3.62 ±0.02
(92 ±0.5)
.98 ±0.04
(25)
3.25 ±0.01
(82.5 ±0.3)
0.16
(4)
Ø0.17
(Ø4.3±0.2)
Ø3.48
(Ø88.5)
.30
STATIC PRESSURE - IN. OF WATER
AC AXIAL FANS
UF92B series
.25
H
.20
L
.15
.10
.5
(92 x 92 x 25 mm)
Operating voltage: 115 or 230 VAC
Construction:
aluminum die cast frame;
UL94V-0 PBT impeller
Bearing option:
ball bearing or sintered bronze
sleeve
Motor:
shaded pole
Air Flow:
Model No.
15
30
35
TERMINAL TYPE
Rated Freq. Input Rated Locked Speed
Voltage
Power Cur.
Cur.
Air Volume
V
HZ
W
A
A
RPM
MM
INCH
dbA
kg
60
11
0.12
0.13
3,000
1.13
40
6.5
0.26
36
0.28
exhaust over struts
UF92B23-_ _H
230
60
14
0.07
0.08
3,000
1,13
40
6.5
0.26
36
0.28
terminal or 22 AWG lead wire
UF92B12-_ _L
115
60
11
0.11
0.12
2,300
0.70
25
4.0
0.16
32
0.28
UF92B23-_ _L
230
60
14
0.06
0.07
2,300
0.70
25
4.0
0.16
32
0.28
impedance
Option:
dual voltage 115/230VAC
E - mail: S ales @ M echatronic s.com
Fa x : 425 -2 2 2- 515 5
Tel: 425 -2 2 2- 5 9 0 0
M³/Min. CFM
Max. Static Sound Weight
Pressure (H2 0) Noise
115
Protection:
40
0.31
(8)
UF92B12-_ _H
w w w.mechatronic s.com
10.19.21
10
AIR FLOW (CFM)
0.12
(3)
0.33
(8.5)
3.62 x 3.62 x 0.98 inches
Connection:
5
LEAD WIRE TYPE
800-453-4569
Cooling Simplified
很抱歉,暂时无法提供与“UF92B12-BTHR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+228.448921+29.64106
