74ALVT162245
16-bit transceiver with 30 Ω termination resistors; 3-state
Rev. 4 — 3 February 2021
Product data sheet
1. General description
The 74ALVT162245 is a 16-bit transceiver with 30 Ω termination resistors and 3-state outputs.
The device can be used as two 8-bit transceivers or one 16-bit transceiver. The device features
two output enables (1OE and 2OE) each controlling eight outputs, and two send/receive
(1DIR and 2DIR) inputs for direction control. A HIGH on nOE causes the outputs to assume a
high-impedance OFF-state.
2. Features and benefits
16-bit bidirectional bus interface
3-State buffers
Wide supply voltage range from 2.3 to 3.6 V
5V I/O compatible
Overvoltage tolerant inputs to 5.5 V
Output capability: +12 mA/–12 mA
Direct interface with TTL levels
Input and output interface capability to systems at 5 V supply
BiCMOS high speed and output drive
Bus-hold data inputs eliminate the need for external pull-up resistors to hold unused inputs
Live insertion/extraction permitted
Outputs include series resistance of 30 Ω making external termination resistors unnecessary
IOFF circuitry provides partial Power-down mode operation
Power-up 3-State
No bus current loading when output is tied to 5 V bus
Latch-up performance exceeds 500 mA per JESD 78 Class II Level B
ESD protection:
• MIL STD 883 method 3015: exceeds 2000 V
• MM: exceeds 200 V
Specified from -40 °C to +85 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
74ALVT162245DGG -40 °C to +85 °C
Name
Description
Version
TSSOP48
plastic thin shrink small outline package; 48 leads;
body width 6.1 mm
SOT362-1
74ALVT162245
Nexperia
4. Functional diagram
Table 2.
1OE
1DIR
2DIR
1DIR
2OE
1OE
2OE
2DIR
2A0
1A0
1B0
1A1
2B0
1A0
G3
3EN1[BA]
3EN2[AB]
G6
6EN4[BA]
6EN5[AB]
1B0
1
2A1
1B1
1A2
2B1
2A2
1B2
1A3
2B2
2A3
1B3
1A4
2B3
2A4
1B4
1A5
2B4
2
1A1
1B1
1A2
1B2
1A3
1B3
1A4
1B4
1A5
1B5
1A6
1B6
1A7
1B7
2A0
2B0
4
5
2A5
1B5
1A6
2B5
2A6
1B6
2B6
2A7
1A7
2B7
1B7
2A1
2B1
2A2
2B2
2A3
2B3
2A4
2B4
2A5
2B5
2A6
2B6
2B7
2A7
001aaa790
001aaa789
Fig. 1.
Logic symbol
Fig. 2.
VCC
IEC logic symbol
VCC
27 Ω
output
27 Ω
001aac372
Fig. 3.
Schematic of each output
74ALVT162245
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 13
74ALVT162245
Nexperia
5. Pinning information
5.1. Pinning
74ALVT162245
1DIR
1
48 1OE
1B0
2
47 1A0
1B1
3
46 1A1
GND
4
45 GND
1B2
5
44 1A2
1B3
6
43 1A3
VCC
7
42 VCC
1B4
8
41 1A4
1B5
9
40 1A5
GND 10
39 GND
1B6 11
38 1A6
1B7 12
37 1A7
2B0 13
36 2A0
2B1 14
35 2A1
GND 15
34 GND
2B2 16
33 2A2
2B3 17
32 2A3
VCC 18
31 VCC
2B4 19
30 2A4
2B5 20
29 2A5
GND 21
28 GND
2B6 22
27 2A6
2B7 23
26 2A7
2DIR 24
25 2OE
aaa-028123
Fig. 4.
Pin configuration SOT362-1 (TSSOP48)
5.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1DIR, 2DIR
1, 24
direction control input
1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7
47, 46, 44, 43, 41, 40, 38, 37
data input/output
2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7
36, 35, 33, 32, 30, 29, 27, 26
data input/output
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
1B0, 1B1, 1B2, 1B3, 1B4, 1B5, 1B6, 1B7
2, 3, 5, 6, 8, 9, 11, 12
data input/output
2B0, 2B1, 2B2, 2B3, 2B4, 2B5, 2B6, 2B7
13, 14, 16, 17, 19, 20, 22, 23
data input/output
1OE, 2OE
48, 25
output enable input (active-LOW)
VCC
7, 18, 31, 42
supply voltage
74ALVT162245
Product data sheet
3 / 13
74ALVT162245
Nexperia
6. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Control
Input/output
nOE
nDIR
nAn
nBn
L
L
output nAn = nBn
input
L
H
input
output nBn = nAn
H
X
Z
Z
7. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
output in OFF-state or HIGH-state
IIK
input clamping current
IOK
IO
Min
Max
Unit
−0.5
+4.6
V
[1]
−0.5
+7.0
V
[1]
−0.5
+7.0
V
VI < 0 V
−50
mA
output clamping current
VO < 0 V
−50
mA
output current
output in LOW-state
128
mA
output in HIGH-state
−64
mA
−65
+150
°C
+150
°C
Tstg
storage temperature
Tj
junction temperature
[1]
[2]
Conditions
[2]
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
8. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
VCC = 2.5 V ± 0.2 V
VCC = 3.3 V ± 0.3 V
Unit
Min
Max
Min
Max
2.3
2.7
3.0
3.6
V
input voltage
V
IOH
HIGH-level output current
−8
−12
mA
IOL
LOW-level output current
12
12
mA
Δt/ΔV
input transition rise and fall rate
outputs enabled
Tamb
ambient temperature
free-air
VCC
supply voltage
VI
74ALVT162245
Product data sheet
10
10
ns/V
−40
+85
−40
+85
°C
4 / 13
74ALVT162245
Nexperia
9. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; Tamb = -40 °C to +85 °C; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
-0.85
-1.2
V
VCC = 2.5 V ± 0.2 V
VIK
input clamping voltage
VCC = 2.3 V; IIK = -18 mA
VIH
HIGH-level input voltage
VCC = 2.5 V ± 0.2 V
1.7
V
VIL
LOW-level input voltage
VCC = 2.5 V ± 0.2 V
0.7
V
VOH
HIGH-level output voltage VCC = 2.3 V; IO = -8 mA
1.7
V
VOL
LOW-level output voltage VCC = 2.3 V; IO = 12 mA
0.6
0.7
V
II
input leakage current
0.1
10
μA
0.1
±1
μA
VCC = 2.7 V; VI = VCC
0.1
1
μA
VCC = 2.7 V; VI = 0 V
0.1
-5
μA
0.1
±100
μA
all input pins
[2]
VCC = 0 V or 2.7 V; VI = 5.5 V
control pins
VCC = 2.7 V; VI = VCC or GND
I/O data pins
[2]
IOFF
power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V
IBHL
bus hold LOW current
data inputs; VCC = 2.3 V; VI = 0.7 V
[3]
90
μA
IBHH
bus hold HIGH current
data inputs; VCC = 2.3 V; VI = 1.7 V
[3]
-75
μA
IEX
external current
output in HIGH-state when VO > VCC;
VO = 5.5 V; VCC = 2.3 V
μA
IO(pu/pd)
power-up/power-down
output current
VCC ≤ 1.2 V; VO = 0.5 V to VCC;
VI = GND or VCC; nOE = don’t care
40
100
μA
ICC
supply current
VCC = 2.7 V; VI = GND or VCC; IO = 0 A
outputs HIGH
0.04
0.1
mA
outputs LOW
2.5
4.5
mA
[5]
0.04
0.1
mA
[6]
0.05
0.4
mA
outputs disabled
[4]
ΔICC
additional supply current
per input pin; VCC = 2.3 V to 2.7 V;
one input at VCC - 0.6 V;
other inputs at VCC or GND
CI
input capacitance
nDIR and nOE; VI = 0 V or VCC
3
pF
CI/O
input/output capacitance
VI/O = 0 V or VCC
9
pF
74ALVT162245
Product data sheet
5 / 13
74ALVT162245
Nexperia
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
-0.85
-1.2
V
VCC = 3.3 V ± 0.3 V
VIK
VCC = 3.0 V; IIK = -18 mA
VIH
VCC = 3.3 V ± 0.3 V
2.0
V
VIL
VCC = 3.3 V ± 0.3 V
0.8
V
VOH
HIGH-level output voltage VCC = 3.0 V; IO = -12 mA
2.0
2.3
V
VOL
LOW-level output voltage VCC = 3.0 V; IO = 12 mA
0.6
0.8
V
II
0.1
10
μA
0.1
±1
μA
VCC = 3.6 V; VI = VCC
0.5
1
μA
VCC = 3.6 V; VI = 0 V
0.1
-5
μA
0.1
±100
μA
all input pins
[2]
VCC = 0 V or 3.6 V; VI = 5.5 V
control pins
VCC = 3.6 V; VI = VCC or GND
I/O data pins
[2]
IOFF
IBHL
data inputs; VCC = 3 V; VI = 0.8 V
75
130
μA
IBHH
data inputs; VCC = 3 V; VI = 2.0 V
-75
-140
μA
IBHLO
bus hold LOW
overdrive current
data inputs; VCC = 3.6 V;
VI = 0 V to 3.6 V
[7]
500
μA
IBHHO
bus hold HIGH
overdrive current
VI = 0 V to 3.6 V
[7]
-500
μA
IEX
external current
VO = 5.5 V; VCC = 3.0 V
50
125
μA
IO(pu/pd)
power-up/power-down
output current
40
±100
μA
ICC
supply current
VCC = 3.6 V; VI = GND or VCC; IO = 0 A
outputs HIGH
0.07
0.1
mA
outputs LOW
3.5
5
mA
[5]
0.07
0.1
mA
[6]
0.04
0.4
mA
outputs disabled
[8]
ΔICC
per input pin; VCC = 3 V to 3.6 V;
CI
input capacitance
3
pF
CI/O
VI/O = 0 V or VCC
9
pF
[1]
[2]
[3]
[4]
[5]
[6]
[7]
[8]
Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V and Tamb = 25 °C.
Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V and Tamb = 25 °C.
Unused pins at VCC or GND.
Not guaranteed.
This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms.
From VCC = 1.2 V to VCC = 2.5 V ± 0.2 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
ICC with outputs disabled is measured with outputs pulled to VCC or GND.
This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
This is the bus hold overdrive current required to force the input to the opposite logic state.
From VCC = 1.2 V to VCC = 3.0 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
74ALVT162245
Product data sheet
6 / 13
74ALVT162245
Nexperia
10. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); Tamb = -40 °C to +85 °C; for test circuit see Fig. 7.
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
VCC = 2.5 V ± 0.2 V
tPLH
LOW to HIGH
propagation delay
nAn to nBn or nBn to nAn; see Fig. 5
1.5
2.9
5.3
ns
tPHL
HIGH to LOW
propagation delay
1.5
2.4
4.7
ns
tPZH
OFF-state to HIGH
propagation delay
nOE to nAn or nOE to nBn; see Fig. 6
1.5
4.3
6.3
ns
tPZL
OFF-state to LOW
propagation delay
1.5
3.1
4.6
ns
tPHZ
HIGH to OFF-state
propagation delay
1.5
4.2
6.2
ns
tPLZ
LOW to OFF-state
propagation delay
1.5
3.3
5.1
ns
VCC = 3.3 V ± 0.3 V
tPLH
LOW to HIGH
propagation delay
0.5
2.3
3.6
ns
tPHL
HIGH to LOW
propagation delay
0.5
2.0
3.1
ns
tPZH
OFF-state to HIGH
propagation delay
1.0
3.0
5.0
ns
tPZL
OFF-state to LOW
propagation delay
1.0
2.6
3.9
ns
tPHZ
HIGH to OFF-state
propagation delay
1.0
3.6
5.2
ns
tPLZ
LOW to OFF-state
propagation delay
1.0
3.0
4.6
ns
[1]
74ALVT162245
Product data sheet
7 / 13
74ALVT162245
Nexperia
10.1. Waveforms and test circuit
VI
nAn, nBn
input
VM
GND
t PHL
t PLH
VOH
nBn, nAn
output
VM
VOL
mna477
Measurement points are given in Table 9.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 5.
Input (nAn or nBn) to output (nBn or nAn) propagation delays
VI
nOE input
VM
VM
GND
tPLZ
3.0 V or VCC
output
LOW-to-OFF
OFF-to-LOW
VOL
tPZL
VM
VX
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-028124
Fig. 6.
3-state output enable and disable times
Table 9. Measurement points
VCC
Input
Output
VI
VM
VM
VX
VY
VCC ≤ 2.7 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.1 V
VOH - 0.1 V
VCC ≥ 3.0 V
3.0 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74ALVT162245
Product data sheet
8 / 13
74ALVT162245
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 10.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = Test voltage for switching times.
Fig. 7.
Test circuit for measuring switching times
Table 10. Test data
Input
VI
fi
3.0 V or VCC
≤ 10 MHz
whichever is less
74ALVT162245
Product data sheet
Load
VEXT
tW
tr, tf
CL
RL
tPHZ, tPZH
tPLZ, tPZL
500 ns
≤ 2.5 ns
50 pF
500 Ω
GND
6 V or VCC x 2 open
tPLH, tPHL
9 / 13
74ALVT162245
Nexperia
11. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
A1
(A3)
pin 1 index
A
θ
Lp
1
L
24
bp
e
detail X
w
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A
1.2
A1
A2
0.15 1.05
0.05 0.85
A3
0.25
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
0.17
0.1
12.4
6.0
e
HE
0.5
8.3
7.9
L
1
Lp
Q
0.8
0.50
0.4
0.35
v
w
0.25 0.08
y
0.1
Z
θ
0.8
8°
0.4
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
Fig. 8.
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Package outline SOT362-1 (TSSOP48)
74ALVT162245
Product data sheet
10 / 13
74ALVT162245
Nexperia
12. Abbreviations
Table 11. Abbreviations
Acronym
Description
BiCMOS
Bipolar Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74ALVT162245 v.4
20210203
Product data sheet
Modifications:
74ALVT162245 v.3
20180129
Modifications:
74ALVT162245 v.3
Type number 74ALVT162245DL (SOT370-1 / SSOP48) removed.
Section 1 and Section 2 updated.
Product data sheet
74ALVT162245 v.2
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74ALVT162245 v.2
19980213
Product specification
74ALVT162245 v.1
74ALVT162245 v.1
19960305
74ALVT162245
Product data sheet
11 / 13
74ALVT162245
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ALVT162245
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
74ALVT162245
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 8
11. Package outline........................................................ 10
12. Abbreviations............................................................ 11
13. Revision history........................................................11
14. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 3 February 2021
74ALVT162245
Product data sheet
13 / 13
