F8025E24B-FSR
F8025E24B-FSR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL80X25MM24VDC
F8025E24B-FSR 数据手册
MECHATRONICS ® F8025 Series Size: 3.15 x 3.15 x 0.98 inch (80 x 80 x 25 mm) 0.98 ±0.02 (25 ±0.5) 3.15 ±0.02 (80 ±0.5) • Broad range of models to meet air flow and sound noise targets 2.82 ±0.01 (71.5 ±0.3) 0.16 (4.0) 3.07 (78) 2.82 ±0.01 (71.5 ±0.3) 0.16 (4.0) • Electronic locked rotor sensor, auto-restart, reverse polarity protection (Ø 88 ) • 5, 12, or 24 VDC Ø 3. 46 • Flanged or ribbed frame styles; ball bearings • Options include tachometer or locked rotor output signal, and thermistor control 4x Ø 0.18 (Ø 4.5) .21 4x Ø 0.18 (Ø 4.5) STATIC PRESSURE - IN. OF WATER X .18 E H .15 Model No. Rated Voltage (v) 5 12 24 F8025S F8025L F8025M F8025H F8025E F8025X 5/12/24 5/12/24 5/12/24 5/12/24 5/12/24 12/24 150 200 290 420 800 – 75 90 120 145 240 480 50 60 80 90 140 260 M .12 L S .09 .06 .03 0 10 20 30 40 AIR FLOW - CFM 50 Revolution (rpm) 1,500 1,800 2,100 2,400 2,800 3,200 Air Volume Maximum Static Sound Noise (cfm) Pressure (dBA) (in H2O) 25 29 34 39 46 51 0.05 0.07 0.09 0.12 0.16 0.18 20 22 26 29 32 35 Weight (oz) 2.79 2.79 2.79 2.79 2.79 2.79 60 F8025-HP Series Size: 3.15 x 3.15 x 0.98 inch (80 x 80 x 25 mm) 0.98 ±0.02 (25 ±0.5) 3.15 ±0.02 (80 ±0.5) • High performance impeller design for maximum air flow 2.82 ±0.01 (71.5 ±0.3) 0.16 (4.0) • Electronic locked rotor sensor, auto-restart, reverse polarity protection 3.07 (78) 2.82 ±0.01 (71.5 ±0.3) 0.16 (4.0) 88 ) • 12 or 24 VDC Ø 3. 46 (Ø • Ribbed or flanged frame styles; ball bearings • Options include tachometer or locked rotor output signal, and thermistor control .30 4x Ø 0.18 (Ø 4.5) STATIC PRESSURE - IN. OF WATER X .25 4x Ø 0.18 (Ø 4.5) E H .20 M Rated Voltage (v) Current (mA) 12 24 F8025S-H F8025L-H F8025M-H F8025H-H F8025E-H F8025X-H 12/24 12/24 12/24 12/24 12/24 12/24 75 90 120 145 240 480 L .15 S .10 .05 0 Model No. 10 20 30 40 AIR FLOW - CFM Phone: 800-453-4569 50 50 60 80 90 140 260 Revolution (rpm) 2,000 2,400 2,800 3,200 3,600 4,200 Air Volume Maximum Sound Noise Weight (cfm) Static Pressure (dBA) (oz) (in H2O) 26 31 35 40 46 53 0.07 0.10 0.12 0.17 0.21 0.26 22 26 29 32 35 39 2.79 2.79 2.79 2.79 2.79 2.79 60 E-mail: Sales@MechatronicsInc.com Fax: 425-222-5155
F8025E24B-FSR 价格&库存
很抱歉,暂时无法提供与“F8025E24B-FSR”相匹配的价格&库存,您可以联系我们找货
F8025E24B-FSR
    库存:19
