74ABT16240A
16-bit inverting buffer/line driver; 3-state
Rev. 7 — 7 July 2021
Product data sheet
1. General description
The 74ABT16240A is a 16-bit inverting buffer/line driver with 3-state outputs. The device can be
used as four 4-bit buffers, two 8-bit buffers or one 16-bit buffer. The device features four output
enables (1OE, 2OE, 3OE and 4OE), each controlling four of the 3-state outputs. A HIGH on nOE
causes the outputs to assume a high-impedance OFF-state. This device is fully specified for
partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the
potentially damaging backflow current through the device when it is powered down.
2. Features and benefits
Supply voltage range from 4.5 V to 5.5 V
BiCMOS high speed and output drive
Direct interface with TTL levels
Power-up 3-state
IOFF circuitry provides partial Power-down mode operation
Latch-up protection exceeds 500 mA per JESD78B class II level A
16-bit bus interface
Multiple VCC and GND pins minimize switching noise
3-state buffers
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Output capability: +64 mA and -32 mA
Live insertion and extraction permitted
ESD protection:
• HBM JESD-A114E exceeds 2000 V
• CDM JESD22-C101-C exceeds 1000 V
3. Ordering information
Table 1. Ordering information
Type number
Package
74ABT16240ADGG
Temperature range
Name
Description
Version
-40 °C to +85 °C
TSSOP48
plastic thin shrink small outline package; 48 leads;
body width 6.1 mm
SOT362-1
74ABT16240A
Nexperia
4. Functional diagram
47
46
44
43
1
41
40
38
37
48
1A0
1Y0
1A1
1Y1
1A2
1Y2
1A3
1Y3
2
36
3
35
5
33
6
1OE
2A0
2A1
2A2
2A3
32
25
2Y0
2Y1
2Y2
2Y3
2OE
8
9
11
12
30
29
27
26
24
3A0
3Y0
3A1
3Y1
3A2
3Y2
3A3
3Y3
14
1
1OE
48
2OE
25
3OE
24
4OE
16
1A0
13
1A1
1A2
17
1A3
3OE
2A0
2A1
4A0
4A1
4A2
4A3
4Y0
4Y1
4Y2
4Y3
2A2
19
2A3
3A0
3A1
3A2
22
3A3
4A0
23
4A1
4A2
4OE
4A3
EN1
EN2
EN3
EN4
47
46
Logic symbol
74ABT16240A
Product data sheet
2
1
3
44
5
43
6
41
40
1
8
2
9
38
11
37
12
36
35
1
3
13
14
33
16
32
17
30
29
1
4
19
22
26
23
1Y0
1Y1
1Y2
1Y3
2Y0
2Y1
2Y2
2Y3
3Y0
3Y1
3Y2
3Y3
4Y0
4Y1
4Y2
4Y3
001aad262
001aad261
Fig. 1.
1
Fig. 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 11
74ABT16240A
Nexperia
5. Pinning information
5.1. Pinning
1OE
1
48 2OE
1Y0
2
47 1A0
1Y1
3
46 1A1
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
42 VCC
2Y0
8
41 2A0
2Y1
9
40 2A1
GND 10
39 GND
2Y2 11
38 2A2
2Y3 12
37 2A3
74ABT16240A
3Y0 13
36 3A0
3Y1 14
35 3A1
GND 15
34 GND
3Y2 16
33 3A2
3Y3 17
32 3A3
VCC 18
31 VCC
4Y0 19
30 4A0
4Y1 20
29 4A1
GND 21
28 GND
4Y2 22
27 4A2
4Y3 23
26 4A3
4OE 24
25 3OE
001aaj891
Fig. 3.
Pin configuration SOT362-1 (TSSOP48)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE, 2OE, 3OE, 4OE
1, 48, 25, 24
1 to 4 output enable (LOW active)
1Y0, 1Y1, 1Y2, 1Y3
2, 3, 5, 6
1 data output
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
supply voltage
2Y0, 2Y1, 2Y2, 2Y3
8, 9, 11, 12
2 data output
3Y0, 3Y1, 3Y2, 3Y3
13, 14, 16, 17
3 data output
4Y0, 4Y1, 4Y2, 4Y3
19, 20, 22, 23
4 data output
4A0, 4A1, 4A2, 4A3
30, 29, 27, 26
4 data input
3A0, 3A1, 3A2, 3A3
36, 35, 33, 32
3 data input
2A0, 2A1, 2A2, 2A3
41, 40, 38, 37
2 data input
1A0, 1A1, 1A2, 1A3
47, 46, 44, 43
1 data input
74ABT16240A
Product data sheet
3 / 11
74ABT16240A
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Control
Input
Output
nOE
nAn
nYn
L
L
H
L
H
L
H
X
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
output in OFF-state or HIGH-state
IIK
input clamping current
VI < 0 V
-18
mA
IOK
output clamping current
VO < 0 V
-50
mA
IO
output current
output in LOW-state
128
mA
output in HIGH-state
-64
mA
150
°C
Tj
junction temperature
Tstg
storage temperature
[1]
[2]
Conditions
Min
Max Unit
-0.5
+7.0 V
[1]
-1.2
+7.0 V
[1]
-0.5
+5.5 V
[2]
-65
+150 °C
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
8. Recommended operating conditions
Table 5. Operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VIH
Conditions
Min
Typ
4.5
5.5
V
VCC
V
HIGH-level input voltage
2.0
V
VIL
LOW-level Input voltage
0.8
V
IOH
HIGH-level output current
-32
mA
IOL
LOW-level output current
32
mA
64
mA
10
ns/V
-40
+85
°C
duty cycle ≤ 50 %; fi ≥ 1 kHz
Δt/ΔV
input transition rise and fall rate
Tamb
ambient temperature
74ABT16240A
Product data sheet
in free air
Max Unit
4 / 11
74ABT16240A
Nexperia
9. Static characteristics
Table 6. Static characteristics
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C Unit
Min
Typ
Max
Min
Max
-1.2
-0.9
-1.2
V
VCC = 4.5 V; IOH = -3 mA
2.5
2.9
2.5
V
VCC = 5.0 V; IOH = -3 mA
3.0
3.4
3.0
V
VCC = 4.5 V; IOH = -32 mA
2.0
2.4
2.0
V
0.42
0.55
0.55
V
VIK
input clamping
voltage
VCC = 4.5 V; IIK = -18 mA
VOH
HIGH-level output
voltage
VI = VIL or VIH
VOL
LOW-level output
voltage
VCC = 4.5 V; IOL = 64 mA;
VI = VIL or VIH
II
input leakage current VCC = 5.5 V; VI = VCC or GND
±0.01
±1.0
±1.0
μA
IOFF
power-off leakage
current
±5.0
±100
±100
μA
±5.0
±50
±50
μA
output HIGH-state at VO = 5.5 V
1.0
10
10
μA
output LOW-state at VO = 0.5 V
-1.0
-10
-10
μA
1.0
50
50
μA
-70
-50
-180
-50
mA
VCC = 0 V; VI or VO ≤ 4.5 V
IO(pu/pd) power-up/powerdown output current
VCC = 2.0 V; VO = 0.5 V;
VI = GND or VCC; nOE = HIGH
IOZ
OFF-state output
current
VCC = 5.5 V; VI = VIL or VIH
ICEX
output high leakage
current
HIGH-state; VO = 5.5 V;
VCC = 5.5 V; VI = GND or VCC
IO
output current
VCC = 5.5 V; VO = 2.5 V
ICC
supply current
[1]
[2] -180
outputs HIGH-state
0.5
1.0
1.0
mA
outputs LOW-state
8
19
19
mA
outputs 3-state
0.5
1.0
1.0
mA
10
200
200
μA
ΔICC
additional supply
current
per input pin; VCC = 5.5 V;
one input at 3.4 V and other inputs
at VCC or GND
CI
input capacitance
VI = 0 V or VCC
4
pF
CI/O
input/output
capacitance
outputs disabled; VO = 0 V or VCC
6
pF
[1]
[2]
[3]
[4]
[3]
[4]
This parameter is valid for any VCC between 0 V and 2.1 V, with a transition time of up to 10 ms.
From VCC = 2.1 V to VCC = 5 V ± 10 %, a transition time of up to 100 μs is permitted.
Not more than one output should be tested at a time, and the duration of the test should not exceed one second.
This is the increase in supply current for each input at 3.4 V.
This data sheet limit may vary among suppliers.
74ABT16240A
Product data sheet
5 / 11
74ABT16240A
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V. For test circuit, see Fig. 6.
Symbol Parameter
Conditions
25 °C; VCC = 5.0 V
-40 °C to +85 °C; Unit
VCC = 5.0 V ± 0.5 V
Min
Typ
Max
Min
Max
tPLH
LOW to HIGH
propagation delay
nAn to nYn, see Fig. 4
1.0
2.0
3.0
1.0
3.7
ns
tPHL
HIGH to LOW
propagation delay
1.0
1.5
3.0
1.0
3.5
ns
tPZH
OFF-state to HIGH
propagation delay
nOE to nYn; see Fig. 5
1.2
2.4
3.3
1.2
4.2
ns
tPZL
OFF-state to LOW
propagation delay
1.2
2.3
3.2
1.0
4.2
ns
tPHZ
HIGH to OFF-state
propagation delay
1.3
2.7
4.1
1.6
4.7
ns
tPLZ
LOW to OFF-state
propagation delay
1.3
2.5
3.6
1.4
4.1
ns
10.1. Waveforms and test circuit
VI
input nAn
VM
VM
0V
tPHL
tPLH
VOH
output nYn
VM
VM
VOL
001aaj028
VM = 1.5 V
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 4.
Input (nAn) to output (nYn) propagation delay
VI
VM
nOE input
GND
tPZL
tPLZ
3.5 V
VM
nYn output
VOL
tPZH
VOL + 0.3 V
tPHZ
VOH
VM
nYn output
VOH - 0.3 V
0V
001aaj892
VM = 1.5 V
Fig. 5.
3-state output enable and disable times
74ABT16240A
Product data sheet
6 / 11
74ABT16240A
Nexperia
VI
negative
pulse
tW
90 %
90 %
VM
10 %
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
90 %
VM
PULSE
GENERATOR
VM
10 %
10 %
tW
VEXT
VCC
VI
RL
VO
DUT
CL
RT
RL
001aai298
VM = 1.5 V
a. Input pulse definition
001aac764
b. Test circuit for 3-state outputs
Test data is given in Table 8.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig. 6.
Test circuit for measuring switching times
Table 8. Test data
Input
Load
VEXT
VI
fi
tW
tr, tf
CL
RL
tPHZ, tPZH
tPLZ, tPZL
tPLH, tPHL
3.0 V
1 MHz
500 ns
2.5 ns
50 pF
500 Ω
open
7.0 V
open
74ABT16240A
Product data sheet
7 / 11
74ABT16240A
Nexperia
11. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
A1
(A3)
pin 1 index
A
θ
Lp
1
L
24
bp
e
detail X
w
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A
1.2
A1
A2
0.15 1.05
0.05 0.85
A3
0.25
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
0.17
0.1
12.4
6.0
e
HE
0.5
8.3
7.9
L
1
Lp
Q
0.8
0.50
0.4
0.35
v
w
0.25 0.08
y
0.1
Z
θ
0.8
8°
0.4
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
Fig. 7.
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Package outline SOT362-1 (TSSOP48)
74ABT16240A
Product data sheet
8 / 11
74ABT16240A
Nexperia
12. Abbreviations
Table 9. Abbreviations
Acronym
Description
BiCMOS
Bipolar CMOS
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
CDM
Charged Device Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ABT16240A v.7
20210707
Product data sheet
74ABT16240A v.6
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Fig. 7: Package outline drawing SOT362-1 (TSSOP48) updated.
Type number 74ABT16240ADL (SOT370-1/SSOP48) removed.
Section 1 and Section 2 updated.
74ABT16240A v.6
20111103
Modifications:
74ABT16240A v.5
20100525
74ABT16240A v.4
74ABT16240A v.5
Product data sheet
74ABT16240A v.4
20090325
Product data sheet
74ABT16240A v.3
74ABT16240A v.3
20040212
Product specification
01-A15420
74ABT_H16240A v.2
74ABT_H16240A v.2
19980225
853-1880 19019
74ABT_H16240A
74ABT_H16240A
19961001
74ABT16240A
Product data sheet
Product data sheet
Legal pages updated
9 / 11
74ABT16240A
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ABT16240A
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
10 / 11
74ABT16240A
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 6
11. Package outline.......................................................... 8
12. Abbreviations.............................................................. 9
13. Revision history..........................................................9
14. Legal information......................................................10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 7 July 2021
74ABT16240A
Product data sheet
11 / 11
