9GA0924H401 9GA0924H4011 9GA0924L401 9GA0924L4011 9GA0924M401 9GA0924M4011 9GA0812H4D001 - 9GA0812J4D001 - - - 9GA0812G7D001 - 9GA0824A2D001 9GA0824A2D0011 9GA0824B2D001 9GA0824B2D0011 9GA0824H7D001 9GA0824L2D001 9GA0824L2D0011 9GA0824H1D61 - - - - - 9GA0824G4D001 - 9GA0824H4D001 - 9GA0824J4D001 9GA0824J4D0011 - - 9GA0824G7D001 - - - - - 9GA0912F4D01 9GA0912F4D011 9GA0912H4D01 9GA0912H4D011 9GA0912L4D01 9GA0912L4D011 9GA0912M4D01 9GA0912M4D011 9GA0912H1D01 - 9GA0912G4D01 - 9GA0912J4D01 9GA0912J4D011 9GA0912S4D01 9GA0912S4D011 9GA0912W4D01 9GA0912W4D011 9GA0924F4D01 9GA0924F4D011 9GA0924H4D01 9GA0924H4D011 9GA0924L4D01 9GA0924L4D011 9GA0924M4D01 9GA0924M4D011 9GA0812P4H001 9GA0812P4H0011 9GA0812P4J001 9GA0812P4J0011 9GA0812P6G001 9GA0812P6M001 9GA0812P7G001 9GA0812P7S001 - - - - - - - 9GA0824P1H61 9GA0824P1H611 9GA0824P1S61 9GA0824P1S611 9GA0824P2S001 9GA0824P2S0011 9GA0824P4G001 9GA0824P4G0011 9GA0824P4H001 9GA0824P4H0011 9GA0824P4J001 9GA0824P4J0011 9GA0824P6G001 9GA0824P6M001 9GA0824P7G001 9GA0824P7S001 9GA0848P1S61 9GA0848P1S611 9GA0848P2S001 9GA0848P2S0011 - - - - - - - - 9GA0912P1H03 9GA0912P1H031 9GA0912P4G03 9GA0912P4G031 9GA0912P4J03 9GA0912P4J031 9GA0912P4S03 9GA0912P4S031 - - - - - - - - - - Frame size Rib page 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 20 mm 80 × 80 × 20 mm 80 × 80 × 15 mm 80 × 80 × 15 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 15 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 20 mm 80 × 80 × 20 mm 80 × 80 × 15 mm 80 × 80 × 15 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 32 mm 80 × 80 × 32 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm Yes No Yes No Yes Yes Yes Yes Yes No Yes No Yes Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes Yes Yes Yes Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No 104 104 104 104 98 98 93 93 117 117 117 117 93 117 117 128 128 128 128 117 117 104 104 104 104 104 104 98 98 93 93 128 128 117 117 140 140 140 140 140 140 140 140 156 156 140 140 140 140 140 140 140 140 140 140 140 140 140 140 140 140 Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 630 CATALOG No. C1111B002 '21.9.IT List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) 9GA0924P1H01 9GA0924P1H011 9GA0924P4G03 9GA0924P4G031 9GA0924P4J03 9GA0924P4J031 9GA0924P4S03 9GA0924P4S031 9GA0924W401 9GA0924W4011 9GA0948P1H03 9GA0948P1H031 9GA1212G4001 9GA1212G40011 9GA1212P4G001 9GA1212P4G0011 9GA1212P4S001 9GA1212P4S0011 9GA1212S4001 9GA1212S40011 9GA1224G4001 9GA1224G40011 9GA1224P4G001 9GA1224P4G0011 9GA1224P4S001 9GA1224P4S0011 9GA1224S4001 9GA1224S40011 9GA1248G4001 9GA1248G40011 9GA1248P4G001 9GA1248P4G0011 9GA1248P4S001 9GA1248P4S0011 9GA1248S4001 9GA1248S40011 9GAX0412P3K001 9GAX0412P3K0011 9GAX0412P3K003 9GAX0412P3K0031 9GAX0412P3S001 9GAX0412P3S0011 9GAX0412P3S003 9GAX0412P3S0031 9GE0412P3G03 9GE0412P3J03 9GE0412P3K03 9GL1212E101 9GL1212F101 9GL1212G101 9GL1212H101 9GL1212M101 9GL1224E101 9GL1224F101 9GL1224G101 9GL1224H101 9GL1224M101 9GL1248E101 9GL1248F101 9GL1248G101 9GL1248H101 9GA0924H102 - 9GA0924G402 9GA0924G4021 9GA0924J402 9GA0924J4021 9GA0924S402 9GA0924S4021 9GA0924W402 9GA0924W4021 9GA0948H102 - - - - - - - - - 9GA1224G4002 - 9GA1224G4002 - - - 9GA1224S4002 - - - - - - - - - - - - - - - - - - 9GE0412J302 - 9GL1212E102 9GL1212F102 9GL1212G102 9GL1212H102 9GL1212M102 9GL1224E102 9GL1224F102 9GL1224G102 9GL1224H102 9GL1224M102 9GL1248E102 9GL1248F102 9GL1248G102 9GL1248H102 With pulse sensor With lock sensor 9GA0924H101 9GA0924H1011 9GA0924G401 9GA0924G4011 9GA0924J401 9GA0924J4011 9GA0924S401 9GA0924S4011 9GA0924W401 9GA0924W4011 9GA0948H101 - 9GA1212G4001 9GA1212G40011 9GA1212G4001 9GA1212G40011 9GA1212S4001 9GA1212S40011 9GA1212S4001 9GA1212S40011 9GA1224G4001 9GA1224G40011 9GA1224G4001 9GA1224G40011 9GA1224S4001 9GA1224S40011 9GA1224S4001 9GA1224S40011 9GA1248G4001 9GA1248G40011 9GA1248G4001 9GA1248G40011 9GA1248S4001 9GA1248S40011 9GA1248S4001 9GA1248S40011 - - - - - - - - - 9GE0412J301 9GE0412K301 9GL1212E101 9GL1212F101 9GL1212G101 9GL1212H101 9GL1212M101 9GL1224E101 9GL1224F101 9GL1224G101 9GL1224H101 9GL1224M101 9GL1248E101 9GL1248F101 9GL1248G101 9GL1248H101 9GA0924H1D01 9GA0924H1D011 9GA0924G4D01 - 9GA0924J4D01 - 9GA0924S4D01 - 9GA0924W4D01 9GA0924W4D011 - - - - - - - - - - 9GA1224G4D001 - 9GA1224G4D001 - 9GA1224S4D001 - - - - - - - - - - - - - - - - - - - 9GE0412G3D01 9GE0412J3D01 9GE0412K3D01 9GL1212E1D01 9GL1212F1D01 9GL1212G1D01 9GL1212H1D01 9GL1212M1D01 9GL1224E1D01 9GL1224F1D01 9GL1224G1D01 9GL1224H1D01 9GL1224M1D01 9GL1248E1D01 9GL1248F1D01 9GL1248G1D01 9GL1248H1D01 Frame size Rib page Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No No No No No No No No No No No No No No No No No No 156 156 140 140 140 140 140 140 140 140 156 156 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 165 39 39 39 39 39 39 39 39 48 48 48 425 425 425 425 425 425 425 425 425 425 425 425 425 425 With PWM control function and pulse sensor 9GA0924P1H01 9GA0924P1H011 9GA0924P4G03 9GA0924P4G031 9GA0924P4J03 9GA0924P4J031 9GA0924P4S03 9GA0924P4S031 - - 9GA0948P1H03 9GA0948P1H031 9GA1212P4G001 9GA1212P4G0011 9GA1212P4G001 9GA1212P4G0011 9GA1212P4S001 9GA1212P4S0011 9GA1212P4S001 9GA1212P4S0011 9GA1224P4G001 9GA1224P4G0011 9GA1224P4G001 9GA1224P4G0011 9GA1224P4S001 9GA1224P4S0011 9GA1224P4S001 9GA1224P4S0011 9GA1248P4G001 9GA1248P4G0011 9GA1248P4G001 9GA1248P4G0011 9GA1248P4S001 9GA1248P4S0011 9GA1248P4S001 9GA1248P4S0011 9GAX0412P3K001 9GAX0412P3K0011 9GAX0412P3K003 9GAX0412P3K0031 9GAX0412P3S001 9GAX0412P3S0011 9GAX0412P3S003 9GAX0412P3S0031 9GE0412P3G03 9GE0412P3J03 9GE0412P3K03 - - - - - - - - - - - - - - 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 631 Index by Model No. Without sensor DC Models listed in product pages List of models Models listed in product pages (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Index by Model No. Without sensor 9GL1248M101 9GP1224P1G001 9GP1248P1G001 9GP5724P5H001 9GP5748P5G001 9GT0412P3J001 9GT0424P3J001 9GT0612P4G001 9GT0624P4G001 9GT0812P4S001 9GT0824P4S001 9GT0912P1M001 9GT0912P4J001 9GT0924P1M001 9GT0924P4J001 9GT1212P1S001 9GT1224P1S001 9GV0312E301 9GV0312E3011 9GV0312G301 9GV0312G3011 9GV0312H301 9GV0312H3011 9GV0312J301 9GV0312J3011 9GV0312K301 9GV0312K3011 9GV0412C301 9GV0412C3011 9GV0412G301 9GV0412G3011 9GV0412H301 9GV0412H3011 9GV0412J301 9GV0412J3011 9GV0412K301 9GV0412K3011 9GV0612P1G03 9GV0612P1G031 9GV0624P1G03 9GV0624P1G031 9GV0648P1H03 9GV0648P1H031 9GV0812P1F03 9GV0812P1F031 9GV0812P1G03 9GV0812P1G031 9GV0812P1H03 9GV0812P1H031 9GV0812P1M03 9GV0812P1M031 9GV0824P1G03 9GV0824P1G031 9GV0848P1G03 9GV0848P1G031 9GV0848P4K03 9GV0848P4K031 9GV0912P1F03 9GV0912P1F031 9GV0912P1G03 9GV0912P1G031 9GL1248M102 9GP1224G1002 - - - 9GT0412J3002 9GT0424J3002 9GT0612G4002 9GT0624G4002 9GT0812S4002 9GT0824S4002 9GT0912M1002 9GT0912J4002 9GT0924M1002 9GT0924J4002 - 9GT1224S1002 9GV0312E302 - 9GV0312G302 9GV0312G3021 9GV0312H302 - 9GV0312J302 9GV0312J3021 - - - - 9GV0412G302 9GV0412G3021 - - 9GV0412J302 9GV0412J3021 9GV0412K302 - 9GV0612G102 9GV0612G1021 9GV0624G102 9GV0624G1021 - - - - 9GV0812G102 9GV0812G1021 9GV0812H102 9GV0812H1021 - - 9GV0824G102 - 9GV0848G102 - - - - - 9GV0912G102 - With pulse sensor With lock sensor 9GL1248M101 - - - - 9GT0412J3001 9GT0424J3001 9GT0612G4001 9GT0624G4001 9GT0812S4001 9GT0824S4001 9GT0912M1001 9GT0912J4001 - 9GT0924J4001 - - 9GV0312E301 9GV0312E3011 9GV0312G301 9GV0312G3011 9GV0312H301 9GV0312H3011 9GV0312J301 9GV0312J3011 9GV0312K301 9GV0312K3011 9GV0412C301 9GV0412C3011 9GV0412G301 9GV0412G3011 9GV0412H301 9GV0412H3011 9GV0412J301 9GV0412J3011 9GV0412K301 9GV0412K3011 9GV0612G101 9GV0612G1011 - - - - - - 9GV0812G101 9GV0812G1011 9GV0812H101 9GV0812H1011 - - 9GV0824G101 - 9GV0848G101 9GV0848G1011 9GV0848K401 - - - - - 9GL1248M1D01 - - - - 9GT0412J3D001 9GT0424J3D001 9GT0612G4D001 - 9GT0812S4D001 - 9GT0912M1D001 9GT0912J4D001 9GT0924M1D001 - - 9GT1224S1D001 9GV0312E3D01 9GV0312E3D011 9GV0312G3D01 - 9GV0312H3D01 - 9GV0312J3D01 - 9GV0312K3D01 9GV0312K3D011 9GV0412C3D01 9GV0412C3D011 9GV0412G3D01 9GV0412G3D011 9GV0412H3D01 - 9GV0412J3D01 9GV0412J3D011 9GV0412K3D01 - 9GV0612G1D01 9GV0612G1D011 9GV0624G1D01 - - - - - - - - - - - 9GV0824G1D01 - - - - - - - 9GV0912G1D01 - Frame size Rib page 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 38 × 38 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm No No No No No No No No No No No No No No No No No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No 425 458 458 460 460 444 444 446 446 448 448 452 450 452 450 454 454 21 21 21 21 21 21 21 21 21 21 51 51 51 51 51 51 51 51 51 51 88 88 88 88 88 88 131 131 131 131 131 131 131 131 131 131 131 131 107 107 159 159 159 159 With PWM control function and pulse sensor - 9GP1224P1G001 9GP1248P1G001 9GP5724P5H001 9GP5748P5G001 9GT0412P3J001 9GT0424P3J001 9GT0612P4G001 9GT0624P4G001 9GT0812P4S001 9GT0824P4S001 9GT0912P1M001 9GT0912P4J001 9GT0924P1M001 9GT0924P4J001 9GT1212P1S001 9GT1224P1S001 - - 9GV0312P3G03 - - - 9GV0312P3J03 9GV0312P3J031 9GV0312P3K01 - - - 9GV0412P3G03 9GV0412P3G031 9GV0412P3H01 - 9GV0412P3J03 9GV0412P3J031 9GV0412P3K03 - 9GV0612P1G03 9GV0612P1G031 9GV0624P1G03 9GV0624P1G031 9GV0648P1H03 9GV0648P1H031 9GV0812P1F03 9GV0812P1F031 9GV0812P1G03 9GV0812P1G031 9GV0812P1H03 9GV0812P1H031 9GV0812P1M03 9GV0812P1M031 9GV0824P1G03 9GV0824P1G031 9GV0848P1G03 9GV0848P1G031 9GV0848P4K03 9GV0848P4K031 9GV0912P1F03 9GV0912P1F031 9GV0912P1G03 9GV0912P1G031 Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 632 CATALOG No. C1111B002 '21.9.IT Without sensor 9GV0912P1H03 9GV0912P1H031 9GV0948P1F03 9GV0948P1F031 9GV0948P1H03 9GV0948P1H031 9GV1212P1G01 9GV1212P1G011 9GV1212P1J01 9GV1212P1J011 9GV1212P4G01 9GV1212P4G011 9GV1224P1H01 9GV1224P1H011 9GV1224P1J01 9GV1224P1J011 9GV1224P4G01 9GV1224P4G011 9GV1248P1J01 9GV1248P1J011 9GV1248P4G01 9GV1248P4G011 9GV1248P4H01 9GV1248P4H011 9GV1248P4J01 9GV1248P4J011 9GV1412P1G001 9GV1412P1H001 9GV1412P1S001 9GV1424P1G001 9GV1424P1H001 9GV1424P1S001 9GV1448P1G001 9GV1448P1H001 9GV1448P1S001 9GV1512H501 9GV1512H5011 9GV1512M501 9GV1512M5011 9GV1524M501 9GV1524M5011 9GV2048P0G201 9GV3612G301 9GV3612J301 9GV5724H501 9GV5748H501 9GX3612P3K001 9HV0412P3K001 9HV0612P1J001 9HV0612P1J0011 9HV0812P1G601 9HV0812P1G6011 9HV0824P1G003 9HV0824P1G0011 9HV0848P1G001 9HV0848P1G0011 9HV0912P1G001 9HV0912P1G0011 9HV0924P1G001 9HV0924P1G0011 9HV0948P1G001 9GV0912H102 - - - 9GV0948H102 9GV0948H1021 - - 9GV1212J102 9GV1212J1021 9GV1212G402 9GV1212G4021 9GV1224H102 9GV1224H1021 9GV1224J102 9GV1224J1021 9GV1224G402 9GV1224G4021 9GV1248J102 9GV1248J1021 9GV1248G402 - 9GV1248H402 - - - - 9GV1412H1002 - - 9GV1424H1002 - - - - 9GV1512H502 9GV1512H5021 9GV1512M502 9GV1512M5021 9GV1524M502 - 9GV2048G0202 9GV3612G302 9GV3612J302 9GV5724H502 9GV5748H502 9GX3612K3002 - - - 9HV0812G1002 9HV0812G10021 - - 9HV0848G1002 9HV0848G10021 - - - - - With pulse sensor With lock sensor With PWM control function and pulse sensor 9GV0912H101 - - - 9GV0948H101 - - 9GV1212G1011 9GV1212J101 9GV1212J1011 9GV1212G401 9GV1212G4011 9GV1224H101 9GV1224H1011 9GV1224J101 9GV1224J1011 9GV1224G401 - 9GV1248J101 9GV1248J1011 9GV1248G401 9GV1248G4011 9GV1248H401 - - - - - - - - - - - - 9GV1512H501 9GV1512H5011 9GV1512M501 9GV1512M5011 9GV1524M501 9GV1524M5011 - 9GV3612G301 9GV3612J301 9GV5724H501 9GV5748H501 - - - - 9HV0812G1001 9HV0812G10011 - - 9HV0848G1001 9HV0848G10011 - - - - - 9GV0912H1D01 - - - - - - 9GV1212G1D011 9GV1212J1D01 - - - 9GV1224H1D01 9GV1224H1D011 9GV1224J1D01 9GV1224J1D011 9GV1224G4D01 - 9GV1248J1D01 - - - 9GV1248H4D01 - - - - - - - 9GV1424H1D001 - - - - - - - - 9GV1524M5D01 - - 9GV3612G3D01 9GV3612J3D01 - - - - - - - - 9HV0824G1D001 - 9HV0848G1D001 - - - - - - 9GV0912P1H03 9GV0912P1H031 9GV0948P1F03 9GV0948P1F031 9GV0948P1H03 9GV0948P1H031 9GV1212P1G01 9GV1212P1G011 9GV1212P1J01 9GV1212P1J011 9GV1212P4G01 9GV1212P4G011 9GV1224P1H01 9GV1224P1H011 9GV1224P1J01 9GV1224P1J011 9GV1224P4G01 9GV1224P4G011 9GV1248P1J01 9GV1248P1J011 9GV1248P4G01 9GV1248P4G011 9GV1248P4H01 9GV1248P4H011 9GV1248P4J01 9GV1248P4J011 9GV1412P1G001 9GV1412P1H001 9GV1412P1S001 9GV1424P1G001 9GV1424P1H001 9GV1424P1S001 9GV1448P1G001 9GV1448P1H001 9GV1448P1S001 9GV1512P5H03 - 9GV1512P5M03 9GV1512P5M011 - - 9GV2048P0G201 9GV3612P3G03 9GV3612P3J03 9GV5724P5H03 9GV5748P5H01 9GX3612P3K001 9HV0412P3K001 9HV0612P1J001 9HV0612P1J0011 9HV0812P1G601 9HV0812P1G6011 9HV0824P1G003 9HV0824P1G0011 9HV0848P1G001 9HV0848P1G0011 9HV0912P1G001 9HV0912P1G0011 9HV0924P1G001 9HV0924P1G0011 9HV0948P1G001 Frame size Rib page 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 150 × 150 × 50 mm 150 × 150 × 50 mm 150 × 150 × 50 mm 150 × 150 × 50 mm 150 × 150 × 50 mm 150 × 150 × 50 mm ø 200 × 70 mm 36 × 36 × 28 mm 36 × 36 × 28 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm 36 × 36 × 28 mm 40 × 40 × 28 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No No No No No No No No No No Yes No Yes No Yes No No Yes Yes No No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes 159 159 159 159 159 159 181 181 181 181 169 169 181 181 181 181 169 169 181 181 169 169 169 169 169 169 194 194 194 194 194 194 194 194 194 200 200 200 200 200 200 218 16 16 210 210 14 42 83 83 125 125 125 125 125 125 153 153 153 153 153 Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 633 DC (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Index by Model No. List of models Models listed in product pages List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Models listed in product pages DC Index by Model No. Without sensor 9HV0948P1G0011 9HV0912P4G001 9HV0912P4G0011 9HV0912P4H001 9HV0912P4H0011 9HV0924P4G001 9HV0924P4G0011 9HV0924P4H001 9HV0924P4H0011 9HV1224P1A001 9HV1248P1G001 9HV1248P1H001 9HV3612P3K001 9HV5724P5H001 9HV5748P5G001 9HVA0412P3J001 9HVA0812P1G001 9HVA0812P1G0011 9HVA0848P1G601 9HVA0848P1G6011 9HVB0812P1G001 9HVB0812P1G0011 9L0412H301 9L0412J301 9L0412M301 9LG0612P4H001 9LG0612P4J001 9LG0612P4M001 9LG0612P4S001 9LG0624P4H001 9LG0624P4J001 9LG0624P4M001 9LG0624P4S001 9LG0648P4H001 9LG0648P4J001 9LG0648P4M001 9LG0648P4S001 9LG0812F4001 9LG0812L4001 9LG0812M4001 9LG0812P4G001 9LG0812P4H001 9LG0812P4J001 9LG0812S4001 9LG0824F4001 9LG0824L4001 9LG0824M4001 9LG0824P4G001 9LG0824P4H001 9LG0824P4J001 9LG0824S4001 9LG0912F4001 9LG0912L4001 9LG0912M4001 9LG0912P1F001 9LG0912P1H001 9LG0912P4G001 9LG0912P4H001 9LG0912P4J001 9LG0912P4S001 9LG0924F4001 With pulse sensor With lock sensor - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 9HV1248G1002 9HV1248H1002 - 9HV5724H5002 - - - - - - - - 9L0412H302 9L0412J302 9L0412M302 9LG0612H4002 - - - 9LG0624H4002 - 9LG0624M4002 9LG0624S4002 - - - - 9LG0812F4002 9LG0812L4002 9LG0812M4002 - 9LG0812H4002 9LG0812J4002 9LG0812S4002 9LG0824F4002 9LG0824L4002 9LG0824M4002 9LG0824G4002 9LG0824H4002 - 9LG0824S4002 9LG0912F4002 9LG0912L4002 9LG0912M4002 - - 9LG0912G4002 9LG0912H4002 - 9LG0912S4002 9LG0924F4002 9HV1248G1001 9HV1248H1001 - 9HV5724H5001 - - - - - - - - 9L0412H301 9L0412J301 9L0412M301 9LG0612H4001 - - 9LG0612S4001 9LG0624H4001 - 9LG0624M4001 - - - - - 9LG0812F4001 9LG0812L4001 9LG0812M4001 9LG0812G4001 9LG0812H4001 - 9LG0812S4001 9LG0824F4001 9LG0824L4001 9LG0824M4001 9LG0824G4001 9LG0824H4001 - 9LG0824S4001 9LG0912F4001 9LG0912L4001 9LG0912M4001 - - - 9LG0912H4001 - 9LG0912S4001 9LG0924F4001 9HV1224A1D001 9HV1248G1D001 - - 9HV5724H5D001 - - - - - - - - 9L0412H3D01 9L0412J3D01 9L0412M3D01 9LG0612H4D001 9LG0612J4D001 9LG0612M4D001 9LG0612S4D001 9LG0624H4D001 - - - - - - - 9LG0812F4D001 9LG0812L4D001 9LG0812M4D001 9LG0812G4D001 9LG0812H4D001 9LG0812J4D001 9LG0812S4D001 9LG0824F4D001 9LG0824L4D001 9LG0824M4D001 9LG0824G4D001 9LG0824H4D001 9LG0824J4D001 9LG0824S4D001 9LG0912F4D001 9LG0912L4D001 9LG0912M4D001 - 9LG0912H1D001 - 9LG0912H4D001 9LG0912J4D001 9LG0912S4D001 9LG0924F4D001 Frame size Rib page 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 36 × 36 × 28 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm 40 × 40 × 28 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm No Yes No Yes No Yes No Yes No No No No Yes No No Yes Yes No Yes No Yes No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No 153 137 137 137 137 137 137 137 137 178 178 178 12 205 205 37 123 123 123 123 121 121 394 394 394 396 396 396 396 396 396 396 396 396 396 396 396 405 405 405 405 405 405 405 405 405 405 405 405 405 405 412 412 412 417 417 412 412 412 412 412 With PWM control function and pulse sensor 9HV0948P1G0011 9HV0912P4G001 9HV0912P4G0011 9HV0912P4H001 9HV0912P4H0011 9HV0924P4G001 9HV0924P4G0011 9HV0924P4H001 9HV0924P4H0011 9HV1224P1A001 9HV1248P1G001 9HV1248P1H001 9HV3612P3K001 9HV5724P5H001 9HV5748P5G001 9HVA0412P3J001 9HVA0812P1G001 9HVA0812P1G0011 9HVA0848P1G601 9HVA0848P1G6011 9HVB0812P1G001 9HVB0812P1G0011 - 9L0412P3J01 - 9LG0612P4H001 9LG0612P4J001 9LG0612P4M001 9LG0612P4S001 9LG0624P4H001 9LG0624P4J001 9LG0624P4M001 9LG0624P4S001 9LG0648P4H001 9LG0648P4J001 9LG0648P4M001 9LG0648P4S001 - - - 9LG0812P4G001 9LG0812P4H001 9LG0812P4J001 - - - - 9LG0824P4G001 9LG0824P4H001 9LG0824P4J001 - - - - 9LG0912P1F001 9LG0912P1H001 9LG0912P4G001 9LG0912P4H001 9LG0912P4J001 9LG0912P4S001 - Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 634 CATALOG No. C1111B002 '21.9.IT List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) 9LG0924L4001 9LG0924M4001 9LG0924P1F001 9LG0924P1H001 9LG0924P4G001 9LG0924P4H001 9LG0924P4J001 9LG0924P4S001 9LG1212F1001 9LG1212M1001 9LG1212P1G001 9LG1212P1H001 9LG1212P1S001 9LG1224A1001 9LG1224F1001 9LG1224M1001 9LG1224P1G001 9LG1224P1H001 9LG1224P1S001 9LG1248F1001 9LG1248M1001 9LG1248P1G001 9LG1248P1H001 9LG1248P1S001 9LG1412A5001 9LG1412H5001 9LG1412L1001 9LG1412M5001 9LG1412P1A001 9LG1412P1H001 9LG1412P1M001 9LG1412P5G001 9LG1412P5S001 9LG1424A5001 9LG1424H5001 9LG1424L1001 9LG1424M5001 9LG1424P1A001 9LG1424P1H001 9LG1424P1M001 9LG1424P5G001 9LG1424P5S001 9LG1448A5001 9LG1448H5001 9LG1448L1001 9LG1448M5001 9LG1448P1A001 9LG1448P1H001 9LG1448P1M001 9LG1448P5G001 9LG1448P5S001 9RF0912P1H001 9RF0924P1H001 9RF1312P3H001 9RF1324P3H001 9S0612F401 9S0612F4011 9S0612H401 9S0612H4011 9S0612M401 9S0612M4011 9LG0924L4002 9LG0924M4002 - - - 9LG0924H4002 - - 9LG1212F1002 9LG1212M1002 - - - 9LG1224A1002 9LG1224F1002 9LG1224M1002 - - - 9LG1248F1002 9LG1248M1002 9LG1248G1002 - - 9LG1412A5002 9LG1412H5002 9LG1412L1002 9LG1412M5002 - - 9LG1412M1002 - 9LG1412S5001 9LG1424A5002 9LG1424H5002 9LG1424L1002 9LG1424M5002 - - 9LG1424M1002 - 9LG1424S5002 9LG1448A5002 9LG1448H5002 9LG1448L1002 9LG1448M5002 - - 9LG1448M1002 - - - - - - 9S0612F402 9S0612F4021 9S0612H402 9S0612H4021 9S0612M402 9S0612M4021 With pulse sensor With lock sensor 9LG0924L4001 9LG0924M4001 - - - 9LG0924H4001 - - 9LG1212F1001 9LG1212M1001 - - - 9LG1224A1001 9LG1224F1001 9LG1224M1001 - 9LG1224H1001 9LG1224S1001 9LG1248F1001 9LG1248M1001 - - - 9LG1412A5001 9LG1412H5001 9LG1412L1001 9LG1412M5001 - - 9LG1412M1001 - - 9LG1424A5001 9LG1424H5001 9LG1424L1001 9LG1424M5001 - - 9LG1424M1001 - 9LG1424S5001 9LG1448A5001 9LG1448H5001 9LG1448L1001 9LG1448M5001 - - 9LG1448M1001 - - - - - - 9S0612F401 9S0612F4011 9S0612H401 9S0612H4011 9S0612M401 9S0612M4011 9LG0924L4D001 9LG0924M4D001 - - - 9LG0924H4D001 9LG0924J4D001 9LG0924S4D001 9LG1212F1D001 9LG1212M1D001 - 9LG1212H1D001 - 9LG1224A1D001 9LG1224F1D001 9LG1224M1D001 9LG1224G1D001 9LG1224H1D001 9LG1224S1D001 9LG1248F1D001 9LG1248M1D001 - - - 9LG1412A5D001 9LG1412H5D001 - 9LG1412M5D001 - - 9LG1412M1D001 - - 9LG1424A5D001 9LG1424H5D001 9LG1424L1D001 9LG1424M5D001 - - 9LG1424M1D001 - 9LG1424S5D001 9LG1448A5D001 9LG1448H5D001 9LG1448L1D001 9LG1448M5D001 - - 9LG1448M1D001 - - - - - - 9S0612F4D01 9S0612F4D011 9S0612H4D01 9S0612H4D011 9S0612M4D01 9S0612M4D011 Frame size Rib page No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No Yes No Yes No Yes No 412 412 417 417 412 412 412 412 420 420 420 420 420 420 420 420 420 420 420 420 420 420 420 420 433 433 428 433 428 428 428 433 433 433 433 428 433 428 428 428 433 433 433 433 428 433 428 428 428 433 433 264 264 267 267 78 78 78 78 78 78 With PWM control function and pulse sensor - - 9LG0924P1F001 9LG0924P1H001 9LG0924P4G001 9LG0924P4H001 9LG0924P4J001 9LG0924P4S001 - - 9LG1212P1G001 9LG1212P1H001 9LG1212P1S001 - - - 9LG1224P1G001 9LG1224P1H001 9LG1224P1S001 - - 9LG1248P1G001 9LG1248P1H001 9LG1248P1S001 - - - - 9LG1412P1A001 9LG1412P1H001 9LG1412P1M001 9LG1412P5G001 9LG1412P5S001 - - - - 9LG1424P1A001 9LG1424P1H001 9LG1424P1M001 9LG1424P5G001 9LG1424P5S001 - - - - 9LG1448P1A001 9LG1448P1H001 9LG1448P1M001 9LG1448P5G001 9LG1448P5S001 9RF0912P1H001 9RF0924P1H001 9RF1312P3H001 9RF1324P3H001 9S0612P4F01 9S0612P4F011 9S0612P4H01 9S0612P4H011 9S0612P4M01 - 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 51 mm ø 92 × 38 mm ø 92 × 38 mm ø 136 × 28 mm ø 136 × 28 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 635 Index by Model No. Without sensor DC Models listed in product pages List of models Models listed in product pages (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Index by Model No. Without sensor 9S0612S401 9S0612S4011 9S0812F401 9S0812F4011 9S0812H401 9S0812H4011 9S0812L401 9S0812L4011 9S0812M401 9S0812M4011 9S0824L401 9S0824L4011 9S0824M401 9S0824M4011 9S0912F401 9S0912F4011 9S0912L401 9S0912L4011 9S0912M401 9S0912M4011 9S0924F401 9S0924F4011 9S0924L401 9S0924L4011 9S0924M401 9S0924M4011 9S1212F401 9S1212F4011 9S1212H401 9S1212H4011 9S1212L401 9S1212L4011 9S1212M401 9S1212M4011 9S1224M401 9S1224M4011 9SG1212G101 9SG1224G101 9SG1224H101 9SG1248G101 9SG5724P5H61 9SG5748P5G01 9SG5748P5H01 9TD12P6G001 9TG24P0G01 9TG24P0S01 9TG48P0G01 9TGA24P0H001 9TGA48P0G001 9TJ24P0H61 9TJ48P0H01 9TM24P4H01 9TM48P4H01 9TN24P1H01 9TN48P1H01 9TP24P0H001 9TP48P0G001 9TP48P0H001 9TS48P0G001 9TS48P0H001 9W1BM12P2H001 9S0612S402 - 9S0812F402 9S0812F4021 9S0812H402 - 9S0812L402 9S0812L4021 9S0812M402 9S0812M4021 9S0824L402 9S0824L4021 9S0824M402 9S0824M4021 9S0912F402 9S0912F4021 9S0912L402 9S0912L4021 9S0912M402 9S0912M4021 9S0924F402 9S0924F4021 9S0924L402 9S0924L4021 9S0924M402 9S0924M4021 9S1212F402 9S1212F4021 9S1212H402 9S1212H4021 9S1212L402 9S1212L4021 9S1212M402 9S1212M4021 9S1224M402 9S1224M4021 9SG1212G102 9SG1224G102 9SG1224H102 9SG1248G102 9SG5724H562 - - - 9TG24G002 9TG24S002 - - - - - - 9TM48H402 - - - 9TP48G0002 - - - - With pulse sensor With lock sensor 9S0612S401 9S0612S4011 9S0812F401 9S0812F4011 9S0812H401 9S0812H4011 9S0812L401 9S0812L4011 9S0812M401 9S0812M4011 9S0824L401 9S0824L4011 9S0824M401 9S0824M4011 9S0912F401 9S0912F4011 9S0912L401 9S0912L4011 9S0912M401 9S0912M4011 9S0924F401 9S0924F4011 9S0924L401 9S0924L4011 9S0924M401 9S0924M4011 9S1212F401 9S1212F4011 9S1212H401 9S1212H4011 9S1212L401 9S1212L4011 9S1212M401 9S1212M4011 9S1224M401 9S1224M4011 9SG1212G101 9SG1224G101 9SG1224H101 9SG1248G101 - - - - 9TG24G001 9TG24S001 - - - - - - - - - - - - - - - 9S0612S4D01 - 9S0812F4D01 9S0812F4D011 9S0812H4D01 9S0812H4D011 9S0812L4D01 9S0812L4D011 9S0812M4D01 9S0812M4D011 9S0824L4D01 9S0824L4D011 9S0824M4D01 9S0824M4D011 9S0912F4D01 9S0912F4D011 9S0912L4D01 9S0912L4D011 9S0912M4D01 9S0912M4D011 9S0924F4D01 - 9S0924L4D01 - 9S0924M4D01 - 9S1212F4D01 9S1212F4D011 9S1212H4D01 - 9S1212L4D01 9S1212L4D011 9S1212M4D01 9S1212M4D011 9S1224M4D01 9S1224M4D011 9SG1212G1D01 9SG1224G1D01 9SG1224H1D01 - - - - - - - - - - - - - - - - - - - - - - Frame size Rib page 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm ø 70 × 20 mm ø 175 × 69 mm ø 175 × 69 mm ø 175 × 69 mm ø 175 × 69 mm ø 175 × 69 mm ø 133 × 91 mm ø 133 × 91 mm ø 100 × 25 mm ø 100 × 25 mm ø 150 × 35 mm ø 150 × 35 mm ø 221 × 71 mm ø 221 × 71 mm ø 221 × 71 mm ø 225 × 99 mm ø 225 × 99 mm 97 × 33 mm Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No No No No No No No No No - - - - - - - - - - - - - - - - - 78 78 112 112 112 112 112 112 112 112 112 112 112 112 145 145 145 145 145 145 145 145 145 145 145 145 176 176 176 176 176 176 176 176 176 176 184 184 184 184 207 207 207 464 476 476 476 473 473 469 469 466 466 471 471 479 479 479 482 482 360 With PWM control function and pulse sensor 9S0612P4S01 9S0612P4S011 9S0812P4F01 9S0812P4F011 - - - - 9S0812P4M01 9S0812P4M011 - - - - 9S0912P4F01 9S0912P4F011 - - 9S0912P4M01 9S0912P4M011 - - - - - - 9S1212P4F01 9S1212P4F011 9S1212P4H01 9S1212P4H011 - 9S1212P4L011 9S1212P4M01 9S1212P4M011 - - 9SG1212P1G01 9SG1224P1G01 - 9SG1248P1G01 9SG5724P5H61 9SG5748P5G01 9SG5748P5H01 9TD12P6G001 9TG24P0G01 9TG24P0S01 9TG48P0G01 9TGA24P0H001 9TGA48P0G001 9TJ24P0H61 9TJ48P0H01 9TM24P4H01 9TM48P4H01 9TN24P1H01 9TN48P1H01 9TP24P0H001 9TP48P0G001 9TP48P0H001 9TS48P0G001 9TS48P0H001 9W1BM12P2H001 Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 636 CATALOG No. C1111B002 '21.9.IT List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) 9W1BM12P2M001 9W1BM24P2H001 9W1BM24P2M001 9W1TG48P0H61 9W1TJ24P0H61 9W1TJ48P0H61 9W1TM48P4G01 9W1TM48P4H01 9W1TN48P1H01 9W2TGA48P0G001 9W2TN24P1H001 9W2TN48P1H001 9W2TP24P0H001 9W2TP48P0S001 9W2TS48P0S001 9WE1724K501 9WE5724K501 9WE5748K501 9WF0424F601 9WF0424H601 9WF0424H701 9WF0624H401 9WF0624H601 9WF0624H701 9WF0824S401 9WF0924H201 9WF0924H2011 9WF0924H401 9WF0924H4011 9WF0924S201 9WF0924S2011 9WF1224H101 9WFA0424G6001 9WFA0624G6001 9WFA0824G6001 9WFA0924G2001 9WFA0924G4001 9WFA0924G40011 9WFA0924H4001 9WFA0924H40011 9WG1212E101-E 9WG1212F101-E 9WG1212G101-E 9WG1212H101-E 9WG1212M101-E 9WG1224E101-E 9WG1224F101-E 9WG1224G101-E 9WG1224H101-E 9WG1224M101-E 9WG1248E101-E 9WG1248F101-E 9WG1248G101-E 9WG1248H101-E 9WG1248M101-E 9WG5748P5G001 9WG5748P5H001 9WL0412P3G001 9WL0412P3J001 9WL0424P3G001 9WL0424P3J001 With pulse sensor With lock sensor - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 9WE1724K502 9WE5724K502 9WE5748K502 9WF0424F602 9WF0424H602 9WF0424H702 9WF0624H402 - 9WF0624H702 9WF0824S402 9WF0924H202 - 9WF0924H402 - 9WF0924S202 - 9WF1224H102 9WFA0424G6002 9WFA0624G6002 9WFA0824G6002 9WFA0924G2002 - - - - 9WG1212E102-E 9WG1212F102-E 9WG1212G102-E 9WG1212H102-E 9WG1212M102-E 9WG1224E102-E 9WG1224F102-E 9WG1224G102-E 9WG1224H102-E 9WG1224M102-E 9WG1248E102-E 9WG1248F102-E 9WG1248G102-E 9WG1248H102-E 9WG1248M102-E 9WG5748G5002 9WG5748H5002 9WL0412G3002 9WL0412J3002 9WL0424G3002 9WL0424J3002 9WE1724K501 9WE5724K501 9WE5748K501 9WF0424F601 9WF0424H601 9WF0424H701 9WF0624H401 9WF0624H601 9WF0624H701 9WF0824S401 9WF0924H201 9WF0924H2011 9WF0924H401 9WF0924H4011 9WF0924S201 9WF0924S2011 9WF1224H101 9WFA0424G6001 9WFA0624G6001 9WFA0824G6001 9WFA0924G2001 9WFA0924G4001 9WFA0924G40011 9WFA0924H4001 9WFA0924H40011 9WG1212E101-E 9WG1212F101-E 9WG1212G101-E 9WG1212H101-E 9WG1212M101-E 9WG1224E101-E 9WG1224F101-E 9WG1224G101-E 9WG1224H101-E 9WG1224M101-E 9WG1248E101-E 9WG1248F101-E 9WG1248G101-E 9WG1248H101-E 9WG1248M101-E - 9WG5748H5001 9WL0412G3001 9WL0412J3001 9WL0424G3001 9WL0424J3001 - - - - - - - - - - - - - - - - - 9WE5748K5D01 9WF0424F6D01 9WF0424H6D01 9WF0424H7D01 9WF0624H4D01 9WF0624H6D01 9WF0624H7D01 9WF0824S4D01 9WF0924H2D01 - 9WF0924H4D01 9WF0924H4D011 9WF0924S2D01 - 9WF1224H1D01 9WFA0424G6D001 9WFA0624G6D001 9WFA0824G6D001 9WFA0924G2D001 - - - - 9WG1212E1D01-E 9WG1212F1D01-E 9WG1212G1D01-E 9WG1212H1D01-E 9WG1212M1D01-E 9WG1224E1D01-E 9WG1224F1D01-E 9WG1224G1D01-E 9WG1224H1D01-E 9WG1224M1D01-E 9WG1248E1D01-E 9WG1248F1D01-E 9WG1248G1D01-E 9WG1248H1D01-E 9WG1248M1D01-E - 9WG5748H5D001 9WL0412G3D001 - - - Frame size Rib page 97 × 33 mm 97 × 33 mm 97 × 33 mm ø 175 × 69 mm ø 133 × 91 mm ø 133 × 91 mm ø 100 × 25 mm ø 100 × 25 mm ø 150 × 35 mm ø 175 × 69 mm ø 150 × 35 mm ø 150 × 35 mm ø 221 × 71 mm ø 221 × 71 mm ø 225 × 99 mm ø 172 × 51 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 40 × 40 × 15 mm 60 × 60 × 25 mm 60 × 60 × 20 mm 60 × 60 × 15 mm 80 × 80 × 25 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 32 mm 92 × 92 × 32 mm 120 × 120 × 38 mm 40 × 40 × 20 mm 60 × 60 × 20 mm 80 × 80 × 20 mm 92 × 92 × 32 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm ø 172 × 150 × 51 mm ø 172 × 150 × 51 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm 40 × 40 × 28 mm - - - - - - - - - - - - - - - 360 360 360 346 337 337 334 334 342 344 339 339 348 348 351 330 328 328 368 368 364 376 374 370 380 388 388 384 384 388 388 390 366 372 378 386 382 382 382 382 310 310 310 310 310 310 310 310 310 310 310 310 310 310 310 326 326 272 272 272 272 With PWM control function and pulse sensor 9W1BM12P2M001 9W1BM24P2H001 9W1BM24P2M001 9W1TG48P0H61 9W1TJ24P0H61 9W1TJ48P0H61 9W1TM48P4G01 9W1TM48P4H01 9W1TN48P1H01 9W2TGA48P0G001 9W2TN24P1H001 9W2TN48P1H001 9W2TP24P0H001 9W2TP48P0S001 9W2TS48P0S001 - - 9WE5748P5K01 - - - - - - - - - - - - - - 9WFA0424P6G001 9WFA0624P6G001 9WFA0824P6G001 9WFA0924P2G001 9WFA0924P4G001 9WFA0924P4G0011 9WFA0924P4H001 9WFA0924P4H0011 - - - - - - - - - - - - - - - 9WG5748P5G001 9WG5748P5H001 9WL0412P3G001 9WL0412P3J001 9WL0424P3G001 9WL0424P3J001 No No No Yes Yes Yes Yes Yes Yes Yes Yes No Yes No Yes No Yes Yes Yes Yes Yes Yes No Yes No No No No No No No No No No No No No No No No No No No No No No Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 637 Index by Model No. Without sensor DC Models listed in product pages List of models Models listed in product pages (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Index by Model No. Without sensor 9WL0612P4H001 9WL0612P4J001 9WL0612P4S001 9WL0624P4H001 9WL0624P4J001 9WL0624P4S001 9WL0812L4001 9WL0812P4G001 9WL0812P4H001 9WL0812P4J001 9WL0824F4001 9WL0824L4001 9WL0824P4G001 9WL0824P4H001 9WL0824P4J001 9WL0912M4001 9WL0912P1F001 9WL0912P1H001 9WL0912P4G001 9WL0912P4H001 9WL0912P4J001 9WL0912P4S001 9WL0924F4001 9WL0924M4001 9WL0924P1F001 9WL0924P1H001 9WL0924P4H001 9WL0924P4J001 9WL0924P4S001 9WL0948P1F601 9WL0948P1H601 9WL1412P1A001 9WL1412P1H001 9WL1412P1M001 9WL1412A5001 9WL1412H5001 9WL1412M5001 9WL1412P5G001 9WL1412P5S001 9WL1424P1A001 9WL1424P1H001 9WL1424P1M001 9WL1424A5001 9WL1424H5001 9WL1424M5001 9WL1424P5G001 9WL1424P5S001 9WL1448A5001 9WL1448H5001 9WL1448L1001 9WL1448M5001 9WL1448P1A001 9WL1448P1H001 9WL1448P1M001 9WL1448P5G001 9WL1448P5S001 9WP0412F6001 9WP0412H6001 9WP0612D401 9WP0612D4011 9WP0612G401 9WL0612H4002 9WL0612J4002 9WL0612S4002 - - 9WL0624S4002 9WL0812L4002 - 9WL0812H4002 - 9WL0824F4002 9WL0824L4002 - 9WL0824H4002 9WL0824J4002 9WL0912M4002 - - - 9WL0912H4002 9WL0912J4002 - 9WL0924F4002 9WL0924M4002 9WL0924F1002 - 9WL0924H4002 - - - - - - 9WL1412M1002 9WL1412A5002 9WL1412H5002 9WL1412M5002 - - - - 9WL1424M1002 9WL1424A5002 9WL1424H5002 9WL1424M5002 - - 9WL1448A5002 9WL1448H5002 9WL1448L1002 9WL1448M5002 - - 9WL1448M1002 - - 9WP0412F6002 9WP0412H6002 9WP0612D402 - 9WP0612G402 With pulse sensor With lock sensor With PWM control function and pulse sensor - - - - 9WL0612J4D001 9WL0612S4D001 - 9WL0624J4D001 - - 9WL0812G4D001 9WL0812H4D001 - - - - 9WL0824H4D001 - - - - - 9WL0912H4D001 - - - 9WL0924M4D001 - - 9WL0924H4D001 - - - - - - 9WL1412M1D001 9WL1412A5D001 9WL1412H5D001 9WL1412M5D001 9WL1412G5D001 - - - 9WL1424M1D001 9WL1424A5D001 9WL1424H5D001 9WL1424M5D001 - - 9WL1448A5D001 9WL1448H5D001 9WL1448L1D001 9WL1448M5D001 - - 9WL1448M1D001 - - 9WP0412F6D001 - 9WP0612D4D01 9WP0612D4D011 9WP0612G4D01 9WL0612P4H001 9WL0612P4J001 9WL0612P4S001 9WL0624P4H001 9WL0624P4J001 9WL0624P4S001 - 9WL0812P4G001 9WL0812P4H001 9WL0812P4J001 - 9WL0624H4001 - 9WL0624S4001 9WL0812L4001 - 9WL0812H4001 - 9WL0824F4001 9WL0824L4001 - 9WL0824H4001 9WL0912M4001 - - - 9WL0912H4001 - - 9WL0924F4001 9WL0924M4001 - - 9WL0924H4001 - - - - - - 9WL1412M1001 9WL1412A5001 9WL1412H5001 9WL1412M5001 - - - - 9WL1424M1001 9WL1424A5001 9WL1424H5001 9WL1424M5001 9WL1424G5001 - 9WL1448A5001 9WL1448H5001 9WL1448L1001 9WL1448M5001 - - 9WL1448M1001 - - 9WP0412F6001 9WP0412H6001 9WP0612D401 9WP0612D4011 9WP0612G401 9WL0824P4G001 9WL0824P4H001 9WL0824P4J001 - 9WL0912P1F001 9WL0912P1H001 9WL0912P4G001 9WL0912P4H001 9WL0912P4J001 9WL0912P4S001 - - 9WL0924P1F001 9WL0924P1H001 9WL0924P4H001 9WL0924P4J001 9WL0924P4S001 9WL0948P1F601 9WL0948P1H601 9WL1412P1A001 9WL1412P1H001 9WL1412P1M001 - - - 9WL1412P5G001 9WL1412P5S001 9WL1424P1A001 9WL1424P1H001 9WL1424P1M001 - - - 9WL1424P5G001 9WL1424P5S001 - - - - 9WL1448P1A001 9WL1448P1H001 9WL1448P1M001 9WL1448P5G001 9WL1448P5S001 - - - - 9WP0612P4G01 Frame size 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 38 mm 140 × 140 × 51 mm 140 × 140 × 51 mm 40 × 40 × 20 mm 40 × 40 × 20 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 638 CATALOG No. C1111B002 '21.9.IT Rib page No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No No Yes Yes Yes No Yes 277 277 277 277 277 277 285 285 285 285 285 285 285 285 285 295 302 302 295 295 295 295 295 295 302 302 295 295 295 302 302 316 316 316 321 321 321 321 321 316 316 316 321 321 321 321 321 321 321 316 321 316 316 316 321 321 270 270 280 280 280 List of models Without sensor With pulse sensor With lock sensor 9WP0612G4021 9WP0612H402 9WP0612H4021 9WP0624G402 - 9WP0624H402 9WP0624H4021 9WP0624J402 - 9WP0648H402 9WP0648H4021 9WP0812G402 9WP0812G4021 9WP0812H402 9WP0812H4021 9WP0824H402 9WP0824H4021 9WP0824S402 9WP0824S4021 9WP0848S402 9WP0848S4021 9WP0912F402 - 9WP0912S402 - 9WP0924B402 9WP0924B4021 9WP0924F402 9WP0924F4021 9WP0924G402 - 9WP0924H402 - 9WP0924S402 - 9WP1212H102 9WP1212H1021 9WP1212L102 - 9WP1212M102 9WP1212M1021 9WP1224H102 9WP1224H1021 9WP1224M102 9WP1224M1021 9WP1248H102 9WP1248H1021 9WP1248M102 9WP1248M1021 9WPA0612G4002 - 9WPA0624G4002 - 9WPA0812G4002 - 9WPA0824G4002 - - - - - 9WP0612G4011 9WP0612H401 9WP0612H4011 9WP0624G401 9WP0624G4011 9WP0624H401 9WP0624H4011 9WP0624J401 9WP0624J4011 9WP0648H401 9WP0648H4011 9WP0812G401 9WP0812G4011 9WP0812H401 9WP0812H4011 9WP0824H401 9WP0824H4011 9WP0824S401 9WP0824S4011 9WP0848S401 9WP0848S4011 9WP0912F401 9WP0912F4011 9WP0912S401 9WP0912S4011 9WP0924B401 9WP0924B4011 9WP0924F401 9WP0924F4011 9WP0924G401 9WP0924G4011 9WP0924H401 9WP0924H4011 9WP0924S401 9WP0924S4011 9WP1212H101 9WP1212H1011 9WP1212L101 9WP1212L1011 9WP1212M101 9WP1212M1011 9WP1224H101 9WP1224H1011 9WP1224M101 9WP1224M1011 9WP1248H101 9WP1248H1011 9WP1248M101 9WP1248M1011 9WPA0612G4001 - 9WPA0624G4001 - 9WPA0812G4001 - 9WPA0824G4001 - - - - - - 9WP0612H4D01 9WP0612H4D011 9WP0624G4D01 - 9WP0624H4D01 9WP0624H4D011 - - 9WP0648H4D01 9WP0648H4D011 9WP0812G4D01 9WP0812G4D011 9WP0812H4D01 9WP0812H4D011 9WP0824H4D01 9WP0824H4D011 9WP0824S4D01 - 9WP0848S4D01 9WP0848S4D011 9WP0912F4D01 9WP0912F4D011 9WP0912S4D01 - 9WP0924B4D01 9WP0924B4D011 9WP0924F4D01 9WP0924F4D011 9WP0924G4D01 - 9WP0924H4D01 - 9WP0924S4D01 - 9WP1212H1D01 9WP1212H1D011 - - - - 9WP1224H1D01 9WP1224H1D011 - - 9WP1248H1D01 9WP1248H1D011 9WP1248M1D01 9WP1248M1D011 9WPA0612G4D001 - 9WPA0624G4D001 - 9WPA0812G4D001 - 9WPA0824G4D001 - - - - - Frame size Rib page No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No Yes No 280 280 280 280 280 280 280 280 280 280 280 289 289 289 289 289 289 289 289 289 289 299 299 299 299 299 299 299 299 299 299 299 299 299 299 313 313 313 313 313 313 313 313 313 313 313 313 313 313 275 275 275 275 283 283 283 283 293 293 293 293 With PWM control function and pulse sensor - - - - - - - - - - - 9WP0812P4G01 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 9WPA0612P4G001 9WPA0612P4G0011 9WPA0624P4G001 9WPA0624P4G0011 9WPA0812P4G001 9WPA0812P4G0011 9WPA0824P4G001 9WPA0824P4G0011 9WPA0912P4G001 9WPA0912P4G0011 9WPA0924P4G001 9WPA0924P4G0011 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. CATALOG No. C1111B002 '21.9.IT 639 Index by Model No. 9WP0612G4011 9WP0612H401 9WP0612H4011 9WP0624G401 9WP0624G4011 9WP0624H401 9WP0624H4011 9WP0624J401 9WP0624J4011 9WP0648H401 9WP0648H4011 9WP0812G401 9WP0812G4011 9WP0812H401 9WP0812H4011 9WP0824H401 9WP0824H4011 9WP0824S401 9WP0824S4011 9WP0848S401 9WP0848S4011 9WP0912F401 9WP0912F4011 9WP0912S401 9WP0912S4011 9WP0924B401 9WP0924B4011 9WP0924F401 9WP0924F4011 9WP0924G401 9WP0924G4011 9WP0924H401 9WP0924H4011 9WP0924S401 9WP0924S4011 9WP1212H101 9WP1212H1011 9WP1212L101 9WP1212L1011 9WP1212M101 9WP1212M1011 9WP1224H101 9WP1224H1011 9WP1224M101 9WP1224M1011 9WP1248H101 9WP1248H1011 9WP1248M101 9WP1248M1011 9WPA0612P4G001 9WPA0612P4G0011 9WPA0624P4G001 9WPA0624P4G0011 9WPA0812P4G001 9WPA0812P4G0011 9WPA0824P4G001 9WPA0824P4G0011 9WPA0912P4G001 9WPA0912P4G0011 9WPA0924P4G001 9WPA0924P4G0011 (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) DC Models listed in product pages List of models (Below are optional models and not listed in product pages. Standard compliance of these optional models may differ from that of the models listed in product pages. Contact us for details of "-" models.) Models listed in product pages Without sensor 9WV0812P1M001 9WV0812P1M0011 9WV0848P1H001 9WV0848P1H0011 9WV0924P1H001 9WV0948P1H001 9WV1212P1J001 9WV1224P1H001 9WV1224P1J601 9WV1248P1J001 - - - - 9WV0924H1002 - 9WV1212J1002 9WV1224H102 9WV1224J1002 9WV1248J1002 With pulse sensor With lock sensor 9WV0812M1001 - - - - - - 9WV1224H101 9WV1224J1001 9WV1248J1001 9WV0812M1D001 - - - 9WV1212J1D001 9WV1224H1D001 - 9WV1248J1D001 Frame size 9WV0812P1M001 9WV0812P1M0011 9WV0848P1H001 9WV0848P1H0011 9WV0924P1H001 9WV0948P1H001 9WV1212P1J001 9WV1224P1H001 9WV1224P1J601 9WV1248P1J001 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm DC Index by Model No. Note 1: For compliance with standards, see individual product pages. Please contact your point of sale regarding low-speed sensors. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. 640 CATALOG No. C1111B002 '21.9.IT Rib page Yes No Yes No Yes Yes No No No No 291 291 291 291 305 305 307 307 307 307 With PWM control function and pulse sensor Index by Model No./Safety Standards List - ACDC Fans Models listed in product pages Option Standard Frame size Model Rated voltage [V] Rib Pulse sensor 9AD0901H12 9AD0901H121 9AD0901H1H 9AD0901H1H1 9AD0901M12 9AD0901M121 9AD0901M1H 9AD0901M1H1 9AD1201H12 9AD1201H121 9AD1201H1H 9AD1201H1H1 9ADTS11P0F001 9ADTS11P0G001 9ADTS23P0F001 9ADTS23P0G001 9ADW1TS11P0H001 9ADW1TS11P0M001 9ADW1TS23P0H001 9ADW1TS23P0M001 9ADB1TS11P0F001 9ADB1TS11P0G001 9ADB1TS23P0F001 9ADB1TS23P0G001 9ADB1W1TS11P0H001 9ADB1W1TS11P0M001 9ADB1W1TS23P0H001 9ADB1W1TS23P0M001 9AD0901H11 9AD0901H111 9AD0901H11 9AD0901H111 9AD0901M11 9AD0901M111 9AD0901M11 9AD0901M111 9AD1201H11 9AD1201H111 9AD1201H11 9AD1201H111 - - - - - - - - - - - - - - - - 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 92 × 92 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm ø 225 × 99 mm ø 225 × 99 mm ø 225 × 99 mm ø 225 × 99 mm ø 225 × 99 mm ø 225 × 99 mm ø 225 × 99 mm ø 225 × 99 mm 270 × 270 × 119 mm 270 × 270 × 119 mm 270 × 270 × 119 mm 270 × 270 × 119 mm 270 × 270 × 119 mm 270 × 270 × 119 mm 270 × 270 × 119 mm 270 × 270 × 119 mm San Ace 92AD San Ace 92AD San Ace 92AD San Ace 92AD San Ace 92AD San Ace 92AD San Ace 92AD San Ace 92AD San Ace 120AD San Ace 120AD San Ace 120AD San Ace 120AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD San Ace 225AD 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 100 to 240 115 115 230 230 115 115 230 230 115 115 230 230 115 115 230 230 Yes No Yes No Yes No Yes No Yes No Yes No - - - - - - - - - - - - - - - - (certification status is for the models listed in this catalog, and standards for optional model numbers may differ.) UL (cUL) CSA (cUL) TÜV CE PSE ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - - - - - - - - - - - - - - - - page 516 516 516 516 516 516 516 516 519 519 519 519 522 522 522 522 525 525 525 525 528 528 528 528 531 531 531 531 ACDC Index by Model No. Note 1: Please contact your point of sale for pulse sensors and lock sensors. mark indicates Short Lead Time Service applicable models. See p. 654 for details. Note 2: The CATALOG No. C1111B002 '21.9.IT 641 Index by Model No./Safety Standards List - AC Fans AC Index by Model No. Models listed in product pages 109-033UL 109-040UL 109-041UL 109-043UL 109-044UL 109-047UL 109-130 109-133 109-150 109-151 109-153 109-154 109-180 109-183 109-210 109-213 109-311 109-312 109-313 109-314 109-371 109-372 109-373 109-374 109-601 109-602 109-603 109-604 109-641 109-642 109-643 109-644 109S005 109S005UL 109S006 109S006UL 109S008 109S008UL 109S010 109S010UL 109S013 109S013UL 109S024 109S024UL 109S025 109S025UL 109S029UL 109S030 109S031 109S033 109S034 109S050 109S051 109S053 109S054 109S072UL 109S074UL 109S075UL 109S078UL 109S081 109S082 109S083 109S084 109S085 642 Frame size 80 × 80 × 42 mm 80 × 80 × 42 mm 80 × 80 × 42 mm 80 × 80 × 42 mm 80 × 80 × 42 mm 80 × 80 × 42 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 80 × 80 × 38 mm 60 × 60 × 28 mm 60 × 60 × 28 mm 80 × 80 × 20 mm 80 × 80 × 20 mm ø 172 × 51 mm (Round type) ø 172 × 51 mm (Round type) ø 172 × 51 mm (Round type) ø 172 × 51 mm (Round type) ø 172 × 51 mm (with sensor) ø 172 × 51 mm (with sensor) ø 172 × 51 mm (with sensor) ø 172 × 51 mm (with sensor) 160 × 160 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm (with sensor) 160 × 160 × 51 mm (with sensor) 160 × 160 × 51 mm (with sensor) 160 × 160 × 51 mm (with sensor) 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm CATALOG No. C1111B002 '21.9.IT Model San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 60 San Ace 60 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 60 San Ace 60 San Ace 80 San Ace 80 San Ace 172 San Ace 172 San Ace 172 San Ace 172 San Ace 172 San Ace 172 San Ace 172 San Ace 172 San Ace 160 San Ace 160 San Ace 160 San Ace 160 San Ace 160 San Ace 160 San Ace 160 San Ace 160 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 80 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 115 100 200 115 230 100 100 115 100 200 115 230 100 115 100 115 100 200 230 115 100 200 230 115 100 200 230 115 100 200 230 115 100 100 100 100/115 200 200 200 200/240 100 100 120 115 230 230 100 100 200 115 230 100 200 115 230 230 115 100 200 100 200 115 115 100 CSA TÜV CE PSE ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - ✓ - - - - - ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ - ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ Rated voltage [V] UL ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - - ✓ ✓ ✓ ✓ - - ✓ ✓ ✓ ✓ ✓ ✓ - - - - ✓ ✓ ✓ ✓ - - ✓ ✓ ✓ ✓ - - - - ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ Note page 546 546 546 546 546 546 538 538 544 544 544 544 536 536 540 540 566 566 566 566 566 566 566 566 561 561 561 561 561 561 561 561 556 556 556 556 556 556 556 556 556 556 556 556 556 556 556 542 542 542 542 542 542 542 542 556 556 556 556 552 552 552 552 552 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 120 × 120 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm ø 172 × 150 × 51 mm (Sidecut type) ø 172 × 150 × 51 mm (Sidecut type) ø 172 × 150 × 51 mm (Sidecut type) ø 172 × 150 × 51 mm (Sidecut type) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 38 mm (with sensor) 120 × 120 × 25 mm (with sensor) 120 × 120 × 25 mm (with sensor) 120 × 120 × 25 mm (with sensor) 120 × 120 × 25 mm (with sensor) 120 × 120 × 25 mm (with sensor) 92 × 92 × 25 mm (with sensor) 92 × 92 × 25 mm (with sensor) 92 × 92 × 25 mm (with sensor) 92 × 92 × 25 mm (with sensor) 92 × 92 × 25 mm (with sensor) 92 × 92 × 25 mm (with sensor) Model San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 172 San Ace 172 San Ace 172 San Ace 172 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 120 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 92 San Ace 92 Rated voltage [V] UL 100 230 200 230 100 200 115 230 100 100 200 115 230 100 200 230 115 100 100 200 115 230 100 230 115 100 200 115 100 100 230 200 100 200 115 230 100 100 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ CSA TÜV ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ - - - - - - - - - - - - - - - - - - - - - ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ CE PSE ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ Note page 552 552 552 552 548 548 548 548 548 548 548 548 548 564 564 564 564 557 557 557 557 557 557 557 557 557 557 552 552 552 552 552 548 548 548 548 548 548 Index by Model No. 109S086 109S087 109S088 109S089 109S091 109S092 109S093 109S094 109S095 109S096 109S192 109S193 109S194 109S301 109S302 109S303 109S304 109S405UL 109S406UL 109S408UL 109S424UL 109S425UL 109S429UL 109S472UL 109S474UL 109S475UL 109S478UL 109S484 109S485 109S486 109S487 109S488 109S491 109S492 109S493 109S494 109S495 109S496 Frame size AC Models listed in product pages CATALOG No. C1111B002 '21.9.IT 643 Index by Model No. - Options ■ Finger Guards Index by Model No. Model no. 109-019C 109-019E 109-019H 109-019K 109-049C 109-049E 109-049H 109-059 109-059H 109-099C 109-099E 109-099H 109-1050 109-1051 109-1052 109-1065 109-1066 109-1068 109-1102 109-1102H 109-1103 109-1103H 109-1104 109-1104H 109-1112 109-1128 109-1137 109-1137H 109-1138 109-1138H 109-1139 109-1146 109-1146H 109-1147 109-139E 109-139H 109-149 109-149E 109-319E 109-319H 109-319J 109-320 109-619E 109-619H 109-620 109-719 109-719H 109-720 109-720H 109-721 109-721H 109-722 109-722H 109-723 644 ■ Resin Finger Guards/Resin Filter Kits Category Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards Finger Guards CATALOG No. C1111B002 '21.9.IT Matching fan size page Model no. 120 mm sq. type 120 mm sq. type 120 mm sq. type 120 mm sq. type 80 mm sq. type 80 mm sq. type 80 mm sq. type 40 mm sq. type 40 mm sq. type 92 mm sq. type 92 mm sq., ø100 mm type 92 mm sq., ø100 mm type 36 mm sq. type 150 mm sq. type 150 mm sq. type 38 mm sq. type ø172 mm type ø 172 mm type ø 200 mm type ø 200 mm type ø 200 mm type ø 200 mm type ø 150 mm type ø 150 mm type ø 133 mm type 70 mm sq., ø70 mm type ø 225 mm type ø 225 mm type ø 221 mm type ø 221 mm type ø 136 mm type 270 mm sq. type 270 mm sq. type ø 92 mm type 60 mm sq. type 60 mm sq. type 52 mm sq. type 52 mm sq. type ø 172 mm type ø 172 mm type ø 172 mm type ø 172 mm type 160 mm sq. type 160 mm sq. type 160 mm sq. type 140 mm sq. type 140 mm sq. type ø 200 mm type ø 200 mm type ø 200 mm type ø 200 mm type 127 mm sq., ø175 mm type 127 mm sq., ø175 mm type 127 mm sq. type 585 585 585 585 584 584 584 584 584 584 584 584 584 585 585 584 586 586 587 587 587 587 585 585 585 584 587 587 587 587 585 588 588 584 584 584 584 584 586 586 586 586 585 585 585 585 585 587 587 587 587 585 585 585 109-1000F13 109-1000F20 109-1000F30 109-1000F40 109-1001F13 109-1001F20 109-1001F30 109-1001F40 109-1002F13 109-1002F20 109-1002F30 109-1002F40 109-1003F13 109-1003F20 109-1003F30 109-1003F40 109-1000G 109-1001G 109-1002G 109-1003G Category Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Filter Kits Resin Finger Guards Resin Finger Guards Resin Finger Guards Resin Finger Guards Matching fan size page 120 mm sq. type 120 mm sq. type 120 mm sq. type 120 mm sq. type 92 mm sq. type 92 mm sq. type 92 mm sq. type 92 mm sq. type 80 mm sq. type 80 mm sq. type 80 mm sq. type 80 mm sq. type 60 mm sq. type 60 mm sq. type 60 mm sq. type 60 mm sq. type 120 mm sq. type 92 mm sq. type 80 mm sq. type 60 mm sq. type 592 592 592 592 592 592 592 592 592 592 592 592 592 592 592 592 591 591 591 591 Matching fan size page 120 mm sq. type 120 mm sq. type 120 mm sq. type 120 mm sq. type 92 mm sq. type 92 mm sq. type 92 mm sq. type 92 mm sq. type 80 mm sq. type 80 mm sq. type 80 mm sq. type 80 mm sq. type 60 mm sq. type 60 mm sq. type 60 mm sq. type 60 mm sq. type 592 592 592 592 592 592 592 592 592 592 592 592 592 592 592 592 ■ Replacement filter Model no. 109-1000M13 109-1000M20 109-1000M30 109-1000M40 109-1001M13 109-1001M20 109-1001M30 109-1001M40 109-1002M13 109-1002M20 109-1002M30 109-1002M40 109-1003M13 109-1003M20 109-1003M30 109-1003M40 Category Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter Replacement filter and splash proof centrifugal fan Model no. 109-1036 109-1037 109-1038 109-1039 109-1040 109-1069 109-1069H 109-1073 109-1073H 109-1080 109-1080H 109-1081 109-1081H 109-1106 109-1134 109-1134H 109-1135 109-1135H Category EMC guards EMC guards EMC guards EMC guards EMC guards Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Inlet nozzle for centrifugal fan and splash proof centrifugal fan Matching fan size ø 172 mm type 120 mm sq. type 80 mm sq. type 80 mm sq. type 92 mm sq. type ø 133 mm type ø 133 mm type ø 175 mm type ø 175 mm type ø 100 mm type ø 100 mm type ø 150 mm type ø 150 mm type ø 70 mm type ø 225 mm type ø 225 mm type ø 221 mm type ø 221 mm type Model no. page 590 590 590 590 590 589 589 589 589 589 589 589 589 589 589 589 589 589 ■ Filter kits/Screen kits Model no. Category 109-018 Filter kits 109-020 Screen kits Matching fan size Note 120 × 120 × 38 mm Not mountable on AC fans with a sensor or 120 × 120 × 38 mm ACDC fans. ■ Plug Cord page 593 593 489-006-L10 489-006-L21 489-006-L35 489-007-L10 489-007-L21 489-008-L10 489-008-L21 489-008-L35 UL CSA PSE ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ 489-016-L10 ✓ 489-016-L21 ✓ 489-037-L10 489-037-L21 489-037-L35 ✓ ✓ ✓ 489-047-L10 ✓ ✓ 489-047-L21 ✓ ✓ 489-084-L10 ✓ ✓ 489-084-L21 ✓ ✓ 489-086-L10 489-086-L21 489-1618-L10 489-1618-L21 489-1618-L28 ✓ ✓ ✓ ✓ ✓ ✓ ✓ 489-1619-L10 ✓ 489-1619-L21 ✓ 489-1635-L10 489-1635-L21 ✓ ✓ ✓ ✓ ✓ ✓ Applicable model page 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 80 × 80 × 42 mm 80 × 80 × 42 mm 80 × 80 × 42 mm 120 × 120 × 25 mm 92 × 92 × 25 mm 80 × 80 × 25 mm 80 × 80 × 38 mm 120 × 120 × 25 mm 92 × 92 × 25 mm 80 × 80 × 25 mm 80 × 80 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 38 mm 120 × 120 × 25 mm 92 × 92 × 25 mm 80 × 80 × 25 mm 80 × 80 × 38 mm 120 × 120 × 25 mm 92 × 92 × 25 mm 80 × 80 × 25 mm 80 × 80 × 38 mm ø 172 × 51 mm ø 172 × 150 × 51 mm 160 × 160 × 51 mm ø 172 × 51 mm ø 172 × 150 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm 160 × 160 × 51 mm ø 172 × 51 mm ø 172 × 150 × 51 mm 160 × 160 × 51 mm ø 172 × 51 mm ø 172 × 150 × 51 mm 160 × 160 × 51 mm ACDC Fan 594 594 594 595 595 594 594 594 594 594 594 594 594 595 595 595 595 595 595 594 594 594 594 594 595 595 Typical Connectors for DC Fans ‥‥‥‥‥‥ page 596 Index by Model No. ■ EMC guards/Inlet nozzle for centrifugal fan CATALOG No. C1111B002 '21.9.IT 645 Deleted Models in this Catalog Following models were deleted in this latest version of catalog. However, these models are not discontinued product. Please contact us for further assistance if necessary. ■ DC Fan Size Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 0.21 0.1 0.07 0.11 0.05 0.04 0.26 0.15 0.26 0.15 0.09 0.07 0.05 0.14 0.08 0.06 0.04 0.13 0.13 0.09 0.07 0.07 0.05 0.07 1.54 1.36 0.85 0.7 0.57 0.35 0.29 1.9 1.0 1.9 1.45 1.0 0.63 2.52 1.2 0.84 2.64 1.2 0.96 1.3 0.75 3.12 1.8 1.08 0.84 0.6 3.36 1.92 1.44 0.96 1.56 1.56 1.08 1.68 1.68 1.2 3.36 18.5 16.3 20.4 16.8 13.68 16.8 13.9 45.6 24 45.6 34.8 24 15.12 6800 4600 3700 6800 4600 3700 4100 3100 6500 5000 4100 3100 2200 6200 5000 4100 3100 4200 4200 3200 4200 4200 3200 5600 11800 10800 11800 10800 9800 11800 10800 3200 2600 3200 2800 2600 2100 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 52 × 52 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 15 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 20 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm 60 × 60 × 38 mm ø 200 × 70 mm ø 200 × 70 mm 109P0512A701 109P0512H701 109P0512M701 109P0524A701 109P0524H701 109P0524M701 109P0605H701 109P0605M701 109P0612K701 109P0612S701 109P0612H701 109P0612M701 109P0612B701 109P0624J701 109P0624S701 109P0624H701 109P0624M701 109P0612W601 109P0612H601 109P0612M601 109P0624W601 109P0624H601 109P0624M601 109P0648H601 9G0612G101 9G0612S101 9G0624G101 9G0624S101 9G0624H101 9G0648G101 9G0648S101 109E2024S001 109E2024H001 Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Aluminum Aluminum 12 12 12 24 24 24 5 5 12 12 12 12 12 24 24 24 24 12 12 12 24 24 24 48 12 12 24 24 24 48 48 24 24 10.2 to 13.8 7 to 13.8 7 to 13.8 14 to 27.6 14 to 27.6 14 to 27.6 4.5 to 5.5 4.5 to 5.5 10.2 to 13.8 10.2 to 13.8 7 to 13.8 10.2 to 13.8 10.2 to 13.8 14 to 27.6 14 to 27.6 14 to 27.6 20.4 to 27.6 6 to 16 10.2 to 13.8 10.2 to 13.8 12 to 30 20.4 to 27.6 20.4 to 27.6 43 to 53 7.0 to 13.8 7.0 to 13.8 14.0 to 27.6 14.0 to 27.6 14.0 to 27.6 28 to 55.2 28 to 55.2 21.6 to 26.4 20.4 to 27.6 ø 200 × 70 mm 109E2024AS001 Aluminum 24 21.6 to 26.4 ø 200 × 70 mm 109E2024MH001 Aluminum 24 20.4 to 27.6 Size Model no. Frame material [V] [V] 9GV0612P1H03 Plastics 12 8.0 to 13.8 60 × 60 × 38 mm 9GV0612P1M03 Plastics 12 8.0 to 13.8 60 × 60 × 38 mm 60 × 60 × 38 mm 9GV0612P1L01 Plastics 9GV0624P1M03 Plastics 12 24 8.0 to 13.8 20.4 to 27.6 * PWM frequency: 25 kHz 646 CATALOG No. C1111B002 '21.9.IT Max. airflow [m³/min] 0.375 0.255 0.205 0.375 0.255 0.205 0.4 0.3 0.62 0.48 0.4 0.3 0.21 0.61 0.48 0.4 0.3 0.42 0.42 0.3 0.42 0.42 0.3 0.55 1.84 1.7 1.84 1.7 1.54 1.84 1.7 10.45 8.2 10.45 9 8.2 6.7 Rated voltage Operating voltage range PWM duty cycle* Rated current Rated input Rated speed 60 × 60 × 38 mm DC Deleted Models in this Catalog Frame material Model no. Max. static pressure [CFM] [Pa] 13.25 9.0 7.24 13.24 9.0 7.24 14.1 10.6 21.9 17 14.1 10.6 7.42 21.5 16.9 14.1 10.6 14.8 14.8 10.6 14.8 14.8 10.6 19.4 65 60 65 60 54.4 65 60 369 289.5 369 317.8 289.5 236.6 69.7 31.9 21.4 69.7 31.9 21.4 38.2 22.6 99.3 58.8 38.2 22.6 11.7 86.5 58.8 38.2 22.6 31.8 31.8 18.8 31.8 31.8 18.8 52.9 435 370 435 370 304.6 435 370 287.1 192 287.1 215.6 192 115.4 Max. airflow SPL [inchH²O] [dB (A)] 0.28 0.128 0.086 0.28 0.128 0.086 0.153 0.091 0.399 0.236 0.153 0.091 0.047 0.347 0.236 0.153 0.091 0.128 0.128 0.076 0.128 0.128 0.076 0.212 1.747 1.486 1.747 1.486 1.223 1.747 1.486 1.153 0.771 1.153 0.865 0.771 0.463 Max. static pressure 36 27 22 36 27 22 32 25 45 36 32 25 21 44 36 32 25 31 31 25 31 31 25 41 58 56 58 56 54 58 56 57 51 57 54 51 45 SPL [%] [A] [W] [min-1] [m³/min] [CFM] [Pa] [inchH²O] [dB (A)] 100 0 100 0 100 100 2.0 0.1 1.5 0.08 0.7 0.73 24.0 1.2 18.0 1.0 8.4 17.52 14500 2700 13000 2500 10000 13000 2.15 0.4 1.93 0.38 1.49 1.93 76 14 68 13 52.6 68.0 617 21 496 18 293 496 2.48 0.09 1.99 0.07 1.17 1.99 63 22 60 19 52 60 Operating temperature Expected life [˚C] [h] -20 to +70 -20 to +70 -20 to +70 -20 to +60 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +60 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +60 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -10 to +70 -10 to +70 40000/60˚C 60000/60˚C 60000/60˚C 40000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 40000/60˚C 40000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 40000/60˚C 40000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 60000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000 40000 -10 to +70 40000 -10 to +70 40000 Operating temperature Expected life [˚C] [h] -20 to +70 40000/60˚C -20 to +70 40000/60˚C -20 to +70 -20 to +70 40000/60˚C 40000/60˚C ■ Counter Rotating Fan Size Model no. Frame material Rated voltage Operating voltage range Rated current Rated input [V] [V] [A] Rated speed Max. airflow [min-1] [m³/min] [CFM] [W] Inlet 40 × 40 × 56 mm 80 × 80 × 80 mm 80 × 80 × 80 mm 9CRA0412K501 9CR0812S801 9CR0812H801 Size 60 × 60 × 76 mm 80 × 80 × 80 mm Model no. Plastic Plastic Plastic Frame material 12 12 12 10.8 to 12.6 10.8 to 13.2 10.8 to 13.2 1.8 5.5 3.6 21.6 66.0 43.2 [V] [kHz] [A] [Pa] SPL Operating temperature Expected life [inchH²O] [dB (A)] [˚C] [h] -20 to +60 -10 to +60 -10 to +60 40000 40000 40000 Outlet 17000 13000 8000 5300 7000 4600 0.95 4.53 3.97 33.5 650 160 520 140 400 2.61 2.09 1.61 Max. airflow Max. static pressure Rated speed [min -1] Rated voltage PWM frequency Rated current Max. static pressure Duty cycle 0% Duty cycle 100% 65 71 68 SPL Expected Life [m3/min] [CFM] [Pa] [inchH2O] [dB (A)] [h] 9CR0612P0S03 Plastic 12 25.0 3.2 Inlet: 1300 Outlet: 800 Inlet: 11500 Outlet: 7000 2.26 79.8 550 2.21 66 40000 9CR0612P0H03 Plastic 12 25.0 2.7 Inlet: 1200 Outlet: 800 Inlet: 10300 Outlet: 6500 1.98 69.91 450 1.81 64 40000 9CR0848P8S03 Plastic 48 25.0 1.29 Inlet: 2000 Outlet: 1300 Inlet: 8000 Outlet: 5300 4.53 159.95 520 2.09 71 40000 Size Model no. Frame Rated voltage Operating voltage range PWM duty cycle* Rated current Rated input material [V] [V] [%] [A] [W] Rated speed Max. airflow [min-1] [m³/min] [CFM] Inlet 40 × 40 × 56 mm 9CRB0412P5S201 Plastic 12 10.8 to 13.2 40 × 40 × 56 mm 9CRB0412P5K001 Plastic 12 10.8 to 13.2 40 × 40 × 56 mm 9CRB0412P5J201 Plastic 12 10.8 to 13.2 100 0 100 0 100 0 1.4 0.09 0.88 0.11 0.72 0.07 Max. static pressure [Pa] SPL Operating temperature Expected life [inchH²O] [dB (A)] [˚C] [h] -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 40000 40000 40000 40000 40000 40000 Outlet 16.8 22000 19700 0.9 31.8 1045 1.08 3800 3500 0.15 5.3 31 10.56 19000 17000 0.76 26.83 730 1.32 5700 5100 0.21 7.41 67 8.64 17300 16000 0.71 25.1 650 0.84 3450 3200 0.13 4.59 26 4.197 0.124 2.93 0.26 2.61 0.1 68 26 62 33 61 24 * PWM frequency: 25 kHz ■ Splash Proof Fan Size 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 80 × 80 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm 92 × 92 × 25 mm Model no. 9WS0812H401 9WS0812F401 9WS0812M401 9WS0824H401 9WS0824F401 9WS0824M401 9WS0912H401 9WS0912F401 9WS0912M401 9WS0912L401 9WS0924H401 9WS0924F401 9WS0924M401 9WS0924L401 Frame material Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Plastics Rated voltage Operating voltage range Rated current Rated input Rated speed Max. airflow Max. static pressure [V] [V] [A] [W] [min-1] [m³/min] [CFM] [Pa] 12 12 12 24 24 24 12 12 12 12 24 24 24 24 10.2 to 13.8 10.2 to 13.8 10.2 to 13.8 20.4 to 27.6 20.4 to 27.6 20.4 to 27.6 10.2 to 13.8 10.2 to 13.8 10.2 to 13.8 10.2 to 13.8 20.4 to 27.6 20.4 to 27.6 20.4 to 27.6 20.4 to 27.6 0.16 0.13 0.1 0.09 0.07 0.05 0.17 0.13 0.1 0.06 0.1 0.07 0.06 0.05 1.92 1.56 1.2 2.16 1.68 1.2 2.04 1.56 1.2 0.72 2.4 1.68 1.44 1.2 3100 2700 2200 3100 2700 2200 2850 2450 2100 1700 2850 2450 2100 1700 0.94 0.83 0.65 0.94 0.83 0.65 1.38 1.18 1.01 0.8 1.38 1.18 1.01 0.8 33.2 29.3 23.0 33.2 29.3 23.0 48.7 41.7 35.7 28.2 48.7 41.7 35.7 28.2 45.1 34.3 23.5 45.1 34.3 23.5 45.1 32.3 23.5 16.7 45.1 32.3 23.5 16.7 SPL [inchH²O] [dB (A)] 0.181 0.138 0.094 0.181 0.138 0.094 0.181 0.13 0.094 0.067 0.181 0.13 0.094 0.067 32 28 23 32 28 23 33 30 27 23 33 30 27 23 Operating temperature Expected life [˚C] [h] -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C 40000/60˚C ■ Long Life Fan 109L0612G401 109L0612S401 109L0612H401 109L0612F401 109L0612M401 109L0624D401 109L0624S401 109L0624H401 109L0624F401 109L0624M401 109L0648G401 109L0648H401 Frame material Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum Aluminum Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] 12 12 12 12 12 24 24 24 24 24 48 48 10.2 to 13.8 10.2 to 13.8 10.2 to 13.8 10.2 to 13.8 10.2 to 13.8 20.4 to 27.6 20.4 to 27.6 20.4 to 27.6 20.4 to 27.6 20.4 to 27.6 40.8 to 55.2 40 to 53 0.24 0.17 0.11 0.09 0.06 0.12 0.08 0.06 0.05 0.04 0.07 0.04 2.88 2.04 1.32 1.08 0.72 2.88 1.92 1.44 1.2 0.96 3.36 1.92 [min-1] 5600 4600 3800 3200 2600 5150 4600 3800 3200 2600 5600 3800 Max. airflow [m³/min] 0.78 0.65 0.53 0.44 0.36 0.72 0.65 0.53 0.44 0.36 0.78 0.53 Max. static pressure [CFM] [Pa] 27.5 23.0 18.7 15.5 12.7 25.4 23.0 18.7 15.5 12.7 27.5 18.7 87.3 56.8 40.2 29.4 19.6 73.8 56.8 40.2 29.4 19.6 87.3 40.2 SPL [inchH²O] [dB (A)] 0.35 0.228 0.161 0.118 0.079 0.296 0.23 0.161 0.118 0.079 0.35 0.161 Operating temperature Expected life [˚C] [h] 39 33 28 24 20 37 33 28 24 20 39 28 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +70 -20 to +60 -20 to +70 100000 100000 100000 100000 100000 100000 100000 100000 100000 100000 80000 100000 SPL Operating temperature Expected life ■ Blower Size 120 × 32 mm 120 × 32 mm 120 × 32 mm 120 × 32 mm Model no. Frame material 109BF12HC2 109BF12MC2 109BF24HC2 109BF24MC2 Plastic Plastic Plastic Plastic Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 12 12 24 24 10.2 to 13.8 10.2 to 13.8 20.4 to 27.6 20.4 to 27.6 0.6 0.32 0.3 0.16 7.2 3.84 7.2 3.84 2400 1900 2400 1900 Max. airflow [m³/min] 0.78 0.61 0.78 0.61 Max. static pressure [CFM] [Pa] 27.5 21.5 27.5 21.5 175.4 109.8 175.4 109.8 [inchH²O] [dB (A)] 0.704 0.441 0.704 0.441 52 44 52 44 [˚C] [h] -20 to +60 -20 to +60 -20 to +60 -20 to +60 40000 40000 40000 40000 Note: Storage temperature is -30 to +70˚C. CATALOG No. C1111B002 '21.9.IT 647 Deleted Models in this Catalog 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm 60 × 60 × 25 mm Model no. DC Size
9CRA0612P6J001 价格&库存
很抱歉,暂时无法提供与“9CRA0612P6J001”相匹配的价格&库存,您可以联系我们找货
