3110MS-24W-B30-A00
3110MS-24W-B30-A00
    NMBTECHNOLOGIESCORPORATION
    插件
    FAN AXIAL 80X25.3MM 240VAC WIRE
3110MS-24W-B30-A00 数据手册
08025MB (80 X 25L) Legacy Part No. 3110MS NMBTC.COM / 818.341.3355 General Specifications Characteristic Curves Motor Structure: Shaded Pole Induction Motor Motor Protection: Impedance Protection Insulation Resistance: In H2O (Pa) 80 .32 Static Pressure 10M Ω or over with a DC500V Megger Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) .24 60 .16 40 .08 20 60Hz 50Hz L Ps Failure Rate: 10% 25°C 100,000 Hours 0 0 Material Casing : Aluminum (Black Painting) Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL3266, AWG22 7.06 14.1 21.1 Air Flow (m3/min) 0.8 CFM 28.2 NAME PLATE 2.81 (71.5 ±0.3) 3.07 (78.0) 2.81 (71.5 ±0.3) INLET SIDE OUTLET SIDE ROTATION AIR .169 4 – (φ4.3 ±0.2) 3.15 (80.0 ±0.5) 2.81 (71.5 ±0.3) 07 ) 3. 8.0 7 (φ 11.8 (300) min .169 4 – (φ4.3 ±0.2) .394 7.87 (200) min (10 ± 2) .177 4 – (φ4.5) 2.81 (71.5 ±0.3) 0.6 2.81 (71.5 ±0.3) 3.15 (80.0 ±0.5) .177 4 – (φ4.5) (φ 3.5 91 5 .0 ) 3.07 (78.0) 2.81 (71.5 ±0.3) 0.4 Outline Panel Cut-Outs inch Units: (mm) 0.2 2.81 (71.5 ±0.3) 3.15 (80.0 ±0.5) .126 (3.2) 2.81 (71.5 ±0.3) 3.15 (80.0 ±0.5) .126 (3.2) .996 (25.3 ±0.5) Specifications MODEL ** ** ** LEGACY P/N Rated Frequency Starting Current Input Speed Voltage Voltage Power (V) Max. Max. Static Noise Air Flow Pressure Mass (W) (min-1)*2 CFM*1 (m3/min)*2 in H2O (Pa)*2 (dB)*2 (g) (Hz) (V) (A)*1 100 08025MB-A0L-AA-00 3110MS-10W-B30-B00 100 50 65 0.13 8.00 2500 20.1 0.57 .15 39.0 24.0 60 65 0.11 6.50 3000 24.0 0.68 .22 55.0 31.0 240 08025MB-A1L-AA-00 3110MS-12W-B30-A00 50 75 0.11 8.00 2500 20.1 0.57 .15 39.0 24.0 240 115 240 115 60 75 0.09 6.50 3000 24.0 0.68 .22 55.0 31.0 240 115 08025MB-A1L-CA-00 3110MS-12W-B30-AM0 115 50 75 0.11 8.00 2500 20.1 0.57 .15 39.0 24.0 240 60 75 0.09 6.50 3000 24.0 0.68 .22 55.0 31.0 240 08025MB-B0L-AA-00 3110MS-20W-B30-B00 200 50 130 0.06 7.00 2500 20.1 0.57 .15 39.0 24.0 240 200 60 130 0.05 6.00 3000 24.0 0.68 .22 55.0 31.0 240 08025MB-B2L-AA-00 3110MS-22W-B30-B00 220 50 165 0.06 7.50 2500 20.1 0.57 .15 39.0 24.0 240 220 60 165 0.05 6.50 3000 24.0 0.68 .22 55.0 31.0 240 230 08025MB-B3L-AA-00 3110MS-23W-B30-A00 230 50 180 0.05 7.50 2500 20.1 0.57 .15 39.0 24.0 240 60 180 0.05 6.50 3000 24.0 0.68 .22 55.0 31.0 240 230 08025MB-B3L-CA-00 3110MS-23W-B30-AM0 230 50 180 0.05 7.50 2500 20.1 0.57 .15 39.0 24.0 240 60 180 0.05 6.50 3000 24.0 0.68 .22 55.0 31.0 240 240 08025MB-B4L-AA-00 3110MS-24W-B30-A00 240 50 180 0.05 7.50 2500 20.1 0.57 .15 39.0 24.0 240 60 180 0.05 6.50 3000 24.0 0.68 .22 55.0 31.0 240 Rotation: Counterclockwise Airflow Outlet: Air Out Over Struts Contact NMB for Availability ** *1: Maximum Values in Free Air *2: Average Values in Free Air *3: Minimum Values in Free Air DC AC Axial Fans Expected Life
3110MS-24W-B30-A00 价格&库存
很抱歉,暂时无法提供与“3110MS-24W-B30-A00”相匹配的价格&库存,您可以联系我们找货
