Long Life Fan
80
San Ace 80L
25mm thick
mm sq.
■ General Specifications
・Material …………………… Frame: Aluminum, Impeller: Plastics (Flammability: UL94V-1)
・Expected Life …………… Refer to specifications(L10:Survival rate:90% at 60℃ ,
rated voltage, and continuously run in a free air state)
・Lead Wire ………………… 䊝red 䊞black or blue Sensor yellow
・Storage Temperature …−30℃ to +70℃(Non-condensing)
80×80×25mm
■ Specifications
Model No.
109L0812S401
109L0812H401
109L0812F401
109L0812M401
109L0812L401
109L0824S401
109L0824H401
109L0824F401
109L0824M401
109L0824L401
109L0848H401
〔Mass:150g〕
The following nos. have pulse sensors.
Rated Voltage Operating Voltage Range Rated Current Rated Input
[V]
12
[V]
10.2 to 13.8
24
20.4 to 27.6
48
40.8 to 55.2
Rated Speed
Max. Air Flow
[A]
[W]
[min-1]
[m³/min]
[CFM]
0.26
0.18
0.14
0.1
0.08
0.11
0.09
0.08
0.07
0.05
0.06
3.12
2.16
1.68
1.2
0.96
2.64
2.16
1.92
1.68
1.2
2.88
3,400
3,000
2,700
2,400
1,900
3,400
3,000
2,700
2,400
1,900
3,150
1.2
1.06
0.93
0.83
0.63
1.2
1.06
0.93
0.83
0.63
1.1
42.4
37.4
32.8
29.3
22.2
42.4
37.4
32.8
29.3
22.2
38.8
Max. Static Pressure
50
39.2
32.3
26.5
16.7
50
39.2
32.3
26.5
16.7
43.1
0.2
0.157
0.130
0.106
0.067
0.2
0.157
0.130
0.106
0.067
0.173
・Available options: ⇒ Without Sensor
・Please inquire as the availability of these functions depend on the model. ⇒ Lock Sensor
Low speed Sensor
■ Dimensions(Unit : mm)
25±0.5
80±0.5
71.5±0.3
8-φ4.3±0.3
Mounting
Hole
取付用穴
3.5±0.3
3.5±0.3
80±0.5
71.5±0.3
リード線
Lead
Wire
AWG24
UL1007
+50
300 0
(10)
Rotating
Direction
回転方向
Air Flow
Direction
風吹出方向
■ Reference dimension of mounting holes and vent opening(Unit : mm)
Inlet side
Outlet side
4-φ4.5
78
287
4-φ4.5
71.5±0.3
78
90
71.5±0.3
φ
78
78
87
φ
71.5±0.3
71.5±0.3
SPL
[Pa] [inchH²O] [dB(A)]
37
32
29
26
22
37
32
29
26
22
34
Operating Temperature Expected Life
[h]
− 20 to + 70
100,000
■ Options(Unit : mm)
Finger guards
Resin Finger guards
Model:109-049C
Model:109-1002G
Color
Surface treatment :Nickel-chrome plating(silver)
Outlet side
82±1
4.3±0.3
75
φ
82±1
88
+1.5
ー0.5
φ1.6
105
4-φ4.3±0.3
4-2±0.5
φ3
9.6
71.5±0.3
φ1.6
7±0.5
71.5±0.3
5 +10
φ101.2
Resin filter kits
Model:109-1002F13(13PPI)
,109-1002F20(20PPI)
:109-1002F30(30PPI)
,109-1002F40(40PPI)
Inlet side, Outlet side
+1
4-φ4.3±0.3
71.5±0.3
85.5±1
71.5±0.3
5 0
88
+1.5
105 −0.5
φ75
10.5±0.5
85.5±1
4.3±0.3
φ1.6
φ1.6
Long Life Fan 80mm
Color
:Cation electropainting(black)
Model:109-049E
:109-049H
φ101.2
4-φ10±0.5
4-2±0.5
■ Air Flow - Static Pressure Characteristics
S speed
(inch H2O)(Pa)
H speed
50
0.15
12V/24V
10.2V/20.4V
40
30
0.10
10
30
40
1.5 (m3/min)
50
50
13.8V/27.6V
40
12V/24V
30
10.2V/20.4V
(CFM)
Air風量
Flow
10
M speed
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
13.8V/27.6V
30
12V/24V
10.2V/20.4V
0.06
10
30
40
13.8V/27.6V
30
12V/24V
10.2V/20.4V
10
(CFM)
10
0.10
25
0.08
15
5
40
1.5 (m3/min)
Air風量
Flow
109L0812M401
109L0824M401
(CFM)
1.5 (m3/min)
50
(CFM)
H speed
13.8V/27.6V
12V/24V
0.2
(inch H2O)(Pa)
10
0.02
1.0
30
109L0812F401
109L0824F401
10.2V/20.4V
0.04
Air風量
Flow
0.02
L speed
40
0.10
0.04
50
(inch H2O)(Pa)
0.14
0.08
40
109L0812H401
109L0824H401
(inch H2O)(Pa)
0.12
30
1.5 (m3/min)
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
Air風量
Flow
109L0812S401
109L0824S401
0.16
→ Static
Pressure
→ 静圧
0.20
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
(inch H2O)(Pa)
→ Static
Pressure
→ 静圧
13.8V/27.6V
60
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
70
0.25
F speed
(inch H2O)(Pa)
0.30
5
0.4
10
15
0.6
0.8 (m3/min)
25
Air風量
Flow
109L0812L401
109L0824L401
30
(CFM)
0.24
0.22
0.20
0.18
0.16
0.14
0.12
0.10
0.08
0.06
0.04
0.02
55.2V
50
40
48V
30
40.8V
30
40
1.5 (m3/min)
50
(CFM)
Air風量
Flow
109L0848H401
288
很抱歉,暂时无法提供与“109L0824H402”相匹配的价格&库存,您可以联系我们找货
