UF80B12-STHR
UF80B12-STHR
    MECHATRONICSFANGROUP(机电一体化)
    FAN AXIAL 80X25MM 115VAC TERM
UF80B12-STHR 数据手册
3.15 ±0.02 (80 ±0.5) .98 ±0.02 (25 ±0.5) 2.81 ±0.01 (71.5 ±0.3) .25 Ø0.17 (Ø4.3 ±0.2) STATIC PRESSURE - IN. OF WATER AC AXIAL FANS UF80B series 0.16 (4) Ø2.99 (Ø76) Operating voltage: 115 or 230 VAC Construction: aluminum die cast frame; UL94V-0 PBT impeller Bearing option: ball bearing or sintered bronze sleeve Motor: .05 5 10 15 20 25 0.31 (8) TERMINAL TYPE Model No. Rated Freq. Input Rated Locked Speed Voltage Power Cur. Cur. Air Volume M³/Min. CFM Max. Static Sound Weight Pressure (H2 0) Noise V HZ W A A RPM MM INCH dbA kg UF80B12-_ _H 115 60 11 0.12 0.13 3,100 0.68 24 5.5 0.22 35 0.26 shaded pole Air Flow: exhaust over struts UF80B23-_ _H 230 60 14 0.07 0.08 3,100 0.68 24 5.5 0.22 35 0.26 Connection: terminal or 22 AWG lead wire UF80B12-_ _L 115 60 11 0.12 0.13 2,400 0.50 18 3.5 0.14 31 0.26 Protection: impedance UF80B23-_ _L 230 60 14 0.06 0.07 2,400 0.50 18 3.5 0.14 31 0.26 Options: dual voltage 115/230VAC, IP55; IP55 + salt fog w w w.mechatronic s.com 12.20.18 L .10 AIR FLOW (CFM) 0.12 (3) 0.35 (8.5) 3.15 x 3.15 x 0.98 inches H .15 0 LEAD WIRE TYPE (80 x 80 x 25 mm) .20 E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
UF80B12-STHR 价格&库存
很抱歉,暂时无法提供与“UF80B12-STHR”相匹配的价格&库存,您可以联系我们找货
