74ALVT16244
16-bit buffer/line driver; 3-state
Rev. 5 — 2 February 2018
1
Product data sheet
General description
The 74ALVT16244 is a high-performance BiCMOS product designed for VCC operation at
2.5V or 3.3V with I/O compatibility up to 5V.
This device is a 16-bit buffer and line driver featuring non-inverting 3-state bus outputs.
The device can be used as four 4-bit buffers, two 8-bit buffers, or one 16-bit buffer.
2
Features and benefits
3
16-bit bus interface
3-State buffers
5V I/O compatible
Output capability: +64 mA/–32 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Bus-hold data inputs eliminate the need for external pull-up resistors to hold unused
inputs
Live insertion/extraction permitted
Power-up 3-State
No bus current loading when output is tied to 5 V bus
Latch-up protection:
– JESD17: exceeds 500 mA
ESD protection:
– MIL STD 883 method 3015: exceeds 2000 V
– MM exceeds 200 V
Ordering information
Table 1. Ordering information
Type number
74ALVT16244DGG
Package
Temperature range Name
Description
Version
-40 °C to +85 °C
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
TSSOP48
74ALVT16244
Nexperia
4
Functional diagram
1A0
1A1
1A2
1A3
47
2
46
3
44
5
43
6
1Y0
3A0
1Y1
3A1
1Y2
3A2
1Y3
3A3
1
1OE
3OE
36
13
35
14
33
16
32
17
3Y0
3Y1
1
1OE
48
2OE
25
3OE
24
4OE
3Y2
3Y3
1A0
1A1
25
1A2
1A3
2A0
2A1
41
40
8
9
2Y0
2Y1
4A0
4A1
30
29
19
2A0
2A1
4Y0
2A2
2A3
3A0
4Y1
3A1
2A2
2A3
2OE
38
37
11
12
2Y2
2Y3
48
4A2
4A3
4OE
27
26
22
23
3A2
4Y2
3A3
4A0
4A1
4Y3
4A2
24
4A3
EN1
EN2
EN3
EN4
47
46
74ALVT16244
Product data sheet
1
2
3
44
5
43
6
41
40
1
2
8
9
38
11
37
12
36
35
1
3
13
14
33
16
32
17
30
29
1
4
19
22
26
23
1Y0
1Y1
1Y2
1Y3
2Y0
2Y1
2Y2
2Y3
3Y0
3Y1
3Y2
3Y3
4Y0
4Y1
4Y2
4Y3
001aae231
mna996
Figure 1. Logic symbol
1
Figure 2. IEC logic symbol
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 15
74ALVT16244
Nexperia
5
Pinning information
5.1 Pinning
74ALVT16244
1OE
1
48 2OE
1Y0
2
47 1A0
1Y1
3
46 1A1
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
2Y0
8
42 VCC
41 2A0
2Y1
9
40 2A1
GND 10
39 GND
2Y2 11
38 2A2
2Y3 12
37 2A3
3Y0 13
36 3A0
3Y1 14
35 3A1
GND 15
34 GND
3Y2 16
33 3A2
3Y3 17
32 3A3
VCC 18
4Y0 19
31 VCC
30 4A0
4Y1 20
29 4A1
GND 21
28 GND
4Y2 22
27 4A2
4Y3 23
26 4A3
4OE 24
25 3OE
aaa-028125
Figure 3. Pin configuration SOT362-1 (TSSOP48)
74ALVT16244
Product data sheet
3 / 15
74ALVT16244
Nexperia
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE, 2OE, 3OE, 4OE
1, 48, 25, 24
output enable inputs (active LOW)
1A0, 1A1, 1A2, 1A3
47, 46, 44, 43
data inputs
2A0, 2A1, 2A2, 2A3
41, 40, 38, 37
data inputs
3A0, 3A1, 3A2, 3A3
36, 35, 33, 32
data inputs
4A0, 4A1, 4A2, 4A3
30, 29, 27, 26
data inputs
1Y0, 1Y1, 1Y2, 1Y3
2, 3, 5, 6
data outputs
2Y0, 2Y1, 2Y2, 2Y3
8, 9, 11, 12
data outputs
3Y0, 3Y1, 3Y2, 3Y3
13, 14, 16, 17
data outputs
4Y0, 4Y1, 4Y2, 4Y3
19, 20, 22, 23
data outputs
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
supply voltage
6
Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Output
Input
nOE
nAn
nYn
L
L
L
L
H
H
H
X
Z
74ALVT16244
Product data sheet
4 / 15
74ALVT16244
Nexperia
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
-0.5
+4.6
V
input voltage
[1]
-0.5
+7.0
V
VO
output voltage
output in OFF-state or HIGH-state
[1]
-0.5
+7.0
V
IIK
input clamping current
VI < 0 V
-50
mA
IOK
output clamping current
VO < 0 V
-50
mA
IO
output current
output in LOW-state
128
mA
output in HIGH-state
-64
mA
-65
+150
°C
150
°C
VI
Tstg
storage temperature
Tj
[2]
junction temperature
[1] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
[2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are
detrimental to reliability.
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
VCC = 2.5 V ± 0.2 V
VCC = 3.3 V ± 0.3 V
Unit
Min
Max
Min
Max
2.3
2.7
3.0
3.6
V
VCC
supply voltage
VI
input voltage
V
IOH
HIGH-level output current
−8
−32
mA
IOL
LOW-level output current
none
8
32
mA
current duty cycle ≤ 50 %;
fi ≥ 1 kHz
24
64
mA
10
10
ns/V
−40
+85
−40
+85
°C
Δt/ΔV
input transition
rise and fall rate
outputs enabled
Tamb
ambient temperature
free-air
9
Static characteristics
Table 6. Static characteristics
At recommended operating conditions; Tamb = -40 °C to +85 °C ; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Typ
[1]
Max
Unit
-0.85
-1.2
V
Min
VCC = 2.5 V ± 0.2 V
VIK
input clamping voltage
VCC = 2.3 V; IIK = -18 mA
VIH
HIGH-level input voltage
VCC = 2.5 V ± 0.2 V
1.7
V
VIL
LOW-level input voltage
VCC = 2.5 V ± 0.2 V
0.7
V
74ALVT16244
Product data sheet
5 / 15
74ALVT16244
Nexperia
Symbol
Parameter
Conditions
VOH
HIGH-level output voltage VCC = 2.5 V ± 0.2 V; IO = -100 μA
Min
V
1.8
2.5
V
0.07
0.2
V
0.3
0.5
V
0.1
10
μA
0.1
±1
μA
VCC = 2.7 V; VI = VCC
0.1
1
μA
VCC = 2.7 V; VI = 0 V
0.1
-5
μA
LOW-level output voltage VCC = 2.3 V; IO = 100 μA
input leakage current
Unit
VCC
VCC = 2.3 V; IO = 24 mA
II
Max
VCC − 0.2
VCC = 2.3 V; IO = -8 mA
VOL
[1]
Typ
all input pins
[2]
VCC = 0 V or 2.7 V; VI = 5.5 V
control pins
VCC = 2.7 V; VI = VCC or GND
[2]
data pins;
IOFF
IBHL
power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V
bus hold LOW current
0.1
±100
μA
data inputs; VCC = 2.3 V; VI = 0.7 V
[3]
115
μA
[3]
-10
μA
10
125
μA
1
±100
μA
output HIGH: VO = 2.3V
0.5
5
μA
output LOW: VO = 0.5 V
0.5
-5
μA
0.04
0.1
mA
IBHH
bus hold HIGH current
data inputs; VCC = 2.3 V; VI = 1.7 V
IEX
external current
output in HIGH-state when VO > VCC;
VO = 5.5 V; VCC = 2.3 V
IO(pu/pd)
power-up/power-down
output current
VCC ≤ 1.2 V; VO = 0.5 V to VCC;
VI = GND or VCC; nOE = don’t care
IOZ
OFF-state output current
VCC = 2.7 V; VI = VIL or VIH
ICC
supply current
[4]
VCC = 2.7 V; VI = GND or VCC; IO = 0 A
outputs HIGH
outputs LOW
outputs disabled
2.5
4.5
mA
[5]
0.04
0.1
mA
[6]
0.04
0.4
mA
ΔICC
additional supply current
per input pin; VCC = 2.3 V to 2.7 V;
one input at VCC - 0.6 V;
other inputs at VCC or GND
CI
input capacitance
nOE; VI = 0 V or VCC
3
pF
CO
output capacitance
VO = 0 V or VCC
9
pF
-0.85
-1.2
V
VCC = 3.3 V ± 0.3 V
VIK
VCC = 3.0 V; IIK = -18 mA
VIH
VCC = 3.3 V ± 0.3 V
2.0
V
VIL
VCC = 3.3 V ± 0.3 V
0.8
V
VOH
HIGH-level output voltage VCC = 3.3 V ± 0.3 V; IO = -100 μA
VCC − 0.2
VCC
V
2.0
2.3
V
VCC = 3.0 V; IO = -32 mA
74ALVT16244
Product data sheet
6 / 15
74ALVT16244
Nexperia
Symbol
Parameter
Conditions
Min
VOL
LOW-level output voltage VCC = 3.0 V; IO = 100 μA
VCC = 3.0 V; IO = 16 mA
VCC = 3.0 V; IO = 32 mA
Max
Unit
0.07
0.2
V
0.25
0.4
V
0.3
0.5
V
0.4
0.55
V
0.1
10
μA
0.1
±1
μA
VCC = 3.6 V; VI = VCC
0.5
1
μA
VCC = 3.6 V; VI = 0 V
0.1
-5
μA
0.1
±100
μA
75
130
μA
VCC = 3.0 V; IO = 64 mA
II
[1]
all input pins
Typ
[2]
VCC = 0 V or 3.6 V; VI = 5.5 V
control pins
VCC = 3.6 V; VI = VCC or GND
[2]
data pins
IOFF
IBHL
data inputs; VCC = 3 V; VI = 0.8 V
IBHH
data inputs; VCC = 3 V; VI = 2.0 V
-75
-140
μA
500
μA
-500
μA
10
125
μA
1
±100
μA
output HIGH: VO = 3.0V
0.5
5
μA
0.5
-5
μA
0.05
0.1
mA
IBHLO
bus hold LOW overdrive
current
data inputs; VCC = 3.6 V; VI = 0 V to 3.6 V
[7]
IBHHO
bus hold HIGH overdrive
current
[7]
IEX
external current
VO = 5.5 V; VCC = 3.0 V
IO(pu/pd)
power-up/power-down
output current
IOZ
VCC = 3.6 V; VI = VIL or VIH
ICC
supply current
[8]
VCC = 3.6 V; VI = GND or VCC; IO = 0 A
outputs HIGH
outputs LOW
outputs disabled
3.6
5
mA
[5]
0.06
0.1
mA
[6]
0.04
0.4
mA
ΔICC
per input pin; VCC = 3 V to 3.6 V;
CI
input capacitance
3
pF
CO
output capacitance
VO = 0 V or VCC
9
pF
[1] Typical values for VCC = 2.5 V ± 0.2 V are measured at VCC = 2.5 V and Tamb = 25 °C.
Typical values for VCC = 3.3 V ± 0.3 V are measured at VCC = 3.3 V and Tamb = 25 °C.
[2] Unused pins at VCC or GND.
[3] Not guaranteed.
[4] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms.
From VCC = 1.2 V to VCC = 2.5 V ± 0.2 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
[5] ICC is measured with outputs pulled to VCC or GND.
[6] This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
[7] This is the bus hold overdrive current required to force the input to the opposite logic state.
[8] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms.
From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
74ALVT16244
Product data sheet
7 / 15
74ALVT16244
Nexperia
10 Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); Tamb = -40 °C to +85 °C; for test circuit see Figure 6.
Symbol
Parameter
Conditions
Min
Typ
[1]
Max
Unit
VCC = 2.5 V ± 0.2 V
tPLH
LOW to HIGH propagation delay
nAn to nYn; see Figure 4
1.0
1.8
3.0
ns
tPHL
HIGH to LOW propagation delay
1.0
1.9
3.5
ns
tPZH
OFF-state to HIGH propagation delay
nOE to nYn; see Figure 5
2.0
3.1
5.9
ns
tPZL
OFF-state to LOW propagation delay
1.5
2.5
4.7
ns
tPHZ
HIGH to OFF-state propagation delay
1.5
2.7
4.4
ns
tPLZ
LOW to OFF-state propagation delay
1.0
2.0
3.4
ns
VCC = 3.3 V ± 0.3 V
tPLH
0.8
1.5
2.4
ns
tPHL
0.8
1.5
2.5
ns
tPZH
1.0
2.3
3.8
ns
tPZL
0.5
1.8
2.9
ns
tPHZ
1.5
2.7
4.2
ns
tPLZ
1.5
2.3
3.6
ns
10.1 Waveforms and test circuit
VI
nAn input
VM
VM
GND
tPLH
tPHL
VOH
nYn output
VM
VOL
VM
mna171
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Figure 4. Inputs nAn to output nYn propagation delays
74ALVT16244
Product data sheet
8 / 15
74ALVT16244
Nexperia
VI
nOE input
VM
VM
GND
tPLZ
3.0 V or VCC
output
LOW-to-OFF
OFF-to-LOW
VOL
tPZL
VM
VX
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-028124
Figure 5. OFF-state to HIGH or LOW and HIGH or LOW to OFF-state propagation delays
Table 8. Measurement points
VCC
Input
Output
VI
VM
VM
VX
VY
VCC ≤ 2.7 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
VCC ≥ 3.0 V
3.0 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74ALVT16244
Product data sheet
9 / 15
74ALVT16244
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
0V
tf
tr
VI
positive
pulse
0V
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
VI
G
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 6. Test circuit for measuring switching times
Table 9. Test data
Input
VI
Load
fi
3.0 V or VCC
≤ 10 MHz
whichever is less
74ALVT16244
Product data sheet
VEXT
tW
tr, tf
CL
RL
tPHZ, tPZH
tPLZ, tPZL
500 ns
≤ 2.5 ns
50 pF
500 Ω
GND
6 V or VCC x 2 open
tPLH, tPHL
10 / 15
74ALVT16244
Nexperia
11 Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
A1
(A3)
pin 1 index
A
θ
Lp
1
L
24
bp
e
detail X
w
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A
1.2
A1
A2
0.15 1.05
0.05 0.85
A3
0.25
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
0.17
0.1
12.4
6.0
e
HE
0.5
8.3
7.9
L
1
Lp
Q
0.8
0.50
0.4
0.35
v
w
0.25 0.08
y
0.1
Z
θ
0.8
8°
0.4
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Figure 7. Package outline SOT362-1 (TSSOP48)
74ALVT16244
Product data sheet
11 / 15
74ALVT16244
Nexperia
12 Abbreviations
Table 10. Abbreviations
Acronym
Description
BiCMOS
Bipolar Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13 Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVT16244 v.5
20180202
Product data sheet
74ALVT16244 v.4
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Type number 74ALVT16244DL (SOT370-1 / SSOP48) removed.
74ALVT16244 v.4
19981007
Product specification
74ALVT16244 v.3
74ALVT16244 v.3
19980213
74ALVT16244 v.2
74ALVT16244 v.2
19980213
74ALVT16244 v.1
74ALVT16244 v.1
19960529
74ALVT16244
Product data sheet
12 / 15
74ALVT16244
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74ALVT16244
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
13 / 15
74ALVT16244
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74ALVT16244
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
74ALVT16244
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 5
Dynamic characteristics .....................................8
Waveforms and test circuit ................................ 8
Package outline .................................................11
Abbreviations .................................................... 12
Revision history ................................................ 12
Legal information .............................................. 13
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 2 February 2018
Document identifier: 74ALVT16244
