09225VA-12Q-CA-00
09225VA-12Q-CA-00
    NMBTECHNOLOGIESCORPORATION
    FAN92X25MM12VDCIP69K
09225VA-12Q-CA-00 数据手册
DC Axial Fan 92 X25L ■ General Specifications Motor Protection DC FAN 09225VA (3610VL) Auto Restart / Polarity Protection General purpose Insulation Resistance 10MΩ or over with a DC500V Megger Dielectric Withstand Voltage:AC700V 1s Allowable Ambient :­ 10℃ ~ + 70℃ (Operating) Temperature Range ­ 40℃ ~ + 70℃ (Storage) Industrial non-condensing environment ■ Outline ※ Failure Rate: 10%(L10 Life) Server ■ Expected Life 60℃ 40,000 (Hours) 4 – φ4.3 4 – φ4.3 .0 φ9 82.5 89.0 NAME PLATE 25.0 ±0.5 4. 92.0 ±0.5 82.5 ±0.3 AIR φ1 82.5 ±0.3 82.5 89.0 92.0 ±0.5 Blower 05 0 4 – φ4.3 ±0.2 (Outlet Side) 82.5 89.0 min 300 (Inlet Side) Refrigerator ■ Panel Out-cuts 82.5 89.0 *Outline is A (Rib) type. ■ Characteristic Curves 160 Q Class Static Pressure 140 Ps (Pa) ■ Material 120 Casing Impeller Bearing Lead Wire P Class 100 N Class 80 :Plastic (Black) UL94V-0 :Plastic (Black) UL94V-0 :Ball Bearing :UL3385 AWG26 +:Red, ­:Black M Class 60 40 20 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 Customize service for IP compatible type and Oil-proof type is available for this item. Please contact to our sales representative for more detail. Q (m3/min) Air Flow ■ Specifications □= Casing Form - - - A: Rib Type、E: Flange Type Model 09225VA-12M- □ A09225VA-12N- □ A09225VA-12P- □ A09225VA-12Q- □ A09225VA-24M- □ A09225VA-24N- □ A09225VA-24P- □ A09225VA-24Q- □ A- Rating Voltage Operating Voltage Product No. 00 00 00 00 00 00 00 00 (V) (V) 12 7.0 ~ 13.8 24  Rotation: Clockwise as seen from the label side  Airflow Outlet: Label side 14.0 ~ 27.6 Current Input Power Speed Max.Air Flow (A)*1 0.30 0.40 0.52 0.72 0.17 0.22 0.28 0.38 (W)*1 3.60 4.80 6.24 8.64 4.08 5.28 6.72 9.12 (min-1)*1 4000 4500 5000 5600 4000 4500 5000 5600 (m3/min)*1 (CFM)*1 1.93 68.1 2.18 77.0 2.43 85.8 2.73 96.4 1.93 68.1 2.18 77.0 2.43 85.8 2.73 96.4 Max. Static Pressure (Pa)*1 80.0 98.0 120.0 150.0 80.0 98.0 120.0 150.0 (In H2O)*1 0.32 0.39 0.48 0.60 0.32 0.39 0.48 0.60 Noise Mass (dB)*1 42.0 45.0 48.0 51.0 42.0 45.0 48.0 51.0 (g) 135 *1: Average Values in Free Air 09225VA (92 X 25L) IP69K NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: Auto Restart/Polarity Protection (Pa) 0.80 200 Insulation Resistance: 10M Ω or over with a DC500V Megger P-Q Curve Speed Curve Static Pressure Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) 0.60 P 150 4,500 N M L 0.40 K 100 IP Code: IP69K P Ps 0.20 50 K 0 Expected Life 25°C 6,000 Q 100,000 Hours (L10) 0 3,000 Q N M L 1,500 0 1.0 0 35 2.0 3.0 (m3/min) 70 105 CFM Air Flow Material Outline Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3385, AWG26, +Red, -Black 11.81 (min 300) NO SOLDER 0.137 (4−φ4.3± 0.2) IMPELLER ROTATION 3.50 (89.0) 3.29 .169 (4 – φ4.3) (82.5) INLET SIDE NAME PLATE .169 (4 – φ4.3) ( φ 4.1 10 3 5) 3 ( φ .70 94 ) 3.50 (89.0) 3.29 (82.5) AIR 3.50 (89.0) 3.50 (89.0) 3.29 (82.5) 3.29 (82.5) 3.62 (92.0± 0.5) inch Units: (mm) 3.25 (82.5± 0.3) Panel Cut-Outs 3.25 (82.5± 0.3) 0.98 (25.0± 0.5) 3.62 (92.0± 0.5) OUTLET SIDE Specifications Rated Operating Voltage Voltage (V) (V) (A)*1 (W)*1 09225VA-12K-CA-00 12 7.0 ~ 13.8 0.18 2.16 3200 54.03 1.53 .20 50.0 35.5 09225VA-12L-CA-00 12 7.0 ~ 13.8 0.24 2.88 3600 61.09 1.73 .26 65.0 38.5 150 09225VA-12M-CA-00 12 7.0 ~ 13.8 0.30 3.60 4000 68.16 1.93 .32 80.0 42.0 150 09225VA-12N-CA-00 12 7.0 ~ 13.8 0.40 4.80 4500 76.99 2.18 .39 98.0 45.0 150 09225VA-12P-CA-00 12 7.0 ~ 13.8 0.52 6.24 5000 85.81 2.43 .48 120.0 48.0 150 09225VA-12Q-CA-00 12 7.0 ~ 13.8 0.72 8.64 5600 96.41 2.73 .60 150.0 51.0 150 MODEL Rotation: Clockwise Current Input Speed Power Airflow Outlet: Air Out Over Struts Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 *1: Average Values in Free Air Mass (g) 150 Note: PWM/Locked Rotor/Tach Available Extreme Environment In H2O Speed General Specifications 09225VA (92 X 25L) IP69K NMBTC.COM / 248.919.2250 Specifications Operating Voltage (V) (V) 09225VA-24K-CA-00 24 09225VA-24L-CA-00 24 09225VA-24M-CA-00 09225VA-24N-CA-00 Current Input Speed Power Max. Max. Static Air Flow Pressure Noise (min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 Mass (A)*1 (W)*1 (g) 14.0 ~ 27.6 0.11 2.64 3200 54.03 1.53 .20 50.0 35.5 150 14.0 ~ 27.6 0.14 3.36 3600 61.09 1.73 .26 65.0 38.5 150 24 14.0 ~ 27.6 0.17 4.08 4000 68.16 1.93 .32 80.0 42.0 150 24 14.0 ~ 27.6 0.22 5.28 4500 76.99 2.18 .39 98.0 45.0 150 09225VA-24P-CA-00 24 14.0 ~ 27.6 0.28 6.72 5000 85.81 2.43 .48 120.0 48.0 150 09225VA-24Q-CA-00 24 14.0 ~ 27.6 0.38 9.12 5600 96.41 2.73 .60 150.0 51.0 150 Rotation: Clockwise Airflow Outlet: Air Out Over Struts *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available Extreme Environment Rated Voltage MODEL
09225VA-12Q-CA-00 价格&库存
很抱歉,暂时无法提供与“09225VA-12Q-CA-00”相匹配的价格&库存,您可以联系我们找货
09225VA-12Q-CA-00
  • 1+233.548111+30.31834
  • 10+187.9730210+24.40196
  • 25+171.1631825+22.21977
  • 65+154.8861765+20.10675
  • 130+152.72451130+19.82613
库存:9837
