74LVT162240ADL,118
74LVT162240ADL,118
    NEXPERIA(安世)
    SSOP48_300MIL
    IC BUFFER INVERT 3.6V 48SSOP
74LVT162240ADL,118 数据手册
74LVT162240A 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state Rev. 4 — 4 June 2018 1 Product data sheet General description The 74LVT162240A is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is an inverting 16-bit buffer that is ideal for driving bus lines. The device features four output enable pins (1OE, 2OE, 3OE, 4OE), each controlling four of the 3state outputs. The 74LVT162240A is designed with 30 Ω series resistance in both the pull-up and pulldown output structures. This design reduces line noise in applications such as memory address drivers, clock drivers, and bus receivers/transmitters. 2 Features and benefits • • • • • • • • • • • • 16-bit bus interface 3-state buffers Output capability: +12 mA/–12 mA TTL input and output switching levels Input and output interface capability to systems at 5 V supply Bus-hold data inputs eliminate the need for external pull-up resistors to hold unused inputs Live insertion/extraction permitted Outputs include series resistance of 30 Ω making external termination resistors unnecessary Power-up 3-state No bus current loading when output is tied to 5 V bus Latch-up protection: – JESD17: exceeds 500 mA ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name 74LVT162240ADGG -40 °C to +85 °C 4 TSSOP48 Description Version plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 Functional diagram 47 46 44 43 1 41 40 38 37 48 1A0 1Y0 1A1 1Y1 1A2 1Y2 1A3 1Y3 2 36 3 35 5 33 6 1OE 2A0 2A1 2A2 2A3 32 25 2Y0 8 2Y1 2Y2 2Y3 9 11 12 2OE 30 29 27 26 24 3A0 3Y0 3A1 3Y1 3A2 3Y2 3A3 3Y3 14 1 1OE 48 2OE 25 3OE 24 4OE 16 1A0 13 1A1 1A2 17 1A3 3OE 2A0 2A1 4A0 4A1 4A2 4A3 4Y0 4Y1 4Y2 4Y3 2A2 19 2A3 3A0 20 3A1 3A2 22 3A3 4A0 23 4A1 4A2 4OE 4A3 EN1 EN2 EN3 EN4 47 46 1 2 3 44 5 43 6 41 40 1 2 8 9 38 11 37 12 36 35 1 3 13 14 33 16 32 17 30 29 1 4 19 20 27 22 26 23 1Y0 1Y1 1Y2 1Y3 2Y0 2Y1 2Y2 2Y3 3Y0 3Y1 3Y2 3Y3 4Y0 4Y1 4Y2 4Y3 001aad262 001aad261 Figure 1. Logic symbol 1 Figure 2. IEC logic symbol VCC VCC 27 Ω output 27 Ω 001aac372 Figure 3. Schematic of one output 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 5 Pinning information 5.1 Pinning 74LVT162240A 1OE 1 48 2OE 1Y0 2 47 1A0 1Y1 3 46 1A1 GND 4 45 GND 1Y2 5 44 1A2 1Y3 6 43 1A3 VCC 7 2Y0 8 42 VCC 41 2A0 2Y1 9 40 2A1 GND 10 39 GND 2Y2 11 38 2A2 2Y3 12 37 2A3 3Y0 13 36 3A0 3Y1 14 35 3A1 GND 15 34 GND 3Y2 16 33 3A2 3Y3 17 32 3A3 VCC 18 4Y0 19 31 VCC 30 4A0 4Y1 20 29 4A1 GND 21 28 GND 4Y2 22 27 4A2 4Y3 23 26 4A3 40E 24 25 3OE aaa-028619 Figure 4. Pin configuration SOT362-1 (TSSOP48) 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 48, 25, 24 output enable inputs (active LOW) 1A0, 1A1, 1A2, 1A3 47, 46, 44, 43 data inputs 2A0, 2A1, 2A2, 2A3 41, 40, 38, 37 data inputs 3A0, 3A1, 3A2, 3A3 36, 35, 33, 32 data inputs 4A0, 4A1, 4A2, 4A3 30, 29, 27, 26 data inputs 1Y0, 1Y1, 1Y2, 1Y3 2, 3, 5, 6 data outputs 2Y0, 2Y1, 2Y2, 2Y3 8, 9, 11, 12 data outputs 3Y0, 3Y1, 3Y2, 3Y3 13, 14, 16, 17 data outputs 4Y0, 4Y1, 4Y2, 4Y3 19, 20, 22, 23 data outputs GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 6 Functional description Table 3. Function table [1] Input Output nOE nAn nYn L L H L H L H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit -0.5 +4.6 V input voltage [1] -0.5 +7.0 V VO output voltage output in OFF-state or HIGH-state [1] -0.5 +7.0 V IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current output in LOW-state - 128 mA output in HIGH-state -64 - mA -65 +150 °C - +150 °C VI Tstg storage temperature Tj [2] junction temperature [1] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 8 Recommended operating conditions Table 5. Operating conditions Symbol Parameter VCC supply voltage VI Min Typ Max Unit 2.7 - 3.6 V input voltage 0 - 5.5 V IOH HIGH-level output current - - -12 mA IOL LOW-level output current - - 12 mA Tamb ambient temperature -40 - +85 °C Δt/ΔV input transition rise and fall rate outputs enabled - - 10 ns/V [1] Max Unit - -0.85 -1.2 V 9 Conditions in free air Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VIK input clamping voltage VCC = 2.7 V; IIK = -18 mA VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V VOH HIGH-level output voltage VCC = 3.0 V; IOH = -12 mA 2.0 - - V VOL LOW-level output voltage VCC = 3.0 V; IOL = 12 mA - - 0.8 V 74LVT162240A Product data sheet Min All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 Typ © Nexperia B.V. 2018. All rights reserved. 5 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state Symbol Parameter Conditions II input leakage current all input pins Min VCC = 0 V or 3.6 V; VI = 5.5 V Typ [1] Max Unit - 0.4 10 μA - ±0.1 ±1 μA control pins VCC = 3.6 V; VI = VCC or GND data pins VCC = 3.6 V; VI = VCC [2] - 0.1 1 μA VCC = 3.6 V; VI = 0 V [2] - -0.4 -5 μA - 0.1 ±100 μA 75 135 - μA IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V IBHL bus hold LOW current nAn input; VCC = 3 V; VI = 0.8 V IBHH bus hold HIGH current nAn input; VCC = 3 V; VI = 2.0 V -75 -135 - μA 500 - - μA - - -500 μA - 50 125 μA - 1 ±100 μA output HIGH: VO = 3.0 V - 0.5 5 μA output LOW: VO = 0.5 V - 0.5 -5 μA - 0.07 0.12 mA IBHLO bus hold LOW overdrive current nAn input; VCC = 3.6 V; VI = 0 V to 3.6 V [3] IBHHO bus hold HIGH overdrive current nAn input; VCC = 3.6 V; VI = 0 V to 3.6 V [3] IEX external current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V IO(pu/pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care IOZ OFF-state output current VCC = 3.6 V; VI = VIL or VIH ICC supply current [4] VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs HIGH outputs LOW outputs disabled - 4.0 6 mA [5] - 0.07 0.12 mA [6] - 0.1 0.2 mA ΔICC additional supply current per input pin; VCC = 3 V to 3.6 V; one input at VCC - 0.6 V and other inputs at VCC or GND CI input capacitance nOE; VI = 0 V or 3 V - 3 - pF CO output capacitance VO = 0 V or 3.0 V - 9 - pF [1] [2] [3] [4] All typical values are at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. Unused pins at VCC or GND. This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. [5] Measured with outputs pulled up to VCC or GND. [6] This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7. Symbol Parameter Conditions Min tPLH LOW to HIGH propagation delay nAn to nYn; see Figure 5 VCC = 2.7 V VCC = 3.3 V ± 0.3 V tPHL HIGH to LOW propagation delay OFF-state to HIGH propagation delay VCC = 2.7 V OFF-state to LOW propagation delay VCC = 2.7 V HIGH to OFF-state propagation delay VCC = 2.7 V LOW to OFF-state propagation delay - - 5.0 ns 0.5 2.6 4.2 ns - - 5.0 ns 0.5 2.6 4.2 ns - - 6.5 ns 1.0 3.3 5.5 ns - - 5.5 ns 1.0 3.0 5.0 ns - - 5.5 ns 1.0 3.5 5.0 ns - - 4.5 ns 1.0 3.2 4.5 ns nOE to nYn; see Figure 6 VCC = 2.7 V VCC = 3.3 V ± 0.3 V tPLZ Unit nOE to nYn; see Figure 6 VCC = 3.3 V ± 0.3 V tPHZ Max nOE to nYn; see Figure 6 VCC = 3.3 V ± 0.3 V tPZL [1] nAn to nYn; see Figure 5 VCC = 3.3 V ± 0.3 V tPZH Typ nOE to nYn; see Figure 6 VCC = 2.7 V VCC = 3.3 V ± 0.3 V [1] Typical values are at VCC = 3.3 V and Tamb = 25 °C. 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 10.1 Waveforms and test circuit VI nAn input VM VM GND tPHL tPLH VOH VM nYn output VM VOL aaa-028620 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 5. Input (nAn) to output (nYn) propagation delay VI VM nOE input GND tPLZ tPZL 3.0 V nYn output VM VX VOL tPHZ VOH tPZH VY nYn output VM GND aaa-028621 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Enable and disable times of 3-state outputs Table 8. Measurement points Input Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state tW VI 90 % negative pulse 90 % VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V 10 % tW 001aac221 VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Figure 7. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω GND 6V open 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 11 Package outline TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit max nom min mm A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Figure 8. Package outline TSSOP48 (SOT362-1) 74LVT162240A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge MIL Military MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVT162240A v.4 20180604 Product data sheet - 74LVT162240A v.3 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Type number 74LVT162240ADL (SSOP48 / SOT370-1) removed. 74LVT162240A v.3 20030221 Modifications: • Table 1 corrected: removed ‘North America’ column. • Figure 2 modified to correct pin names 74LVT162240A v.2 19980219 Product specification ECN 853-1777 18990 74LVT162240A v.1 74LVT162240A v.1 19950822 Product specification - - 74LVT162240A Product data sheet Product data sheet ECN 853-1777 29438 All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 74LVT162240A v.2 © Nexperia B.V. 2018. All rights reserved. 11 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVT162240A Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVT162240A Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 June 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 14 74LVT162240A Nexperia 3.3 V 16-bit inverting buffer/driver with 30 Ω termination resistors; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 4 Functional description ........................................4 Limiting values .................................................... 5 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 8 Package outline .................................................10 Abbreviations .................................................... 11 Revision history ................................................ 11 Legal information .............................................. 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 4 June 2018 Document identifier: 74LVT162240A
74LVT162240ADL,118 价格&库存
很抱歉,暂时无法提供与“74LVT162240ADL,118”相匹配的价格&库存,您可以联系我们找货
