Long Life Fan
92
San Ace 92L
25mm thick
mm sq.
■ General Specifications
・Material …………………… Frame: Aluminum, Impeller: Plastics (Flammability: UL94V-1)
・Expected Life …………… Refer to specifications (L10:Survival rate: 90% at 60℃ ,
rated voltage, and continuously run in a free air state)
・Lead Wire ………………… 䊝red 䊞black or blue Sensor yellow
・Storage Temperature …−30℃ to +70℃(Non-condensing)
92×92×25mm
■ Specifications
Model No.
Model no. 109L0948C401 is not certified.
〔Mass:170g〕
The following nos. have pulse sensors.
Rated Voltage Operating Voltage Range Rated Current Rated Input
[V]
109L0912S401
109L0912H401
109L0912F401
109L0912M401
109L0912L401
109L0924H401
109L0924F401
109L0924M401
109L0924L401
109L0948C401
109L0948H401
12
[V]
20.4 to 27.6
48
43 to 53
40.8 to 55.2
Max. Air Flow
Max. Static Pressure
[W]
[min-1]
[m³/min]
[CFM]
0.32
0.21
0.14
0.11
0.08
0.12
0.08
0.06
0.05
0.1
0.06
3.84
2.52
1.68
1.32
0.96
2.88
1.92
1.44
1.2
4.8
2.88
3,500
2,850
2,450
2,100
1,700
2,850
2,450
2,100
1,700
3,400
2,850
1.69
1.38
1.18
1.01
0.80
1.38
1.18
1.01
0.80
1.65
1.38
59.7
48.7
41.7
35.7
28.2
48.7
41.7
35.7
28.2
58.3
48.7
10.2 to 13.8
24
Rated Speed
[A]
SPL
[Pa] [inchH²O] [dB(A)]
66.6
45.1
32.3
23.5
16.7
45.1
32.3
23.5
16.7
64.2
45.1
0.267
0.181
0.130
0.094
0.067
0.181
0.130
0.094
0.067
0.258
0.181
39
33
30
27
23
33
30
27
23
38
33
・Available options: ⇒ Without Sensor
・Please inquire as the availability of these functions depend on the model. ⇒ Lock Sensor
Low speed Sensor
■ Dimensions(Unit : mm)
8-φ4.3±0.3
Mounting
Hole
取付用穴
25±0.5
3.5±0.3
3.5±0.3
Lead
Wire
リード線
AWG24
UL1007
82.5±0.3
92±0.5
92±0.5
82.5±0.3
+30
300 0
(10)
Rotating
Direction
回転方向
Air Flow
Direction
風吹出方向
■ Reference dimension of mounting holes and vent opening(Unit : mm)
Inlet side
Outlet side
4-φ4.5
2
293
10
φ
90
10
82.5±0.3
90
φ
4-φ4.5
82.5±0.3
90
82.5±0.3
82.5±0.3
Operating Temperature Expected Life
[h]
100,000
− 20 to + 70
80,000
100,000
■ Options(Unit : mm)
Finger guards
Resin Finger guards
Model:109-099C
Model:109-1001G
Color
Surface treatment :Nickel-chrome plating(silver)
92±1
Outlet side
92±1
4-φ4.3±0.3
4-2±0.5
82.5±0.3
99
+1.5
120.5 ー0.5
4.3±0.3
φ1.6
φ1.6
9.8
φ3φ87
7±0.5
82.5±0.3
5+10
.6
16
φ1
Resin filter kits
Model:109-1001F13(13PPI)
,109-1001F20(20PPI)
:109-1001F30(30PPI)
,109-1001F40(40PPI)
Inlet side, Outlet side
96.5±1
5
4.3±0.3
φ1.6
φ1.6
10.5±0.5
82.5±0.3
+1
Long Life Fan 92mm
Color
:Cation electropainting(black)
Model:109-099E
:109-099H
4-φ4.3±0.3
96.5±1
82.5±0.3
91
99
+1.5
120.5 −0.5
7
φ8
.6
16
φ1
4-φ9.5±0.5
4-2±0.5
■ Air Flow - Static Pressure Characteristics
S speed
(inch H2O)(Pa)
0.40
60
0.20
50
0.15
40
12V
10.2V
30
10
0.5
40
2.0
60
0.25
50
0.15
40
0.10
53V
60
0.20
48V
43V
30
(m3/min)
80
70
10
F speed
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
13.8V/27.6V
12V/24V
10.2V/20.4V
0.5
10.2V/20.4V/40.8V
30
0.10
10
0.12
30
1.0
30
1.5
50
→ Air
→ Flow
風量
109L0912F401
109L0924F401
(m3/min)
60(CFM)
12V/24V
10.2V/20.4V
10
2.0 (m3/min)
L speed
13.8V/27.6V
0.06
0.04
1.5
(inch H2O)(Pa)
0.10
0.08
1.0
109L0912H401
109L0924H401
109L0948H401
0.02
0 10 20 30 50 60 70 (CFM)
0.14
0.10
12V/24V/48V
40
M speed
50
40
50
→ Air
→ Flow
風量
(inch H2O)(Pa)
30
2.0 (m3/min)
13.8V/27.6V/55.2V
0.20
109L0948C401
(inch H2O)(Pa)
0.05
1.5
60
→ Air
→ Flow
風量
109L0912S401
0.15
1.0
0.25
(CFM)
→ Air
→ Flow
風量
0.20
→ Static
Pressure
→ 静圧
13.8V
70
H speed
0.30
80
0.30
80
0.25
0.10
(inch H2O)(Pa)
→ Static
Pressure
→ 静圧
0.30
90
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
0.35
C speed
(inch H2O)(Pa)
10
30
40
1.5 (m3/min)
50
→ Air
→ Flow
風量
109L0912M401
109L0924M401
(CFM)
0.10
25
0.08
15
0.04
10
0.02
5
13.8V/27.6V
12V/24V
10.2V/20.4V
0.2 0.4 0.6 0.8 1.0 1.2 (m3/min)
40
(CFM)
→ Air
→ Flow
風量
109L0912L401
109L0924L401
294
很抱歉,暂时无法提供与“109L0924H402”相匹配的价格&库存,您可以联系我们找货
