N74F38D,623
N74F38D,623
    NEXPERIA(安世)
    SOIC-14
    IC GATE NAND OP COL 4CH 2IN 14SO
N74F38D,623 数据手册
74F38 Quad 2-input NAND buffer (open collector) Rev. 3 — 10 January 2014 Product data sheet 1. General description The 74F38 provides four 2-input NAND functions with open-collector outputs. 2. Features and benefits  Industrial temperature range available (40C to +85 C) 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version N74F38N 0 C to +70 C DIP14 plastic dual in-line package; 14 leads (300 mil) SOT27-1 I74F38N 40 C to +85 C N74F38D 0 C to +70 C SO14 SOT108-1 I74F38D 40 C to +85 C plastic small outline package; 14 leads; body width 3.9 mm 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 4. Functional diagram 1 & 3 & 6 & 8 & 11 2 1 1A 2 1B 4 2A 5 2B 9 3A 10 3B 12 4A 13 4B 1Y 3 4 5 2Y 6 9 3Y 8 4Y 11 10 12 13 mna698 mna697 Fig 1. Logic symbol Fig 2. IEC logic symbol 5. Pinning information 5.1 Pinning 74F38 1A 1 14 VCC 1B 2 13 4B 1Y 3 12 4A 2A 4 11 4Y 2B 5 10 3B 2Y 6 9 3A GND 7 8 3Y aaa-010562 Fig 3. Pin configuration DIP14 and SO14 package 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 2 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 5.2 Pin description Table 2. Pin description Symbol Pin Description Unit load HIGH/LOW Load value[1][2] HIGH/LOW 1A, 2A, 3A, 4A 1, 4, 9, 12 data input 1.0/2.0 20 A/1.2 mA 1B, 2B, 3B, 4B 2, 5, 10, 13 data input 1.0/2.0 20 A/1.2 mA 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output OC/106.7 OC/64 mA GND 7 ground (0 V) - - VCC 14 supply voltage - - [1] One FAST Unit Load (UL) is defined as 20 A in HIGH state, 0.6 mA in LOW state. [2] OC = open collector. 6. Functional description Table 3. Function table[1] Input Output nA nB nY L L H L H H H L H H H L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VCC supply voltage VI input voltage [1] VO output voltage output in HIGH-state [1] IIK input clamping current VI < 0 V IO output current output in LOW-state Tamb ambient temperature in free-air Tstg Conditions Min Max Unit 0.5 +7.0 V 0.5 +7.0 V 0.5 VCC V 30 +5 mA - 128 mA commercial 0 70 C industrial 40 +85 C 65 +150 C storage temperature [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 C. 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 3 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC Conditions Min Typ Max Unit supply voltage 4.5 5.0 5.5 V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V VOH HIGH-level output voltage - - 4.5 V IIK input clamping current 18 - - mA IOL LOW-level output current - - 64 mA 9. Static characteristics Table 6. Static characteristics Symbol Parameter 25 C Conditions Min VIK input clamping voltage VCC = 4.5 V; IIK = 18 mA VOL LOW-level output voltage VCC = 4.5 V; VIL = 0.8 V; VIH = 2.0 V Typ[1] 0 C to +70 C Unit Max Min Max - 1.2 - V 1.2 0.73 IOL = 64 mA VCC = 10 % - - - - 0.55 V VCC = 5 % - 0.42 - - 0.55 V II input leakage current VCC = 0 V; VI = 7.0 V - - - - 100 A IIH HIGH-level input current VCC = 5.5 V; VI = 2.7 V - - - - 20 A IIL LOW-level input current VCC = 5.5 V; VI = 0.5 V - - - 20 - A ICC supply current VCC = 5.5 V VI = GND - 4 - - 7 mA VI = 4.5 V - 22 - - 30 mA [1] All typical values are measured at VCC = 5 V. 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V. Test circuit is shown in Figure 6. Symbol Parameter Conditions 25 C; VCC = 5.0 V 0 C to +70 C; VCC = 5.0 V  0.5 V 40 C to +85 C; VCC = 5.0 V  0.5 V Min Typ Max Min Max Min Max Unit tPZL OFF-state to LOW propagation delay nA, nB to nY; see Figure 4 1.5 3.0 5.0 1.5 5.5 1.5 6.0 ns tPLZ LOW to OFF-state propagation delay nA, nB to nY; see Figure 4 7.5 10.0 12.5 7.5 13.0 7.5 14.5 ns 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 4 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 11. Waveforms VI nA, nB input VM GND tPLZ tPZL VCC nY output VM VM VOL aaa-010563 VM = 1.5 V VOL is a typical output voltage level that occurs with the output load. Fig 4. Propagation delay for inverting outputs aaa-010521 18 Propagation delay (ns) 14 12 tPLZ 10 8 6 4 tPZL 2 0 0 200 400 600 Load resistor (Ω) When using open collector parts, the value of the pull-up resistor greatly affects the value of the tPLZ. For example, changing the specified pull-up resistor value from 500  to 100  improves the tPLZ up to 50% with only a slight increase in the tPZL. However, if the value of the pull-up resistor is changed, the user must ensure that the total IOL current through the resistor and the total IIL of the receivers, does not exceed the IOL minimum specification. Fig 5. Typical propagation delays versus load for open collector outputs 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 5 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) VI tW 90 % 90 % negative pulse VM 0V 10 % VEXT tf tr tr tf VI 90 % positive pulse 0V VM 10 % VCC VI 90 % VM VM 10 % DUT RT 10 % RL VO G RL CL tW 001aai298 a. Input pulse definition mna616 b. Test circuit Test data is given in Table 8. Test circuit definitions: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig 6. Table 8. Load circuitry for switching times Test data Input Load VEXT VI fi tW tr, tf CL RL tPZL, tPLZ 3.0 V 1 MHz 500 ns  2.5 ns 50 pF 500  7.0 V 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 6 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 12. Package outline DIP14: plastic dual in-line package; 14 leads (300 mil) SOT27-1 ME seating plane D A2 A A1 L c e Z w M b1 (e 1) b MH 8 14 pin 1 index E 1 7 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 min. A2 max. b b1 c D (1) E (1) e e1 L ME MH w Z (1) max. mm 4.2 0.51 3.2 1.73 1.13 0.53 0.38 0.36 0.23 19.50 18.55 6.48 6.20 2.54 7.62 3.60 3.05 8.25 7.80 10.0 8.3 0.254 2.2 inches 0.17 0.02 0.13 0.068 0.044 0.021 0.015 0.014 0.009 0.77 0.73 0.26 0.24 0.1 0.3 0.14 0.12 0.32 0.31 0.39 0.33 0.01 0.087 Note 1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT27-1 050G04 MO-001 SC-501-14 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-13 Fig 7. Package outline SOT27-1 (DIP14) 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 7 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 8. Package outline SOT108-1 (SO14) 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 8 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 13. Abbreviations Table 9. Abbreviations Acronym Description CDM Charged-Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74F38 v.3 20140110 Product data sheet - 74F38 v.2 Modifications: 74F38 v.2 74F38 Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. General update of values 19901004 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 - © NXP B.V. 2014. All rights reserved. 9 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74F38 Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 10 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74F38 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 10 January 2014 © NXP B.V. 2014. All rights reserved. 11 of 12 74F38 NXP Semiconductors Quad 2-input NAND buffer (open collector) 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 4 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2014. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 10 January 2014 Document identifier: 74F38
N74F38D,623
物料型号:74F38
器件简介: 74F38是一款提供四个2输入NAND门功能的集成电路,具有开路集电极输出。它适用于工业温度范围,即-40°C至+85°C。
引脚分配: - 1A, 2A, 3A, 4A:数据输入,引脚1, 4, 9, 12 - 1B, 2B, 3B, 4B:数据输入,引脚2, 5, 10, 13 - 1Y, 2Y, 3Y, 4Y:数据输出,开路集电极,引脚3, 6, 8, 11 - GND:地,引脚7 - VCC:供电电压,引脚14
参数特性: - 供电电压(Vcc):-0.5V至+7.0V - 输入电压(V1):0V至-0.5V至+7.0V - 输出电压(Vo):在高状态下,-0.5V至Vcc - 输入钳位电流(k):-30mA至+5mA - 输出电流(Io):在低状态下,最大128mA - 环境温度(Tamb):商业级0°C至+70°C,工业级-40°C至+85°C - 存储温度(Tstg):-65°C至+150°C
功能详解: 74F38的逻辑功能表显示了输入和输出的关系,其中"H"代表高电平,"L"代表低电平,"X"表示无关,"Z"表示高阻态。
应用信息: 74F38适用于需要开路集电极输出的数字逻辑电路设计。
封装信息: - N74F38N和174F38N型号采用DIP14封装,即塑料双列直插式封装,14个引脚(300 mil)。 - N74F38D和174F38D型号采用SO14封装,即塑料小外形封装,14个引脚,体宽3.9mm。
N74F38D,623 价格&库存
很抱歉,暂时无法提供与“N74F38D,623”相匹配的价格&库存,您可以联系我们找货
