R200A0-051-D0760
R200A0-051-D0760
    NMBTECHNOLOGIESCORPORATION
    插件
    FANAXIAL200X51MM48VDC
R200A0-051-D0760 数据手册
NE W ! R200 (Ø200 X 51L) NMBTC.COM / 818.341.3355 Characteristic Curves 1400 R200A0_6500rpm 1200 R200A4_5000rpm 6 High Power Fans Static Pressure 1600 5 4 1000 800 3 600 2 400 1 200 0 0 0   -40 ∼+80 (保存) 0 100 200 200 300 400 400 500 600 800 600 700 1000 800 1200 900 3/ 1400 Air Flow General Specifications Outline Motor Protection: [inch] Units: mm Locked Rotor, Reverse Polarity 0. 3 9. 8 5 Insulation Resistance: 8 19 0. .75 4 X 4 X 90° -30°C ~ +70°C (Operating) -40°C ~ +80°C (Storage) 45° In H2O Casing : Aluminum Impeller : Plastic Bearing : Ball Bearing Lead Wire : UL3266, AWG20, +Red, -Black, Speed Control = Yellow AWG22 Speed Signal = White AWG22 Static Pressure Material Ps Specifications 0.4] 270 10 7.9 2 - 200 0.26 6.5 2.01 51 Speed Curve 3.20 800 24000 2.80 700 21000 2.40 600 18000 2.00 500 15000 N class 1.60 400 1.20 300 .80 200 Current Q c las s R c las s 12000 9000 6000 Operating Voltage Voltage .40 100 Power (V) (V) (A)*1 0 R200A0-051-D0760 48 30 ~ 72 2.9 139 0 R200A4-051-D0550 24 18 ~ 30 2.8 67 0.0 P c las s [10.3 0.4] 270 10 Rated Rotation: Counterclockwise looking at air inlet 0.26 6.5 P-Q Curve (Pa) [10.6 Speed 70,000 Hours MODEL Air Flow 4 X M4 [8.20] 2 X P.C.D 208 Expected Life 40°C 8X 8 Dielectric Withstand Voltage: AC 500V 1 minute Allowable Ambient Temperature Range: L10 Life: 0.18 4.6 X 10M Ω min measured with 500V DC between all leads shorted together and case Input (W)*1 Speed (min-1)*1 Max. Max. Static Air Flow Pressure CFM*1 (m3/hr)*1 in H2O 0.1 6500 0.2 783 0.3 1330 0.4 4.12 5000 590 1002 3.32 (Pa)*1 Noise Mass (dB)*1 (g) 0.5 1028 0.6 74 828 67 *1: Average Values in Free Air and Rated Voltage Condition 0 3.53 7.06 10.59 14.12 17.65 21.18 Air Flow 3000 0 0.7 1200 (m3/min) 1200 CFM 24.71 V.1
R200A0-051-D0760 价格&库存
很抱歉,暂时无法提供与“R200A0-051-D0760”相匹配的价格&库存,您可以联系我们找货
