74ABTH162245ADL:11
74ABTH162245ADL:11
    NEXPERIA(安世)
    SSOP48
    IC TXRX NON-INVERT 5.5V 48SSOP
74ABTH162245ADL:11 数据手册
74ABT162245A; 74ABTH162245A 16-bit bus transceiver with 30 Ω series termination resistors; 3-state Rev. 5 — 2 July 2021 Product data sheet 1. General description The 74ABT162245A; 74ABTH162245A is a 16-bit transceiver with 30 Ω termination resistors and 3-state outputs. The device can be used as two 8-bit transceivers or one 16-bit transceiver. The device features two output enables (1OE and 2OE) each controlling eight outputs, and two send/receive (1DIR and 2DIR) inputs for direction control. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. Two options are available, 74ABT162245A which does not have the bus hold feature and the 74ABTH162245A which incorporates the bus hold feature. 2. Features and benefits • • • • • • • • • • • • • • 16-bit bidirectional bus interface Multiple VCC and GND pins minimize switching noise 3-state buffers Output capability: +12 mA/–32 mA 74ABTH162245A incorporates bus-hold data inputs which eliminate the need for external pull-up resistors to hold unused inputs Integrated 30 Ω termination resistors Supply voltage range from 4.5 to 5.5 V BiCMOS high speed and output drive Direct interface with TTL levels Power-up 3-state IOFF circuitry provides partial Power-down mode operation Latch-up performance exceeds 500 mA per JESD 78 Class II Level B ESD protection: • HBM JESD-A114E exceeds 2000 V • CDM JESD22-C101C exceeds 1000 V Specified from -40 °C to +85 °C 3. Ordering information Table 1. Ordering information Type number Package 74ABT162245ADGG 74ABTH162245ADGG Temperature range Name Description Version -40 °C to +85 °C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 4. Functional diagram 2DIR 1DIR 2OE 1OE 2A0 1A0 1B0 1A1 2B0 2A1 1B1 1A2 2B1 2A2 1B2 1A3 2B2 2A3 1B3 1A4 2B3 2A4 1B4 1A5 2B4 2A5 1B5 1A6 2B5 2A6 1B6 2B6 2A7 1A7 1B7 2B7 001aaa789 Fig. 1. Logic symbol 74ABT_ABTH162245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 2 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 1OE G3 1DIR 3EN1[BA] 3EN2[AB] 2OE G6 2DIR 6EN4[BA] 6EN5[AB] 1A0 1 1B0 2 1A1 1B1 1A2 1B2 1A3 1B3 1A4 1B4 1A5 1B5 1A6 1B6 1A7 1B7 2A0 4 VCC 2B0 5 2A1 2B1 2A2 2B2 2A3 2B3 2A4 2B4 2A5 2B5 2A6 2B6 2A7 output 2B7 GND 001aak306 Fig. 2. IEC logic symbol 74ABT_ABTH162245A Product data sheet Fig. 3. Schematic of each output All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 001aac384 © Nexperia B.V. 2021. All rights reserved 3 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 5. Pinning information 5.1. Pinning 74ABT162245A 74ABTH162245A 1DIR 1 48 1OE 1B0 2 47 1A0 1B1 3 46 1A1 GND 4 45 GND 1B2 5 44 1A2 1B3 6 43 1A3 VCC 7 42 VCC 1B4 8 41 1A4 1B5 9 40 1A5 GND 10 39 GND 1B6 11 38 1A6 1B7 12 37 1A7 2B0 13 36 2A0 2B1 14 35 2A1 GND 15 34 GND 2B2 16 33 2A2 2B3 17 32 2A3 VCC 18 31 VCC 2B4 19 30 2A4 2B5 20 29 2A5 GND 21 28 GND 2B6 22 27 2A6 2B7 23 26 2A7 2DIR 24 25 2OE aaa-026795 Fig. 4. Pin configuration SOT362-1 (TSSOP48) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1DIR, 2DIR 1, 24 direction control input 1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7 47, 46, 44, 43, 41, 40, 38, 37 data input/output 2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7 36, 35, 33, 32, 30, 29, 27, 26 data input/output GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) 1B0, 1B1, 1B2, 1B3, 1B4, 1B5, 1B6, 1B7 2, 3, 5, 6, 8, 9, 11, 12 data input/output 2B0, 2B1, 2B2, 2B3, 2B4, 2B5, 2B6, 2B7 13, 14, 16, 17, 19, 20, 22, 23 data input/output 1OE, 2OE 48, 25 output enable input VCC 7, 18, 31, 42 supply voltage 74ABT_ABTH162245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 4 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input/output nOE nDIR nAn nBn L L output nAn = nBn input L H input output nBn = nAn H X Z Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current IOK IO Max Unit -0.5 +7.0 V [1] -1.2 +7.0 V [1] -0.5 +5.5 V VI < 0 V -18 - mA output clamping current VO < 0 V -50 - mA output current output in LOW-state - 128 mA output in HIGH-state -64 - mA - 150 °C -65 +150 °C Tj junction temperature Tstg storage temperature [1] [2] Min [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 8. Recommended operating conditions Table 5. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit 4.5 0 - 5.5 V - VCC V VCC supply voltage VI input voltage IOH HIGH-level output current -32 - - mA IOL LOW-level output current - - 12 mA Δt/ΔV input transition rise and fall rate 0 - 10 ns/V Tamb ambient temperature -40 - +85 °C 74ABT_ABTH162245A Product data sheet in free air All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 5 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C Unit Min Typ Max Min Max VIK input clamping voltage VCC = 4.5 V; IIK = -18 mA -1.2 -0.9 - -1.2 - V VIH HIGH-level input voltage 2.0 - - 2.0 - V VIL LOW-level input voltage - - 0.8 - 0.8 V VOH HIGH-level output voltage VCC = 4.5 V; IOH = -3 mA; VI = VIL or VIH 2.5 2.9 - 2.5 - V VCC = 5.0 V; IOH = -3 mA; VI = VIL or VIH 3.0 3.4 - 3.0 - V VCC = 4.5 V; IOH = -32 mA; VI = VIL or VIH 2.0 2.4 - 2.0 - V VCC = 4.5 V; IOL = 8 mA; VI = VIL or VIH - 0.46 0.65 - 0.65 V VCC = 4.5 V; IOL = 12 mA; VI = VIL or VIH - 0.5 0.8 - 0.8 V VOL LOW-level output voltage II input leakage current nOE, nDIR; VCC = 5.5 V; VI = GND or 5.5 V - ±0.01 ±1 - ±1 μA IOFF power-off leakage current VCC = 0 V; VI or VO ≤ 4.5 V - ±5.0 ±100 - ±100 μA IBHL bus hold LOW current VCC = 4.5 V; VI = 0.8 V [1] 50 - - 50 - μA IBHH bus hold HIGH current VCC = 5.5 V; VI = 2.0 V [1] -75 - - -75 - μA IBHLO bus hold LOW overdrive current VCC = 5.5 V; VI = 0 V to 5.5 V [1] [2] 500 - - - - μA IBHHO bus hold HIGH overdrive current VCC = 5.5 V; VI = 0 V to 5.5 V [1] [2] -500 - - - - μA - ±5.0 ±50 - ±50 μA VO = 5.5 V - 0.5 10 - 10 μA VO = 0.0 V - -0.5 -10 - -10 μA - 5.0 50 - 50 μA -50 -92 -180 -50 -180 mA outputs HIGH - 0.3 0.7 - 0.7 mA outputs LOW - 10 19 - 19 mA outputs 3-state - 0.3 0.7 - 0.7 mA IO(pu/pd) power-up/power-down VCC = 2.0 V; VO = 0.5 V; output current VI = GND or VCC; nOE = don’t care OFF-state output current VCC = 5.5 V; VI = VIL or VIH ICEX output high leakage current VCC = 5.5 V; VO = 5.5 V; VI = GND or VCC IO output current VCC = 5.5 V; VO = 2.5 V ICC supply current VCC = 5.5 V; VI = GND or VCC IOZ 74ABT_ABTH162245A Product data sheet [3] [4] All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 6 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state Symbol Parameter ΔICC additional supply current Conditions 25 °C -40 °C to +85 °C Unit Min Typ Max Min Max outputs enabled - 400 700 - 700 μA 74ABT162245A; outputs 3-state - 1.0 50 - 50 μA 74ABTH162245A; outputs 3-state - 100 250 - 250 μA nOE, nDIR - 400 700 - 700 μA per input pin; VCC = 5.5 V; one input at 3.4 V, other inputs at VCC or GND [5] CI input capacitance VI = 0 V or VCC - 3 - - - pF CI/O input/output capacitance VO = 0 V or VCC; outputs 3-state - 7 - - - pF [1] [2] [3] [4] [5] Valid for data inputs of bus hold parts only (74ABTH162245A) This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 2.1 V with a transition time of up to 10 ms. From VCC = 2.1 V to VCC = 4.5 V to 5.5 V a transition time of 100 μs is permitted. Not more than one output should be tested at a time and the duration of the test should not exceed one second This is the increase in supply current for each input at 3.4 V. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7. Symbol Parameter Conditions Min Typ Max Min Max tPLH LOW to HIGH propagation delay nAn to nBn or nBn to nAn; see Fig. 5 1.0 2.0 3.3 1.0 3.5 ns tPHL HIGH to LOW propagation delay nAn to nBn or nBn to nAn; see Fig. 5 1.5 3.0 4.5 1.5 4.9 ns tPZH OFF-state to HIGH propagation delay nOE to nAn or nBn; see Fig. 6 1.5 3.1 4.3 1.5 5.0 ns tPZL OFF-state to LOW propagation delay nOE to nAn or nBn; see Fig. 6 2.0 5.0 6.1 2.0 7.0 ns tPHZ HIGH to OFF-state propagation delay nOE to nAn or nBn; see Fig. 6 1.7 3.5 4.8 1.7 5.4 ns tPLZ LOW to OFF-state propagation delay nOE to nAn or nBn; see Fig. 6 1.5 3.2 4.5 1.5 4.9 ns 74ABT_ABTH162245A Product data sheet Tamb = 25 °C; VCC = 5.0 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 Tamb = -40 °C to 85 °C; Unit VCC = 5.0 V ± 0.5 V © Nexperia B.V. 2021. All rights reserved 7 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 10.1. Waveforms and test circuit VI nAn, nBn input VM GND t PHL t PLH VOH nBn, nAn output VM VOL mna477 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 5. Input (An or Bn) to output (Bn or An) propagation delays VI VM nOE input GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL 3.5 V VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled aaa-027291 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. 3-state output enable and disable times Table 8. Measurement points Input Output VI VM VM VX VY 3.0 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ABT_ABTH162245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 8 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig. 7. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 3.0 V ≤ 1 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω open 7V open 74ABT_ABTH162245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 9 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 11. Package outline TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 Fig. 8. References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Package outline SOT362-1 (TSSOP48) 74ABT_ABTH162245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 10 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ABT_ABTH162245A v.5 20210702 Product data sheet - Modifications: • • 74ABT_H162245A v.4 20190220 Modifications: • 74ABT_H162245A v.3 20170831 Modifications: • • 74ABT_H162245A v.4 Type number 74ABT162245ADL (SOT370-1 / SSOP48) removed. Section 1 and Section 2 updated. Product data sheet - 74ABT_H162245A v.3 Type number 74ABTH162245ADL (SOT370-1) removed. Product data sheet - 74ABT_H162245A v.2 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74ABT_H162245A v.2 19980225 Product specification - 74ABT_H162245A v.1 74ABT_H162245A v.1 19961120 Product specification - - 74ABT_ABTH162245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 11 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74ABT_ABTH162245A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 12 / 13 74ABT162245A; 74ABTH162245A Nexperia 16-bit bus transceiver with 30 Ω series termination resistors; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................4 5.1. Pinning.........................................................................4 5.2. Pin description............................................................. 4 6. Functional description................................................. 5 7. Limiting values............................................................. 5 8. Recommended operating conditions..........................5 9. Static characteristics....................................................6 10. Dynamic characteristics............................................ 7 10.1. Waveforms and test circuit........................................ 8 11. Package outline........................................................ 10 12. Abbreviations............................................................ 11 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 July 2021 74ABT_ABTH162245A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 2 July 2021 © Nexperia B.V. 2021. All rights reserved 13 / 13
74ABTH162245ADL:11 价格&库存
很抱歉,暂时无法提供与“74ABTH162245ADL:11”相匹配的价格&库存,您可以联系我们找货
