UF92B12-BWHR
UF92B12-BWHR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL92X25MM115VACWIRE
UF92B12-BWHR 数据手册
3.62 ±0.02 (92 ±0.5) .98 ±0.04 (25) 3.25 ±0.01 (82.5 ±0.3) 0.16 (4) Ø0.17 (Ø4.3±0.2) Ø3.48 (Ø88.5) .30 STATIC PRESSURE - IN. OF WATER AC AXIAL FANS UF92B series .25 H .20 L .15 .10 .5 0 (92 x 92 x 25 mm) Operating voltage: 115 or 230 VAC Construction: aluminum die cast frame; UL94V-0 PBT impeller Bearing option: ball bearing or sintered bronze sleeve Motor: shaded pole Air Flow: Model No. 15 20 25 30 35 TERMINAL TYPE Rated Freq. Input Rated Locked Speed Voltage Power Cur. Cur. Air Volume V HZ W A A RPM MM INCH dbA kg 60 11 0.12 0.13 3,000 1.13 40 6.5 0.26 36 0.28 exhaust over struts UF92B23-_ _H 230 60 14 0.07 0.08 3,000 1,13 40 6.5 0.26 36 0.28 terminal or 22 AWG lead wire UF92B12-_ _L 115 60 11 0.11 0.12 2,300 0.70 25 4.0 0.16 32 0.28 UF92B23-_ _L 230 60 14 0.06 0.07 2,300 0.70 25 4.0 0.16 32 0.28 impedance Option: dual voltage 115/230VAC E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 M³/Min. CFM Max. Static Sound Weight Pressure (H2 0) Noise 115 Protection: 40 0.31 (8) UF92B12-_ _H w w w.mechatronic s.com 10.19.21 10 AIR FLOW (CFM) 0.12 (3) 0.33 (8.5) 3.62 x 3.62 x 0.98 inches Connection: 5 LEAD WIRE TYPE 800-453-4569 Cooling Simplified
UF92B12-BWHR 价格&库存
很抱歉,暂时无法提供与“UF92B12-BWHR”相匹配的价格&库存,您可以联系我们找货
