74AHC3G14; 74AHCT3G14
Triple inverting Schmitt trigger
Rev. 9 — 4 December 2018
Product data sheet
1. General description
74AHC3G14 and 74AHCT3G14 are high-speed Si-gate CMOS devices. They provide three
inverting buffers with Schmitt trigger action. These devices are capable of transforming slowly
changing input signals into sharply defined, jitter-free output signals.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
2. Features and benefits
Symmetrical output impedance
High noise immunity
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101D exceeds 1000 V
Low power dissipation
Balanced propagation delays
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
3. Applications
Wave and pulse shaper for highly noisy environment
Astable multivibrator
Monostable multivibrator
4. Ordering information
Table 1. Ordering information
Type number
Package
74AHC3G14DP
Temperature range
Name
Description
Version
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package; 8 leads; SOT765-1
body width 2.3 mm
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package; no leads; SOT833-1
8 terminals; body 1 x 1.95 x 0.5 mm
74AHCT3G14DP
74AHC3G14DC
74AHCT3G14DC
74AHC3G14GT
74AHCT3G14GT
Nexperia
5. Marking
Table 2. Marking codes
Type number
Marking code[1]
74AHC3G14DP
A14
74AHCT3G14DP
C14
74AHC3G14DC
A14
74AHCT3G14DC
C14
74AHC3G14GT
A14
74AHCT3G14GT
C14
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
6. Functional diagram
1A
1Y
3Y
3A
2A
2Y
A
Y
mna025
001aah729
001aah728
Fig. 1.
Logic symbo
Fig. 2.
Fig. 3.
IEC logic symbol
Logic diagram (one Schmitt
trigger)
7. Pinning information
7.1. Pinning
74AHC3G14
74AHCT3G14
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
74AHC3G14
74AHCT3G14
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
001aam630
Transparent top view
001aai259
Fig. 4.
Pin configuration SOT505-2 and SOT765-1
74AHC_AHCT3G14
Product data sheet
Fig. 5.
Pin configuration SOT833-1
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 15
Nexperia
7.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A, 2A, 3A
1, 3, 6
data input
GND
4
ground (0 V)
1Y, 2Y, 3Y
7, 5, 2
data output
VCC
8
supply voltage
8. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level
Input nA
Output nY
L
H
H
L
9. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
VI
input voltage
IIK
input clamping current
VI < -0.5 V
-0.5
+7.0
V
-20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±25
mA
ICC
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
Conditions
[1]
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly at 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly at 8 mW/K.
For XSON8 package: above 118 °C the value of Ptot derates linearly at 7.8 mW/K.
10. Recommended operating conditions
Table 6. Recommended operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
74AHC3G14
74AHCT3G14
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
74AHC_AHCT3G14
Product data sheet
3 / 15
Nexperia
11. Static characteristics
Table 7. Static characteristics
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VI = VT+ or VTHIGH-level
output voltage
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V
74AHC3G14
VOH
VOL
3.94
3.8
3.70
V
VI = VT+ or VTLOW-level
output voltage
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
0.1
1.0
2.0
μA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
μA
CI
input
capacitance
1.5
10
10
10
pF
4.4
4.5
4.4
4.4
V
3.94
3.8
3.70
V
0.1
0.1
V
IO = 8.0 mA
0.36
0.44
0.55
V
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
74AHCT3G14
VOH
VI = VT+ or VT-; VCC = 4.5 V
HIGH-level
output voltage
IO = -50 μA
IO = -8.0 mA
VOL
LOW-level
output voltage
IO = 50 μA
II
input leakage
current
ICC
VCC = 5.5 V
1.0
10
40
μA
ΔICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
74AHC_AHCT3G14
Product data sheet
4 / 15
Nexperia
11.1. Transfer characteristics
Table 8. Transfer characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V). See Fig. 8 and Fig. 9.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 3.0 V
2.2
2.2
2.2
V
VCC = 4.5 V
3.15
3.15
3.15
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 4.5 V
1.35
1.35
1.35
V
VCC = 5.5 V
1.65
1.65
1.65
V
hysteresis voltage VCC = 3.0 V
0.3
1.2
0.3
1.2
0.25
1.2
V
VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.5
1.6
0.5
1.6
0.45
1.6
V
2.0
2.0
2.0
V
74AHC3G14
VT+
VT-
VH
positive-going
threshold voltage
negative-going
threshold voltage
74AHCT3G14
VT+
positive-going
threshold voltage
VCC = 4.5 V
VCC = 5.5 V
2.0
2.0
2.0
V
VT-
negative-going
threshold voltage
VCC = 4.5 V
0.5
0.5
0.5
V
VCC = 5.5 V
0.6
0.6
0.6
V
hysteresis voltage VCC = 4.5 V
0.4
1.4
0.4
1.4
0.35
1.4
V
VCC = 5.5 V
0.4
1.6
0.4
1.6
0.35
1.6
V
VH
74AHC_AHCT3G14
Product data sheet
5 / 15
Nexperia
12. Dynamic characteristics
Table 9. Dynamic characteristics
GND = 0 V; tr = tf ≤ 3.0 ns; for test circuit see Fig. 7.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
CL = 15 pF
4.2
12.8
1.0
15.0
1.0
16.5
ns
CL = 50 pF
6.0
16.3
1.0
18.5
1.0
20.5
ns
CL = 15 pF
3.2
8.6
1.0
10.0
1.0
11.0
ns
CL = 50 pF
4.6
10.6
1.0
12.0
1.0
13.5
ns
10
pF
4.1
7.0
1.0
8.0
1.0
9.0
ns
5.9
8.5
1.0
10.0
1.0
11.0
ns
12
pF
74AHC3G14
tpd
propagation
delay
nA to nY; see Fig. 6
[1]
VCC = 3.0 V to 3.6 V
[2]
VCC = 4.5 V to 5.5 V
CPD
power
per buffer;
dissipation
CL = 50 pF; fi = 1 MHz;
capacitance VI = GND to VCC
[3]
[4]
74AHCT3G14
tpd
propagation
delay
[1]
[3]
CL = 15 pF
CL = 50 pF
CPD
[1]
[2]
[3]
[4]
power
per buffer;
dissipation
[4]
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD x VCC x fi + Σ (CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
2
Σ(CL x VCC x fo) = sum of the outputs.
74AHC_AHCT3G14
Product data sheet
6 / 15
Nexperia
12.1. Waveform and test circuit
VCC
tPHL
mna101
The test data is given in Table 10
The input (nA) to output (nY) propagation
delays
Table 10. Test data
Type number
CL
Test data is given in Table 10.
Definitions for test circuit:
CL = Load capacitance.
RT = Termination resistance should be equal to
output impedance Zo of the pulse generator.
mna033
Fig. 6.
VO
DUT
RT
tPLH
VM
Y output
VI
PULSE
GENERATOR
VM
A input
Fig. 7.
Test circuit for measuring switching times
Output
Input
VI
VM
VM
74AHC3G14
GND to VCC
0.5 x VCC
0.5 x VCC
74AHCT3G14
GND to 3.0 V
1.5 V
0.5 x VCC
12.2. Transfer characteristic waveforms
VO
VI
VH
VT-
Fig. 8.
VI
VT+
74AHC_AHCT3G14
Product data sheet
VT+
VH
VT-
VO
mna027
mna026
Fig. 9.
The definitions of VT+, VT- and VH
7 / 15
Nexperia
mna401
1.5
mna402
5
ICC
(mA)
ICC
(mA)
4
1
3
2
0.5
1
2
VI (V)
VCC = 3.0 V.
2
3
4 V (V) 5
I
VCC = 4.5 V.
Fig. 10. Typical 74AHC3G14 transfer characteristics
Fig. 11. Typical 74AHC3G14 transfer characteristics
mna403
8
mna404
5
ICC
(mA)
ICC
(mA)
4
6
3
4
2
2
4
VI (V)
VCC = 5.5 V.
2
3
4 V (V) 5
I
VCC = 4.5 V.
Fig. 12. Typical 74AHC3G14 transfer characteristics
Fig. 13. Typical 74AHCT3G14 transfer characteristics
mna405
8
ICC
(mA)
6
4
2
4
VI (V)
6
VCC = 5.5 V.
Fig. 14. Typical 74AHCT3G14 transfer characteristics
74AHC_AHCT3G14
Product data sheet
8 / 15
Nexperia
13. Application information
The slow input rise and fall times cause additional power dissipation, which can be calculated using
the following formula:
Padd = fi x (tr x ΔICC(AV) + tf x ΔICC(AV)) × VCC where:
Padd = additional power dissipation (μW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
ΔICC(AV) = average additional supply current (μA).
ΔICC(AV) differs with positive or negative input transitions, as shown in Fig. 15 and Fig. 16.
For 74AHC3G14 and 74AHCT3G14 used in relaxation oscillator circuit, see Fig. 17.
Note to the application information:
1. All values given are typical unless otherwise specified.
mna036
200
mna058
200
ΔICC(AV)
(µA)
ΔICC(AV)
(µA)
150
150
positive-going
edge
positive-going
edge
100
100
50
50
negative-going
edge
4.0
VCC (V)
Linear change of VI between 0.1VCC to 0.9VCC
negative-going
edge
4
VCC (V)
6
Fig. 15. Average additional ICC for 74AHC3G14 Schmitt
trigger devices
Fig. 16. Average additional ICC for 74AHCT3G14 Schmitt
trigger devices
R
C
mna035
For 74AHC3G14:
For 74AHCT3G14:
Fig. 17. Relaxation oscillator using the 74AHC3G14 and 74AHCT3G14
74AHC_AHCT3G14
Product data sheet
9 / 15
Nexperia
14. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig. 18. Package outline SOT505-2 (TSSOP8)
74AHC_AHCT3G14
Product data sheet
10 / 15
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Fig. 19. Package outline SOT765-1 (VSSOP8)
74AHC_AHCT3G14
Product data sheet
11 / 15
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Fig. 20. Package outline SOT833-1 (XSON8)
74AHC_AHCT3G14
Product data sheet
12 / 15
Nexperia
15. Abbreviations
Table 11. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
16. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT3G14 v.9
20181204
Product data sheet
74AHC_AHCT3G14 v.8
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74AHC3G14GD and 74AHCT3G14GD (SOT996-2/XSON8) removed.
74AHC_AHCT3G14 v.8
20130513
Modifications:
74AHC_AHCT3G14 v.7
20111108
Modifications:
74AHC_AHCT3G14 v.6
20101118
74AHC_AHCT3G14 v.5
20100923
74AHC_AHCT3G14 v.4
Product data sheet
74AHC_AHCT3G14 v.7
For type number 74AHC3G14GD and 74AHCT3G14GD XSON8U has changed to
XSON8.
74AHC_AHCT3G14 v.6
Product data sheet
74AHC_AHCT3G14 v.5
Product data sheet
74AHC_AHCT3G14 v.4
20090505
Product data sheet
74AHC_AHCT3G14 v.3
74AHC_AHCT3G14 v.3
20080617
Product data sheet
74AHC_AHCT3G14 v.2
74AHC_AHCT3G14 v.2
20041018
Product specification -
74AHC_AHCT3G14 v.1
74AHC_AHCT3G14 v.1
20031127
74AHC_AHCT3G14
Product data sheet
Product data sheet
Legal pages updated.
13 / 15
Nexperia
17. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AHC_AHCT3G14
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................1
5. Marking.......................................................................... 2
6. Functional diagram.......................................................2
7. Pinning information......................................................2
7.1. Pinning.........................................................................2
7.2. Pin description............................................................. 3
8. Functional description................................................. 3
9. Limiting values............................................................. 3
10. Recommended operating conditions........................3
11. Static characteristics..................................................4
11.1. Transfer characteristics..............................................5
12. Dynamic characteristics............................................ 6
12.1. Waveform and test circuit.......................................... 7
12.2. Transfer characteristic waveforms............................. 7
13. Application information............................................. 9
14. Package outline........................................................ 10
15. Abbreviations............................................................ 13
16. Revision history........................................................13
17. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 4 December 2018
74AHC_AHCT3G14
Product data sheet
15 / 15
