109L0824S401
109L0824S401
    SANYODENKI
    FAN80X25MM24VDCRBLSTACH
109L0824S401 数据手册
Long Life Fan 80 San Ace 80L 25mm thick mm sq. ■ General Specifications ・Material …………………… Frame: Aluminum, Impeller: Plastics (Flammability: UL94V-1) ・Expected Life …………… Refer to specifications(L10:Survival rate:90% at 60℃ , rated voltage, and continuously run in a free air state) ・Lead Wire ………………… 䊝red 䊞black or blue Sensor yellow ・Storage Temperature …−30℃ to +70℃(Non-condensing) 80×80×25mm ■ Specifications Model No. 109L0812S401 109L0812H401 109L0812F401 109L0812M401 109L0812L401 109L0824S401 109L0824H401 109L0824F401 109L0824M401 109L0824L401 109L0848H401 〔Mass:150g〕 The following nos. have pulse sensors. Rated Voltage Operating Voltage Range Rated Current Rated Input [V] 12 [V] 10.2 to 13.8 24 20.4 to 27.6 48 40.8 to 55.2 Rated Speed Max. Air Flow [A] [W] [min-1] [m³/min] [CFM] 0.26 0.18 0.14 0.1 0.08 0.11 0.09 0.08 0.07 0.05 0.06 3.12 2.16 1.68 1.2 0.96 2.64 2.16 1.92 1.68 1.2 2.88 3,400 3,000 2,700 2,400 1,900 3,400 3,000 2,700 2,400 1,900 3,150 1.2 1.06 0.93 0.83 0.63 1.2 1.06 0.93 0.83 0.63 1.1 42.4 37.4 32.8 29.3 22.2 42.4 37.4 32.8 29.3 22.2 38.8 Max. Static Pressure 50 39.2 32.3 26.5 16.7 50 39.2 32.3 26.5 16.7 43.1 0.2 0.157 0.130 0.106 0.067 0.2 0.157 0.130 0.106 0.067 0.173 ・Available options: ⇒ Without Sensor ・Please inquire as the availability of these functions depend on the model. ⇒ Lock Sensor Low speed Sensor ■ Dimensions(Unit : mm) 25±0.5 80±0.5 71.5±0.3 8-φ4.3±0.3 Mounting Hole 取付用穴 3.5±0.3 3.5±0.3 80±0.5 71.5±0.3 リード線 Lead Wire AWG24 UL1007 +50 300 0 (10) Rotating Direction 回転方向 Air Flow Direction 風吹出方向 ■ Reference dimension of mounting holes and vent opening(Unit : mm) Inlet side Outlet side 4-φ4.5 78 287 4-φ4.5 71.5±0.3 78 90 71.5±0.3 φ 78 78 87 φ 71.5±0.3 71.5±0.3 SPL [Pa] [inchH²O] [dB(A)] 37 32 29 26 22 37 32 29 26 22 34 Operating Temperature Expected Life [℃] [h] − 20 to + 70 100,000 ■ Options(Unit : mm) Finger guards Resin Finger guards Model:109-049C Model:109-1002G Color Surface treatment :Nickel-chrome plating(silver) Outlet side 82±1 4.3±0.3 75 φ 82±1 88 +1.5 ー0.5 φ1.6 105 4-φ4.3±0.3 4-2±0.5 φ3 9.6 71.5±0.3 φ1.6 7±0.5 71.5±0.3 5 +10 φ101.2 Resin filter kits Model:109-1002F13(13PPI) ,109-1002F20(20PPI) :109-1002F30(30PPI) ,109-1002F40(40PPI) Inlet side, Outlet side +1 4-φ4.3±0.3 71.5±0.3 85.5±1 71.5±0.3 5 0 88 +1.5 105 −0.5 φ75 10.5±0.5 85.5±1 4.3±0.3 φ1.6 φ1.6 Long Life Fan 80mm Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Model:109-049E :109-049H φ101.2 4-φ10±0.5 4-2±0.5 ■ Air Flow - Static Pressure Characteristics S speed (inch H2O)(Pa) H speed 50 0.15 12V/24V 10.2V/20.4V 40 30 0.10 20 0.05 10 0 0 0.5 0 10 20 1.0 30 40 1.5 (m3/min) 50 50 13.8V/27.6V 40 12V/24V 30 10.2V/20.4V 20 10 0 0.5 0 (CFM) →→ Air風量 Flow 10 M speed → Static Pressure → 静圧 → Static Pressure → 静圧 13.8V/27.6V 30 12V/24V 20 10.2V/20.4V 0.06 10 0 0.5 0 10 20 1.0 30 40 13.8V/27.6V 30 12V/24V 20 10.2V/20.4V 10 0 0.5 0 (CFM) 10 0.10 25 0.08 20 0.06 15 5 40 1.5 (m3/min) 0 0 50 →→ Air風量 Flow 109L0812M401 109L0824M401 (CFM) 1.5 (m3/min) 50 (CFM) H speed 13.8V/27.6V 12V/24V 0.2 0 40 (inch H2O)(Pa) 10 0.02 1.0 30 109L0812F401 109L0824F401 10.2V/20.4V 0.04 20 →→ Air風量 Flow 0.02 0 50 L speed 40 0.10 0.04 50 (inch H2O)(Pa) 0.14 0.08 40 109L0812H401 109L0824H401 (inch H2O)(Pa) 0.12 30 1.5 (m3/min) 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 →→ Air風量 Flow 109L0812S401 109L0824S401 0.16 20 1.0 → Static Pressure → 静圧 0.20 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 (inch H2O)(Pa) → Static Pressure → 静圧 13.8V/27.6V 60 → Static Pressure → 静圧 → Static Pressure → 静圧 70 0.25 F speed (inch H2O)(Pa) 0.30 5 0.4 10 15 0.6 20 0.8 (m3/min) 25 →→ Air風量 Flow 109L0812L401 109L0824L401 30 (CFM) 0.24 0.22 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 60 55.2V 50 40 48V 30 40.8V 20 10 0 0.5 0 10 20 1.0 30 40 1.5 (m3/min) 50 (CFM) →→ Air風量 Flow 109L0848H401 288
109L0824S401 价格&库存
很抱歉,暂时无法提供与“109L0824S401”相匹配的价格&库存,您可以联系我们找货
