UF12AR12-BWLR
UF12AR12-BWLR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL120X38MM115VACWIRE
UF12AR12-BWLR 数据手册
4.69 ±0.02 (120 ±0.5) 1.50 ±0.02 (38 ±0.5) 4.12 ±0.01 (104.8 ±0.3) .35 0.16 (4) Ø0.17 (Ø4.3 ±0.2) Ø4.49 (Ø114) Nom. 11.8 (300) STATIC PRESSURE - IN. OF WATER AC AXIAL FANS UF12AR series .30 H M .25 L .20 .15 .10 .05 0 (120 x 120 x 38 mm) Reverse air flow aluminum die cast frame; UL94V-0 PBT impeller Bearing option: ball bearing or sintered bronze sleeve Motor: shaded pole Air Flow: intake over struts Connection: terminal or 22 AWG lead wire Protection: impedance w w w.mechatronic s.com 11.23.20 60 80 100 120 AIR FLOW (CFM) TERMINAL TYPE 0.33 (8.5) Operating voltage: 115 or 230 VAC Construction: 40 0.12 (3) 4.69 x 4.69 x 1.5 inches Features: 20 LEAD WIRE TYPE Model No. Rated Freq. Input Rated Locked Speed Voltage Power Cur. Cur. V HZ UF12AR12-_ _H 115 60 UF12AR23-_ _H 230 60 UF12AR12-_ _M 115 60 UF12AR23-_ _M 230 UF12AR12-_ _L UF12AR23-_ _L E - mail: S ales @ M echatronic s.com 0.31 (8) M³/Min. CFM INCH dbA kg 99 8.5 0.33 47 0.53 99 8.5 0.33 47 0.53 2.4 85 6.5 0.26 45 0.53 2,750 2.4 85 6.5 0.26 45 0.53 0.16 2,300 2.1 75 4.0 0.16 38 0.53 0.08 2,300 2.1 75 4.0 0.16 38 0.53 A RPM 11 0.19 0.20 3,100 2.8 15 0.09 0.10 3,100 2.8 11 0.17 0.19 2,750 60 15 0.08 0.09 115 60 11 0.15 230 60 15 0.07 Tel: 425 -2 2 2- 5 9 0 0 Max. Static Sound Weight Pressure (H2 0) Noise MM A Fa x : 425 -2 2 2- 515 5 W Air Volume 800-453-4569 Cooling Simplified
UF12AR12-BWLR 价格&库存
很抱歉,暂时无法提供与“UF12AR12-BWLR”相匹配的价格&库存,您可以联系我们找货
UF12AR12-BWLR
