74LVC16240A
16-bit buffer/line driver with 5V tolerant inputs/outputs;
inverting; 3-state
Rev. 5 — 25 April 2019
Product data sheet
1. General description
The 74LVC16240A is a 16-bit inverting buffer/line driver with 3-state outputs. The device can be
used as four 4-bit buffers, two 8-bit buffers or one 16-bit buffer. The device features four output
enables (1OE, 2OE, 3OE and 4OE), each controlling four of the 3-state outputs. A HIGH on nOE
causes the outputs to assume a high-impedance OFF-state.
Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to
the outputs. These features allow the use of these devices in mixed 3.3 V and 5 V applications.
This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry
disables the output, preventing the damaging backflow current through the device when it is
powered down.
2. Features and benefits
5 V tolerant inputs/outputs for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
MULTIBYTE flow-through standard pin-out architecture
Low inductance multiple power and ground pins for minimum noise and ground bounce
Direct interface with TTL levels
Complies with JEDEC standard:
• JESD8-7A (1.65 V to 1.95 V)
• JESD8-5A (2.3 V to 2.7 V)
• JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115B exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Specified from -40 °C to +85 °C and from -40 °C to +125 °C.
3. Ordering information
Table 1. Ordering information
Type number
Package
74LVC16240ADGG
Temperature range
Name
Description
Version
-40 °C to +125 °C
TSSOP48
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
74LVC16240A
Nexperia
16-bit buffer/line driver with 5V tolerant inputs/outputs; inverting; 3-state
4. Functional diagram
1A0
1A1
1A2
1A3
1OE
2A0
2A1
2A2
2A3
2OE
Fig. 1.
47
2
46
3
44
5
43
6
1Y0
3A0
1Y1
3A1
1Y2
3A2
1Y3
3A3
1
3OE
41
8
40
9
38
11
37
12
2Y0
4A0
2Y1
4A1
2Y2
4A2
2Y3
4A3
48
4OE
36
13
35
14
33
16
32
17
3Y0
3Y1
3Y2
3Y3
25
30
19
29
22
26
23
4Y0
4Y1
4Y2
4Y3
24
001aaa439
Logic symbol
1OE
2OE
3OE
4OE
1A0
1A1
1A2
1A3
2A0
2A1
2A2
2A3
3A0
3A1
3A2
3A3
4A0
4A1
4A2
4A3
1
48
25
24
47
46
1EN
2EN
3EN
4EN
1
1
2
3
44
5
43
6
41
8
40
1 2
9
38
11
37
12
36
13
35
1 3
14
33
16
32
17
30
29
1 4
19
22
26
23
1Y0
1Y1
1Y2
1Y3
2Y0
2Y1
2Y2
2Y3
3Y0
3Y1
3Y2
3Y3
4Y0
4Y1
4Y2
4Y3
001aaa442
Fig. 2.
IEC logic symbol
74LVC16240A
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 12
74LVC16240A
Nexperia
5. Pinning information
5.1. Pinning
74LVC16240A
1OE
1
48 2OE
1Y0
2
47 1A0
1Y1
3
46 1A1
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
42 VCC
2Y0
8
41 2A0
2Y1
9
40 2A1
GND 10
39 GND
2Y2 11
38 2A2
2Y3 12
37 2A3
3Y0 13
36 3A0
3Y1 14
35 3A1
GND 15
34 GND
3Y2 16
33 3A2
3Y3 17
32 3A3
VCC 18
31 VCC
4Y0 19
30 4A0
4Y1 20
29 4A1
GND 21
28 GND
4Y2 22
27 4A2
4Y3 23
26 4A3
4OE 24
25 3OE
001aaa440
Fig. 3.
Pin configuration SOT362-1 (TSSOP48)
5.2. Pin description
Table 2. Pin description
Name
Pin
Description
1OE, 2OE, 3OE, 4OE
1, 48, 25, 24
output enable input (active LOW)
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
supply voltage
1Y0, 1Y1, 1Y2, 1Y3
2, 3, 5, 6
data output
2Y0, 2Y1, 2Y2, 2Y3
8, 9, 11, 12
data output
3Y0, 3Y1, 3Y2, 3Y3
13, 14, 16, 17
data output
4Y0, 4Y1, 4Y2, 4Y3
19, 20, 22, 23
data output
1A0, 1A1, 1A2, 1A3
47, 46, 44, 43
data input
2A0, 2A1, 2A2, 2A3
41, 40, 38, 37
data input
3A0, 3A1, 3A2, 3A3
36, 35, 33, 32
data input
4A0, 4A1, 4A2, 4A3
30, 29, 27, 26
data input
74LVC16240A
Product data sheet
3 / 12
74LVC16240A
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state
Output
Input
nOE
nAn
nYn
L
L
H
L
H
L
H
X
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
V
±50
mA
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
VO
output voltage
output HIGH or LOW state
[2]
-0.5
output 3-state
[2]
-0.5
+6.5
V
IO
output current
±50
mA
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
Min
Typ
Max
Unit
1.65
3.6
V
1.2
V
V
VCC
V
output 3-state
V
-40
+125
°C
[1]
[2]
[3]
VI < 0 V
[1]
VO = 0 V to VCC
Tamb = -40 °C to +125 °C
[3]
mA
VCC + 0.5 V
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
The output voltage ratings may be exceeded if the output current ratings are observed.
Above 60 °C the value of Ptot derates linearly with 5.5 mW/K.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
VCC
Conditions
supply voltage
functional
VI
input voltage
VO
output voltage
Tamb
ambient temperature
in free air
Δt/ΔV
input transition rise and fall rate
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
10
ns/V
74LVC16240A
Product data sheet
4 / 12
74LVC16240A
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
HIGH-level input
voltage
VIL
LOW-level input
voltage
VOH
VOL
Conditions
-40 °C to +85 °C
VCC = 1.2 V
VCC = 1.65 V to 1.95 V
Unit
Min
Typ [1]
Max
Min
Max
1.08
1.08
V
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
VCC = 1.2 V
0.12
0.12
V
0.35VCC
0.7
0.7
V
0.8
0.8
V
VCC - 0.2
VCC - 0.3
V
IO = -4 mA; VCC = 1.65 V
1.2
1.05
V
IO = -8 mA; VCC = 2.3 V
1.8
1.65
V
IO = -12 mA; VCC = 2.7 V
2.2
2.05
V
IO = -18 mA; VCC = 3.0 V
2.4
2.25
V
IO = -24 mA; VCC = 3.0 V
2.2
2.0
V
IO = 100 μA;
VCC = 1.65 V to 3.6 V
0.2
0.3
V
IO = 4 mA; VCC = 1.65 V
0.45
0.65
V
IO = 8 mA; VCC = 2.3 V
0.6
0.8
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
HIGH-level output VI = VIH or VIL
voltage
IO = -100 μA;
LOW-level output
voltage
-40 °C to +125 °C
0.35VCC V
VI = VIH or VIL
II
input leakage
current
VCC = 3.6 V; VI = 5.5 V or GND
±0.1
±5
±20
μA
IOZ
OFF-state output
current
VI = VIH or VIL; VCC = 3.6 V;
VO = 5.5 V or GND
0.1
±5
±20
μA
IOFF
power-off leakage VCC = 0 V; VI or VO = 5.5 V
current
0.1
±10
±20
μA
ICC
supply current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
μA
ΔICC
additional supply
current
per input pin; VCC = 2.7 V to 3.6 V;
VI = VCC - 0.6 V; IO = 0 A
5
500
5000
μA
CI
input capacitance VCC = 0 V to 3.6 V;
VI = GND to VCC
5.0
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C.
74LVC16240A
Product data sheet
5 / 12
74LVC16240A
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 6.
Symbol Parameter
tpd
propagation delay
Conditions
-40 °C to +85 °C
nAn to nYn; see Fig. 4
enable time
12.0
ns
5.1
11.0
1.0
11.7
ns
0.5
2.7
5.5
0.5
6.1
ns
VCC = 2.7 V
1.0
2.7
5.2
1.0
6.5
ns
VCC = 3.0 V to 3.6 V
1.0
2.3
4.2
1.0
5.5
ns
18.0
ns
1.5
6.6
12.8
1.5
13.5
ns
1.0
3.8
6.8
1.0
7.5
ns
VCC = 2.7 V
1.5
3.5
5.8
1.5
7.5
ns
1.0
3.0
5.0
1.0
6.5
ns
11.0
ns
2.9
4.7
9.2
2.9
9.7
ns
1.0
2.6
5.0
1.0
5.6
ns
VCC = 2.7 V
1.5
3.5
5.1
1.5
6.5
ns
1.5
3.2
4.9
1.5
6.5
ns
1.0
1.5
ns
4.8
pF
8.3
pF
11.4
pF
nOE to nYn; see Fig. 5
[2]
[2]
tsk(o)
output skew time
[3]
CPD
power dissipation
capacitance
per input; VI = GND to VCC
[4]
[3]
[4]
Max
VCC = 1.2 V
[1]
[2]
Min
1.0
disable time
Max
VCC = 1.2 V
tdis
Typ [1]
[2]
VCC = 1.2 V
ten
Min
-40 °C to +125 °C Unit
Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
2
Σ(CL × VCC × fo) = sum of the outputs
74LVC16240A
Product data sheet
6 / 12
74LVC16240A
Nexperia
10.1. Waveforms and test circuit
VI
nAn input
VM
VM
GND
tPHL
VOH
tPLH
90 %
90 %
VM
nYn output
VM
10 %
VOL
10 %
tTHL
tTLH
mgu781
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 4.
The input nAn to output nYn propagation delays
VI
nOE input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
VOH
tPZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
GND
VM
outputs
enabled
outputs
disabled
outputs
enabled
mna362
Fig. 5.
3-state enable and disable times
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
1.2 V
0.5 × VCC
0.5 × VCC
VOL + 0.1 V
VOH - 0.1 V
1.65 V to 1.95 V
0.5 × VCC
0.5 × VCC
VOL + 0.1 V
VOH - 0.1 V
2.3 V to 2.7 V
0.5 × VCC
0.5 × VCC
VOL + 0.1 V
VOH - 0.1 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74LVC16240A
Product data sheet
7 / 12
74LVC16240A
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 6.
Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
≤ 2 ns
30 pF
1 kΩ
open
2 × VCC
GND
1.65 V to 1.95 V
VCC
≤ 2 ns
30 pF
1 kΩ
open
2 × VCC
GND
2.3 V to 2.7 V
VCC
≤ 2 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74LVC16240A
Product data sheet
8 / 12
74LVC16240A
Nexperia
11. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
A1
(A3)
pin 1 index
A
θ
Lp
1
L
24
bp
e
detail X
w
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A
1.2
A1
A2
0.15 1.05
0.05 0.85
A3
0.25
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
0.17
0.1
12.4
6.0
e
HE
0.5
8.3
7.9
L
1
Lp
Q
0.8
0.50
0.4
0.35
v
w
0.25 0.08
y
0.1
Z
θ
0.8
8°
0.4
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
Fig. 7.
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Package outline SOT362-1 (TSSOP48)
74LVC16240A
Product data sheet
9 / 12
74LVC16240A
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC16240A v.5
20190425
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74LVC16240ADL (SOT370-1) removed.
Package outline drawing SOT362-1 (TSSOP48) updated.
Typo corrected in Section 5.2.
74LVC16240A v.4
20111103
Modifications:
74LVC16240A v.4
Product data sheet
74LVC16240A v.3
The format of this document has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Table 4, Table 5, Table 6, Table 7, and Table 9: values added for lower voltage ranges.
74LVC16240A v.3
20040305
Product specification
74LVC16240A v.2
74LVC16240A v.2
19970729
74LVC16240A v.1
74LVC16240A v.1
19951226
74LVC16240A
Product data sheet
10 / 12
74LVC16240A
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVC16240A
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
11 / 12
74LVC16240A
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 7
11. Package outline.......................................................... 9
12. Abbreviations............................................................ 10
13. Revision history........................................................10
14. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 25 April 2019
74LVC16240A
Product data sheet
12 / 12
