74HC1GU04GW,165
74HC1GU04GW,165
    NEXPERIA(安世)
    TSSOP-5_2.05X1.25MM
    IC INVERTER 1CH 1-INP 5TSSOP
74HC1GU04GW,165 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia 74HC1GU04 Inverter Rev. 05 — 10 July 2007 Product data sheet 1. General description The 74HC1GU04 is a high-speed Si-gate CMOS device. It provides an inverting single stage function. The standard output currents are half those of the 74HCU04. 2. Features n n n n n Symmetrical output impedance Wide operating voltage range from 2.0 V to 6.0 V Low power dissipation Balanced propagation delays SOT353-1 and SOT753 package options 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC1GU04GW −40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74HC1GU04GV −40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 4. Marking Table 2. Marking codes Type number Marking 74HC1GU04GW HD 74HC1GU04GV HU4 5. Functional diagram 2 A Y mna043 Fig 1. Logic symbol 4 2 1 4 mna044 Fig 2. IEC logic symbol A Y mna045 Fig 3. Logic diagram 74HC1GU04 NXP Semiconductors Inverter 6. Pinning information 6.1 Pinning 74HC1GU04 n.c. 1 A 2 GND 3 5 VCC 4 Y 001aaf105 Fig 4. Pin configuration 6.2 Pin description Table 3. Pin description Symbol Pin Description n.c. 1 not connected A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level Input Output A Y L H H L 74HC1GU04_5 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 2 of 12 74HC1GU04 NXP Semiconductors Inverter 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit −0.5 +7.0 V IIK input clamping current VI < −0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current −0.5 V < VO < VCC + 0.5 V [1] - ±12.5 mA ICC supply current - 25 mA IGND ground current −25 - mA Tstg storage temperature −65 +150 °C - 200 mW Tamb = −40 °C to +125 °C total power dissipation Ptot [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 55 °C the value of Ptot derates linearity with 2.5 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions Min Typ Max Unit supply voltage 2.0 5.0 6.0 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - - 139 ns/V VCC = 6.0 V - - 83 ns/V 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol VIH VIL Parameter HIGH-level input voltage LOW-level input voltage Conditions −40 °C to +85 °C Unit Min Typ Max Min Max VCC = 2.0 V 1.7 1.4 - 1.7 - V VCC = 4.5 V 3.6 2.6 - 3.6 - V VCC = 6.0 V 4.8 3.4 - 4.8 - V VCC = 2.0 V - 0.6 0.3 - 0.3 V VCC = 4.5 V - 1.9 0.9 - 0.9 V VCC = 6.0 V - 2.6 1.2 - 1.2 V 74HC1GU04_5 Product data sheet −40 °C to +125 °C © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 3 of 12 74HC1GU04 NXP Semiconductors Inverter Table 7. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol VOH Parameter HIGH-level output voltage −40 °C to +125 °C Min Typ Max Min Max Unit VI = VIH or VIL LOW-level output voltage VOL −40 °C to +85 °C Conditions IO = −20 µA; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = −20 µA; VCC = 4.5 V 4.0 4.5 - 4.0 - V IO = −20 µA; VCC = 6.0 V 5.5 6.0 - 5.5 - V IO = −2.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V IO = −2.6 mA; VCC = 6.0 V 5.63 5.81 - 5.2 - V IO = 20 µA; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 20 µA; VCC = 4.5 V - 0 0.5 - 0.5 V IO = 20 µA; VCC = 6.0 V - 0 0.5 - 0.5 V IO = 2.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 2.6 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 - 1.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 10 - 20 µA CI input capacitance - 5 - - - pF 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; tr = tf = 6.0 ns; For test circuit see Figure 6. All typical values are measured at Tamb = 25 °C. Symbol Parameter −40 °C to +85 °C Conditions Min Typ Max Min Max VCC = 2.0 V; CL = 50 pF - 10 90 - 105 ns VCC = 4.5 V; CL = 50 pF - 7 18 - 21 ns VCC = 6.0 V; CL = 50 pF - 6 15 - 18 ns VCC = 5.0 V; CL = 15 pF - 5 - - - ns - 14 - - - pF [1] propagation delay A to Y; see Figure 5 tpd [2] power dissipation VI = GND to VCC capacitance CPD [1] tpd is the same as tPLH and tPHL. [2] CPD is used to determine the dynamic power dissipation PD (µW). PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. 74HC1GU04_5 Product data sheet −40 °C to +125 °C Unit © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 4 of 12 74HC1GU04 NXP Semiconductors Inverter 12. Waveforms A input VM(1) VCC tPHL Y output tPLH PULSE GENERATOR VI VO DUT CL 50 pF RT VM(1) mna046 VM(1) = 0.5 × VCC; VI = GND to VCC. mna034 Test data is given in Table 8. DUT = Device Under Test CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 5. Input to output propagation delays Fig 6. Load circuitry for switching times 13. Typical transfer characteristics mna047 1 2 VO (V) ICC (mA) 0.5 0 0 1 Fig 7. VCC = 2.0 V; IO = 0 A VI (V) 2 mna048 10 VO (V) ICC (mA) 1 5 0 0 2.5 0 0 2.5 VI (V) 5 Fig 8. VCC = 4.5 V; IO = 0 A 74HC1GU04_5 Product data sheet 5 © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 5 of 12 74HC1GU04 NXP Semiconductors Inverter mna049 20 6 ICC (mA) VO (V) Rbias = 560 kΩ VCC 10 3 0.47 µF input output 100 µF VI (f = 1 kHz) A IO GND mna050 0 0 0 3 6 VI (V) Fig 9. VCC = 6.0 V; IO = 0 A Fig 10. Test set-up for measuring forward transfer conductance gfs = ∆IO/∆VI at VO is constant 14. Application information Some applications are: • Linear amplifier (see Figure 11) • In crystal oscillator design (see Figure 12) Remark: All values given are typical unless otherwise specified R2 R1 VCC 1 µF R2 R1 U04 U04 C1 ZL C2 out mna053 mna052 Maximum Vo(p-p) = VCC − 1.5 V centered at 0.5 × VCC. C1 = 47 pF (typ.) G ol G v = – --------------------------------------R1 1 + ------- ( 1 + G ol ) R2 R1 = 1 MΩ to 10 MΩ (typ.) Gol = open loop gain C2 = 22 pF (typ.) R2 optimum value depends on the frequency and required stability against changes in VCC or average minimum ICC (ICC is typically 2 mA at VCC = 3 V and f = 1 MHz). Gv = voltage gain R1 ≥ 3 kΩ, R2 ≤ 1 MΩ ZL > 10 kΩ; Gol = 20 (typ.) Typical unity gain bandwidth product is 5 MHz. Fig 11. Used as a linear amplifier Fig 12. Crystal oscillator configuration 74HC1GU04_5 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 6 of 12 74HC1GU04 NXP Semiconductors Inverter Table 9. External components for resonator (f < 1 MHz) All values given are typical and must be used as an initial set-up Frequency R1 R2 C1 C2 10 kHz to 15.9 kHz 2.2 MΩ 220 kΩ 56 pF 20 pF 16 kHz to 24.9 kHz 2.2 MΩ 220 kΩ 56 pF 10 pF 25 kHz to 54.9 kHz 2.2 MΩ 100 kΩ 56 pF 10 pF 55 kHz to 129.9 kHz 2.2 MΩ 100 kΩ 47 pF 5 pF 130 kHz to 199.9 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF 200 kHz to 349.9 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF 350 kHz to 600 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF Table 10. Optimum value for R2 Frequency R2 Optimum for 3 kHz 2.0 kΩ minimum required ICC 8.0 kΩ minimum influence due to change in VCC 1.0 kΩ minimum required ICC 6 kHz 10 kHz 14 kHz >14 kHz 4.7 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 2.0 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 1.0 kΩ minimum influence by VCC - replace R2 by C3 with a typical value of 35 pF mna054 80 input capacitance (pF) (1) 60 (2) 40 (3) 20 0 0 2 4 6 VI (V) 8 (1) VCC = 2.0 V. (2) VCC = 4.5 V. (3) VCC = 6.0 V. Fig 13. Typical input capacitance as a function of the input voltage 74HC1GU04_5 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 7 of 12 74HC1GU04 NXP Semiconductors Inverter 15. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm E D SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 L e w M bp detail X e1 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Fig 14. Package outline SOT353-1 (TSSOP5) 74HC1GU04_5 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 8 of 12 74HC1GU04 NXP Semiconductors Inverter Plastic surface-mounted package; 5 leads SOT753 D E B y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 JEITA SC-74A EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 Fig 15. Package outline SOT753 (SC-74A) 74HC1GU04_5 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 9 of 12 74HC1GU04 NXP Semiconductors Inverter 16. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC1GU04_5 20070710 Product data sheet - 74HC1GU04_4 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • Legal texts have been adapted to the new company name where appropriate. Package SOT353 changed to SOT353-1 in Table 1 and Figure 14. Quick Reference Data and Soldering sections removed. Section 2 “Features” updated. 74HC1GU04_4 20020527 Product specification - 74HC1GU04_3 74HC1GU04_3 20020513 Product specification - 74HC1GU04_2 74HC1GU04_2 20010427 Product specification - 74HC1GU04_1 74HC1GU04_1 19981118 Product specification - - 74HC1GU04_5 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 10 of 12 74HC1GU04 NXP Semiconductors Inverter 17. Legal information 17.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 17.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 17.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 17.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 18. Contact information For additional information, please visit: http://www.nxp.com For sales office addresses, send an email to: salesaddresses@nxp.com 74HC1GU04_5 Product data sheet © NXP B.V. 2007. All rights reserved. Rev. 05 — 10 July 2007 11 of 12 74HC1GU04 NXP Semiconductors Inverter 19. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 17 17.1 17.2 17.3 17.4 18 19 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional description . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 3 Static characteristics. . . . . . . . . . . . . . . . . . . . . 3 Dynamic characteristics . . . . . . . . . . . . . . . . . . 4 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Typical transfer characteristics . . . . . . . . . . . . 5 Application information. . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2007. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 10 July 2007 Document identifier: 74HC1GU04_5
74HC1GU04GW,165
物料型号:74HC1GU04
器件简介:74HC1GU04是一款高速硅门CMOS设备,提供反相单级功能,标准输出电流是74HCU04的一半。
引脚分配: - 1: 不连接 (n.c.) - 2: 数据输入 (A) - 3: 地 (GND) - 4: 数据输出 (Y) - 5: 供电电压 (VCC)
参数特性: - 工作电压范围宽,从2.0V至6.0V - 低功耗 - 传播延迟平衡 - 提供SOT353-1和SOT753封装选项
功能详解: - 功能表显示输入A与输出Y的逻辑关系,即输入低电平(L)输出高电平(H),输入高电平(H)输出低电平(L)。
应用信息: - 可用于线性放大器设计 - 可用于晶体振荡器设计
封装信息: - TSSOP5: 塑料薄型收缩小外形封装,5个引脚,体宽1.25毫米 - SOT753: 塑料表面贴装封装,5个引脚
74HC1GU04GW,165 价格&库存
很抱歉,暂时无法提供与“74HC1GU04GW,165”相匹配的价格&库存,您可以联系我们找货
