74ALVCH162245DGG,5
74ALVCH162245DGG,5
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    IC TXRX NON-INVERT 3.6V 48TSSOP
74ALVCH162245DGG,5 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS 74ALVCH162245 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) Product specification IC24 Data Handbook       1998 Jun 29 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) FEATURES 74ALVCH162245 PIN CONFIGURATION • Wide supply voltage range of 1.2V to 3.6V • Complies with JEDEC standard no. 8-1A • CMOS low power consumption • MULTIBYTETM flow-through standard pin-out architecture • Low inductance multiple VCC and ground pins for minimum noise and ground bounce • Direct interface with TTL levels • Bus hold on all data inputs • Integrated 30Ω termination resistor 1DIR 1 48 1OE 1B0 2 47 1A0 1B1 3 46 1A1 GND 4 45 GND 1B2 5 44 1A2 1B3 6 43 1A3 VCC1 7 42 VCC2 1B4 8 41 1A4 1B5 9 40 1A5 GND 10 39 GND DESCRIPTION 1B6 11 38 1A6 The 74ALVCH162245 is a 16-bit transceiver featuring non-inverting 3-State bus compatible outputs in both send and receive directions. 1B7 12 37 1A7 2B0 13 36 2A0 2B1 14 35 2A1 GND 15 34 GND 2B2 16 33 2A2 2B3 17 32 2A3 The 74ALVCH162245 features two output enable (nOE) inputs for easy cascading and two send/receive (nDIR) inputs for direction control. nOE controls the outputs so that the buses are effectively isolated. This device can be used as two 8-bit transceivers or one 16-bit transceiver. The 74ALVCH162245 is designed with 30Ω series resistors in both HIGH and LOW output states. 31 VCC2 VCC1 18 The 74ALVCH162245 has active bus hold circuitry which is provided to hold unused or floating data inputs at a valid logic level. This feature eliminates the need for external pull-up or pull-down resistors. 30 2A4 2B4 19 2B5 20 29 2A5 GND 21 28 GND 2B6 22 27 2A6 2B7 23 26 2A7 2DIR 24 25 2OE SW00198 QUICK REFERENCE DATA GND = 0V; Tamb = 25°C; tr = tf ≤ 2.5ns PARAMETER SYMBOL CONDITIONS TYPICAL UNIT 2.4 ns tPHL/tPLH Propagation delay An to Bn; Bn to An VCC = 2.5V, CL = 30pF VCC = 3.3V, CL = 50pF CI Input capacitance 4.0 pF CI/O Input/output capacitance 8.0 pF CPD Power dissipation capacitance per buffer Outputs enabled 27 pF Outputs disabled 4 pF VI = GND to VCC1 NOTES: 1. CPD is used to determine the dynamic power dissipation (PD in µW): PD = CPD × VCC2 × fi +  (CL × VCC2 × fo) where: fi = input frequency in MHz; CL = output load capacitance in pF; fo = output frequency in MHz; VCC = supply voltage in V;  (CL × VCC2 × fo) = sum of the outputs. ORDERING INFORMATION PACKAGES TEMPERATURE RANGE OUTSIDE NORTH AMERICA NORTH AMERICA DWG NUMBER 48-Pin Plastic SSOP Type III –40°C to +85°C 74ALVCH162245 DL ACH162245 DL SOT370-1 48-Pin Plastic TSSOP Type II –40°C to +85°C 74ALVCH162245 DGG ACH162245 DGG SOT362-1 1998 Jun 29 2 853-2085 19638 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) PIN DESCRIPTION LOGIC SYMBOL (IEEE/IEC) PIN NUMBER SYMBOL 1 1DIR 2, 3, 5, 6, 8, 9, 11, 12 74ALVCH162245 NAME AND FUNCTION Direction control 1B0 to 1B7 Data inputs/outputs 1OE 48 G3 1DIR 1 3 EN1 [BA] 2OE 25 G6 2DIR 24 6 EN4 [BA] 3 EN2 [AB] 4, 10, 15, 21, 28, 34, 39, 45 GND 7, 18, 31, 42 VCC 13, 14, 16, 17, 19, 20, 22, 23 2B0 to 2B7 Ground (0V) Positive supply voltage Data inputs/outputs 24 2DIR Direction control 25 2OE Output enable input (active LOW) 36, 35, 33, 32, 30, 29, 27, 26 2A0 to 2A7 47, 46, 44, 43, 41, 40, 38, 37 1A0 to 1A7 6 EN5 [AB] 1A0 1A1 1A2 1A3 Data inputs/outputs Data inputs/outputs 1A5 1A6 Output enable input (active LOW) 1OE 1A7 2A0 46 3 44 5 43 6 41 8 40 9 38 11 37 12 36 1A1 2DIR 47 2 46 3 24 2A1 25 1OE 1B0 1B1 2A0 2A1 36 13 35 14 2A2 2OE 2A3 2B0 2A4 2A5 2B1 2A6 1A2 1A3 1A4 1A5 1A6 1A7 1B0 1B1 1B2 1B3 1B4 1B5 1B6 1B7 2B0 5 1 48 1A0 13 4 LOGIC SYMBOL 1DIR 2 1 2 1A4 48 47 44 5 43 6 41 8 40 9 38 11 37 12 1B2 2A2 1B3 2A3 1B4 2A4 1B5 2A5 1B6 2A6 1B7 2A7 33 16 32 17 30 19 29 20 27 22 26 23 2A7 2B2 35 14 33 16 32 17 30 19 29 20 27 22 26 23 2B1 2B2 2B3 2B4 2B5 2B6 2B7 SW00196 2B3 BUS HOLD CIRCUIT 2B4 VCC 2B5 2B6 2B7 Data Input To internal circuit SW00197 FUNCTION TABLE INPUTS INPUTS/OUTPUT nOE nDIR nAn nBn L L A=B inputs L H inputs B=A H X Z Z SW00044 H = HIGH voltage level L = LOW voltage level X = don’t care Z = high impedance OFF–state 1998 Jun 29 3 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) 74ALVCH162245 RECOMMENDED OPERATING CONDITIONS LIMITS SYMBOL VCC PARAMETER CONDITIONS UNIT MIN MAX DC supply voltage 2.5V range (for max. speed performance @ 30 pF output load) 2.3 2.7 DC supply voltage 3.3V range (for max. speed performance @ 50 pF output load) 3.0 3.6 V VI DC Input voltage range 0 VCC V VO DC output voltage range 0 VCC V –40 +85 °C 0 0 20 10 ns/V Tamb Operating free-air temperature range tr, tf Input rise and fall times VCC = 2.3 to 3.0V VCC = 3.0 to 3.6V ABSOLUTE MAXIMUM RATINGS In accordance with the Absolute Maximum Rating System (IEC 134) Voltages are referenced to GND (ground = 0V) SYMBOL VCC IIK PARAMETER CONDITIONS DC supply voltage DC input diode current VI 0 For data inputs with bus hold1 VI DC in input ut voltage IOK DC output diode current VO VCC or VO  0 VO DC output voltage Note 1 IO DC output source or sink current VO = 0 to VCC IGND, ICC Tstg PTOT For control pins1 DC VCC or GND current Storage temperature range Power dissipation per package –plastic medium-shrink (SSOP) –plastic thin-medium-shrink (TSSOP) For temperature range: –40 to +125 °C above +55°C derate linearly with 11.3 mW/K above +55°C derate linearly with 8 mW/K NOTE: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 1998 Jun 29 4 RATING UNIT –0.5 to +4.6 V –50 mA –0.5 to VCC +0.5 –0.5 to +4.6 V 50 mA –0.5 to VCC +0.5 V 50 mA 100 mA –65 to +150 °C 850 600 mW Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) 74ALVCH162245 DC ELECTRICAL CHARACTERISTICS Over recommended operating conditions. Voltage are referenced to GND (ground = 0 V). LIMITS SYMBOL PARAMETER VIH HIGH level Input voltage VIL LOW level Input voltage VOH VOL HIGH level output voltage LOW level output voltage TEST CONDITIONS Temp = -40°C to +85°C MIN TYP1 VCC = 2.3 to 2.7V 1.7 1.2 VCC = 2.7 to 3.6V 2.0 1.5 UNIT MAX V VCC = 2.3 to 2.7V 1.2 0.7 VCC = 2.7 to 3.6V 1.5 0.8 V 3 to 3 6V; VI = VIH or VIL; IO = –100µA 100µA VCC = 2 2.3 3.6V; 02 VCC0.2 VCC = 2.3V; VI = VIH or VIL; IO = –4mA VCC0.4 VCC0.11 VCC = 2.3V; VI = VIH or VIL; IO = –6mA VCC0.6 VCC0.17 VCC = 2.7V; VI = VIH or VIL; IO = –4mA VCC0.5 VCC0.09 VCC = 2.7V; VI = VIH or VIL; IO = –8mA VCC0.7 VCC0.19 VCC = 3.0V; VI = VIH or VIL; IO = –6mA VCC0.6 VCC0.13 VCC = 3.0V; VI = VIH or VIL; IO = –12mA VCC1.0 VCC0.27 VCC V VCC = 2 2.3 3 to 3 3.6V; 6V; VI = VIH or VIL; IO = 100µA GND 0 20 0.20 VCC = 2.3V; VI = VIH or VIL; IO = 4mA 0.07 0.40 VCC = 2.3V; VI = VIH or VIL; IO = 6mA 0.11 0.55 VCC = 2.7V; VI = VIH or VIL; IO = 4mA 0.06 0.40 VCC = 2.7V; VI = VIH or VIL; IO = 8mA 0.13 0.60 VCC = 3.0V; VI = VIH or VIL; IO = 6mA 0.09 0.55 VCC = 3.0V; VI = VIH or VIL; IO = 12mA 0.19 0.80 V II Input leakage current per data pin with bus hold 3 to 3 6V; VCC = 2 2.3 3.6V; VI = VCC or GND 0.1 5 µ µA IOZ 3-State output OFF-state current VCC = 2.3 to 3.6V; VI = VIH or VIL; VO = VCC or GND 0.1 10 µA ICC Quiescent supply current VCC = 2.3 to 3.6V; VI = VCC or GND; IO = 0 0.2 40 µA ∆ICC Additional quiescent supply current given per data I/O pin with bus hold VCC = 2.3V to 3.6V; VI = VCC – 0.6V; IO = 0 150 750 µA IBHL2 Bus hold LOW sustaining current IBHH2 Bus hold HIGH sustaining current IBHLO2 IBHHO2 VCC = 2.3V; VI = 0.7V 45 – VCC = 3.0V; VI = 0.8V 75 150 VCC = 2.3V; VI = 1.7V –45 VCC = 3.0V; VI = 2.0V –75 Bus hold LOW overdrive current VCC = 3.6V 500 µA Bus hold HIGH overdrive current VCC = 3.6V –500 µA NOTES: 1. All typical values are at Tamb = 25°C. 2. Valid for data inputs of bus hold parts. 1998 Jun 29 5 –175 µA µA Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) 74ALVCH162245 AC CHARACTERISTICS FOR VCC = 2.3V TO 2.7V RANGE GND = 0V; tr = tf ≤ 2.0ns; CL = 30pF LIMITS SYMBOL PARAMETER WAVEFORM VCC = 2.3 to 2.7V UNIT MIN TYP1, 2 MAX tPHL/tPLH Propagation delay nAn to nBn; nBn to nAn 1, 3 1.0 2.5 4.9 ns tPZH/tPZL 3-State output enable time nOE to nAn; nOE to nBn 2, 3 1.0 2.9 6.8 ns tPHZ/tPLZ 3-State output disable time nOE to nAn; nOE to nBn 2, 3 1.0 3.0 6.3 ns NOTES: 1. All typical values are measured Tamb = 25°C. 2. Typical value is measured at VCC = 2.5V AC CHARACTERISTICS FOR VCC = 3.0V TO 3.6V RANGE AND VCC = 2.7V GND = 0V; tr = tf ≤ 2.5ns; CL = 50pF LIMITS SYMBOL PARAMETER VCC = 3.3 ± 0.3V WAVEFORM VCC = 2.7V UNIT MIN TYP1, 2 MAX MIN TYP1 MAX tPHL/tPLH Propagation delay nAn to nBn; nBn to nAn 1, 3 1.0 2.4 4.2 1.0 2.7 4.7 ns tPZH/tPZL 3-State output enable time nOE to nAn; nOE to nBn 2, 3 1.0 3.0 5.6 1.0 3.9 6.7 ns tPHZ/tPLZ 3-State output disable time nOE to nAn; nOE to nBn 2, 3 1.0 2.6 5.5 1.0 2.9 5.7 ns NOTES: 1. All typical values are measured Tamb = 25°C. 2. Typical value is measured at VCC = 3.3V 1998 Jun 29 6 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) AC WAVEFORMS FOR VCC = 2.3V TO 2.7V AND VCC < 2.3V RANGE 74ALVCH162245 TEST CIRCUIT VM = 0.5 VCC VX = VOL + 0.15V VY = VOH –0.15V VOL and VOH are the typical output voltage drop that occur with the output load. V =V CC I PULSE GENERATOR D.U.T. RT VM = 1.5 V VX = VOL + 0.3V VY = VOH –0.3V VOL and VOH are the typical output voltage drop that occur with the output load. V = 2.7V I DEFINITIONS RL = Load resistor CL = Load capacitance includes jig and probe capacitance RT = Termination resistance should be equal to ZOUT of pulse generators. SWITCH POSITION VM TEST GND tPLH/tPHL tPHL tPLH VOH Bn, An OUTPUT VM S1 Open tPLZ/tPZL 2  VCC tPHZ/tPZH GND VCC VI < 2.7V VCC 2.7–3.6V 2.7V SV00906 VOL SW00063 Waveform 3. Load circuitry for switching times Waveform 1. Input (nAn, nBn) to output (nBn, nAn) propagation delay times VI VM GND tPLZ tPZL VCC OUTPUT LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ tPZH VOH VY OUTPUT HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled SW00064 Waveform 2. 3-State enable and disable times 1998 Jun 29 RL = 500 Ω CL Test Circuit for switching times VI OE INPUT 2 * VCC Open GND RL = 500 Ω VO VI AC WAVEFORMS FOR VCC = 3.0V TO 3.6V AND VCC = 2.7V RANGE An, Bn INPUT S1 VCC 7 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm 1998 Jun 29 8 74ALVCH162245 SOT370-1 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1mm 1998 Jun 29 9 74ALVCH162245 SOT362-1 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) NOTES 1998 Jun 29 10 74ALVCH162245 Philips Semiconductors Product specification 16-bit bus transceiver with direction pin and 30Ω termination resistor (3-State) 74ALVCH162245 Data sheet status Data sheet status Product status Definition [1] Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make chages at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. [1] Please consult the most recently issued datasheet before initiating or completing a design. Definitions Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Disclaimers Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified.  Copyright Philips Electronics North America Corporation 1998 All rights reserved. Printed in U.S.A. Philips Semiconductors 811 East Arques Avenue P.O. Box 3409 Sunnyvale, California 94088–3409 Telephone 800-234-7381 Date of release: 06-98 Document order number:       yyyy mmm dd 11 9397-750-04539
74ALVCH162245DGG,5 价格&库存
很抱歉,暂时无法提供与“74ALVCH162245DGG,5”相匹配的价格&库存,您可以联系我们找货
