74ALVT162827
20-bit buffer/line driver; non-inverting; with 30 Ω termination
resistors; 3-state
Rev. 3 — 24 January 2018
1
Product data sheet
General description
The 74ALVT162827 high-performance BiCMOS device combines low static and dynamic
power dissipation with high speed and high output drive. It is designed for VCC operation
at 2.5 V or 3.3 V with I/O compatibility to 5 V.
The 74ALVT162827 20-bit buffers provide high performance bus interface buffering
for wide data/address paths or buses carrying parity. They have NOR Output Enables
(nOE0 and nOE1) for maximum control flexibility.
The 74ALVT162827 is designed with 30 Ω series resistance in both HIGH and LOW
output stages. This design reduces the line noise in applications such as memory
address drivers, clock drivers and bus receivers/transmitters.
2
Features and benefits
3
Multiple VCC and GND pins minimize switching noise
5 V I/O compatible
Live insertion and extraction permitted
3-state output buffers
Outputs include series resistance of 30 Ω making external termination resistors
unnecessary
Power-up 3-state
Output capability: +12 mA and -12 mA
Latch-up protection:
– JESD 17 exceeds 500 mA
ESD protection:
– MIL STD 883 Method 3015: exceeds 2000 V
– MM: exceeds 200 V
Bus hold data inputs eliminate the need for external pull-up resistors to hold unused
inputs
Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
74ALVT162827DGG -40 °C to +85 °C
Name
Description
TSSOP56 plastic thin shrink small outline package; 56 leads;
body width 6.1 mm
Version
SOT364-1
74ALVT162827
Nexperia
20-bit buffer/line driver; non-inverting; with 30 Ω termination resistors; 3-state
4
Functional diagram
55
54
52
51
49
48
47
45
44
1OE0
56
1OE1
43
1Y0 1Y1 1Y2 1Y3 1Y4 1Y5 1Y6 1Y7 1Y8 1Y9
2
3
5
6
8
9
10
12
13
14
42
41
40
38
37
36
34
33
31
30
2A0 2A1 2A2 2A3 2A4 2A5 2A6 2A7 2A8 2A9
28
2OE0
29
2OE1
2Y0 2Y1 2Y2 2Y3 2Y4 2Y5 2Y6 2Y7 2Y8 2Y9
15
16
17
19
23
24
26
28
29
55
54
52
51
49
48
47
45
44
43
42
41
40
38
37
36
34
33
31
30
1A0 1A1 1A2 1A3 1A4 1A5 1A6 1A7 1A8 1A9
1
1
56
27
EN1
EN2
1
1
1
2
2
3
5
6
8
9
10
12
13
14
15
16
17
19
23
24
26
27
001aad055
001aad056
Figure 1. Logic symbol
Figure 2. IEC logic symbol
nA0
nA1
nA2
nA3
nA4
nA5
nA6
nA7
nA8
nY0
nY1
nY2
nY3
nY4
nY5
nY6
nY7
nY8
nA9
nOE0
nOE1
nY9
001aad061
Figure 3. Logic diagram
VCC
VCC
27 Ω
output
27 Ω
001aac372
Figure 4. Schematic of each output
74ALVT162827
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 14
74ALVT162827
Nexperia
5
Pinning information
5.1 Pinning
74ALVT162827
1OE0
1
56 1OE1
1Y0
2
55 1A0
1Y1
3
54 1A1
GND
4
53 GND
1Y2
5
52 1A2
1Y3
6
51 1A3
VCC
7
1Y4
8
50 VCC
49 1A4
1Y5
9
48 1A5
1Y6 10
47 1A6
GND 11
46 GND
1Y7 12
45 1A7
1Y8 13
44 1A8
1Y9 14
43 1A9
2Y0 15
42 2A0
2Y1 16
41 2A1
2Y2 17
40 2A2
GND 18
39 GND
2Y3 19
38 2A3
2Y4 20
37 2A4
2Y5 21
36 2A5
VCC 22
2Y6 23
35 VCC
34 2A6
2Y7 24
33 2A7
GND 25
32 GND
2Y8 26
31 2A8
2Y9 27
30 2A9
2OE0 28
29 2OE1
aaa-028100
Figure 5. Pin configuration SOT364-1 (TSSOP56)
74ALVT162827
Product data sheet
3 / 14
74ALVT162827
Nexperia
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7, 1A8, 1A9
55, 54, 52, 51, 49, 48, 47, 45, 44, 43
data input
2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7, 2A8, 2A9
42, 41, 40, 38, 37, 36, 34, 33, 31, 30
data input
1Y0, 1Y1, 1Y2, 1Y3, 1Y4, 1Y5, 1Y6, 1Y7, 1Y8, 1Y9
2, 3, 5, 6, 8, 9, 10, 12, 13, 14
data output
2Y0, 2Y1, 2Y2, 2Y3, 2Y4, 2Y5, 2Y6, 2Y7, 2Y8, 2Y9
15, 16, 17, 19, 20, 21, 23, 24, 26, 27
data output
1OE0, 1OE1, 2OE0, 2OE1
1, 56, 28, 29
output enable inputs
(active-LOW)
GND
4, 11, 18, 25, 32, 39, 46, 53
ground (0 V)
VCC
7, 22, 35, 50
positive voltage
supply
6
Functional description
Table 3. Function table
[1]
Operating mode
Input
Output
nOEn
nAn
nYn
transparent
L
L
L
transparent
L
H
H
High-impedance
H
X
Z
[1] X = don’t care; Z = High-impedance OFF-state; H = HIGH voltage level; L = LOW voltage level.
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
-0.5
+7.0
V
input voltage
[1]
-1.2
+7.0
V
VO
output voltage
output in OFF or HIGH-state
[1]
-0.5
+5.5
V
IIK
input clamping current
VI < 0 V
-18
mA
IOK
output clamping current
VO < 0 V
-50
mA
IO
output current
output in LOW-state
128
mA
+150
°C
-65
+150
°C
VI
Tj
junction temperature
Tstg
storage temperature
[2]
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are
detrimental to reliability.
74ALVT162827
Product data sheet
4 / 14
74ALVT162827
Nexperia
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
VCC = 2.5 V ± 0.2 V
VCC = 3.3 V ± 0.3 V
Unit
Min
Max
Min
Max
2.3
2.7
3.0
3.6
V
VCC
supply voltage
VI
input voltage
V
IOH
HIGH-level output current
-8
-12
mA
IOL
LOW-level output current
12
12
mA
Δt/ΔV
input transition rise and fall rate
outputs enabled
10
10
ns/V
Tamb
ambient temperature
free air
−40
+85
−40
+85
°C
9
Static characteristics
Table 6. Static characteristics
At recommended operating conditions; Tamb = -40 °C to +85 °C; voltages are referred to GND (ground = 0 V).
Symbol
Parameter
Conditions
Typ
[1]
Max
Unit
-0.85
-1.2
V
Min
VCC = 2.5 V ± 0.2 V
VIK
input clamping voltage
VCC = 2.3 V; IIK = -18 mA
VIH
HIGH-level input voltage
1.7
V
VIL
LOW-level input voltage
0.7
V
VOH
HIGH-level output voltage VCC = 2.3 V; IO = -8 mA
1.7
2.3
V
VOL
LOW-level output voltage VCC = 2.3 V; IO = 12 mA
0.5
0.7
V
II
input leakage current
0.1
±1
μA
0.1
10
μA
VCC = 2.7 V; VI = VCC
0.1
1
μA
VCC = 2.7 V; VI = 0 V
0.1
-5
μA
control pins
VCC = 2.7 V; VI = VCC or GND
VCC = 0 V or 2.7 V; VI = 5.5 V
[2]
data pins
IOFF
IBHL
power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V
bus hold LOW current
0.1
±100
μA
VCC = 2.3 V; VI = 0.7 V
[3]
115
μA
[3]
-10
μA
10
125
μA
1
100
μA
output HIGH; VO = 2.3 V
0.5
5
μA
output LOW; VO = 0.5 V
0.5
-5
μA
IBHH
bus hold HIGH current
VCC = 2.3 V; VI = 1.7 V
IEX
external current
output in HIGH-state when VO > VCC;
VO = 5.5 V; VCC = 2.3 V
IO(pu/pd)
power-up/power-down
output current
VCC ≤ 1.2 V; VO = 0.5 V to VCC;
VI = GND or VCC; nOEn = don’t care
IOZ
OFF-state output current
VCC = 2.7 V; VI = VIL or VIH
74ALVT162827
Product data sheet
[4]
5 / 14
74ALVT162827
Nexperia
Symbol
Parameter
Conditions
ICC
supply current
VCC = 2.7 V; VI = GND or VCC; IO = 0 A
Min
outputs HIGH
outputs LOW
outputs disabled
[1]
Typ
Max
Unit
0.04
0.1
mA
3.5
5.0
mA
[5]
0.04
0.1
mA
[6]
0.04
0.4
mA
ΔICC
additional supply current
per input pin; VCC = 2.3 V to 2.7 V;
one input at VCC - 0.6 V;
other inputs at VCC or GND
CI
input capacitance
VI = 0 V or VCC
3
pF
CO
output capacitance
VO = 0 V or VCC
9
pF
VCC = 3.0 V; IIK = -18 mA
-0.85
-1.2
V
VCC = 3.3 V ± 0.3 V
VIK
VIH
2.0
V
VIL
0.8
V
VOH
HIGH-level output voltage VCC = 3.0 V; IO = -12 mA
2.0
2.3
V
VOL
LOW-level output voltage VCC = 3.0 V; IO = 12 mA
0.5
0.8
V
II
0.1
±1
μA
0.1
10
μA
VCC = 3.6 V; VI = VCC
0.5
1
μA
VCC = 3.6 V; VI = 0 V
0.1
-5
μA
0.1
±100
μA
75
130
μA
control pins
VCC = 3.6 V; VI = VCC or GND
VCC = 0 V or 3.6 V; VI = 5.5 V
[2]
data pins
IOFF
IBHL
data inputs; VCC = 3 V; VI = 0.8 V
IBHH
data inputs; VCC = 3 V; VI = 2.0 V
-75
-140
μA
500
μA
-500
μA
10
125
μA
1
±100
μA
output HIGH; VO = 3.0 V
0.5
5
μA
0.5
-5
μA
0.07
0.1
mA
3.9
5.5
mA
0.07
0.1
mA
IBHLO
bus hold LOW
overdrive current
data inputs; VCC = 3.6 V;VI = 0 V to 3.6 V
[7]
IBHHO
bus hold HIGH
overdrive current
[7]
IEX
external current
VO = 5.5 V; VCC = 3.0 V
IO(pu/pd)
power-up/power-down
output current
IOZ
VCC = 3.6 V; VI = VIL or VIH
ICC
supply current
[8]
VCC = 3.6 V; VI = GND or VCC; IO = 0 A
outputs HIGH
outputs LOW
outputs disabled
74ALVT162827
Product data sheet
[5]
6 / 14
74ALVT162827
Nexperia
Symbol
Parameter
Conditions
Min
ΔICC
per input pin; VCC = 3 V to 3.6 V;
CI
input capacitance
CO
output capacitance
[6]
[1]
Typ
Max
Unit
0.04
0.4
mA
VI = 0 V or VCC
3
pF
VO = 0 V or VCC
9
pF
[1] All typical values for VCC = 2.5 V ± 0.2 V are measured at VCC = 2.5 V and Tamb = 25 °C.
All typical values for VCC = 3.3 V ± 0.3 V are measured at VCC = 3.3 V and Tamb = 25 °C.
[2] Unused pins at VCC or GND.
[3] Not guaranteed.
[4] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms.
From VCC = 1.2 V to VCC = 2.5 V ± 0.2 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
[5] ICC with outputs disabled is measured with outputs pulled to VCC or GND.
[6] This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
[7] This is the bus hold overdrive current required to force the input to the opposite logic state.
[8] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms.
From VCC = 1.2 V to VCC = 3.3 V ± 0.3 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only.
10 Dynamic characteristics
Table 7. Dynamic characteristics
At recommended operating conditions; Tamb = -40 °C to +85 °C; Voltages are referenced to GND (ground = 0 V); for test
circuit see Figure 8.
Symbol
Parameter
Conditions
Min
Typ
[1]
Max
Unit
VCC = 2.5 V ± 0.2 V
tPLH
LOW to HIGH propagation delay
nAn to nYn; see Figure 6
1.5
2.7
4.5
ns
tPHL
HIGH to LOW propagation delay
1.5
2.3
3.5
ns
tPZH
OFF-state to HIGH propagation delay
nOEn to nYn; see Figure 7
2.5
4.7
7.5
ns
tPZL
OFF-state to LOW propagation delay
1.5
2.9
4.7
ns
tPHZ
HIGH to OFF-state propagation delay
1.5
3.2
5.2
ns
tPLZ
LOW to OFF-state propagation delay
1.0
2.4
4.0
ns
VCC = 3.3 V ± 0.3 V
tPLH
1.0
2.2
3.3
ns
tPHL
1.0
2.0
3.0
ns
tPZH
1.5
3.4
5.6
ns
tPZL
1.0
2.4
3.7
ns
tPHZ
1.5
3.4
5.2
ns
tPLZ
1.0
2.7
4.5
ns
74ALVT162827
Product data sheet
7 / 14
74ALVT162827
Nexperia
10.1 Waveforms and test circuit
VI
nAn input
VM
VM
GND
tPLH
tPHL
VOH
VM
nYn output
VM
VOL
mna171
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Figure 6. Input (nAn) to output (nYn) propagation delays
VI
nOEn input
VM
VM
GND
tPLZ
3.0 V or VCC
output
LOW-to-OFF
OFF-to-LOW
VOL
tPZL
VM
VX
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-028099
Figure 7. The 3-state output enable and disable times
Table 8. Measurement points
VCC
Input
Output
VI
VM
VM
VX
VY
VCC ≤ 2.7 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
VCC ≥ 3.0 V
3.0 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74ALVT162827
Product data sheet
8 / 14
74ALVT162827
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = Test voltage for switching times.
Figure 8. Test circuit for measuring switching times
Table 9. Test data
Input
VI
Load
fi
3.0 V or VCC
≤ 10 MHz
whichever is less
74ALVT162827
Product data sheet
VEXT
tW
tr, tf
CL
RL
tPHZ, tPZH
tPLZ, tPZL
tPLH, tPHL
500 ns
≤ 2.5 ns
50 pF
500 Ω
GND
6 V or VCC x 2
open
9 / 14
74ALVT162827
Nexperia
11 Package outline
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm
SOT364-1
E
D
A
X
c
HE
y
v M A
Z
56
29
Q
A2
(A 3 )
A1
pin 1 index
A
θ
Lp
L
1
28
w M
bp
e
detail X
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
14.1
13.9
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.5
0.1
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT364-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Figure 9. Package outline SOT364-1 (TSSOP56)
74ALVT162827
Product data sheet
10 / 14
74ALVT162827
Nexperia
12 Abbreviations
Table 10. Abbreviations
Acronym
Description
BiCMOS
Bipolar Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
MIL
Military
MM
Machine Model
13 Revision history
Table 11. Revision history
Document ID
Release date
74ALVT162827 v.3 20180124
Modifications:
Data sheet status
Change notice
Supersedes
Product data sheet
74ALVT162827 v.2
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Type number 74ALVT162827DL (SOT371-1 / SSOP56) removed.
74ALVT162827 v.2 19980213
Product specification
74ALVT162827 v.1
74ALVT162827 v.1 19970501
74ALVT162827
Product data sheet
11 / 14
74ALVT162827
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74ALVT162827
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
12 / 14
74ALVT162827
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74ALVT162827
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
13 / 14
74ALVT162827
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 4
Recommended operating conditions ................ 5
Static characteristics .......................................... 5
Dynamic characteristics .....................................7
Waveforms and test circuit ................................ 8
Package outline .................................................10
Abbreviations .................................................... 11
Revision history ................................................ 11
Legal information .............................................. 12
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 24 January 2018
Document identifier: 74ALVT162827
