4710PS-23T-B3A-A00
4710PS-23T-B3A-A00
    NMBTECHNOLOGIESCORPORATION
    插件
    FANAXIAL119X25.5MM230VACTERM
4710PS-23T-B3A-A00 数据手册
11925PB (119 X 25L) Legacy Part No. 4710PS NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: Dielectric Withstand Voltage: AC 1800V 3s Allowable Ambient Temperature Range: .24 60 .16 40 .08 60Hz 50Hz L K 20 0 Failure Rate: 10% 25°C (Pa) Ps Expected Life 100,000 Hours 0.7 1.5 2.25 (m3/min) 24.7 53 79.4 CFM Air Flow Material : Aluminum (Black Painting) : Plastic (Black) UL93V-0 : Ball Bearing : AWG22, UL3266 : Faston #110 or equivalent ROTATION 4.69 ± .04 (119) 4.13 ± 0.2 (105 ± 0.3) AIR Panel Cut-Outs .14 ± .02 (3.5) inch Units: (mm) 4.14 (105) (φ φ5. 13 35 6) .169 4 – (φ4.3) 4.14 (105) 4.52 (115) INLET SIDE / OUTLET SIDE 1.00 ± .04 (25.5 ± 0.5) .14 ± .02 (3.5) NAME PLATE .169 8 – (φ4.3 ± 0.2) 4.69 ± .04 (119) 4.13 ± 0.2 (105 ± 0.3) Casing Impeller Bearing Lead Wire or Terminal Outline 4.52 (115) AC Axial Fans -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Static Pressure 100M Ω or over with a DC500V Megger In H2O Flange Type 11925PB (119 X 25L) Legacy Part No. 4710PS NMBTC.COM / 248.919.2250 Specifications MODEL LEGACY P/N Rated Frequency Starting Current Input Speed Voltage Voltage Power (V) Max. Max. Static Air Flow Pressure Mass (Pa)*2 (dB)*2 (g) (V) (A)*1 100 11925PB-A0K-EA-00 4710PS-10T-B20-B00 100 50 65 0.120 8.0 1900 49.4 1.40 .08 19.6 29.0 360 60 65 0.100 7.0 2100 53.0 1.50 .086 21.5 30.0 360 11925PB-A0L-EA-00 4710PS-10T-B30-B00 100 50 65 0.220 14.0 2300 63.5 1.80 .16 41.1 34.0 360 100 60 65 0.180 11.0 2700 70.6 2.00 .16 41.1 38.0 360 11925PB-A1K-EA-00 4710PS-12T-B20-A00 115 50 75 0.100 8.0 1900 49.4 1.40 .09 23.5 29.0 360 115 60 75 0.090 7.0 2000 53.0 1.50 .08 21.5 30.0 360 11925PB-A1L-EA-00 4710PS-12T-B30-A00 115 50 75 0.190 14.0 2300 63.5 1.80 .16 41.1 34.0 360 115 60 75 0.160 11.0 2700 70.6 2.00 .16 41.1 38.0 360 11925PB-B0K-EA-00 4710PS-20T-B20-B00 200 50 130 0.070 9.0 1900 45.9 1.30 .08 19.6 29.0 360 200 60 160 0.060 8.0 2000 53.0 1.50 .086 21.5 30.0 360 ** 200 11925PB-B0L-EA-00 4710PS-20T-B30-B00 200 50 130 0.110 14.0 2300 63.5 1.80 .16 41.1 34.0 360 60 130 0.090 11.0 2700 70.6 2.00 .16 41.1 38.0 360 ** 220 11925PB-B2K-EA-00 4710PS-22T-B20-B00 220 50 175 0.060 9.0 1900 49.4 1.40 .08 19.6 29.0 360 60 175 0.050 8.0 2100 53.0 1.50 .086 21.5 30.0 360 ** 220 11925PB-B2L-EA-00 4710PS-22T-B30-B00 220 50 175 0.100 14.0 2300 63.5 1.80 .16 41.1 34.0 360 60 175 0.080 11.0 2700 70.6 2.00 .16 41.1 38.0 360 ** 230 11925PB-B3K-EA-00 4710PS-23T-B20-A00 230 50 175 0.060 9.0 1900 49.4 1.40 .09 23.5 29.0 360 60 175 0.050 8.0 2100 53.0 1.50 .08 21.5 30.0 360 230 11925PB-B3L-EA-00 4710PS-23T-B30-A00 230 50 175 0.100 14.0 2300 63.5 1.80 .16 41.1 34.0 360 60 175 0.090 11.0 2700 70.6 2.00 .16 41.1 38.0 360 240 11925PB-B4K-EA-00 4710PS-24T-B20-A00 240 50 140 0.060 9.0 1900 49.4 1.40 .08 19.6 29.0 360 60 140 0.050 8.0 2100 53.0 1.50 .086 21.5 30.0 360 240 11925PB-B4L-EA-00 4710PS-24T-B30-A00 240 50 130 0.100 15.0 2300 60.0 1.70 .16 41.1 34.0 360 60 130 0.080 13.0 2700 70.6 2.00 .16 41.1 38.0 360 ** ** ** Rotation: Counterclockwise Contact NMB for Availability ** Airflow Outlet: Air Out Over Struts *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air DC AC Axial Fans (Hz) ** (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O Noise
4710PS-23T-B3A-A00 价格&库存
很抱歉,暂时无法提供与“4710PS-23T-B3A-A00”相匹配的价格&库存,您可以联系我们找货
