UF15KC12/23-BWHR
UF15KC12/23-BWHR
    MECHATRONICSFANGROUP(机电一体化)
    FAN 172X150X55MM 115/230VAC
UF15KC12/23-BWHR 数据手册
6.77 ±0.02 (172 ±0.5) 6.38 ±0.01 (162 ±0.3) 2.17 ±0.02 (55 ±0.5) ø5.75 (ø146) Ø5.91 ±0.02 (Ø150±0.5) ø0.16 ±0.01 (ø4.2 ±0.2) 14.96 (350) 5˚ 55. .91 (23) 6.77 x 5.91 x 2.17 inches 1.69 (43) aluminum die cast frame; UL94V-0 PBT impeller Bearing option: ball bearing Motor: permanent split capacitor Air Flow: exhaust over struts Connection: terminal or 22 AWG lead wire Protection: thermal Option: dual voltage 115/130VAC; IP55; IP55 + salt fog w w w.mechatronic s.com 11.23.20 H .80 .60 .40 .20 50 100 LEAD WIRE TYPE 0.12 (3) 1.50 (38) 200 250 TERMINAL TYPE Rated Freq. Input Rated Locked Speed Voltage Power Cur. Cur. Air Volume V HZ W A A RPM MM INCH dbA kg 115 60 38 0.34 0.76 3,400 8.3 293 23 0.90 60 1.05 UF15KC23 -__H 230 60 38 0.17 0.38 3,400 8.3 293 23 0.90 60 1.05 Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 M³/Min. CFM Max. Static Sound Weight Pressure (H2 0) Noise UF15KC12 -__H E - mail: S ales @ M echatronic s.com 300 0.31 (8) t=0.5 Model No. 150 AIR FLOW (CFM) Operating voltage: 115 or 230 VAC Construction: 1.00 0 .79 (20) (172 x 150 x 55 mm) 1.20 STATIC PRESSURE - IN. OF WATER AC AXIAL FANS UF15KC series 800-453-4569 Cooling Simplified
UF15KC12/23-BWHR 价格&库存
很抱歉,暂时无法提供与“UF15KC12/23-BWHR”相匹配的价格&库存,您可以联系我们找货
